[rtems-libbsd commit] Add nexus devices for default-init.
Wed May 4 11:52:00 UTC 2016
On 04/05/16 13:40, Chris Johns wrote:
> On 4/05/2016 9:02 PM, Sebastian Huber wrote:
>> >On 04/05/16 12:53, Chris Johns wrote:
>>> >>On 4/05/2016 8:02 PM, Sebastian Huber wrote:
>>>>> >>> >The <rtems/bsd/test/default-init.h> was intended for tests that are
>>>>> >>> >device independent. For which purpose did you add it?
>>> >>I do not understand what you mean by device independent and so what
>>> >>commands you can run. For example ifconfig does nothing because there
>>> >>are no devices.
>>> >>The patch can be reverted if it is wrong.
>> >Its not necessarily wrong, but I fail to see a use case in the current
>> >test suite for it, e.g.
> Sure this make sense. I am not sure what I should do. Do you want it
> removed?
>> >testsuite/selectpollkqueue01/test_main.c:#include
>> >testsuite/commands01/test_main.c:#include <rtems/bsd/test/default-init.h>
> I saw the default-init as a base of default-network-init. Maybe if it
> was called default-no-devices-init I would not have made the change.
Ok, I revert the change and rename it to default-no-devices-init.h.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
