PWM driver tested in RTEMS with RGB
Wed May 4 03:01:43 UTC 2016
On 04/05/2016 11:53, Gedare Bloom wrote:
>> I added Ti licence at last patch. Do I need to add any other licence ?
> Whenever you copy/paste code, you need to know/observe what the
> license is and keep track of that. So, the question of whether you
> need to add another license depends on whether you copied code from
> somewhere that has a different license.
Where did the TI code from, for example a public tarball, a public TI
git repo, or a TI SDK?
If the code has come from a TI downloaded developers SDK with a front
end EULA then we need to understand the exact licensing terms the code
has been provided under.
Thanks
