[PATCH 6/8] i386/pc386: Add --ide-disable boot command line option.
Sun May 8 23:08:05 UTC 2016
On Sun, May 8, 2016 at 6:53 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 7/05/2016 10:48 PM, Gedare Bloom wrote:
>> While you're mucking about in this code, if you can make the style
>> consistent it would be good, such as to fix the opening brace on next
>> line after if/for.
> If it is ok I might leave this until we start to add UEFI, ACPI and APIC
> support. A lot of code needs to be added. I am not sure if IDE should be
> moved into libbsd where SATA could be looked at.
Ok
