[PATCH 04/11] rtems: Remove task variables
Wed May 4 01:55:46 UTC 2016
I feel like this needs a ringing bell. Maybe a funeral dirge.
On Tue, May 3, 2016 at 8:49 AM, Sebastian Huber
> Update #2494.
> Update #2555.
>  c/src/ada/rtems-tasks.adb                    |  65 ----
>  c/src/ada/rtems-tasks.ads                    |  25 --
>  cpukit/rtems/Makefile.am                     |   7 -
>  cpukit/rtems/include/rtems/rtems/tasks.h     |  46 ---
>  cpukit/rtems/include/rtems/rtems/tasksimpl.h |  15 -
>  cpukit/rtems/mainpage.h                      |  38 +--
>  cpukit/rtems/src/tasks.c                     |  92 +-----
>  cpukit/rtems/src/taskvariable_invoke_dtor.c  |  52 ----
>  cpukit/rtems/src/taskvariableadd.c           |  97 ------
>  cpukit/rtems/src/taskvariabledelete.c        |  86 ------
>  cpukit/rtems/src/taskvariableget.c           |  88 ------
>  cpukit/sapi/include/confdefs.h               |  49 +--
>  cpukit/score/include/rtems/score/thread.h    |  34 ---
>  testsuites/psxtests/psxconfig01/init.c       |  29 --
>  testsuites/sptests/configure.ac              |   1 -
>  testsuites/sptests/sp28/Makefile.am          |  22 --
>  testsuites/sptests/sp28/init.c               | 439 ---------------------------
>  testsuites/sptests/sp28/sp28.doc             |   0
>  testsuites/sptests/sp28/sp28.scn             |  17 --
>  19 files changed, 10 insertions(+), 1192 deletions(-)
>  delete mode 100644 cpukit/rtems/src/taskvariable_invoke_dtor.c
>  delete mode 100644 cpukit/rtems/src/taskvariableadd.c
>  delete mode 100644 cpukit/rtems/src/taskvariabledelete.c
>  delete mode 100644 cpukit/rtems/src/taskvariableget.c
>  delete mode 100644 testsuites/sptests/sp28/Makefile.am
>  delete mode 100644 testsuites/sptests/sp28/init.c
>  delete mode 100644 testsuites/sptests/sp28/sp28.doc
>  delete mode 100644 testsuites/sptests/sp28/sp28.scn
> diff --git a/c/src/ada/rtems-tasks.adb b/c/src/ada/rtems-tasks.adb
> index b809fcf..1fc7fcd 100644
> --- a/c/src/ada/rtems-tasks.adb
> +++ b/c/src/ada/rtems-tasks.adb
> @@ -203,71 +203,6 @@ package body RTEMS.Tasks is
>     end Mode;
> -   procedure Variable_Add
> -     (ID            : in RTEMS.ID;
> -      Task_Variable : in RTEMS.Address;
> -      Dtor          : in Variable_Dtor;
> -      Result        : out RTEMS.Status_Codes)
> -   is
> -      function Variable_Add_Base
> -        (ID            : RTEMS.ID;
> -         Task_Variable : RTEMS.Address;
> -         Dtor          : Variable_Dtor)
> -         return          RTEMS.Status_Codes;
> -      pragma Import (C, Variable_Add_Base, "rtems_task_variable_add");
> -   begin
> -      Result := Variable_Add_Base (ID, Task_Variable, Dtor);
> -   end Variable_Add;
> -   procedure Variable_Get
> -      Task_Variable       : out RTEMS.Address;
> -      Task_Variable_Value : out RTEMS.Address;
> -   is
> -      function Variable_Get_Base
> -        (ID                  : RTEMS.ID;
> -         Task_Variable       : access RTEMS.Address;
> -         Task_Variable_Value : access RTEMS.Address)
> -      pragma Import (C, Variable_Get_Base, "rtems_task_variable_get");
> -      Task_Variable_Base       : aliased RTEMS.Address;
> -      Task_Variable_Value_Base : aliased RTEMS.Address;
> -   begin
> -      Result              :=
> -         Variable_Get_Base
> -           (ID,
> -            Task_Variable_Base'Access,
> -            Task_Variable_Value_Base'Access);
> -      Task_Variable       := Task_Variable_Base;
> -      Task_Variable_Value := Task_Variable_Value_Base;
> -   end Variable_Get;
> -   procedure Variable_Delete
> -   is
> -      function Variable_Delete_Base
> -        (ID            : RTEMS.ID;
> -         Task_Variable : access RTEMS.Address)
> -      pragma Import
> -        (C,
> -         Variable_Delete_Base,
> -         "rtems_task_variable_delete");
> -   begin
> -      Result        := Variable_Delete_Base (ID, Task_Variable_Base'Access);
> -   end Variable_Delete;
>     procedure Wake_When
>       (Time_Buffer : in RTEMS.Time_Of_Day;
> diff --git a/c/src/ada/rtems-tasks.ads b/c/src/ada/rtems-tasks.ads
> index c1f200b..2cb3157 100644
> --- a/c/src/ada/rtems-tasks.ads
> +++ b/c/src/ada/rtems-tasks.ads
> @@ -117,31 +117,6 @@ package RTEMS.Tasks is
> -   type Variable_Dtor is access procedure (
> -      Argument : in     RTEMS.Address
> -   pragma Convention (C, Variable_Dtor);
> -   procedure Variable_Add (
> -      ID            : in     RTEMS.ID;
> -   procedure Variable_Get (
> -      ID                  : in     RTEMS.ID;
> -   procedure Variable_Delete (
> -      ID                  : in     RTEMS.ID;
>     procedure Wake_When (
> diff --git a/cpukit/rtems/Makefile.am b/cpukit/rtems/Makefile.am
> index 6515a08..73d9e30 100644
> --- a/cpukit/rtems/Makefile.am
> +++ b/cpukit/rtems/Makefile.am
> @@ -104,13 +104,6 @@ librtems_a_SOURCES += src/taskstart.c
>  librtems_a_SOURCES += src/tasksuspend.c
>  librtems_a_SOURCES += src/taskwakeafter.c
>  librtems_a_SOURCES += src/taskwakewhen.c
> -if HAS_SMP
> -else
> -librtems_a_SOURCES += src/taskvariableadd.c
> -librtems_a_SOURCES += src/taskvariabledelete.c
> -librtems_a_SOURCES += src/taskvariableget.c
> -librtems_a_SOURCES += src/taskvariable_invoke_dtor.c
> -endif
>  librtems_a_SOURCES += src/schedulergetprocessorset.c
>  librtems_a_SOURCES += src/schedulerident.c
> diff --git a/cpukit/rtems/include/rtems/rtems/tasks.h b/cpukit/rtems/include/rtems/rtems/tasks.h
> index 11e2780..5f33e0b 100644
> --- a/cpukit/rtems/include/rtems/rtems/tasks.h
> +++ b/cpukit/rtems/include/rtems/rtems/tasks.h
> @@ -372,52 +372,6 @@ rtems_status_code rtems_task_is_suspended(
>    rtems_id   id
> -#if !defined(RTEMS_SMP)
> - *  @brief RTEMS Add Task Variable
> - *  @deprecated Task variables are deprecated.
> - *  This directive adds a per task variable.
> - *  @note This service is not available in SMP configurations.
> -rtems_status_code rtems_task_variable_add(
> -  rtems_id  tid,
> -  void    **ptr,
> -  void    (*dtor)(void *)
> -) RTEMS_DEPRECATED;
> - *  @brief Get a per-task variable
> - *  This directive gets the value of a task variable.
> -rtems_status_code rtems_task_variable_get(
> -  rtems_id tid,
> -  void **ptr,
> -  void **result
> - *  @brief RTEMS Delete Task Variable
> - *  This directive removes a per task variable.
> -rtems_status_code rtems_task_variable_delete(
> -  rtems_id  tid,
> -  void    **ptr
> -#endif
>  #if defined(__RTEMS_HAVE_SYS_CPUSET_H__)
>   * @brief Gets the processor affinity set of a task.
> diff --git a/cpukit/rtems/include/rtems/rtems/tasksimpl.h b/cpukit/rtems/include/rtems/rtems/tasksimpl.h
> index 3f8a873..82e8618 100644
> --- a/cpukit/rtems/include/rtems/rtems/tasksimpl.h
> +++ b/cpukit/rtems/include/rtems/rtems/tasksimpl.h
> @@ -47,21 +47,6 @@ extern Thread_Information _RTEMS_tasks_Information;
>  void _RTEMS_tasks_Initialize_user_tasks( void );
> - *  @brief RTEMS Tasks Invoke Task Variable Destructor
> - *  This routine invokes the optional user provided destructor on the
> - *  task variable and frees the memory for the task variable.
> -void _RTEMS_Tasks_Invoke_task_variable_dtor(
> -  Thread_Control        *the_thread,
> -  rtems_task_variable_t *tvp
> -#endif
>  RTEMS_INLINE_ROUTINE Thread_Control *_RTEMS_tasks_Allocate(void)
>    _Objects_Allocator_lock();
> diff --git a/cpukit/rtems/mainpage.h b/cpukit/rtems/mainpage.h
> index 9801bfb..e2d5132 100644
> --- a/cpukit/rtems/mainpage.h
> +++ b/cpukit/rtems/mainpage.h
> @@ -856,40 +856,10 @@
>   * @section ClassicTasksSecPerTaskVariables Per Task Variables
> - * Per task variables are used to support global variables whose value may be
> - * unique to a task. After indicating that a variable should be treated as
> - * private (i.e. per-task) the task can access and modify the variable, but the
> - * modifications will not appear to other tasks, and other tasks' modifications
> - * to that variable will not affect the value seen by the task. This is
> - * accomplished by saving and restoring the variable's value each time a task
> - * switch occurs to or from the calling task.
> - * The value seen by other tasks, including those which have not added the
> - * variable to their set and are thus accessing the variable as a common
> - * location shared among tasks, can not be affected by a task once it has added
> - * a variable to its local set. Changes made to the variable by other tasks
> - * will not affect the value seen by a task which has added the variable to its
> - * private set.
> - * This feature can be used when a routine is to be spawned repeatedly as
> - * several independent tasks. Although each task will have its own stack, and
> - * thus separate stack variables, they will all share the same static and
> - * global variables. To make a variable not shareable (i.e. a "global" variable
> - * that is specific to a single task), the tasks can call
> - * rtems_task_variable_add() to make a separate copy of the variable for each
> - * task, but all at the same physical address.
> - * Task variables increase the context switch time to and from the tasks that
> - * own them so it is desirable to minimize the number of task variables. One
> - * efficient method is to have a single task variable that is a pointer to a
> - * dynamically allocated structure containing the task's private "global" data.
> - * A critical point with per-task variables is that each task must separately
> - * request that the same global variable is per-task private.
> - * @b {WARNING}: Per-task variables are fundamentally incorrect in SMP
> - *               systems and should not be used in SMP applications. They
> - *               are disabled.
> + * Per task variables are no longer available.  In particular the
> + * rtems_task_variable_add(), rtems_task_variable_get() and
> + * rtems_task_variable_delete() functions are neither declared nor defined
> + * anymore.  Use thread local storage or POSIX Keys instead.
>   * @section ClassicTasksSecBuildingTaskAttributeSet Building a Task Attribute Set
> diff --git a/cpukit/rtems/src/tasks.c b/cpukit/rtems/src/tasks.c
> index f18e0ab..56b2455 100644
> --- a/cpukit/rtems/src/tasks.c
> +++ b/cpukit/rtems/src/tasks.c
> @@ -18,20 +18,13 @@
>  #include "config.h"
>  #endif
> -#include <rtems/system.h>
>  #include <rtems/config.h>
>  #include <rtems/sysinit.h>
>  #include <rtems/rtems/asrimpl.h>
>  #include <rtems/rtems/eventimpl.h>
> -#include <rtems/rtems/signalimpl.h>
> -#include <rtems/rtems/status.h>
> -#include <rtems/rtems/support.h>
> -#include <rtems/rtems/modes.h>
>  #include <rtems/rtems/tasksimpl.h>
> -#include <rtems/score/stack.h>
>  #include <rtems/score/threadimpl.h>
>  #include <rtems/score/userextimpl.h>
> -#include <rtems/score/wkspace.h>
> @@ -91,87 +84,12 @@ static void _RTEMS_tasks_Delete_extension(
>    _ASR_Destroy( &api->Signal );
> -static void _RTEMS_tasks_Terminate_extension(
> -  Thread_Control *executing
> -   *  Free per task variable memory
> -   *  Per Task Variables are only enabled in uniprocessor configurations.
> -  #if !defined(RTEMS_SMP)
> -     * We know this is deprecated and don't want a warning on every BSP built.
> -    #pragma GCC diagnostic push
> -    #pragma GCC diagnostic ignored "-Wdeprecated-declarations"
> -    do {
> -      rtems_task_variable_t *tvp, *next;
> -      tvp = executing->task_variables;
> -      executing->task_variables = NULL;
> -      while (tvp) {
> -       next = (rtems_task_variable_t *)tvp->next;
> -       _RTEMS_Tasks_Invoke_task_variable_dtor( executing, tvp );
> -       tvp = next;
> -    } while (0);
> -    #pragma GCC diagnostic pop
> -  #endif
> - *  _RTEMS_tasks_Switch_extension
> - *  This extension routine is invoked at each context switch.
> - *  @note Since this only needs to address per-task variables, it is
> - *        disabled entirely for SMP configurations.
> -static void _RTEMS_tasks_Switch_extension(
> -  Thread_Control *executing,
> -  Thread_Control *heir
> -  rtems_task_variable_t *tvp;
> -  while (tvp) {
> -    tvp->tval = *tvp->ptr;
> -    *tvp->ptr = tvp->gval;
> -    tvp = (rtems_task_variable_t *)tvp->next;
> -  tvp = heir->task_variables;
> -  while (tvp) {
> -    tvp->gval = *tvp->ptr;
> -    *tvp->ptr = tvp->tval;
> -#define RTEMS_TASKS_SWITCH_EXTENSION _RTEMS_tasks_Switch_extension
> -#else
> -#define RTEMS_TASKS_SWITCH_EXTENSION NULL
> -#endif
>  User_extensions_Control _RTEMS_tasks_User_extensions = {
> -  { NULL, NULL },
> -  { { NULL, NULL }, RTEMS_TASKS_SWITCH_EXTENSION },
> -  { _RTEMS_tasks_Create_extension,            /* create */
> -    _RTEMS_tasks_Start_extension,             /* start */
> -    _RTEMS_tasks_Start_extension,             /* restart */
> -    _RTEMS_tasks_Delete_extension,            /* delete */
> -    RTEMS_TASKS_SWITCH_EXTENSION,             /* switch */
> -    NULL,                                     /* begin */
> -    NULL,                                     /* exitted */
> -    NULL,                                     /* fatal */
> -    _RTEMS_tasks_Terminate_extension          /* terminate */
> +  .Callouts = {
> +    .thread_create  = _RTEMS_tasks_Create_extension,
> +    .thread_start   = _RTEMS_tasks_Start_extension,
> +    .thread_restart = _RTEMS_tasks_Start_extension,
> +    .thread_delete  = _RTEMS_tasks_Delete_extension
> diff --git a/cpukit/rtems/src/taskvariable_invoke_dtor.c b/cpukit/rtems/src/taskvariable_invoke_dtor.c
> deleted file mode 100644
> index b9213f2..0000000
> --- a/cpukit/rtems/src/taskvariable_invoke_dtor.c
> +++ /dev/null
> @@ -1,52 +0,0 @@
> - *  @file
> - *  @ingroup ClassicTasks
> - *  COPYRIGHT (c) 1989-2014.
> - *  On-Line Applications Research Corporation (OAR).
> - *  The license and distribution terms for this file may be
> - *  found in the file LICENSE in this distribution or at
> - *  http://www.rtems.org/license/LICENSE.
> -#if HAVE_CONFIG_H
> -#include "config.h"
> -#endif
> -#include <rtems/rtems/tasksimpl.h>
> -#include <rtems/score/threadimpl.h>
> -#pragma GCC diagnostic ignored "-Wdeprecated-declarations"
> -  void (*dtor)(void *);
> -  void *value;
> -  dtor = tvp->dtor;
> -  if (_Thread_Get_executing() == the_thread) {
> -    value = *tvp->ptr;
> -  } else {
> -    value = tvp->tval;
> -  if ( dtor )
> -    (*dtor)(value);
> -  _Workspace_Free(tvp);
> -#endif
> diff --git a/cpukit/rtems/src/taskvariableadd.c b/cpukit/rtems/src/taskvariableadd.c
> index 0fea945..0000000
> --- a/cpukit/rtems/src/taskvariableadd.c
> +++ /dev/null
> @@ -1,97 +0,0 @@
> - *  @file
> -#if HAVE_CONFIG_H
> -#endif
> -#include <rtems/rtems/tasks.h>
> -#include <rtems/config.h>
> -  rtems_id tid,
> -  void **ptr,
> -  Thread_Control        *the_thread;
> -  Objects_Locations      location;
> -  rtems_task_variable_t *tvp, *new;
> -#if defined( RTEMS_SMP )
> -  if ( rtems_configuration_is_smp_enabled() ) {
> -    return RTEMS_NOT_IMPLEMENTED;
> -#endif
> -  if ( !ptr )
> -    return RTEMS_INVALID_ADDRESS;
> -  the_thread = _Thread_Get (tid, &location);
> -  switch (location) {
> -    case OBJECTS_LOCAL:
> -       *  Figure out if the variable is already in this task's list.
> -      tvp = the_thread->task_variables;
> -      while (tvp) {
> -        if (tvp->ptr == ptr) {
> -          tvp->dtor = dtor;
> -          _Objects_Put( &the_thread->Object );
> -          return RTEMS_SUCCESSFUL;
> -       *  Now allocate memory for this task variable.
> -      new = (rtems_task_variable_t *)
> -         _Workspace_Allocate(sizeof(rtems_task_variable_t));
> -      if (new == NULL) {
> -        return RTEMS_NO_MEMORY;
> -      new->gval = *ptr;
> -      new->ptr = ptr;
> -      new->dtor = dtor;
> -      new->next = (struct rtems_task_variable_tt *)the_thread->task_variables;
> -      the_thread->task_variables = new;
> -#if defined(RTEMS_MULTIPROCESSING)
> -    case OBJECTS_REMOTE:
> -      _Thread_Dispatch();
> -      return RTEMS_ILLEGAL_ON_REMOTE_OBJECT;
> -#endif
> -    case OBJECTS_ERROR:
> -      break;
> -  return RTEMS_INVALID_ID;
> -#endif
> diff --git a/cpukit/rtems/src/taskvariabledelete.c b/cpukit/rtems/src/taskvariabledelete.c
> index 3f7f84e..0000000
> --- a/cpukit/rtems/src/taskvariabledelete.c
> +++ /dev/null
> @@ -1,86 +0,0 @@
> - *  @file
> -#if HAVE_CONFIG_H
> -#endif
> -  rtems_id  tid,
> -  void    **ptr
> -  rtems_task_variable_t *tvp, *prev;
> -#endif
> -  if ( !ptr )
> -  prev = NULL;
> -      while (tvp) {
> -          if (prev)
> -            prev->next = tvp->next;
> -          else
> -            the_thread->task_variables = (rtems_task_variable_t *)tvp->next;
> -          _RTEMS_Tasks_Invoke_task_variable_dtor( the_thread, tvp );
> -        prev = tvp;
> -#endif
> -        break;
> -#endif
> diff --git a/cpukit/rtems/src/taskvariableget.c b/cpukit/rtems/src/taskvariableget.c
> index 3b9cd25..0000000
> --- a/cpukit/rtems/src/taskvariableget.c
> +++ /dev/null
> @@ -1,88 +0,0 @@
> - * @file
> - * @ingroup ClassicTasks Tasks
> -#if HAVE_CONFIG_H
> -#endif
> -  rtems_id tid,
> -  void **ptr,
> -  void **result
> -#endif
> -  if ( !ptr )
> -  if ( !result )
> -       *  Figure out if the variable is in this task's list.
> -      while (tvp) {
> -          * Should this return the current (i.e not the
> -          * saved) value if `tid' is the current task?
> -          *result = tvp->tval;
> -#endif
> -      break;
> -#endif
> diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
> index c32a902..b7c2f44 100644
> --- a/cpukit/sapi/include/confdefs.h
> +++ b/cpukit/sapi/include/confdefs.h
> @@ -2100,42 +2100,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
>    #define CONFIGURE_TASKS \
>      (CONFIGURE_MAXIMUM_TASKS + CONFIGURE_LIBBLOCK_TASKS)
> -   * This macro calculates the memory required for task variables.
> -   * Each task variable is individually allocated from the Workspace.
> -   * Hence, we do the multiplication on the configured size.
> -   * @note Per-task variables are disabled for SMP configurations.
> -  #if defined(RTEMS_SMP)
> -    #ifdef CONFIGURE_MAXIMUM_TASK_VARIABLES
> -      #warning "Per-Task Variables are deprecated and will be removed."
> -      #error "Per-Task Variables are not safe for SMP systems and disabled."
> -    #endif
> -    #define CONFIGURE_MAXIMUM_TASK_VARIABLES                     0
> -    #define CONFIGURE_MEMORY_FOR_TASK_VARIABLES(_task_variables) 0
> -  #else
> -    #ifndef CONFIGURE_MAXIMUM_TASK_VARIABLES
> -      /** This macro specifies the maximum number of task variables. */
> -       * This macro is calculated to specify the memory required for task
> -       * variables.
> -       * This is an internal parameter.
> -    #else
> -      #define CONFIGURE_MEMORY_FOR_TASK_VARIABLES(_task_variables) \
> -       (_task_variables) * \
> -          _Configure_From_workspace(sizeof(rtems_task_variable_t))
> -    #endif
> -  #endif
>    #ifndef CONFIGURE_MAXIMUM_TIMERS
>      /** This specifies the maximum number of Classic API timers. */
>      #define CONFIGURE_MAXIMUM_TIMERS             0
> @@ -2818,9 +2782,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
>      #define CONFIGURE_MAXIMUM_GOROUTINES 400
>    #endif
> -  #define CONFIGURE_GOROUTINES_TASK_VARIABLES \
> -    (2 * CONFIGURE_MAXIMUM_GOROUTINES)
>    #ifndef CONFIGURE_MAXIMUM_GO_CHANNELS
>      #define CONFIGURE_MAXIMUM_GO_CHANNELS 500
>    #endif
> @@ -2845,9 +2806,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
>    /** This specifies the maximum number of Go co-routines. */
>    #define CONFIGURE_MAXIMUM_GOROUTINES          0
> -  /** This specifies the maximum number of Go per-task variables required. */
> -  #define CONFIGURE_GOROUTINES_TASK_VARIABLES   0
>    /** This specifies the maximum number of Go channels required. */
>    #define CONFIGURE_MAXIMUM_GO_CHANNELS         0
>  #endif
> @@ -3068,9 +3026,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
>   * Classic API as configured.
>  #define CONFIGURE_MEMORY_FOR_CLASSIC \
> -  (CONFIGURE_MEMORY_FOR_TASK_VARIABLES(CONFIGURE_MAXIMUM_TASK_VARIABLES + \
> -    CONFIGURE_GOROUTINES_TASK_VARIABLES) + \
> -   CONFIGURE_MEMORY_FOR_TIMERS(CONFIGURE_MAXIMUM_TIMERS + \
> +   (CONFIGURE_MEMORY_FOR_TIMERS(CONFIGURE_MAXIMUM_TIMERS + \
>      CONFIGURE_TIMER_FOR_SHARED_MEMORY_DRIVER ) + \
>     CONFIGURE_MEMORY_FOR_SEMAPHORES(CONFIGURE_SEMAPHORES) + \
>     CONFIGURE_MEMORY_FOR_MESSAGE_QUEUES(CONFIGURE_MAXIMUM_MESSAGE_QUEUES) + \
> @@ -3581,7 +3537,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
>      /* Classic API Pieces */
>      uint32_t CLASSIC_TASKS;
> -    uint32_t TASK_VARIABLES;
>      uint32_t TIMERS;
>      uint32_t SEMAPHORES;
>      uint32_t MESSAGE_QUEUES;
> @@ -3635,8 +3590,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
>      CONFIGURE_MEMORY_FOR_TASKS(CONFIGURE_MAXIMUM_TASKS, 0),
> -    CONFIGURE_MEMORY_FOR_TASK_VARIABLES(CONFIGURE_MAXIMUM_TASK_VARIABLES +
> -      CONFIGURE_GOROUTINES_TASK_VARIABLES),
>      CONFIGURE_MEMORY_FOR_TIMERS(CONFIGURE_MAXIMUM_TIMERS),
>      CONFIGURE_MEMORY_FOR_SEMAPHORES(CONFIGURE_SEMAPHORES),
>      CONFIGURE_MEMORY_FOR_MESSAGE_QUEUES(CONFIGURE_MAXIMUM_MESSAGE_QUEUES),
> diff --git a/cpukit/score/include/rtems/score/thread.h b/cpukit/score/include/rtems/score/thread.h
> index 8bc12d2..8ea2db2 100644
> --- a/cpukit/score/include/rtems/score/thread.h
> +++ b/cpukit/score/include/rtems/score/thread.h
> @@ -173,35 +173,6 @@ typedef enum {
>  typedef void (*Thread_CPU_budget_algorithm_callout )( Thread_Control * );
> - *  @brief Forward reference to the per task variable structure..
> - *  Forward reference to the per task variable structure.
> -struct rtems_task_variable_tt;
> - *  @brief Internal structure used to manager per task variables.
> - *  This is the internal structure used to manager per Task Variables.
> -typedef struct {
> -  /** This field points to the next per task variable for this task. */
> -  struct rtems_task_variable_tt  *next;
> -  /** This field points to the physical memory location of this per
> -   *  task variable.
> -  void                          **ptr;
> -  /** This field is to the global value for this per task variable. */
> -  void                           *gval;
> -  /** This field is to this thread's value for this per task variable. */
> -  void                           *tval;
> -  /** This field points to the destructor for this per task variable. */
> -} rtems_task_variable_t;
> -#endif
>   *  The following structure contains the information which defines
>   *  the starting state of a thread.
> @@ -870,11 +841,6 @@ struct _Thread_Control {
>    /** This array contains the API extension area pointers. */
>    void                                 *API_Extensions[ THREAD_API_LAST + 1 ];
> -  /** This field points to the set of per task variables. */
> -  rtems_task_variable_t                *task_variables;
> -#endif
>     * @brief The POSIX Keys information.
> diff --git a/testsuites/psxtests/psxconfig01/init.c b/testsuites/psxtests/psxconfig01/init.c
> index 9f3c134..582fd11 100644
> --- a/testsuites/psxtests/psxconfig01/init.c
> +++ b/testsuites/psxtests/psxconfig01/init.c
> @@ -57,9 +57,6 @@ const char rtems_test_name[] = "PSXCONFIG 1";
>  #define CONFIGURE_MAXIMUM_REGIONS 43
>  #define CONFIGURE_MAXIMUM_SEMAPHORES 47
>  #define CONFIGURE_MAXIMUM_TASKS 11
> -  #define CONFIGURE_MAXIMUM_TASK_VARIABLES 13
> -#endif
>  #define CONFIGURE_MAXIMUM_TIMERS 59
>  #define CONFIGURE_MAXIMUM_USER_EXTENSIONS 17
> @@ -202,10 +199,6 @@ typedef struct {
>  static char posix_name [_POSIX_PATH_MAX + 1];
> -  static void *task_var;
> -#endif
>  static char *get_posix_name(char a, char b, char c, int i)
>    posix_name [_POSIX_PATH_MAX - 4] = a;
> @@ -216,13 +209,6 @@ static char *get_posix_name(char a, char b, char c, int i)
>    return posix_name;
> -static void task_var_dtor(void *var RTEMS_UNUSED)
> -  /* Do nothing */
> -#endif
>  static void *posix_thread(void *arg RTEMS_UNUSED)
>    rtems_test_assert(0);
> @@ -435,21 +421,6 @@ static rtems_task Init(rtems_task_argument argument)
>  #endif
> -#ifdef CONFIGURE_MAXIMUM_TASK_VARIABLES
> -    for (i = 0; i < CONFIGURE_MAXIMUM_TASK_VARIABLES; ++i) {
> -      sc = rtems_task_variable_add(RTEMS_SELF, &task_var, task_var_dtor);
> -      directive_failed(sc, "rtems_task_variable_add");
> -#endif
> -#endif
>  #ifdef CONFIGURE_MAXIMUM_TIMERS
>    for (i = 0; i < CONFIGURE_MAXIMUM_TIMERS; ++i) {
>      sc = rtems_timer_create(name, &id);
> diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
> index f5481ae..593b65b 100644
> --- a/testsuites/sptests/configure.ac
> +++ b/testsuites/sptests/configure.ac
> @@ -107,7 +107,6 @@ sp25/Makefile
>  sp26/Makefile
>  sp27/Makefile
>  sp27a/Makefile
> -sp28/Makefile
>  sp29/Makefile
>  sp30/Makefile
>  sp31/Makefile
> diff --git a/testsuites/sptests/sp28/Makefile.am b/testsuites/sptests/sp28/Makefile.am
> index d02ff97..0000000
> --- a/testsuites/sptests/sp28/Makefile.am
> +++ /dev/null
> @@ -1,22 +0,0 @@
> -rtems_tests_PROGRAMS = sp28
> -sp28_SOURCES = init.c
> -dist_rtems_tests_DATA = sp28.scn
> -dist_rtems_tests_DATA += sp28.doc
> -include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
> -include $(top_srcdir)/../automake/compile.am
> -include $(top_srcdir)/../automake/leaf.am
> -AM_CPPFLAGS += -I$(top_srcdir)/../support/include
> -LINK_OBJS = $(sp28_OBJECTS)
> -LINK_LIBS = $(sp28_LDLIBS)
> -sp28$(EXEEXT): $(sp28_OBJECTS) $(sp28_DEPENDENCIES)
> -       @rm -f sp28$(EXEEXT)
> -       $(make-exe)
> -include $(top_srcdir)/../automake/local.am
> diff --git a/testsuites/sptests/sp28/init.c b/testsuites/sptests/sp28/init.c
> index 4798bff..0000000
> --- a/testsuites/sptests/sp28/init.c
> +++ /dev/null
> @@ -1,439 +0,0 @@
> - *  COPYRIGHT (c) 1989-2012.
> -#ifdef HAVE_CONFIG_H
> -#endif
> -#include <tmacros.h>
> -#include <bsp.h>
> -#include <rtems/error.h>
> -#include <stdio.h>
> -const char rtems_test_name[] = "SP 28";
> -/* forward declarations to avoid warnings */
> -rtems_task Init(rtems_task_argument argument);
> -rtems_task subtask(rtems_task_argument arg);
> -rtems_task Task_variable_deleter(rtems_task_argument ignored);
> -void starttask(int arg);
> -void test_errors(void);
> -void test_dtor(void *pointer);
> -void test_multiple_taskvars(void);
> -void test_out_of_memory(void);
> -rtems_task Other_Task(rtems_task_argument ignored);
> -void test_delete_from_other_task(void);
> -void test_delete_as_side_effect(void);
> -volatile void *taskvar;
> -volatile int nRunning;
> -volatile int nDeleted;
> -rtems_task
> -subtask (rtems_task_argument arg)
> -  uintptr_t         localvar = arg;
> -  int               i;
> -  rtems_status_code sc;
> -  nRunning++;
> -  while (nRunning != 3)
> -    rtems_task_wake_after (0);
> -  sc = rtems_task_variable_add(RTEMS_SELF, (void **)&taskvar, NULL);
> -  directive_failed( sc, "task variable add" );
> -  taskvar = (void *)localvar;
> -  while (localvar < 1000) {
> -    localvar++;
> -    taskvar = (void *)((uintptr_t)taskvar + 1);
> -    if ((uintptr_t)taskvar != localvar) {
> -      printf(
> -        "Task:%" PRIdrtems_task_argument " taskvar:%" PRIuPTR
> -          " localvar:%" PRIuPTR "\n",
> -        arg,
> -        (uintptr_t)taskvar,
> -        localvar
> -      rtems_task_suspend (RTEMS_SELF);
> -  sc = rtems_task_variable_delete(RTEMS_SELF, (void **)&taskvar);
> -  nDeleted++;
> -  directive_failed( sc, "task variable delete" );
> -  if ((uintptr_t)taskvar == localvar) {
> -    printf(
> -      "Task:%" PRIdrtems_task_argument " deleted taskvar:%" PRIuPTR
> -      arg,
> -      localvar
> -    nRunning--;
> -  while (nDeleted != 3)
> -  for (i = 0 ; i < 1000 ; i++) {
> -    taskvar = (void *)(localvar = 100 * arg);
> -    rtems_task_wake_after(0);
> -    if (nRunning <= 1)
> -      break;
> -      printf(
> -       arg,
> -       localvar
> -      nRunning--;
> -      rtems_task_suspend(RTEMS_SELF);
> -  nRunning--;
> -  while (nRunning)
> -  TEST_END();
> -  rtems_test_exit(0);
> -void
> -starttask (int arg)
> -  rtems_id tid;
> -  sc = rtems_task_create(rtems_build_name ('S', 'R', 'V', arg + 'A'),
> -    RTEMS_MAXIMUM_PRIORITY - 1u,
> -    RTEMS_MINIMUM_STACK_SIZE,
> -    RTEMS_PREEMPT|RTEMS_NO_TIMESLICE|RTEMS_NO_ASR|RTEMS_INTERRUPT_LEVEL(0),
> -    RTEMS_NO_FLOATING_POINT|RTEMS_LOCAL,
> -    &tid
> -  directive_failed( sc, "task create" );
> -  sc = rtems_task_start(tid, subtask, arg);
> -  directive_failed( sc, "task start" );
> -volatile void *taskvar1;
> -volatile void *taskvar2;
> -volatile void *taskvar3;
> -  void              *value;
> -   *  task variable add error status codes
> -  puts( "task variable add - NULL pointer - RTEMS_INVALID_ADDRESS" );
> -  sc = rtems_task_variable_add(RTEMS_SELF, NULL, NULL );
> -  fatal_directive_status( sc, RTEMS_INVALID_ADDRESS, "add NULL pointer" );
> -   *  task variable get error status codes
> -  puts( "task variable get - bad Id - RTEMS_INVALID_ID" );
> -  sc = rtems_task_variable_get(
> -    rtems_task_self() + 10,
> -    (void **)&taskvar1,
> -    &value
> -  fatal_directive_status( sc, RTEMS_INVALID_ID, "bad Id" );
> -  puts( "task variable get - NULL pointer - RTEMS_INVALID_ADDRESS" );
> -  sc = rtems_task_variable_get(RTEMS_SELF, NULL, &value );
> -  fatal_directive_status( sc, RTEMS_INVALID_ADDRESS, "get NULL pointer" );
> -  puts( "task variable get - bad result - RTEMS_INVALID_ADDRESS" );
> -  sc = rtems_task_variable_get(RTEMS_SELF, (void **)&taskvar1, NULL);
> -  fatal_directive_status( sc, RTEMS_INVALID_ADDRESS, "get bad result" );
> -  puts( "task variable get - bad pointer - RTEMS_INVALID_ADDRESS" );
> -  sc = rtems_task_variable_get(RTEMS_SELF, (void **)&taskvar1, &value);
> -  fatal_directive_status( sc, RTEMS_INVALID_ADDRESS, "get bad pointer" );
> -   *  task variable delete error status codes
> -  puts( "task variable delete - bad Id - RTEMS_INVALID_ID" );
> -  sc = rtems_task_variable_delete( rtems_task_self() + 10, (void **)&taskvar1 );
> -  puts( "task variable delete - NULL pointer - RTEMS_INVALID_ADDRESS" );
> -  sc = rtems_task_variable_delete(RTEMS_SELF, NULL);
> -  fatal_directive_status( sc, RTEMS_INVALID_ADDRESS, "delete NULL pointer" );
> -  puts( "task variable delete - bad pointer - RTEMS_INVALID_ADDRESS" );
> -  sc = rtems_task_variable_delete(RTEMS_SELF, (void **)&taskvar1);
> -  fatal_directive_status( sc, RTEMS_INVALID_ADDRESS, "delete bad pointer" );
> -volatile uint32_t test_dtor_ran;
> -  test_dtor_ran++;
> -  void              *value;
> -  test_dtor_ran = 0;
> -   *  Add multiple task variables and add each twice to
> -   *  verify that behavior is OK
> -  puts( "task variable add - bad Id - RTEMS_INVALID_ID" );
> -    NULL
> -  puts( "Adding multiple task variables" );
> -  sc = rtems_task_variable_add(RTEMS_SELF, (void **)&taskvar1, NULL);
> -  directive_failed( sc, "add multiple #1" );
> -  sc = rtems_task_variable_add(RTEMS_SELF, (void **)&taskvar1, test_dtor);
> -  directive_failed( sc, "add multiple #2" );
> -  sc = rtems_task_variable_add(RTEMS_SELF, (void **)&taskvar2, test_dtor);
> -  directive_failed( sc, "add multiple #3" );
> -  sc = rtems_task_variable_add(RTEMS_SELF, (void **)&taskvar2, NULL);
> -  directive_failed( sc, "add multiple #4" );
> -  sc = rtems_task_variable_add(RTEMS_SELF, (void **)&taskvar3, NULL);
> -  directive_failed( sc, "add multiple #5" );
> -  sc = rtems_task_variable_add(RTEMS_SELF, (void **)&taskvar3, test_dtor);
> -  directive_failed( sc, "add multiple #6" );
> -   *  Obtain task variables in various spots on the chain
> -  puts( "Obtaining multiple task variables" );
> -  sc = rtems_task_variable_get( RTEMS_SELF, (void **)&taskvar3, &value );
> -  directive_failed( sc, "get multiple #1" );
> -  sc = rtems_task_variable_get( RTEMS_SELF, (void **)&taskvar2, &value );
> -  directive_failed( sc, "get multiple #2" );
> -  sc = rtems_task_variable_get( RTEMS_SELF, (void **)&taskvar1, &value );
> -   *  Delete task variables in various spots on the chain
> -  /* to trip the destructors */
> -  taskvar1 = (void *)1;
> -  taskvar2 = (void *)2;
> -  taskvar3 = (void *)3;
> -  puts( "Deleting multiple task variables" );
> -  sc = rtems_task_variable_delete(RTEMS_SELF, (void **)&taskvar2);
> -  directive_failed( sc, "delete multiple #1" );
> -  sc = rtems_task_variable_delete(RTEMS_SELF, (void **)&taskvar3);
> -  directive_failed( sc, "delete multiple #2" );
> -  directive_failed( sc, "delete multiple #3" );
> -  if ( test_dtor_ran != 2 ) {
> -    printf(
> -      "Test dtor ran %" PRIu32 " times not 2 times as expected\n",
> -       test_dtor_ran
> -#define MAX_VARS 4096
> -void *Pointers[MAX_VARS];
> -  int                 i;
> -  int                 max;
> -  int                 ran_out = 0;
> -  void              **base;
> -  base = Pointers;
> -  for (i=0 ; i<MAX_VARS ; i++ ) {
> -    sc = rtems_task_variable_add(RTEMS_SELF, &base[i], NULL);
> -    if ( sc == RTEMS_NO_MEMORY ) {
> -      puts( "task_variable_add - returns NO_MEMORY" );
> -      max = i;
> -      ran_out = 1;
> -      break;
> -    directive_failed( sc, "add loop until out of memory" );
> -  if ( !ran_out ) {
> -    puts( "ERROR!!! did not run out of memory adding task variables!" );
> -  for (i=0 ; i<max ; i++ ) {
> -    sc = rtems_task_variable_delete(RTEMS_SELF, &base[i]);
> -    directive_failed( sc, "delete loop until out of memory" );
> -rtems_id main_task;
> -rtems_id other_task;
> -  puts( "Deleting task variables in another task" );
> -  sc = rtems_task_variable_delete(main_task, (void **)&taskvar1);
> -  directive_failed( sc, "delete loop for other task" );
> -  (void) rtems_task_delete( RTEMS_SELF );
> -  sc = rtems_task_ident( RTEMS_SELF, 0, &main_task );
> -  directive_failed( sc, "task ident" );
> -  directive_failed( sc, "add for other task case" );
> -  sc = rtems_task_create(rtems_build_name ('O', 'T', 'H', 'R'),
> -    &other_task
> -  directive_failed( sc, "task create other" );
> -  sc = rtems_task_start(other_task, Other_Task, 0);
> -  directive_failed( sc, "task start other" );
> -  rtems_task_wake_after( 100 );
> -  if ( test_dtor_ran != 1 ) {
> -    printf(
> -      "Test dtor ran %" PRIu32 " times not 1 times as expected\n",
> -      test_dtor_ran
> - *  Task which adds task variables just to delete them
> -  puts( "Adding multiple task variables to delete implicitly" );
> -  directive_failed( sc, "add multiple for delete #1" );
> -  directive_failed( sc, "add multiple for delete #2" );
> -  directive_failed( sc, "add multiple for delete #3" );
> -  rtems_id          deleter_task;
> -    &deleter_task
> -  directive_failed( sc, "task create deleter" );
> -  sc = rtems_task_start(deleter_task, Task_variable_deleter, 0);
> -  directive_failed( sc, "task start deleter" );
> -    printf(
> -      test_dtor_ran
> -rtems_task Init (rtems_task_argument ignored)
> -  TEST_BEGIN();
> -  test_errors();
> -  test_multiple_taskvars();
> -  test_delete_as_side_effect();
> -  test_delete_from_other_task();
> -  starttask (1);
> -  starttask (2);
> -  starttask (3);
> -  test_out_of_memory();
> -#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> -#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> -#define CONFIGURE_MAXIMUM_USER_EXTENSIONS    2
> -#define CONFIGURE_MAXIMUM_TASKS              4
> -#define CONFIGURE_MAXIMUM_TASK_VARIABLES     (4)
> -#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> -#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> -#define CONFIGURE_MICROSECONDS_PER_TICK      10000
> -#include <rtems/confdefs.h>
> diff --git a/testsuites/sptests/sp28/sp28.doc b/testsuites/sptests/sp28/sp28.doc
> index e69de29..0000000
> diff --git a/testsuites/sptests/sp28/sp28.scn b/testsuites/sptests/sp28/sp28.scn
> index 654ae97..0000000
> --- a/testsuites/sptests/sp28/sp28.scn
> +++ /dev/null
> @@ -1,17 +0,0 @@
> -*** START OF TEST 28 ***
> -task variable add - NULL pointer - RTEMS_INVALID_ADDRESS
> -task variable get - bad Id - RTEMS_INVALID_ID
> -task variable get - NULL pointer - RTEMS_INVALID_ADDRESS
> -task variable get - bad result - RTEMS_INVALID_ADDRESS
> -task variable get - bad pointer - RTEMS_INVALID_ADDRESS
> -task variable delete - bad Id - RTEMS_INVALID_ID
> -task variable delete - NULL pointer - RTEMS_INVALID_ADDRESS
> -task variable delete - bad pointer - RTEMS_INVALID_ADDRESS
> -task variable add - bad Id - RTEMS_INVALID_ID
> -Adding multiple task variables
> -Obtaining multiple task variables
> -Deleting multiple task variables
> -Adding multiple task variables to delete implicitly
> -Deleting task variables in another task
> -task_variable_add - returns NO_MEMORY
> -*** END OF TEST 28 ***
> 1.8.4.5
> devel mailing list
> devel at rtems.org
