[PATCH 14/15] score: Rename _Objects_Get_local()
Fri May 20 13:33:51 UTC 2016
Rename _Objects_Get_local() into _Objects_Get().  Confusions with the
previous _Objects_Get() function are avoided since the Objects_Locations
parameter is gone.
 cpukit/posix/include/rtems/posix/barrierimpl.h   | 2 +-
 cpukit/posix/include/rtems/posix/mqueueimpl.h    | 2 +-
 cpukit/posix/include/rtems/posix/posixapi.h      | 4 ++--
 cpukit/posix/include/rtems/posix/semaphoreimpl.h | 2 +-
 cpukit/posix/include/rtems/posix/spinlockimpl.h  | 2 +-
 cpukit/posix/include/rtems/posix/timerimpl.h     | 2 +-
 cpukit/rtems/include/rtems/rtems/barrierimpl.h   | 2 +-
 cpukit/rtems/include/rtems/rtems/dpmemimpl.h     | 2 +-
 cpukit/rtems/include/rtems/rtems/messageimpl.h   | 2 +-
 cpukit/rtems/include/rtems/rtems/partimpl.h      | 2 +-
 cpukit/rtems/include/rtems/rtems/ratemonimpl.h   | 2 +-
 cpukit/rtems/include/rtems/rtems/semimpl.h       | 2 +-
 cpukit/rtems/include/rtems/rtems/timerimpl.h     | 2 +-
 cpukit/score/include/rtems/score/objectimpl.h    | 2 +-
 cpukit/score/include/rtems/score/threadimpl.h    | 2 +-
 cpukit/score/src/objectgetlocal.c                | 2 +-
 cpukit/score/src/objectgetnameasstring.c         | 2 +-
 cpukit/score/src/objectidtoname.c                | 2 +-
 cpukit/score/src/threadget.c                     | 2 +-
 19 files changed, 20 insertions(+), 20 deletions(-)
diff --git a/cpukit/posix/include/rtems/posix/barrierimpl.h b/cpukit/posix/include/rtems/posix/barrierimpl.h
index f4c350e..5173531 100644
--- a/cpukit/posix/include/rtems/posix/barrierimpl.h
+++ b/cpukit/posix/include/rtems/posix/barrierimpl.h
@@ -82,7 +82,7 @@ RTEMS_INLINE_ROUTINE POSIX_Barrier_Control *_POSIX_Barrier_Get (
   ISR_lock_Context        *lock_context
-  return (POSIX_Barrier_Control *) _Objects_Get_local(
+  return (POSIX_Barrier_Control *) _Objects_Get(
     (Objects_Id) *barrier,
     lock_context,
     &_POSIX_Barrier_Information
diff --git a/cpukit/posix/include/rtems/posix/mqueueimpl.h b/cpukit/posix/include/rtems/posix/mqueueimpl.h
index 9d13226..3185970 100644
--- a/cpukit/posix/include/rtems/posix/mqueueimpl.h
+++ b/cpukit/posix/include/rtems/posix/mqueueimpl.h
@@ -112,7 +112,7 @@ RTEMS_INLINE_ROUTINE POSIX_Message_queue_Control *_POSIX_Message_queue_Get(
   return (POSIX_Message_queue_Control *)
-    _Objects_Get_local( id, lock_context, &_POSIX_Message_queue_Information );
+    _Objects_Get( id, lock_context, &_POSIX_Message_queue_Information );
diff --git a/cpukit/posix/include/rtems/posix/posixapi.h b/cpukit/posix/include/rtems/posix/posixapi.h
index 0001d98..14f8cf1 100644
--- a/cpukit/posix/include/rtems/posix/posixapi.h
+++ b/cpukit/posix/include/rtems/posix/posixapi.h
@@ -77,14 +77,14 @@ RTEMS_INLINE_ROUTINE int _POSIX_Get_by_name_error(
   if ( id == NULL ) { \
     return NULL; \
-  the_object = _Objects_Get_local( (Objects_Id) *id, lock_context, info ); \
+  the_object = _Objects_Get( (Objects_Id) *id, lock_context, info ); \
   if ( the_object == NULL ) { \
     _Once_Lock(); \
     if ( *id == initializer ) { \
       init( id, NULL ); \
     _Once_Unlock(); \
   return (type *) the_object
diff --git a/cpukit/posix/include/rtems/posix/semaphoreimpl.h b/cpukit/posix/include/rtems/posix/semaphoreimpl.h
index a409044..402329a 100644
--- a/cpukit/posix/include/rtems/posix/semaphoreimpl.h
+++ b/cpukit/posix/include/rtems/posix/semaphoreimpl.h
@@ -65,7 +65,7 @@ RTEMS_INLINE_ROUTINE POSIX_Semaphore_Control *_POSIX_Semaphore_Get(
-  return (POSIX_Semaphore_Control *) _Objects_Get_local(
+  return (POSIX_Semaphore_Control *) _Objects_Get(
     (Objects_Id) *id,
     lock_context,
     &_POSIX_Semaphore_Information
diff --git a/cpukit/posix/include/rtems/posix/spinlockimpl.h b/cpukit/posix/include/rtems/posix/spinlockimpl.h
index 80de3d1..e0217a0 100644
--- a/cpukit/posix/include/rtems/posix/spinlockimpl.h
+++ b/cpukit/posix/include/rtems/posix/spinlockimpl.h
@@ -84,7 +84,7 @@ RTEMS_INLINE_ROUTINE POSIX_Spinlock_Control *_POSIX_Spinlock_Get(
     return NULL;
-  return (POSIX_Spinlock_Control *) _Objects_Get_local(
+  return (POSIX_Spinlock_Control *) _Objects_Get(
     *spinlock,
     lock_context,
     &_POSIX_Spinlock_Information
diff --git a/cpukit/posix/include/rtems/posix/timerimpl.h b/cpukit/posix/include/rtems/posix/timerimpl.h
index 5a6cf28..42a814c 100644
--- a/cpukit/posix/include/rtems/posix/timerimpl.h
+++ b/cpukit/posix/include/rtems/posix/timerimpl.h
@@ -97,7 +97,7 @@ RTEMS_INLINE_ROUTINE POSIX_Timer_Control *_POSIX_Timer_Get (
-  return (POSIX_Timer_Control *) _Objects_Get_local(
+  return (POSIX_Timer_Control *) _Objects_Get(
     (Objects_Id) id,
     lock_context,
     &_POSIX_Timer_Information
diff --git a/cpukit/rtems/include/rtems/rtems/barrierimpl.h b/cpukit/rtems/include/rtems/rtems/barrierimpl.h
index 99ce276..39632fc 100644
--- a/cpukit/rtems/include/rtems/rtems/barrierimpl.h
+++ b/cpukit/rtems/include/rtems/rtems/barrierimpl.h
@@ -75,7 +75,7 @@ RTEMS_INLINE_ROUTINE Barrier_Control *_Barrier_Get(
   return (Barrier_Control *)
-    _Objects_Get_local( id, lock_context, &_Barrier_Information );
+    _Objects_Get( id, lock_context, &_Barrier_Information );
diff --git a/cpukit/rtems/include/rtems/rtems/dpmemimpl.h b/cpukit/rtems/include/rtems/rtems/dpmemimpl.h
index df51378..52ac48c 100644
--- a/cpukit/rtems/include/rtems/rtems/dpmemimpl.h
+++ b/cpukit/rtems/include/rtems/rtems/dpmemimpl.h
@@ -72,7 +72,7 @@ RTEMS_INLINE_ROUTINE Dual_ported_memory_Control *_Dual_ported_memory_Get(
   return (Dual_ported_memory_Control *)
-    _Objects_Get_local( id, lock_context, &_Dual_ported_memory_Information );
+    _Objects_Get( id, lock_context, &_Dual_ported_memory_Information );
diff --git a/cpukit/rtems/include/rtems/rtems/messageimpl.h b/cpukit/rtems/include/rtems/rtems/messageimpl.h
index a40ace3..5a12b85 100644
--- a/cpukit/rtems/include/rtems/rtems/messageimpl.h
+++ b/cpukit/rtems/include/rtems/rtems/messageimpl.h
@@ -107,7 +107,7 @@ _Message_queue_Get_interrupt_disable(
-  return (Message_queue_Control *) _Objects_Get_local(
+  return (Message_queue_Control *) _Objects_Get(
     id,
     lock_context,
     &_Message_queue_Information
diff --git a/cpukit/rtems/include/rtems/rtems/partimpl.h b/cpukit/rtems/include/rtems/rtems/partimpl.h
index ea79155..13ee86b 100644
--- a/cpukit/rtems/include/rtems/rtems/partimpl.h
+++ b/cpukit/rtems/include/rtems/rtems/partimpl.h
@@ -186,7 +186,7 @@ RTEMS_INLINE_ROUTINE Partition_Control *_Partition_Get(
-  return (Partition_Control *) _Objects_Get_local(
+  return (Partition_Control *) _Objects_Get(
     id,
     lock_context,
     &_Partition_Information
diff --git a/cpukit/rtems/include/rtems/rtems/ratemonimpl.h b/cpukit/rtems/include/rtems/rtems/ratemonimpl.h
index ac0c2c5..61ebb5a 100644
--- a/cpukit/rtems/include/rtems/rtems/ratemonimpl.h
+++ b/cpukit/rtems/include/rtems/rtems/ratemonimpl.h
@@ -90,7 +90,7 @@ RTEMS_INLINE_ROUTINE Rate_monotonic_Control *_Rate_monotonic_Get(
   return (Rate_monotonic_Control *)
-    _Objects_Get_local( id, lock_context, &_Rate_monotonic_Information );
+    _Objects_Get( id, lock_context, &_Rate_monotonic_Information );
 void _Rate_monotonic_Timeout( Watchdog_Control *watchdog );
diff --git a/cpukit/rtems/include/rtems/rtems/semimpl.h b/cpukit/rtems/include/rtems/rtems/semimpl.h
index 7c26c24..670b480 100644
--- a/cpukit/rtems/include/rtems/rtems/semimpl.h
+++ b/cpukit/rtems/include/rtems/rtems/semimpl.h
@@ -139,7 +139,7 @@ RTEMS_INLINE_ROUTINE Semaphore_Control *_Semaphore_Get_interrupt_disable(
-  return (Semaphore_Control *) _Objects_Get_local(
+  return (Semaphore_Control *) _Objects_Get(
     id,
     lock_context,
     &_Semaphore_Information
diff --git a/cpukit/rtems/include/rtems/rtems/timerimpl.h b/cpukit/rtems/include/rtems/rtems/timerimpl.h
index 5605be7..d8581bf 100644
--- a/cpukit/rtems/include/rtems/rtems/timerimpl.h
+++ b/cpukit/rtems/include/rtems/rtems/timerimpl.h
@@ -87,7 +87,7 @@ RTEMS_INLINE_ROUTINE Timer_Control *_Timer_Get(
-  return (Timer_Control *) _Objects_Get_local(
+  return (Timer_Control *) _Objects_Get(
     id,
     lock_context,
     &_Timer_Information
diff --git a/cpukit/score/include/rtems/score/objectimpl.h b/cpukit/score/include/rtems/score/objectimpl.h
index 766080e..f5beb3b 100644
--- a/cpukit/score/include/rtems/score/objectimpl.h
+++ b/cpukit/score/include/rtems/score/objectimpl.h
@@ -549,7 +549,7 @@ Objects_Name_or_id_lookup_errors _Objects_Id_to_name (
  * Interrupts are now disabled and must be restored using the specified lock
  * context via _ISR_lock_ISR_enable() or _ISR_lock_Release_and_ISR_enable().
-Objects_Control *_Objects_Get_local(
+Objects_Control *_Objects_Get(
   Objects_Id                 id,
   ISR_lock_Context          *lock_context,
   const Objects_Information *information
diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
index ce31457..66b655d 100644
--- a/cpukit/score/include/rtems/score/threadimpl.h
+++ b/cpukit/score/include/rtems/score/threadimpl.h
@@ -580,7 +580,7 @@ RTEMS_INLINE_ROUTINE Objects_Information *_Thread_Get_objects_information(
  * @brief Gets a thread by its identifier.
- * @see _Objects_Get_local().
+ * @see _Objects_Get().
 Thread_Control *_Thread_Get_interrupt_disable(
   Objects_Id         id,
diff --git a/cpukit/score/src/objectgetlocal.c b/cpukit/score/src/objectgetlocal.c
index 2024b59..a1a81db 100644
--- a/cpukit/score/src/objectgetlocal.c
+++ b/cpukit/score/src/objectgetlocal.c
@@ -25,7 +25,7 @@
   Objects_Id                 id,
diff --git a/cpukit/score/src/objectgetnameasstring.c b/cpukit/score/src/objectgetnameasstring.c
index f513774..ca6e1f4 100644
--- a/cpukit/score/src/objectgetnameasstring.c
+++ b/cpukit/score/src/objectgetnameasstring.c
@@ -56,7 +56,7 @@ char *_Objects_Get_name_as_string(
   if ( !information )
     return NULL;
-  the_object = _Objects_Get_local( tmpId, &lock_context, information );
+  the_object = _Objects_Get( tmpId, &lock_context, information );
     return NULL;
diff --git a/cpukit/score/src/objectidtoname.c b/cpukit/score/src/objectidtoname.c
index 115d0e9..aff3296 100644
--- a/cpukit/score/src/objectidtoname.c
+++ b/cpukit/score/src/objectidtoname.c
@@ -45,7 +45,7 @@ Objects_Name_or_id_lookup_errors _Objects_Id_to_name (
       return OBJECTS_INVALID_ID;
   #endif
     tmpId,
     &lock_context,
     information
diff --git a/cpukit/score/src/threadget.c b/cpukit/score/src/threadget.c
index 194b68b..61dce7d 100644
--- a/cpukit/score/src/threadget.c
+++ b/cpukit/score/src/threadget.c
@@ -39,5 +39,5 @@ Thread_Control *_Thread_Get_interrupt_disable(
   return (Thread_Control *)
-    _Objects_Get_local( id, lock_context, information );
+    _Objects_Get( id, lock_context, information );
1.8.4.5
