[PATCH 04/11] rtems: Remove task variables
Tue May 3 12:49:40 UTC 2016
Update #2494.
Update #2555.
 c/src/ada/rtems-tasks.adb                    |  65 ----
 c/src/ada/rtems-tasks.ads                    |  25 --
 cpukit/rtems/Makefile.am                     |   7 -
 cpukit/rtems/include/rtems/rtems/tasks.h     |  46 ---
 cpukit/rtems/include/rtems/rtems/tasksimpl.h |  15 -
 cpukit/rtems/mainpage.h                      |  38 +--
 cpukit/rtems/src/tasks.c                     |  92 +-----
 cpukit/rtems/src/taskvariable_invoke_dtor.c  |  52 ----
 cpukit/rtems/src/taskvariableadd.c           |  97 ------
 cpukit/rtems/src/taskvariabledelete.c        |  86 ------
 cpukit/rtems/src/taskvariableget.c           |  88 ------
 cpukit/sapi/include/confdefs.h               |  49 +--
 cpukit/score/include/rtems/score/thread.h    |  34 ---
 testsuites/psxtests/psxconfig01/init.c       |  29 --
 testsuites/sptests/configure.ac              |   1 -
 testsuites/sptests/sp28/Makefile.am          |  22 --
 testsuites/sptests/sp28/init.c               | 439 ---------------------------
 testsuites/sptests/sp28/sp28.doc             |   0
 testsuites/sptests/sp28/sp28.scn             |  17 --
 19 files changed, 10 insertions(+), 1192 deletions(-)
 delete mode 100644 cpukit/rtems/src/taskvariable_invoke_dtor.c
 delete mode 100644 cpukit/rtems/src/taskvariableadd.c
 delete mode 100644 cpukit/rtems/src/taskvariabledelete.c
 delete mode 100644 cpukit/rtems/src/taskvariableget.c
 delete mode 100644 testsuites/sptests/sp28/Makefile.am
 delete mode 100644 testsuites/sptests/sp28/init.c
 delete mode 100644 testsuites/sptests/sp28/sp28.doc
 delete mode 100644 testsuites/sptests/sp28/sp28.scn
diff --git a/c/src/ada/rtems-tasks.adb b/c/src/ada/rtems-tasks.adb
index b809fcf..1fc7fcd 100644
--- a/c/src/ada/rtems-tasks.adb
+++ b/c/src/ada/rtems-tasks.adb
@@ -203,71 +203,6 @@ package body RTEMS.Tasks is
    end Mode;
-   procedure Variable_Add
-     (ID            : in RTEMS.ID;
-      Task_Variable : in RTEMS.Address;
-      Dtor          : in Variable_Dtor;
-      Result        : out RTEMS.Status_Codes)
-   is
-      function Variable_Add_Base
-        (ID            : RTEMS.ID;
-         Task_Variable : RTEMS.Address;
-         Dtor          : Variable_Dtor)
-         return          RTEMS.Status_Codes;
-      pragma Import (C, Variable_Add_Base, "rtems_task_variable_add");
-   begin
-      Result := Variable_Add_Base (ID, Task_Variable, Dtor);
-   end Variable_Add;
-   procedure Variable_Get
-      Task_Variable       : out RTEMS.Address;
-      Task_Variable_Value : out RTEMS.Address;
-   is
-      function Variable_Get_Base
-        (ID                  : RTEMS.ID;
-         Task_Variable       : access RTEMS.Address;
-         Task_Variable_Value : access RTEMS.Address)
-      pragma Import (C, Variable_Get_Base, "rtems_task_variable_get");
-      Task_Variable_Base       : aliased RTEMS.Address;
-      Task_Variable_Value_Base : aliased RTEMS.Address;
-   begin
-      Result              :=
-         Variable_Get_Base
-           (ID,
-            Task_Variable_Base'Access,
-            Task_Variable_Value_Base'Access);
-      Task_Variable       := Task_Variable_Base;
-      Task_Variable_Value := Task_Variable_Value_Base;
-   end Variable_Get;
-   procedure Variable_Delete
-   is
-      function Variable_Delete_Base
-        (ID            : RTEMS.ID;
-         Task_Variable : access RTEMS.Address)
-      pragma Import
-        (C,
-         Variable_Delete_Base,
-         "rtems_task_variable_delete");
-   begin
-      Result        := Variable_Delete_Base (ID, Task_Variable_Base'Access);
-   end Variable_Delete;
    procedure Wake_When
      (Time_Buffer : in RTEMS.Time_Of_Day;
diff --git a/c/src/ada/rtems-tasks.ads b/c/src/ada/rtems-tasks.ads
index c1f200b..2cb3157 100644
--- a/c/src/ada/rtems-tasks.ads
+++ b/c/src/ada/rtems-tasks.ads
@@ -117,31 +117,6 @@ package RTEMS.Tasks is
-   type Variable_Dtor is access procedure (
-      Argument : in     RTEMS.Address
-   pragma Convention (C, Variable_Dtor);
-   procedure Variable_Add (
-      ID            : in     RTEMS.ID;
-   procedure Variable_Get (
-      ID                  : in     RTEMS.ID;
-   procedure Variable_Delete (
-      ID                  : in     RTEMS.ID;
    procedure Wake_When (
diff --git a/cpukit/rtems/Makefile.am b/cpukit/rtems/Makefile.am
index 6515a08..73d9e30 100644
--- a/cpukit/rtems/Makefile.am
+++ b/cpukit/rtems/Makefile.am
@@ -104,13 +104,6 @@ librtems_a_SOURCES += src/taskstart.c
 librtems_a_SOURCES += src/tasksuspend.c
 librtems_a_SOURCES += src/taskwakeafter.c
 librtems_a_SOURCES += src/taskwakewhen.c
-if HAS_SMP
-else
-librtems_a_SOURCES += src/taskvariableadd.c
-librtems_a_SOURCES += src/taskvariabledelete.c
-librtems_a_SOURCES += src/taskvariableget.c
-librtems_a_SOURCES += src/taskvariable_invoke_dtor.c
-endif
 librtems_a_SOURCES += src/schedulergetprocessorset.c
 librtems_a_SOURCES += src/schedulerident.c
diff --git a/cpukit/rtems/include/rtems/rtems/tasks.h b/cpukit/rtems/include/rtems/rtems/tasks.h
index 11e2780..5f33e0b 100644
--- a/cpukit/rtems/include/rtems/rtems/tasks.h
+++ b/cpukit/rtems/include/rtems/rtems/tasks.h
@@ -372,52 +372,6 @@ rtems_status_code rtems_task_is_suspended(
   rtems_id   id
-#if !defined(RTEMS_SMP)
- *  @brief RTEMS Add Task Variable
- *  @deprecated Task variables are deprecated.
- *  This directive adds a per task variable.
- *  @note This service is not available in SMP configurations.
-rtems_status_code rtems_task_variable_add(
-  rtems_id  tid,
-  void    **ptr,
-  void    (*dtor)(void *)
-) RTEMS_DEPRECATED;
- *  @brief Get a per-task variable
- *  This directive gets the value of a task variable.
-rtems_status_code rtems_task_variable_get(
-  rtems_id tid,
-  void **ptr,
-  void **result
- *  @brief RTEMS Delete Task Variable
- *  This directive removes a per task variable.
-rtems_status_code rtems_task_variable_delete(
-  rtems_id  tid,
-  void    **ptr
-#endif
 #if defined(__RTEMS_HAVE_SYS_CPUSET_H__)
  * @brief Gets the processor affinity set of a task.
diff --git a/cpukit/rtems/include/rtems/rtems/tasksimpl.h b/cpukit/rtems/include/rtems/rtems/tasksimpl.h
index 3f8a873..82e8618 100644
--- a/cpukit/rtems/include/rtems/rtems/tasksimpl.h
+++ b/cpukit/rtems/include/rtems/rtems/tasksimpl.h
@@ -47,21 +47,6 @@ extern Thread_Information _RTEMS_tasks_Information;
 void _RTEMS_tasks_Initialize_user_tasks( void );
- *  @brief RTEMS Tasks Invoke Task Variable Destructor
- *  This routine invokes the optional user provided destructor on the
- *  task variable and frees the memory for the task variable.
-void _RTEMS_Tasks_Invoke_task_variable_dtor(
-  Thread_Control        *the_thread,
-  rtems_task_variable_t *tvp
-#endif
 RTEMS_INLINE_ROUTINE Thread_Control *_RTEMS_tasks_Allocate(void)
   _Objects_Allocator_lock();
diff --git a/cpukit/rtems/mainpage.h b/cpukit/rtems/mainpage.h
index 9801bfb..e2d5132 100644
--- a/cpukit/rtems/mainpage.h
+++ b/cpukit/rtems/mainpage.h
@@ -856,40 +856,10 @@
  * @section ClassicTasksSecPerTaskVariables Per Task Variables
- * Per task variables are used to support global variables whose value may be
- * unique to a task. After indicating that a variable should be treated as
- * private (i.e. per-task) the task can access and modify the variable, but the
- * modifications will not appear to other tasks, and other tasks' modifications
- * to that variable will not affect the value seen by the task. This is
- * accomplished by saving and restoring the variable's value each time a task
- * switch occurs to or from the calling task.
- * The value seen by other tasks, including those which have not added the
- * variable to their set and are thus accessing the variable as a common
- * location shared among tasks, can not be affected by a task once it has added
- * a variable to its local set. Changes made to the variable by other tasks
- * will not affect the value seen by a task which has added the variable to its
- * private set.
- * This feature can be used when a routine is to be spawned repeatedly as
- * several independent tasks. Although each task will have its own stack, and
- * thus separate stack variables, they will all share the same static and
- * global variables. To make a variable not shareable (i.e. a "global" variable
- * that is specific to a single task), the tasks can call
- * rtems_task_variable_add() to make a separate copy of the variable for each
- * task, but all at the same physical address.
- * Task variables increase the context switch time to and from the tasks that
- * own them so it is desirable to minimize the number of task variables. One
- * efficient method is to have a single task variable that is a pointer to a
- * dynamically allocated structure containing the task's private "global" data.
- * A critical point with per-task variables is that each task must separately
- * request that the same global variable is per-task private.
- * @b {WARNING}: Per-task variables are fundamentally incorrect in SMP
- *               systems and should not be used in SMP applications. They
- *               are disabled.
+ * Per task variables are no longer available.  In particular the
+ * rtems_task_variable_add(), rtems_task_variable_get() and
+ * rtems_task_variable_delete() functions are neither declared nor defined
+ * anymore.  Use thread local storage or POSIX Keys instead.
  * @section ClassicTasksSecBuildingTaskAttributeSet Building a Task Attribute Set
diff --git a/cpukit/rtems/src/tasks.c b/cpukit/rtems/src/tasks.c
index f18e0ab..56b2455 100644
--- a/cpukit/rtems/src/tasks.c
+++ b/cpukit/rtems/src/tasks.c
@@ -18,20 +18,13 @@
 #include "config.h"
 #endif
-#include <rtems/system.h>
 #include <rtems/config.h>
 #include <rtems/sysinit.h>
 #include <rtems/rtems/asrimpl.h>
 #include <rtems/rtems/eventimpl.h>
-#include <rtems/rtems/signalimpl.h>
-#include <rtems/rtems/status.h>
-#include <rtems/rtems/support.h>
-#include <rtems/rtems/modes.h>
-#include <rtems/score/stack.h>
 #include <rtems/score/userextimpl.h>
-#include <rtems/score/wkspace.h>
@@ -91,87 +84,12 @@ static void _RTEMS_tasks_Delete_extension(
   _ASR_Destroy( &api->Signal );
-static void _RTEMS_tasks_Terminate_extension(
-  Thread_Control *executing
-   *  Free per task variable memory
-   *  Per Task Variables are only enabled in uniprocessor configurations.
-  #if !defined(RTEMS_SMP)
-     * We know this is deprecated and don't want a warning on every BSP built.
-    #pragma GCC diagnostic push
-    #pragma GCC diagnostic ignored "-Wdeprecated-declarations"
-    do {
-      rtems_task_variable_t *tvp, *next;
-      tvp = executing->task_variables;
-      executing->task_variables = NULL;
-      while (tvp) {
-	next = (rtems_task_variable_t *)tvp->next;
-	_RTEMS_Tasks_Invoke_task_variable_dtor( executing, tvp );
-	tvp = next;
-    } while (0);
-    #pragma GCC diagnostic pop
-  #endif
- *  _RTEMS_tasks_Switch_extension
- *  This extension routine is invoked at each context switch.
- *  @note Since this only needs to address per-task variables, it is
- *        disabled entirely for SMP configurations.
-static void _RTEMS_tasks_Switch_extension(
-  Thread_Control *executing,
-  Thread_Control *heir
-  rtems_task_variable_t *tvp;
-  while (tvp) {
-    tvp->tval = *tvp->ptr;
-    *tvp->ptr = tvp->gval;
-    tvp = (rtems_task_variable_t *)tvp->next;
-  tvp = heir->task_variables;
-  while (tvp) {
-    tvp->gval = *tvp->ptr;
-    *tvp->ptr = tvp->tval;
-#define RTEMS_TASKS_SWITCH_EXTENSION _RTEMS_tasks_Switch_extension
-#else
-#define RTEMS_TASKS_SWITCH_EXTENSION NULL
-#endif
 User_extensions_Control _RTEMS_tasks_User_extensions = {
-  { NULL, NULL },
-  { { NULL, NULL }, RTEMS_TASKS_SWITCH_EXTENSION },
-  { _RTEMS_tasks_Create_extension,            /* create */
-    _RTEMS_tasks_Start_extension,             /* start */
-    _RTEMS_tasks_Start_extension,             /* restart */
-    _RTEMS_tasks_Delete_extension,            /* delete */
-    RTEMS_TASKS_SWITCH_EXTENSION,             /* switch */
-    NULL,                                     /* begin */
-    NULL,                                     /* exitted */
-    NULL,                                     /* fatal */
-    _RTEMS_tasks_Terminate_extension          /* terminate */
+  .Callouts = {
+    .thread_create  = _RTEMS_tasks_Create_extension,
+    .thread_start   = _RTEMS_tasks_Start_extension,
+    .thread_restart = _RTEMS_tasks_Start_extension,
+    .thread_delete  = _RTEMS_tasks_Delete_extension
diff --git a/cpukit/rtems/src/taskvariable_invoke_dtor.c b/cpukit/rtems/src/taskvariable_invoke_dtor.c
deleted file mode 100644
index b9213f2..0000000
--- a/cpukit/rtems/src/taskvariable_invoke_dtor.c
+++ /dev/null
@@ -1,52 +0,0 @@
- *  @file
- *  @ingroup ClassicTasks
- *  COPYRIGHT (c) 1989-2014.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#if HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <rtems/rtems/tasksimpl.h>
-#include <rtems/score/threadimpl.h>
-#pragma GCC diagnostic ignored "-Wdeprecated-declarations"
-  void (*dtor)(void *);
-  void *value;
-  dtor = tvp->dtor;
-  if (_Thread_Get_executing() == the_thread) {
-    value = *tvp->ptr;
-  } else {
-    value = tvp->tval;
-  if ( dtor )
-    (*dtor)(value);
-  _Workspace_Free(tvp);
-#endif
diff --git a/cpukit/rtems/src/taskvariableadd.c b/cpukit/rtems/src/taskvariableadd.c
index 0fea945..0000000
--- a/cpukit/rtems/src/taskvariableadd.c
+++ /dev/null
@@ -1,97 +0,0 @@
- *  @file
-#if HAVE_CONFIG_H
-#endif
-#include <rtems/rtems/tasks.h>
-#include <rtems/config.h>
-  rtems_id tid,
-  void **ptr,
-  Thread_Control        *the_thread;
-  Objects_Locations      location;
-  rtems_task_variable_t *tvp, *new;
-#if defined( RTEMS_SMP )
-  if ( rtems_configuration_is_smp_enabled() ) {
-    return RTEMS_NOT_IMPLEMENTED;
-#endif
-  if ( !ptr )
-    return RTEMS_INVALID_ADDRESS;
-  the_thread = _Thread_Get (tid, &location);
-  switch (location) {
-    case OBJECTS_LOCAL:
-       *  Figure out if the variable is already in this task's list.
-      tvp = the_thread->task_variables;
-      while (tvp) {
-        if (tvp->ptr == ptr) {
-          tvp->dtor = dtor;
-          _Objects_Put( &the_thread->Object );
-          return RTEMS_SUCCESSFUL;
-       *  Now allocate memory for this task variable.
-      new = (rtems_task_variable_t *)
-         _Workspace_Allocate(sizeof(rtems_task_variable_t));
-      if (new == NULL) {
-        return RTEMS_NO_MEMORY;
-      new->gval = *ptr;
-      new->ptr = ptr;
-      new->dtor = dtor;
-      new->next = (struct rtems_task_variable_tt *)the_thread->task_variables;
-      the_thread->task_variables = new;
-#if defined(RTEMS_MULTIPROCESSING)
-    case OBJECTS_REMOTE:
-      _Thread_Dispatch();
-      return RTEMS_ILLEGAL_ON_REMOTE_OBJECT;
-#endif
-    case OBJECTS_ERROR:
-      break;
-  return RTEMS_INVALID_ID;
-#endif
diff --git a/cpukit/rtems/src/taskvariabledelete.c b/cpukit/rtems/src/taskvariabledelete.c
index 3f7f84e..0000000
--- a/cpukit/rtems/src/taskvariabledelete.c
+++ /dev/null
@@ -1,86 +0,0 @@
- *  @file
-#if HAVE_CONFIG_H
-#endif
-  rtems_id  tid,
-  void    **ptr
-  rtems_task_variable_t *tvp, *prev;
-#endif
-  if ( !ptr )
-  prev = NULL;
-      while (tvp) {
-          if (prev)
-            prev->next = tvp->next;
-          else
-            the_thread->task_variables = (rtems_task_variable_t *)tvp->next;
-          _RTEMS_Tasks_Invoke_task_variable_dtor( the_thread, tvp );
-        prev = tvp;
-#endif
-        break;
-#endif
diff --git a/cpukit/rtems/src/taskvariableget.c b/cpukit/rtems/src/taskvariableget.c
index 3b9cd25..0000000
--- a/cpukit/rtems/src/taskvariableget.c
+++ /dev/null
@@ -1,88 +0,0 @@
- * @file
- * @ingroup ClassicTasks Tasks
-#if HAVE_CONFIG_H
-#endif
-  rtems_id tid,
-  void **ptr,
-  void **result
-#endif
-  if ( !ptr )
-  if ( !result )
-       *  Figure out if the variable is in this task's list.
-      while (tvp) {
-	   * Should this return the current (i.e not the
-	   * saved) value if `tid' is the current task?
-          *result = tvp->tval;
-#endif
-      break;
-#endif
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index c32a902..b7c2f44 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -2100,42 +2100,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
   #define CONFIGURE_TASKS \
     (CONFIGURE_MAXIMUM_TASKS + CONFIGURE_LIBBLOCK_TASKS)
-   * This macro calculates the memory required for task variables.
-   * Each task variable is individually allocated from the Workspace.
-   * Hence, we do the multiplication on the configured size.
-   * @note Per-task variables are disabled for SMP configurations.
-  #if defined(RTEMS_SMP)
-    #ifdef CONFIGURE_MAXIMUM_TASK_VARIABLES
-      #warning "Per-Task Variables are deprecated and will be removed."
-      #error "Per-Task Variables are not safe for SMP systems and disabled."
-    #endif
-    #define CONFIGURE_MAXIMUM_TASK_VARIABLES                     0
-    #define CONFIGURE_MEMORY_FOR_TASK_VARIABLES(_task_variables) 0
-  #else
-    #ifndef CONFIGURE_MAXIMUM_TASK_VARIABLES
-      /** This macro specifies the maximum number of task variables. */
-       * This macro is calculated to specify the memory required for task
-       * variables.
-       * This is an internal parameter.
-    #else
-      #define CONFIGURE_MEMORY_FOR_TASK_VARIABLES(_task_variables) \
-	(_task_variables) * \
-	   _Configure_From_workspace(sizeof(rtems_task_variable_t))
-    #endif
-  #endif
   #ifndef CONFIGURE_MAXIMUM_TIMERS
     /** This specifies the maximum number of Classic API timers. */
     #define CONFIGURE_MAXIMUM_TIMERS             0
@@ -2818,9 +2782,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     #define CONFIGURE_MAXIMUM_GOROUTINES 400
   #endif
-  #define CONFIGURE_GOROUTINES_TASK_VARIABLES \
-    (2 * CONFIGURE_MAXIMUM_GOROUTINES)
   #ifndef CONFIGURE_MAXIMUM_GO_CHANNELS
     #define CONFIGURE_MAXIMUM_GO_CHANNELS 500
   #endif
@@ -2845,9 +2806,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
   /** This specifies the maximum number of Go co-routines. */
   #define CONFIGURE_MAXIMUM_GOROUTINES          0
-  /** This specifies the maximum number of Go per-task variables required. */
-  #define CONFIGURE_GOROUTINES_TASK_VARIABLES   0
   /** This specifies the maximum number of Go channels required. */
   #define CONFIGURE_MAXIMUM_GO_CHANNELS         0
 #endif
@@ -3068,9 +3026,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
  * Classic API as configured.
 #define CONFIGURE_MEMORY_FOR_CLASSIC \
-  (CONFIGURE_MEMORY_FOR_TASK_VARIABLES(CONFIGURE_MAXIMUM_TASK_VARIABLES + \
-    CONFIGURE_GOROUTINES_TASK_VARIABLES) + \
-   CONFIGURE_MEMORY_FOR_TIMERS(CONFIGURE_MAXIMUM_TIMERS + \
+   (CONFIGURE_MEMORY_FOR_TIMERS(CONFIGURE_MAXIMUM_TIMERS + \
     CONFIGURE_TIMER_FOR_SHARED_MEMORY_DRIVER ) + \
    CONFIGURE_MEMORY_FOR_SEMAPHORES(CONFIGURE_SEMAPHORES) + \
    CONFIGURE_MEMORY_FOR_MESSAGE_QUEUES(CONFIGURE_MAXIMUM_MESSAGE_QUEUES) + \
@@ -3581,7 +3537,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     /* Classic API Pieces */
     uint32_t CLASSIC_TASKS;
-    uint32_t TASK_VARIABLES;
     uint32_t TIMERS;
     uint32_t SEMAPHORES;
     uint32_t MESSAGE_QUEUES;
@@ -3635,8 +3590,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     CONFIGURE_MEMORY_FOR_TASKS(CONFIGURE_MAXIMUM_TASKS, 0),
-    CONFIGURE_MEMORY_FOR_TASK_VARIABLES(CONFIGURE_MAXIMUM_TASK_VARIABLES +
-      CONFIGURE_GOROUTINES_TASK_VARIABLES),
     CONFIGURE_MEMORY_FOR_TIMERS(CONFIGURE_MAXIMUM_TIMERS),
     CONFIGURE_MEMORY_FOR_SEMAPHORES(CONFIGURE_SEMAPHORES),
     CONFIGURE_MEMORY_FOR_MESSAGE_QUEUES(CONFIGURE_MAXIMUM_MESSAGE_QUEUES),
diff --git a/cpukit/score/include/rtems/score/thread.h b/cpukit/score/include/rtems/score/thread.h
index 8bc12d2..8ea2db2 100644
--- a/cpukit/score/include/rtems/score/thread.h
+++ b/cpukit/score/include/rtems/score/thread.h
@@ -173,35 +173,6 @@ typedef enum {
 typedef void (*Thread_CPU_budget_algorithm_callout )( Thread_Control * );
- *  @brief Forward reference to the per task variable structure..
- *  Forward reference to the per task variable structure.
-struct rtems_task_variable_tt;
- *  @brief Internal structure used to manager per task variables.
- *  This is the internal structure used to manager per Task Variables.
-typedef struct {
-  /** This field points to the next per task variable for this task. */
-  struct rtems_task_variable_tt  *next;
-  /** This field points to the physical memory location of this per
-   *  task variable.
-  void                          **ptr;
-  /** This field is to the global value for this per task variable. */
-  void                           *gval;
-  /** This field is to this thread's value for this per task variable. */
-  void                           *tval;
-  /** This field points to the destructor for this per task variable. */
-} rtems_task_variable_t;
-#endif
  *  The following structure contains the information which defines
  *  the starting state of a thread.
@@ -870,11 +841,6 @@ struct _Thread_Control {
   /** This array contains the API extension area pointers. */
   void                                 *API_Extensions[ THREAD_API_LAST + 1 ];
-  /** This field points to the set of per task variables. */
-  rtems_task_variable_t                *task_variables;
-#endif
    * @brief The POSIX Keys information.
diff --git a/testsuites/psxtests/psxconfig01/init.c b/testsuites/psxtests/psxconfig01/init.c
index 9f3c134..582fd11 100644
--- a/testsuites/psxtests/psxconfig01/init.c
+++ b/testsuites/psxtests/psxconfig01/init.c
@@ -57,9 +57,6 @@ const char rtems_test_name[] = "PSXCONFIG 1";
 #define CONFIGURE_MAXIMUM_REGIONS 43
 #define CONFIGURE_MAXIMUM_SEMAPHORES 47
 #define CONFIGURE_MAXIMUM_TASKS 11
-  #define CONFIGURE_MAXIMUM_TASK_VARIABLES 13
-#endif
 #define CONFIGURE_MAXIMUM_TIMERS 59
 #define CONFIGURE_MAXIMUM_USER_EXTENSIONS 17
@@ -202,10 +199,6 @@ typedef struct {
 static char posix_name [_POSIX_PATH_MAX + 1];
-  static void *task_var;
-#endif
 static char *get_posix_name(char a, char b, char c, int i)
   posix_name [_POSIX_PATH_MAX - 4] = a;
@@ -216,13 +209,6 @@ static char *get_posix_name(char a, char b, char c, int i)
   return posix_name;
-static void task_var_dtor(void *var RTEMS_UNUSED)
-  /* Do nothing */
-#endif
 static void *posix_thread(void *arg RTEMS_UNUSED)
   rtems_test_assert(0);
@@ -435,21 +421,6 @@ static rtems_task Init(rtems_task_argument argument)
 #endif
-#ifdef CONFIGURE_MAXIMUM_TASK_VARIABLES
-    for (i = 0; i < CONFIGURE_MAXIMUM_TASK_VARIABLES; ++i) {
-      sc = rtems_task_variable_add(RTEMS_SELF, &task_var, task_var_dtor);
-      directive_failed(sc, "rtems_task_variable_add");
-#endif
-#endif
 #ifdef CONFIGURE_MAXIMUM_TIMERS
   for (i = 0; i < CONFIGURE_MAXIMUM_TIMERS; ++i) {
     sc = rtems_timer_create(name, &id);
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index f5481ae..593b65b 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -107,7 +107,6 @@ sp25/Makefile
 sp26/Makefile
 sp27/Makefile
 sp27a/Makefile
-sp28/Makefile
 sp29/Makefile
 sp30/Makefile
 sp31/Makefile
diff --git a/testsuites/sptests/sp28/Makefile.am b/testsuites/sptests/sp28/Makefile.am
index d02ff97..0000000
--- a/testsuites/sptests/sp28/Makefile.am
+++ /dev/null
@@ -1,22 +0,0 @@
-rtems_tests_PROGRAMS = sp28
-sp28_SOURCES = init.c
-dist_rtems_tests_DATA = sp28.scn
-dist_rtems_tests_DATA += sp28.doc
-include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
-include $(top_srcdir)/../automake/compile.am
-include $(top_srcdir)/../automake/leaf.am
-AM_CPPFLAGS += -I$(top_srcdir)/../support/include
-LINK_OBJS = $(sp28_OBJECTS)
-LINK_LIBS = $(sp28_LDLIBS)
-sp28$(EXEEXT): $(sp28_OBJECTS) $(sp28_DEPENDENCIES)
-	@rm -f sp28$(EXEEXT)
-	$(make-exe)
-include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/sp28/init.c b/testsuites/sptests/sp28/init.c
index 4798bff..0000000
--- a/testsuites/sptests/sp28/init.c
+++ /dev/null
@@ -1,439 +0,0 @@
- *  COPYRIGHT (c) 1989-2012.
-#ifdef HAVE_CONFIG_H
-#endif
-#include <tmacros.h>
-#include <bsp.h>
-#include <rtems/error.h>
-#include <stdio.h>
-const char rtems_test_name[] = "SP 28";
-/* forward declarations to avoid warnings */
-rtems_task Init(rtems_task_argument argument);
-rtems_task subtask(rtems_task_argument arg);
-rtems_task Task_variable_deleter(rtems_task_argument ignored);
-void starttask(int arg);
-void test_errors(void);
-void test_dtor(void *pointer);
-void test_multiple_taskvars(void);
-void test_out_of_memory(void);
-rtems_task Other_Task(rtems_task_argument ignored);
-void test_delete_from_other_task(void);
-void test_delete_as_side_effect(void);
-volatile void *taskvar;
-volatile int nRunning;
-volatile int nDeleted;
-rtems_task
-subtask (rtems_task_argument arg)
-  uintptr_t         localvar = arg;
-  int               i;
-  rtems_status_code sc;
-  nRunning++;
-  while (nRunning != 3)
-    rtems_task_wake_after (0);
-  sc = rtems_task_variable_add(RTEMS_SELF, (void **)&taskvar, NULL);
-  directive_failed( sc, "task variable add" );
-  taskvar = (void *)localvar;
-  while (localvar < 1000) {
-    localvar++;
-    taskvar = (void *)((uintptr_t)taskvar + 1);
-    if ((uintptr_t)taskvar != localvar) {
-      printf(
-        "Task:%" PRIdrtems_task_argument " taskvar:%" PRIuPTR
-          " localvar:%" PRIuPTR "\n",
-        arg,
-        (uintptr_t)taskvar,
-        localvar
-      rtems_task_suspend (RTEMS_SELF);
-  sc = rtems_task_variable_delete(RTEMS_SELF, (void **)&taskvar);
-  nDeleted++;
-  directive_failed( sc, "task variable delete" );
-  if ((uintptr_t)taskvar == localvar) {
-    printf(
-      "Task:%" PRIdrtems_task_argument " deleted taskvar:%" PRIuPTR
-      arg,
-      localvar
-    nRunning--;
-  while (nDeleted != 3)
-  for (i = 0 ; i < 1000 ; i++) {
-    taskvar = (void *)(localvar = 100 * arg);
-    rtems_task_wake_after(0);
-    if (nRunning <= 1)
-      break;
-      printf(
-       arg,
-       localvar
-      nRunning--;
-      rtems_task_suspend(RTEMS_SELF);
-  nRunning--;
-  while (nRunning)
-  TEST_END();
-  rtems_test_exit(0);
-void
-starttask (int arg)
-  rtems_id tid;
-  sc = rtems_task_create(rtems_build_name ('S', 'R', 'V', arg + 'A'),
-    RTEMS_MAXIMUM_PRIORITY - 1u,
-    RTEMS_MINIMUM_STACK_SIZE,
-    RTEMS_PREEMPT|RTEMS_NO_TIMESLICE|RTEMS_NO_ASR|RTEMS_INTERRUPT_LEVEL(0),
-    RTEMS_NO_FLOATING_POINT|RTEMS_LOCAL,
-    &tid
-  directive_failed( sc, "task create" );
-  sc = rtems_task_start(tid, subtask, arg);
-  directive_failed( sc, "task start" );
-volatile void *taskvar1;
-volatile void *taskvar2;
-volatile void *taskvar3;
-  void              *value;
-   *  task variable add error status codes
-  puts( "task variable add - NULL pointer - RTEMS_INVALID_ADDRESS" );
-  sc = rtems_task_variable_add(RTEMS_SELF, NULL, NULL );
-  fatal_directive_status( sc, RTEMS_INVALID_ADDRESS, "add NULL pointer" );
-   *  task variable get error status codes
-  puts( "task variable get - bad Id - RTEMS_INVALID_ID" );
-  sc = rtems_task_variable_get(
-    rtems_task_self() + 10,
-    (void **)&taskvar1,
-    &value
-  fatal_directive_status( sc, RTEMS_INVALID_ID, "bad Id" );
-  puts( "task variable get - NULL pointer - RTEMS_INVALID_ADDRESS" );
-  sc = rtems_task_variable_get(RTEMS_SELF, NULL, &value );
-  fatal_directive_status( sc, RTEMS_INVALID_ADDRESS, "get NULL pointer" );
-  puts( "task variable get - bad result - RTEMS_INVALID_ADDRESS" );
-  sc = rtems_task_variable_get(RTEMS_SELF, (void **)&taskvar1, NULL);
-  fatal_directive_status( sc, RTEMS_INVALID_ADDRESS, "get bad result" );
-  puts( "task variable get - bad pointer - RTEMS_INVALID_ADDRESS" );
-  sc = rtems_task_variable_get(RTEMS_SELF, (void **)&taskvar1, &value);
-  fatal_directive_status( sc, RTEMS_INVALID_ADDRESS, "get bad pointer" );
-   *  task variable delete error status codes
-  puts( "task variable delete - bad Id - RTEMS_INVALID_ID" );
-  sc = rtems_task_variable_delete( rtems_task_self() + 10, (void **)&taskvar1 );
-  puts( "task variable delete - NULL pointer - RTEMS_INVALID_ADDRESS" );
-  sc = rtems_task_variable_delete(RTEMS_SELF, NULL);
-  fatal_directive_status( sc, RTEMS_INVALID_ADDRESS, "delete NULL pointer" );
-  puts( "task variable delete - bad pointer - RTEMS_INVALID_ADDRESS" );
-  sc = rtems_task_variable_delete(RTEMS_SELF, (void **)&taskvar1);
-  fatal_directive_status( sc, RTEMS_INVALID_ADDRESS, "delete bad pointer" );
-volatile uint32_t test_dtor_ran;
-  test_dtor_ran++;
-  void              *value;
-  test_dtor_ran = 0;
-   *  Add multiple task variables and add each twice to
-   *  verify that behavior is OK
-  puts( "task variable add - bad Id - RTEMS_INVALID_ID" );
-    NULL
-  puts( "Adding multiple task variables" );
-  sc = rtems_task_variable_add(RTEMS_SELF, (void **)&taskvar1, NULL);
-  directive_failed( sc, "add multiple #1" );
-  sc = rtems_task_variable_add(RTEMS_SELF, (void **)&taskvar1, test_dtor);
-  directive_failed( sc, "add multiple #2" );
-  sc = rtems_task_variable_add(RTEMS_SELF, (void **)&taskvar2, test_dtor);
-  directive_failed( sc, "add multiple #3" );
-  sc = rtems_task_variable_add(RTEMS_SELF, (void **)&taskvar2, NULL);
-  directive_failed( sc, "add multiple #4" );
-  sc = rtems_task_variable_add(RTEMS_SELF, (void **)&taskvar3, NULL);
-  directive_failed( sc, "add multiple #5" );
-  sc = rtems_task_variable_add(RTEMS_SELF, (void **)&taskvar3, test_dtor);
-  directive_failed( sc, "add multiple #6" );
-   *  Obtain task variables in various spots on the chain
-  puts( "Obtaining multiple task variables" );
-  sc = rtems_task_variable_get( RTEMS_SELF, (void **)&taskvar3, &value );
-  directive_failed( sc, "get multiple #1" );
-  sc = rtems_task_variable_get( RTEMS_SELF, (void **)&taskvar2, &value );
-  directive_failed( sc, "get multiple #2" );
-  sc = rtems_task_variable_get( RTEMS_SELF, (void **)&taskvar1, &value );
-   *  Delete task variables in various spots on the chain
-  /* to trip the destructors */
-  taskvar1 = (void *)1;
-  taskvar2 = (void *)2;
-  taskvar3 = (void *)3;
-  puts( "Deleting multiple task variables" );
-  sc = rtems_task_variable_delete(RTEMS_SELF, (void **)&taskvar2);
-  directive_failed( sc, "delete multiple #1" );
-  sc = rtems_task_variable_delete(RTEMS_SELF, (void **)&taskvar3);
-  directive_failed( sc, "delete multiple #2" );
-  directive_failed( sc, "delete multiple #3" );
-  if ( test_dtor_ran != 2 ) {
-    printf(
-      "Test dtor ran %" PRIu32 " times not 2 times as expected\n",
-       test_dtor_ran
-#define MAX_VARS 4096
-void *Pointers[MAX_VARS];
-  int                 i;
-  int                 max;
-  int                 ran_out = 0;
-  void              **base;
-  base = Pointers;
-  for (i=0 ; i<MAX_VARS ; i++ ) {
-    sc = rtems_task_variable_add(RTEMS_SELF, &base[i], NULL);
-    if ( sc == RTEMS_NO_MEMORY ) {
-      puts( "task_variable_add - returns NO_MEMORY" );
-      max = i;
-      ran_out = 1;
-      break;
-    directive_failed( sc, "add loop until out of memory" );
-  if ( !ran_out ) {
-    puts( "ERROR!!! did not run out of memory adding task variables!" );
-  for (i=0 ; i<max ; i++ ) {
-    sc = rtems_task_variable_delete(RTEMS_SELF, &base[i]);
-    directive_failed( sc, "delete loop until out of memory" );
-rtems_id main_task;
-rtems_id other_task;
-  puts( "Deleting task variables in another task" );
-  sc = rtems_task_variable_delete(main_task, (void **)&taskvar1);
-  directive_failed( sc, "delete loop for other task" );
-  (void) rtems_task_delete( RTEMS_SELF );
-  sc = rtems_task_ident( RTEMS_SELF, 0, &main_task );
-  directive_failed( sc, "task ident" );
-  directive_failed( sc, "add for other task case" );
-  sc = rtems_task_create(rtems_build_name ('O', 'T', 'H', 'R'),
-    &other_task
-  directive_failed( sc, "task create other" );
-  sc = rtems_task_start(other_task, Other_Task, 0);
-  directive_failed( sc, "task start other" );
-  rtems_task_wake_after( 100 );
-  if ( test_dtor_ran != 1 ) {
-    printf(
-      "Test dtor ran %" PRIu32 " times not 1 times as expected\n",
-      test_dtor_ran
- *  Task which adds task variables just to delete them
-  puts( "Adding multiple task variables to delete implicitly" );
-  directive_failed( sc, "add multiple for delete #1" );
-  directive_failed( sc, "add multiple for delete #2" );
-  directive_failed( sc, "add multiple for delete #3" );
-  rtems_id          deleter_task;
-    &deleter_task
-  directive_failed( sc, "task create deleter" );
-  sc = rtems_task_start(deleter_task, Task_variable_deleter, 0);
-  directive_failed( sc, "task start deleter" );
-    printf(
-      test_dtor_ran
-rtems_task Init (rtems_task_argument ignored)
-  TEST_BEGIN();
-  test_errors();
-  test_multiple_taskvars();
-  test_delete_as_side_effect();
-  test_delete_from_other_task();
-  starttask (1);
-  starttask (2);
-  starttask (3);
-  test_out_of_memory();
-#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
-#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
-#define CONFIGURE_MAXIMUM_USER_EXTENSIONS    2
-#define CONFIGURE_MAXIMUM_TASKS              4
-#define CONFIGURE_MAXIMUM_TASK_VARIABLES     (4)
-#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
-#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
-#define CONFIGURE_MICROSECONDS_PER_TICK      10000
-#include <rtems/confdefs.h>
diff --git a/testsuites/sptests/sp28/sp28.doc b/testsuites/sptests/sp28/sp28.doc
index e69de29..0000000
diff --git a/testsuites/sptests/sp28/sp28.scn b/testsuites/sptests/sp28/sp28.scn
index 654ae97..0000000
--- a/testsuites/sptests/sp28/sp28.scn
+++ /dev/null
@@ -1,17 +0,0 @@
-*** START OF TEST 28 ***
-task variable add - NULL pointer - RTEMS_INVALID_ADDRESS
-task variable get - bad Id - RTEMS_INVALID_ID
-task variable get - NULL pointer - RTEMS_INVALID_ADDRESS
-task variable get - bad result - RTEMS_INVALID_ADDRESS
-task variable get - bad pointer - RTEMS_INVALID_ADDRESS
-task variable delete - bad Id - RTEMS_INVALID_ID
-task variable delete - NULL pointer - RTEMS_INVALID_ADDRESS
-task variable delete - bad pointer - RTEMS_INVALID_ADDRESS
-task variable add - bad Id - RTEMS_INVALID_ID
-Adding multiple task variables
-Obtaining multiple task variables
-Deleting multiple task variables
-Adding multiple task variables to delete implicitly
-Deleting task variables in another task
-task_variable_add - returns NO_MEMORY
-*** END OF TEST 28 ***
1.8.4.5
