PWM driver tested in RTEMS with RGB
punit vara punitvara at gmail.com
Tue May 10 14:47:51 UTC 2016
Please consider following code as reference original code.
https://github.com/punitvara/TI-Starterware
I have forked from sourceforge repo that I have already discussed.
https://sourceforge.net/p/starterwarefree/code/ci/master/tree/
On Tue, May 10, 2016 at 7:44 PM, punit vara <punitvara at gmail.com> wrote:
> On Fri, May 6, 2016 at 5:22 PM, Chris Johns <chrisj at rtems.org> wrote:
>> On 6/05/2016 9:47 PM, punit vara wrote:
>>> Official TI wiki page.  http://processors.wiki.ti.com/index.php/StarterWare
>>> leads me to same repo.
>>> If you are saying here we need to be careful than I would like to have
>>> a suggestion from my mentors that from where should I copy the code ?
>>> I think few days back Martin and Marcos both discussed licence issue
>>> with Gedare. I hope they can help me regarding this.
>> This is what I was after. The link is on a TI domain and as you indicate
>> it does point to the SF site.
>> Thanks for providing this. The code looks fine to me.
>> Chris
> Hi all!
> I have successfully added original Ti Starter Ware code to RTEMS.
> RTEMS build is also successful with this code.
> Well patch is quite big but I will reduce size as community suggests.
> Licence is added to .c file
> Coding style preserved to original TI SW.
> Full header file added from TI SW as it will be helpful for other BSP
> development for BBB.
> Please review code and let me know the issue.
> https://github.com/punitvara/rtems_gsoc16/blob/master/pwm/patch/0001-Added-original-Ti-StarterWare-with-successful-build.patch
> This is my first patch after getting selected in GSOC'16. Any
> suggestions are most welcome.
> Thank you,
> Punit Vara
