[PATCH 32/32] score: Remove the Giant lock
Wed May 18 09:20:51 UTC 2016
Update #2555.
 cpukit/score/Makefile.am                          |   5 -
 cpukit/score/include/rtems/score/percpu.h         |   6 -
 cpukit/score/include/rtems/score/threaddispatch.h | 175 ----------------------
 cpukit/score/src/smp.c                            |   9 --
 cpukit/score/src/threaddisabledispatch.c          |  60 --------
 cpukit/score/src/threaddispatchdisablelevel.c     | 140 -----------------
 cpukit/score/src/threadenabledispatch.c           |  32 ----
 testsuites/smptests/Makefile.am                   |   1 -
 testsuites/smptests/configure.ac                  |   1 -
 testsuites/smptests/smpfatal03/Makefile.am        |  19 ---
 testsuites/smptests/smpfatal03/init.c             | 151 -------------------
 testsuites/smptests/smpfatal03/smpfatal03.doc     |  12 --
 testsuites/smptests/smpfatal03/smpfatal03.scn     |   2 -
 13 files changed, 613 deletions(-)
 delete mode 100644 cpukit/score/src/threaddisabledispatch.c
 delete mode 100644 cpukit/score/src/threaddispatchdisablelevel.c
 delete mode 100644 cpukit/score/src/threadenabledispatch.c
 delete mode 100644 testsuites/smptests/smpfatal03/Makefile.am
 delete mode 100644 testsuites/smptests/smpfatal03/init.c
 delete mode 100644 testsuites/smptests/smpfatal03/smpfatal03.doc
 delete mode 100644 testsuites/smptests/smpfatal03/smpfatal03.scn
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index f5bf11c..0d2b395 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -296,7 +296,6 @@ libscore_a_SOURCES += src/rbtreereplace.c
 libscore_a_SOURCES += src/thread.c src/threadchangepriority.c \
     src/threadclearstate.c src/threadcreateidle.c \
     src/threaddispatch.c \
-    src/threadenabledispatch.c src/threaddisabledispatch.c \
     src/threadget.c src/threadhandler.c src/threadinitialize.c \
     src/threadloadenv.c \
     src/threadrestart.c src/threadsetpriority.c \
@@ -312,10 +311,6 @@ libscore_a_SOURCES += src/threadtimeout.c
 libscore_a_SOURCES += src/threadwaitgetid.c
 libscore_a_SOURCES += src/threadyield.c
-if HAS_SMP
-libscore_a_SOURCES += src/threaddispatchdisablelevel.c
-endif
 ## THREADQ_C_FILES
 libscore_a_SOURCES += src/threadq.c \
     src/threadqenqueue.c \
diff --git a/cpukit/score/include/rtems/score/percpu.h b/cpukit/score/include/rtems/score/percpu.h
index ea69cd6..55f799e 100644
--- a/cpukit/score/include/rtems/score/percpu.h
+++ b/cpukit/score/include/rtems/score/percpu.h
@@ -393,12 +393,6 @@ typedef struct Per_CPU_Control {
     #endif
-     * @brief Context for the Giant lock acquire and release pair of this
-     * processor.
-    SMP_lock_Context Giant_lock_context;
      * @brief Bit field for SMP messages.
      * This bit field is not protected locks.  Atomic operations are used to
diff --git a/cpukit/score/include/rtems/score/threaddispatch.h b/cpukit/score/include/rtems/score/threaddispatch.h
index be3883f..573d1be 100644
--- a/cpukit/score/include/rtems/score/threaddispatch.h
+++ b/cpukit/score/include/rtems/score/threaddispatch.h
@@ -86,122 +86,6 @@ RTEMS_INLINE_ROUTINE void _Thread_Dispatch_initialization( void )
   _Thread_Dispatch_disable_level = 1;
-#if defined(RTEMS_SMP)
-   * @brief Acquires the giant lock.
-   * The giant lock is a recursive SMP lock protecting nearly all operating
-   * system services.
-   * This lock is implicitly acquired in
-   * _Thread_Dispatch_increment_disable_level().
-   * Thread dispatching must be disabled before the Giant lock can be acquired
-   * and must no be enabled while owning the Giant lock.  The thread dispatch
-   * disable level is not altered by this function.
-   * @param[in] cpu_self The current processor.
-  void _Giant_Acquire( Per_CPU_Control *cpu_self );
-   * @brief Releases the giant lock.
-   * This lock is implicitly released in
-   * _Thread_Dispatch_decrement_disable_level().
-   * The thread dispatch disable level is not altered by this function.
-  void _Giant_Release( Per_CPU_Control *cpu_self );
-   * @brief Releases the giant lock completely if held by the executing processor.
-   * The only use case for this operation is in _SMP_Request_shutdown().
-  void _Giant_Drop( Per_CPU_Control *cpu_self );
-   *  @brief Increments the thread dispatch level.
-   * This rountine increments the thread dispatch level
-  uint32_t _Thread_Dispatch_increment_disable_level(void);
-   *  @brief Decrements the thread dispatch level.
-   * This routine decrements the thread dispatch level.
-  uint32_t _Thread_Dispatch_decrement_disable_level(void);
-#else /* RTEMS_SMP */
-   * @brief Increase thread dispatch disable level.
-  RTEMS_INLINE_ROUTINE uint32_t _Thread_Dispatch_increment_disable_level(void)
-    uint32_t disable_level = _Thread_Dispatch_disable_level;
-#if defined( RTEMS_PROFILING )
-    ISR_Level level;
-    _ISR_Local_disable( level );
-    _Profiling_Thread_dispatch_disable( _Per_CPU_Get(), disable_level );
-#endif
-    ++disable_level;
-    _Thread_Dispatch_disable_level = disable_level;
-    _ISR_Local_enable( level );
-#endif
-    return disable_level;
-   * @brief Decrease thread dispatch disable level.
-  RTEMS_INLINE_ROUTINE uint32_t _Thread_Dispatch_decrement_disable_level(void)
-    ISR_Level level;
-#endif
-    --disable_level;
-    _Profiling_Thread_dispatch_enable( _Per_CPU_Get(), disable_level );
-#endif
-  RTEMS_INLINE_ROUTINE void _Giant_Acquire( Per_CPU_Control *cpu_self )
-    (void) cpu_self;
-  RTEMS_INLINE_ROUTINE void _Giant_Release( Per_CPU_Control *cpu_self )
-    (void) cpu_self;
-#endif /* RTEMS_SMP */
  * @brief Performs a thread dispatch if necessary.
@@ -240,8 +124,6 @@ void _Thread_Do_dispatch( Per_CPU_Control *cpu_self, ISR_Level level );
  * @brief Disables thread dispatching inside a critical section (interrupts
  * disabled) with the current processor.
- * This function does not acquire the Giant lock.
  * @param[in] lock_context The lock context of the corresponding
  * _ISR_lock_ISR_disable() that started the critical section.
@@ -270,8 +152,6 @@ RTEMS_INLINE_ROUTINE Per_CPU_Control *_Thread_Dispatch_disable_with_CPU(
  * disabled).
@@ -287,8 +167,6 @@ RTEMS_INLINE_ROUTINE Per_CPU_Control *_Thread_Dispatch_disable_critical(
  * @brief Disables thread dispatching.
  * @return The current processor.
 RTEMS_INLINE_ROUTINE Per_CPU_Control *_Thread_Dispatch_disable( void )
@@ -314,8 +192,6 @@ RTEMS_INLINE_ROUTINE Per_CPU_Control *_Thread_Dispatch_disable( void )
  * May perfrom a thread dispatch if necessary as a side-effect.
- * This function does not release the Giant lock.
 RTEMS_INLINE_ROUTINE void _Thread_Dispatch_enable( Per_CPU_Control *cpu_self )
@@ -343,8 +219,6 @@ RTEMS_INLINE_ROUTINE void _Thread_Dispatch_enable( Per_CPU_Control *cpu_self )
  * @brief Unnests thread dispatching.
 RTEMS_INLINE_ROUTINE void _Thread_Dispatch_unnest( Per_CPU_Control *cpu_self )
@@ -352,55 +226,6 @@ RTEMS_INLINE_ROUTINE void _Thread_Dispatch_unnest( Per_CPU_Control *cpu_self )
   --cpu_self->thread_dispatch_disable_level;
- * @brief Disables thread dispatching and acquires the Giant lock.
-#if defined ( __THREAD_DO_NOT_INLINE_DISABLE_DISPATCH__ )
-void _Thread_Disable_dispatch( void );
-#else
-RTEMS_INLINE_ROUTINE void _Thread_Disable_dispatch( void )
-  _Thread_Dispatch_increment_disable_level();
-  RTEMS_COMPILER_MEMORY_BARRIER();
-#endif
-RTEMS_INLINE_ROUTINE void _Thread_Enable_dispatch_body( void )
-  Per_CPU_Control *cpu_self = _Per_CPU_Get();
-  _Giant_Release( cpu_self );
-  _Thread_Dispatch_enable( cpu_self );
- * @brief Enables thread dispatching and releases the Giant lock.
- * May perfrom a thread dispatch if necessary as a side-effect.
-#if defined ( __THREAD_DO_NOT_INLINE_ENABLE_DISPATCH__ )
-  void _Thread_Enable_dispatch( void );
-#else
-  /* inlining of enable dispatching must be true */
-  RTEMS_INLINE_ROUTINE void _Thread_Enable_dispatch( void )
-    _Thread_Enable_dispatch_body();
-#endif
- * @warning A thread dispatch is not performed as a side-effect.  Use this
- * function with
-RTEMS_INLINE_ROUTINE void _Thread_Unnest_dispatch( void )
-  _Thread_Dispatch_decrement_disable_level();
 #ifdef __cplusplus
diff --git a/cpukit/score/src/smp.c b/cpukit/score/src/smp.c
index 85256b0..e26de42 100644
--- a/cpukit/score/src/smp.c
+++ b/cpukit/score/src/smp.c
@@ -21,7 +21,6 @@
 #include <rtems/score/smpimpl.h>
-#include <rtems/score/threaddispatch.h>
 #include <rtems/config.h>
@@ -162,14 +161,6 @@ void _SMP_Request_shutdown( void )
   Per_CPU_Control *self_cpu = _Per_CPU_Get();
   _Per_CPU_State_change( self_cpu, PER_CPU_STATE_SHUTDOWN );
-   * We have to drop the Giant lock here in order to give other processors the
-   * opportunity to receive the inter-processor interrupts issued previously.
-   * In case the executing thread still holds SMP locks, then other processors
-   * already waiting for this SMP lock will spin forever.
-  _Giant_Drop( self_cpu );
 void _SMP_Send_message( uint32_t cpu_index, unsigned long message )
diff --git a/cpukit/score/src/threaddisabledispatch.c b/cpukit/score/src/threaddisabledispatch.c
deleted file mode 100644
index 8746cd0..0000000
--- a/cpukit/score/src/threaddisabledispatch.c
+++ /dev/null
@@ -1,60 +0,0 @@
- * @file
- * @brief Disaable Thread Dispatching
- * @ingroup ScoreThread
- *  COPYRIGHT (c) 1989-2011.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#if HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <rtems/system.h>
-#include <rtems/score/sysstate.h>
-#include <rtems/score/thread.h>
-   *  This check is very brutal to system performance but is very helpful
-   *  at finding blown stack problems.  If you have a stack problem and
-   *  need help finding it, then uncomment this code.  Every system
-   *  call will check the stack and since mutexes are used frequently
-   *  in most systems, you might get lucky.
-  #if defined(RTEMS_HEAVY_STACK_DEBUG)
-    if (_System_state_Is_up(_System_state_Get()) && (_ISR_Nest_level == 0)) {
-      if ( rtems_stack_checker_is_blown() ) {
-	printk( "Stack blown!!\n" );
-	rtems_fatal_error_occurred( 99 );
-  #endif
-   * This check is even more brutal than the other one.  This enables
-   * malloc heap integrity checking upon entry to every system call.
-  #if defined(RTEMS_HEAVY_MALLOC_DEBUG)
-    if ( _Thread_Dispatch_get_disable_level() == 1 ) {
-      _Heap_Walk( RTEMS_Malloc_Heap,99, false );
-  #endif
-#endif
diff --git a/cpukit/score/src/threaddispatchdisablelevel.c b/cpukit/score/src/threaddispatchdisablelevel.c
index 75b12bd..0000000
--- a/cpukit/score/src/threaddispatchdisablelevel.c
+++ /dev/null
@@ -1,140 +0,0 @@
- * @file
- * @brief Thread Dispatch Disable Functions
-#include <rtems/score/assert.h>
-#include <rtems/score/profiling.h>
-#define NO_OWNER_CPU NULL
-typedef struct {
-  SMP_lock_Control lock;
-  Per_CPU_Control *owner_cpu;
-  uint32_t nest_level;
-} Giant_Control;
-static Giant_Control _Giant = {
-  .lock = SMP_LOCK_INITIALIZER("Giant"),
-  .owner_cpu = NO_OWNER_CPU,
-  .nest_level = 0
-static void _Giant_Do_acquire( Per_CPU_Control *cpu_self )
-  Giant_Control *giant = &_Giant;
-  if ( giant->owner_cpu != cpu_self ) {
-    _SMP_lock_Acquire( &giant->lock, &cpu_self->Giant_lock_context );
-    giant->owner_cpu = cpu_self;
-    giant->nest_level = 1;
-  } else {
-    ++giant->nest_level;
-static void _Giant_Do_release( Per_CPU_Control *cpu_self )
-  --giant->nest_level;
-  if ( giant->nest_level == 0 ) {
-    giant->owner_cpu = NO_OWNER_CPU;
-    _SMP_lock_Release( &giant->lock, &cpu_self->Giant_lock_context );
-void _Giant_Drop( Per_CPU_Control *cpu_self )
-  _Assert( _ISR_Get_level() != 0 );
-  if ( giant->owner_cpu == cpu_self ) {
-    giant->nest_level = 0;
-uint32_t _Thread_Dispatch_increment_disable_level( void )
-  ISR_Level isr_level;
-  uint32_t disable_level;
-  Per_CPU_Control *cpu_self;
-  _ISR_Local_disable( isr_level );
-   * We must obtain the processor after interrupts are disabled to prevent
-   * thread migration.
-  cpu_self = _Per_CPU_Get();
-  _Giant_Do_acquire( cpu_self );
-  disable_level = cpu_self->thread_dispatch_disable_level;
-  _Profiling_Thread_dispatch_disable( cpu_self, disable_level );
-  ++disable_level;
-  cpu_self->thread_dispatch_disable_level = disable_level;
-  _ISR_Local_enable( isr_level );
-uint32_t _Thread_Dispatch_decrement_disable_level( void )
-  _Assert( disable_level > 0);
-  --disable_level;
-  _Giant_Do_release( cpu_self );
-  _Profiling_Thread_dispatch_enable( cpu_self, disable_level );
-void _Giant_Acquire( Per_CPU_Control *cpu_self )
-  _Assert( _Thread_Dispatch_disable_level != 0 );
-void _Giant_Release( Per_CPU_Control *cpu_self )
diff --git a/cpukit/score/src/threadenabledispatch.c b/cpukit/score/src/threadenabledispatch.c
index baf58a0..0000000
--- a/cpukit/score/src/threadenabledispatch.c
+++ /dev/null
@@ -1,32 +0,0 @@
- * @file
- * @brief Enable Dispatching of Threads
- *   _Thread_Enable_dispatch
-#if HAVE_CONFIG_H
-#endif
-#if defined (__THREAD_DO_NOT_INLINE_ENABLE_DISPATCH__ )
-void _Thread_Enable_dispatch( void )
-#endif
diff --git a/testsuites/smptests/Makefile.am b/testsuites/smptests/Makefile.am
index 8ab12dc..9cefd26 100644
--- a/testsuites/smptests/Makefile.am
+++ b/testsuites/smptests/Makefile.am
@@ -17,7 +17,6 @@ SUBDIRS += smpcapture02
 SUBDIRS += smpclock01
 SUBDIRS += smpfatal01
 SUBDIRS += smpfatal02
-SUBDIRS += smpfatal03
 SUBDIRS += smpfatal04
 SUBDIRS += smpfatal05
 SUBDIRS += smpfatal08
diff --git a/testsuites/smptests/configure.ac b/testsuites/smptests/configure.ac
index 3611e32..2ea9eec 100644
--- a/testsuites/smptests/configure.ac
+++ b/testsuites/smptests/configure.ac
@@ -73,7 +73,6 @@ smpcapture02/Makefile
 smpclock01/Makefile
 smpfatal01/Makefile
 smpfatal02/Makefile
-smpfatal03/Makefile
 smpfatal04/Makefile
 smpfatal05/Makefile
 smpfatal08/Makefile
diff --git a/testsuites/smptests/smpfatal03/Makefile.am b/testsuites/smptests/smpfatal03/Makefile.am
index 4ec2862..0000000
--- a/testsuites/smptests/smpfatal03/Makefile.am
+++ /dev/null
@@ -1,19 +0,0 @@
-rtems_tests_PROGRAMS = smpfatal03
-smpfatal03_SOURCES = init.c
-dist_rtems_tests_DATA = smpfatal03.scn smpfatal03.doc
-include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
-include $(top_srcdir)/../automake/compile.am
-include $(top_srcdir)/../automake/leaf.am
-AM_CPPFLAGS += -I$(top_srcdir)/../support/include
-LINK_OBJS = $(smpfatal03_OBJECTS)
-LINK_LIBS = $(smpfatal03_LDLIBS)
-smpfatal03$(EXEEXT): $(smpfatal03_OBJECTS) $(smpfatal03_DEPENDENCIES)
-	@rm -f smpfatal03$(EXEEXT)
-	$(make-exe)
-include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/smptests/smpfatal03/init.c b/testsuites/smptests/smpfatal03/init.c
index 2f3980b..0000000
--- a/testsuites/smptests/smpfatal03/init.c
+++ /dev/null
@@ -1,151 +0,0 @@
- * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
- *  embedded brains GmbH
- *  Dornierstr. 4
- *  82178 Puchheim
- *  Germany
- *  <rtems at embedded-brains.de>
-#ifdef HAVE_CONFIG_H
-  #include "config.h"
-#endif
-#include <rtems.h>
-#include <rtems/counter.h>
-#include <rtems/test.h>
-#include <rtems/score/smpbarrier.h>
-#include <rtems/score/smpimpl.h>
-#include <assert.h>
-#include <stdlib.h>
-const char rtems_test_name[] = "SMPFATAL 3";
-#define CPU_COUNT 2
-static uint32_t main_cpu;
-static SMP_barrier_Control giant_barrier = SMP_BARRIER_CONTROL_INITIALIZER;
-static SMP_barrier_Control fatal_barrier = SMP_BARRIER_CONTROL_INITIALIZER;
-static void acquire_giant_and_fatal_task(rtems_task_argument arg)
-  SMP_barrier_State state = SMP_BARRIER_STATE_INITIALIZER;
-  int i;
-  for (i = 0; i < 13; ++i) {
-    _Giant_Acquire();
-  _SMP_barrier_Wait(&giant_barrier, &state, CPU_COUNT);
-   * Now we have to wait some time so that the other thread can actually start
-   * with the _Giant_Acquire() procedure.
-  rtems_counter_delay_nanoseconds(1000000);
-  rtems_fatal(RTEMS_FATAL_SOURCE_APPLICATION, 0xdeadbeef);
-static void wait_for_giant(void)
-  _Giant_Release();
-static void Init(rtems_task_argument arg)
-  uint32_t self = rtems_get_current_processor();
-  uint32_t cpu_count = rtems_get_processor_count();
-  rtems_test_begink();
-  main_cpu = self;
-  if (cpu_count >= CPU_COUNT) {
-    rtems_status_code sc;
-    rtems_id id;
-    sc = rtems_task_create(
-      rtems_build_name( 'W', 'A', 'I', 'T' ),
-      1,
-      RTEMS_MINIMUM_STACK_SIZE,
-      RTEMS_DEFAULT_MODES,
-      RTEMS_DEFAULT_ATTRIBUTES,
-      &id
-    assert(sc == RTEMS_SUCCESSFUL);
-    sc = rtems_task_start(id, acquire_giant_and_fatal_task, 0);
-    wait_for_giant();
-  } else {
-    rtems_test_endk();
-    exit(0);
-static void fatal_extension(
-  rtems_fatal_source source,
-  bool is_internal,
-  rtems_fatal_code code
-  if (
-    source == RTEMS_FATAL_SOURCE_APPLICATION
-      || source == RTEMS_FATAL_SOURCE_SMP
-    assert(!is_internal);
-    if (self == main_cpu) {
-      assert(source == RTEMS_FATAL_SOURCE_SMP);
-      assert(code == SMP_FATAL_SHUTDOWN_RESPONSE);
-    } else {
-      assert(source == RTEMS_FATAL_SOURCE_APPLICATION);
-      assert(code == 0xdeadbeef);
-    _SMP_barrier_Wait(&fatal_barrier, &state, CPU_COUNT);
-    if (self == 0) {
-#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
-#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
-#define CONFIGURE_INITIAL_EXTENSIONS \
-  { .fatal = fatal_extension }, \
-  RTEMS_TEST_INITIAL_EXTENSION
-#define CONFIGURE_SMP_APPLICATION
-#define CONFIGURE_SMP_MAXIMUM_PROCESSORS CPU_COUNT
-#define CONFIGURE_MAXIMUM_TASKS 2
-#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
-#include <rtems/confdefs.h>
diff --git a/testsuites/smptests/smpfatal03/smpfatal03.doc b/testsuites/smptests/smpfatal03/smpfatal03.doc
index 5c5a8ba..0000000
--- a/testsuites/smptests/smpfatal03/smpfatal03.doc
+++ /dev/null
@@ -1,12 +0,0 @@
-This file describes the directives and concepts tested by this test set.
-test set name: smpfatal03
-directives:
-  - _Terminate()
-concepts:
-  - Ensure that _Terminate() drops the Giant lock so that other processors
-    waiting on the Giant lock can receive shutdown requests.
diff --git a/testsuites/smptests/smpfatal03/smpfatal03.scn b/testsuites/smptests/smpfatal03/smpfatal03.scn
index f502b4e..0000000
--- a/testsuites/smptests/smpfatal03/smpfatal03.scn
+++ /dev/null
@@ -1,2 +0,0 @@
-*** TEST SMPFATAL 3 ***
-*** END OF TEST SMPFATAL 3 ***
1.8.4.5
