Name for Strong APA Scheduler?
Darshit Shah darnir at gmail.com
Thu Mar 31 09:29:32 UTC 2016
On 03/31, Sebastian Huber wrote:
>On 31/03/16 11:13, Darshit Shah wrote:
>>>I need this name to generate the skeleton files for the scheduler
>>>implementation and its configuration.
>>>My preference is APA, since three letter acronyms are quite
>>>popular, like EDF and CBS. So, I would omit that we actually
>>>support strong APA in the name. From my point of view a weak APA
>>>scheduler makes no sense for a supposed to be real-time operating
>>>system. In the documentation we should emphasis this.
>>I agree that a three letter acronym is quite popular and would make
>>things easy, but I would still support strong APA as the name since
>>it clearly states what the scheduler is doing.
>So, you suggest "Strong APA"?
Yes
>>>New files are for example:
>>>cpukit/score/include/rtems/score/schedulerapa.h
>>>cpukit/score/include/rtems/score/schedulerapaimpl.h
>>>cpukit/score/src/schedulerapa.c
>>Going by some of the existing filenames, I thought the files should
>>be called `schedulerapasmp.c` and similarly for others. That is also
>>the name I used in the proposal.
>Its implicitly clear that APA has something to do with SMP. The other
>schedulers need the SMP in their name since we have basically two
>version of them, non-SMP (no postfix) and SMP.
That clears things up.
>How about:
>cpukit/score/include/rtems/score/schedulerstrongapa.h
>cpukit/score/include/rtems/score/schedulerstrongapaimpl.h
>cpukit/score/src/schedulerstrongapa.c
Those look good to me.
>Sebastian Huber, embedded brains GmbH
>Address : Dornierstr. 4, D-82178 Puchheim, Germany
>Phone   : +49 89 189 47 41-16
>Fax     : +49 89 189 47 41-09
>E-Mail  : sebastian.huber at embedded-brains.de
>PGP     : Public key available on request.
>Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
Thanking You,
Darshit Shah
Type: application/pgp-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160331/8e28e984/attachment-0002.bin>
