[PATCH 05/14] score: Add _Thread_queue_Is_lock_owner()
Wed May 11 13:23:32 UTC 2016
Add _Thread_queue_Is_lock_owner() in case RTEMS_DEBUG is defined.
 cpukit/score/include/rtems/score/threadq.h     | 16 ++++++++-
 cpukit/score/include/rtems/score/threadqimpl.h | 48 ++++++++++++++++++++++++--
 2 files changed, 60 insertions(+), 4 deletions(-)
diff --git a/cpukit/score/include/rtems/score/threadq.h b/cpukit/score/include/rtems/score/threadq.h
index 4fddb25..dedeb8d 100644
--- a/cpukit/score/include/rtems/score/threadq.h
+++ b/cpukit/score/include/rtems/score/threadq.h
@@ -269,7 +269,20 @@ typedef struct {
  *  waiting to acquire a resource.
 typedef struct {
-#if defined(RTEMS_SMP) && defined(RTEMS_PROFILING)
+#if defined(RTEMS_SMP)
+#if defined(RTEMS_DEBUG)
+   * @brief The index of the owning processor of the thread queue lock.
+   * The thread queue lock may be acquired via the thread wait information
+   * inner lock also.  This path is not covered by this field.  In case the
+   * lock is not owned directly via _Thread_queue_Acquire(), then the value of
+   * this field is SMP_LOCK_NO_OWNER.
+  uint32_t owner;
+#endif
+#if defined(RTEMS_PROFILING)
    * @brief SMP lock statistics in case SMP and profiling are enabled.
@@ -278,6 +291,7 @@ typedef struct {
   SMP_lock_Stats Lock_stats;
 #endif
+#endif
    * @brief The actual thread queue.
diff --git a/cpukit/score/include/rtems/score/threadqimpl.h b/cpukit/score/include/rtems/score/threadqimpl.h
index 0247842..e6cd401 100644
--- a/cpukit/score/include/rtems/score/threadqimpl.h
+++ b/cpukit/score/include/rtems/score/threadqimpl.h
@@ -23,6 +23,7 @@
 #include <rtems/score/rbtreeimpl.h>
+#include <rtems/score/smp.h>
 #ifdef __cplusplus
@@ -131,6 +132,9 @@ RTEMS_INLINE_ROUTINE void _Thread_queue_Acquire_critical(
     &the_thread_queue->Lock_stats,
     lock_context
+#if defined(RTEMS_DEBUG) && defined(RTEMS_SMP)
+  the_thread_queue->owner = _SMP_Get_current_processor();
+#endif
 RTEMS_INLINE_ROUTINE void _Thread_queue_Acquire(
@@ -142,11 +146,30 @@ RTEMS_INLINE_ROUTINE void _Thread_queue_Acquire(
   _Thread_queue_Acquire_critical( the_thread_queue, lock_context );
+RTEMS_INLINE_ROUTINE bool _Thread_queue_Is_lock_owner(
+  const Thread_queue_Control *the_thread_queue
+  return the_thread_queue->owner == _SMP_Get_current_processor();
+#else
+  return _ISR_Get_level() != 0;
+#endif
+#endif
 RTEMS_INLINE_ROUTINE void _Thread_queue_Release(
   Thread_queue_Control *the_thread_queue,
   ISR_lock_Context     *lock_context
+  _Assert( _Thread_queue_Is_lock_owner( the_thread_queue ) );
+  the_thread_queue->owner = SMP_LOCK_NO_OWNER;
+#endif
+#endif
   _Thread_queue_Queue_release(
     &the_thread_queue->Queue,
     lock_context
@@ -707,14 +730,33 @@ size_t _Thread_queue_Do_flush_critical(
 void _Thread_queue_Initialize( Thread_queue_Control *the_thread_queue );
+#if defined(RTEMS_SMP) && defined(RTEMS_DEBUG) && defined(RTEMS_PROFILING)
+  #define THREAD_QUEUE_INITIALIZER( name ) \
+      .Lock_stats = SMP_LOCK_STATS_INITIALIZER( name ), \
+      .owner = SMP_LOCK_NO_OWNER, \
+      .Queue = { \
+        .heads = NULL, \
+        .Lock = SMP_TICKET_LOCK_INITIALIZER, \
+#elif defined(RTEMS_SMP) && defined(RTEMS_DEBUG)
+      .Queue = { \
+        .heads = NULL, \
+#elif defined(RTEMS_SMP) && defined(RTEMS_PROFILING)
       .Queue = { \
         .heads = NULL, \
-      .Lock_stats = SMP_LOCK_STATS_INITIALIZER( name ) \
1.8.4.5
