Multiple Failures on GCC Master
Tue May 10 14:29:35 UTC 2016
Hi
With a newlib snapshot approaching, I thought I would build tools off the
master for binutils, gdb, gcc, and newlib.  Some failures:
It looks like most targets fail looking for lock.c. This is from
sparc-rtems4.12
but there are others.
make[4]: Entering directory
`/data/home/joel/test-gcc/b-sparc-rtems4.12-gcc/sparc-rtems4.12/libatomic'
make[4]: *** No rule to make target `lock.c', needed by `lock.lo'.  Stop.
make[4]: Leaving directory
Looks like a tiny bit is missing on the gcc master.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160510/cef99f9b/attachment.html>
