PWM driver tested in RTEMS with RGB
punit vara punitvara at gmail.com
Thu May 5 12:25:31 UTC 2016
On Wed, May 4, 2016 at 8:31 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 04/05/2016 11:53, Gedare Bloom wrote:
>>> I added Ti licence at last patch. Do I need to add any other licence ?
>> Whenever you copy/paste code, you need to know/observe what the
>> license is and keep track of that. So, the question of whether you
>> need to add another license depends on whether you copied code from
>> somewhere that has a different license.
I copied the code from 2 files. Both files have same licence . So the
licence I added is enough according to me.
> Where did the TI code from, for example a public tarball, a public TI git
> repo, or a TI SDK?
I have referred code from sourceforge.
https://sourceforge.net/p/starterwarefree/code/ci/master/tree/
@Martin you can clone this code and keep it handy while reviewing my
code. SW code is cloned from following link.
git clone git://git.code.sf.net/p/starterwarefree/code starterwarefree-code
This repo represents 2.0.x variant of SW by TI.
@Martin For further communication should I communicate here or should
I create new thread in user at rtems. I am asking because Gedare told to
introduce project on user at rtems mail list but you mostly prefer
devel at rtems.
If I add code from anywhere else I will inform community. Thanks for
the support.
Regards,
Punit Vara
