[PATCH 04/14] posix: Make _POSIX_signals_Action_handler() static
Wed May 11 13:23:31 UTC 2016
 cpukit/posix/include/rtems/posix/psignalimpl.h |   7 --
 cpukit/posix/src/psignal.c                     | 135 -------------------------
 cpukit/posix/src/psignalunblockthread.c        | 126 +++++++++++++++++++++++
 3 files changed, 126 insertions(+), 142 deletions(-)
diff --git a/cpukit/posix/include/rtems/posix/psignalimpl.h b/cpukit/posix/include/rtems/posix/psignalimpl.h
index 8399a7b..3b76fc3 100644
--- a/cpukit/posix/include/rtems/posix/psignalimpl.h
+++ b/cpukit/posix/include/rtems/posix/psignalimpl.h
@@ -79,13 +79,6 @@ extern Chain_Control _POSIX_signals_Siginfo[ SIG_ARRAY_MAX ];
 #define _POSIX_signals_Release( lock_context ) \
   _Thread_queue_Release( &_POSIX_signals_Wait_queue, lock_context )
-void _POSIX_signals_Action_handler(
-  Thread_Control  *executing,
-  Thread_Action   *action,
-  Per_CPU_Control *cpu,
-  ISR_Level        level
  * @brief Unlock POSIX signals thread.
diff --git a/cpukit/posix/src/psignal.c b/cpukit/posix/src/psignal.c
index 6e18e05..3e887a8 100644
--- a/cpukit/posix/src/psignal.c
+++ b/cpukit/posix/src/psignal.c
@@ -98,141 +98,6 @@ Thread_queue_Control _POSIX_signals_Wait_queue =
 Chain_Control _POSIX_signals_Inactive_siginfo;
- *  XXX - move these
-#define _States_Is_interruptible_signal( _states ) \
-  ( ((_states) & \
-    (STATES_WAITING_FOR_SIGNAL|STATES_INTERRUPTIBLE_BY_SIGNAL)) == \
-static void _POSIX_signals_Check_signal(
-  POSIX_API_Control  *api,
-  int                 signo,
-  bool                is_global
-  siginfo_t siginfo_struct;
-  sigset_t  saved_signals_unblocked;
-  if ( ! _POSIX_signals_Clear_signals( api, signo, &siginfo_struct,
-                                       is_global, true, true ) )
-    return;
-   *  Since we made a union of these, only one test is necessary but this is
-   *  safer.
-  #if defined(RTEMS_DEBUG)
-    assert( _POSIX_signals_Vectors[ signo ].sa_handler ||
-            _POSIX_signals_Vectors[ signo ].sa_sigaction );
-  #endif
-   *  Just to prevent sending a signal which is currently being ignored.
-  if ( _POSIX_signals_Vectors[ signo ].sa_handler == SIG_IGN )
-    return;
-   *  Block the signals requested in sa_mask
-  saved_signals_unblocked = api->signals_unblocked;
-  api->signals_unblocked &= ~_POSIX_signals_Vectors[ signo ].sa_mask;
-   *  Here, the signal handler function executes
-  switch ( _POSIX_signals_Vectors[ signo ].sa_flags ) {
-    case SA_SIGINFO:
-      (*_POSIX_signals_Vectors[ signo ].sa_sigaction)(
-        signo,
-        &siginfo_struct,
-        NULL        /* context is undefined per 1003.1b-1993, p. 66 */
-      break;
-    default:
-      (*_POSIX_signals_Vectors[ signo ].sa_handler)( signo );
-      break;
-   *  Restore the previous set of unblocked signals
-  api->signals_unblocked = saved_signals_unblocked;
-  ISR_Level        level
-  POSIX_API_Control  *api;
-  int                 signo;
-  ISR_lock_Context    lock_context;
-  int                 hold_errno;
-  (void) action;
-  _Thread_Action_release_and_ISR_enable( cpu, level );
-  api = executing->API_Extensions[ THREAD_API_POSIX ];
-   *  We need to ensure that if the signal handler executes a call
-   *  which overwrites the unblocking status, we restore it.
-  hold_errno = executing->Wait.return_code;
-   * api may be NULL in case of a thread close in progress
-  if ( !api )
-    return;
-   *  In case the executing thread is blocked or about to block on something
-   *  that uses the thread wait information, then this is a kernel bug.
-  _Assert(
-    ( _Thread_Wait_flags_get( executing )
-      & ( THREAD_WAIT_STATE_BLOCKED | THREAD_WAIT_STATE_INTEND_TO_BLOCK ) ) == 0
-   *  If we invoke any user code, there is the possibility that
-   *  a new signal has been posted that we should process so we
-   *  restart the loop if a signal handler was invoked.
-   *  The first thing done is to check there are any signals to be
-   *  processed at all.  No point in doing this loop otherwise.
-  while (1) {
-    _POSIX_signals_Acquire( &lock_context );
-      if ( !(api->signals_unblocked &
-            (api->signals_pending | _POSIX_signals_Pending)) ) {
-       _POSIX_signals_Release( &lock_context );
-       break;
-    for ( signo = SIGRTMIN ; signo <= SIGRTMAX ; signo++ ) {
-      _POSIX_signals_Check_signal( api, signo, false );
-      _POSIX_signals_Check_signal( api, signo, true );
-    /* Unfortunately - nothing like __SIGFIRSTNOTRT in newlib signal .h */
-    for ( signo = SIGHUP ; signo <= __SIGLASTNOTRT ; signo++ ) {
-  executing->Wait.return_code = hold_errno;
 static void _POSIX_signals_Manager_Initialization(void)
   uint32_t   signo;
diff --git a/cpukit/posix/src/psignalunblockthread.c b/cpukit/posix/src/psignalunblockthread.c
index 640c758..df4a491 100644
--- a/cpukit/posix/src/psignalunblockthread.c
+++ b/cpukit/posix/src/psignalunblockthread.c
@@ -34,6 +34,132 @@
+static void _POSIX_signals_Check_signal(
+  POSIX_API_Control  *api,
+  int                 signo,
+  bool                is_global
+  siginfo_t siginfo_struct;
+  sigset_t  saved_signals_unblocked;
+  if ( ! _POSIX_signals_Clear_signals( api, signo, &siginfo_struct,
+                                       is_global, true, true ) )
+    return;
+   *  Since we made a union of these, only one test is necessary but this is
+   *  safer.
+  #if defined(RTEMS_DEBUG)
+    assert( _POSIX_signals_Vectors[ signo ].sa_handler ||
+            _POSIX_signals_Vectors[ signo ].sa_sigaction );
+  #endif
+   *  Just to prevent sending a signal which is currently being ignored.
+  if ( _POSIX_signals_Vectors[ signo ].sa_handler == SIG_IGN )
+    return;
+   *  Block the signals requested in sa_mask
+  saved_signals_unblocked = api->signals_unblocked;
+  api->signals_unblocked &= ~_POSIX_signals_Vectors[ signo ].sa_mask;
+   *  Here, the signal handler function executes
+  switch ( _POSIX_signals_Vectors[ signo ].sa_flags ) {
+    case SA_SIGINFO:
+      (*_POSIX_signals_Vectors[ signo ].sa_sigaction)(
+        signo,
+        &siginfo_struct,
+        NULL        /* context is undefined per 1003.1b-1993, p. 66 */
+      break;
+    default:
+      (*_POSIX_signals_Vectors[ signo ].sa_handler)( signo );
+      break;
+   *  Restore the previous set of unblocked signals
+  api->signals_unblocked = saved_signals_unblocked;
+static void _POSIX_signals_Action_handler(
+  Thread_Control  *executing,
+  Thread_Action   *action,
+  Per_CPU_Control *cpu,
+  ISR_Level        level
+  POSIX_API_Control  *api;
+  int                 signo;
+  ISR_lock_Context    lock_context;
+  int                 hold_errno;
+  (void) action;
+  _Thread_Action_release_and_ISR_enable( cpu, level );
+  api = executing->API_Extensions[ THREAD_API_POSIX ];
+   *  We need to ensure that if the signal handler executes a call
+   *  which overwrites the unblocking status, we restore it.
+  hold_errno = executing->Wait.return_code;
+   * api may be NULL in case of a thread close in progress
+  if ( !api )
+    return;
+   *  In case the executing thread is blocked or about to block on something
+   *  that uses the thread wait information, then this is a kernel bug.
+  _Assert(
+    ( _Thread_Wait_flags_get( executing )
+      & ( THREAD_WAIT_STATE_BLOCKED | THREAD_WAIT_STATE_INTEND_TO_BLOCK ) ) == 0
+   *  If we invoke any user code, there is the possibility that
+   *  a new signal has been posted that we should process so we
+   *  restart the loop if a signal handler was invoked.
+   *  The first thing done is to check there are any signals to be
+   *  processed at all.  No point in doing this loop otherwise.
+  while (1) {
+    _POSIX_signals_Acquire( &lock_context );
+      if ( !(api->signals_unblocked &
+            (api->signals_pending | _POSIX_signals_Pending)) ) {
+       _POSIX_signals_Release( &lock_context );
+       break;
+    for ( signo = SIGRTMIN ; signo <= SIGRTMAX ; signo++ ) {
+      _POSIX_signals_Check_signal( api, signo, false );
+      _POSIX_signals_Check_signal( api, signo, true );
+    /* Unfortunately - nothing like __SIGFIRSTNOTRT in newlib signal .h */
+    for ( signo = SIGHUP ; signo <= __SIGLASTNOTRT ; signo++ ) {
+  executing->Wait.return_code = hold_errno;
 static bool _POSIX_signals_Unblock_thread_done(
   Thread_Control    *the_thread,
1.8.4.5
