[PATCH 6/8] i386/pc386: Add --ide-disable boot command line option.
Sat May 7 12:48:13 UTC 2016
While you're mucking about in this code, if you can make the style
consistent it would be good, such as to fix the opening brace on next
line after if/for.
On Fri, May 6, 2016 at 6:23 PM, Chris Johns <chrisj at rtems.org> wrote:
>  c/src/lib/libbsp/i386/pc386/ide/idecfg.c | 108 ++++++++++++++++---------------
>  1 file changed, 57 insertions(+), 51 deletions(-)
> diff --git a/c/src/lib/libbsp/i386/pc386/ide/idecfg.c b/c/src/lib/libbsp/i386/pc386/ide/idecfg.c
> index f0f5bfe..371a6ee 100644
> --- a/c/src/lib/libbsp/i386/pc386/ide/idecfg.c
> +++ b/c/src/lib/libbsp/i386/pc386/ide/idecfg.c
> @@ -74,66 +74,72 @@ unsigned long IDE_Controller_Count;
>  void bsp_ide_cmdline_init(void)
> -  bool ide1 = IDE1_DEFAULT;
> -  bool ide2 = IDE2_DEFAULT;
> -  const char* ide;
> -   * Can have:
> -   *  --ide=0,1
> -  ide = bsp_cmdline_arg ("--ide=");
> -  if (ide)
> -    int i;
> +  const char* ide_disable;
> +  ide_disable = bsp_cmdline_arg ("--ide-disable");
> +  if (ide_disable == NULL) {
> +    bool ide1 = IDE1_DEFAULT;
> +    bool ide2 = IDE2_DEFAULT;
> +    const char* ide;
> -     * If a command line option exists remove the defaults.
> +     * Can have:
> +     *  --ide=0,1
> -    ide1 = ide2 = false;
> +    ide = bsp_cmdline_arg ("--ide=");
> -    ide += sizeof ("--ide=") - 1;
> -    for (i = 0; i < 3; i++)
> +    if (ide)
> -      switch (ide[i])
> +      int i;
> +       * If a command line option exists remove the defaults.
> +      ide1 = ide2 = false;
> +      ide += sizeof ("--ide=") - 1;
> +      for (i = 0; i < 3; i++)
> -        case '0':
> -          ide1 = true;
> -          break;
> -        case '1':
> -          ide2 = true;
> -          break;
> -        case '2':
> -        case '3':
> -        case '4':
> -        case '5':
> -        case '6':
> -        case '7':
> -        case '8':
> -        case '9':
> -        case ',':
> -          break;
> -        default:
> -          break;
> +        switch (ide[i])
> +          case '0':
> +            ide1 = true;
> +            break;
> +          case '1':
> +            ide2 = true;
> +            break;
> +          case '2':
> +          case '3':
> +          case '4':
> +          case '5':
> +          case '6':
> +          case '7':
> +          case '8':
> +          case '9':
> +          case ',':
> +            break;
> +          default:
> +            break;
> -  if (ide2 && !ide1)
> -    IDE_Controller_Table[0] = IDE_Controller_Table[1];
> +    if (ide2 && !ide1)
> +      IDE_Controller_Table[0] = IDE_Controller_Table[1];
> -  if (ide1)
> -    IDE_Controller_Count++;
> -  if (ide2)
> +    if (ide1)
> +      IDE_Controller_Count++;
> +    if (ide2)
> -   * Allow the user to get the initialise to print probing
> -   * type information.
> -  ide = bsp_cmdline_arg ("--ide-show");
> +     * Allow the user to get the initialise to print probing
> +     * type information.
> +    ide = bsp_cmdline_arg ("--ide-show");
> -  if (ide)
> -    pc386_ide_show = true;
> +    if (ide)
> +      pc386_ide_show = true;
> 2.4.6
> devel mailing list
> devel at rtems.org
