[PATCH 6/8] i386/pc386: Add --ide-disable boot command line option.
Sun May 8 22:53:54 UTC 2016
On 7/05/2016 10:48 PM, Gedare Bloom wrote:
> While you're mucking about in this code, if you can make the style
> consistent it would be good, such as to fix the opening brace on next
> line after if/for.
If it is ok I might leave this until we start to add UEFI, ACPI and APIC
support. A lot of code needs to be added. I am not sure if IDE should be
moved into libbsd where SATA could be looked at.
