[PATCH 13/15] score: Delete unused _Objects_Get_isr_disable()
Fri May 20 13:33:50 UTC 2016
Delete now unused Objects_Locations.
 cpukit/score/Makefile.am                      |  2 +-
 cpukit/score/include/rtems/score/objectimpl.h | 42 --------------------
 cpukit/score/src/objectgetisr.c               | 55 ---------------------------
 3 files changed, 1 insertion(+), 98 deletions(-)
 delete mode 100644 cpukit/score/src/objectgetisr.c
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 696a6bd..1f259c6 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -211,7 +211,7 @@ libscore_a_SOURCES += src/heap.c src/heapallocate.c src/heapextend.c \
 ## OBJECT_C_FILES
 libscore_a_SOURCES += src/objectallocate.c src/objectclose.c \
     src/objectextendinformation.c src/objectfree.c \
-    src/objectgetisr.c src/objectgetnext.c src/objectinitializeinformation.c \
+    src/objectgetnext.c src/objectinitializeinformation.c \
     src/objectnametoid.c src/objectnametoidstring.c \
     src/objectshrinkinformation.c src/objectgetnoprotection.c \
     src/objectidtoname.c src/objectgetnameasstring.c src/objectsetname.c \
diff --git a/cpukit/score/include/rtems/score/objectimpl.h b/cpukit/score/include/rtems/score/objectimpl.h
index 52b6ab3..766080e 100644
--- a/cpukit/score/include/rtems/score/objectimpl.h
+++ b/cpukit/score/include/rtems/score/objectimpl.h
@@ -108,19 +108,6 @@ typedef enum {
   OBJECTS_FAKE_OBJECTS_SCHEDULERS = 1
 } Objects_Fake_objects_API;
- *  This enumerated type lists the locations which may be returned
- *  by _Objects_Get_isr_disable.  These codes indicate the success of locating
- *  an object with the specified ID.
-typedef enum {
-#if defined(RTEMS_MULTIPROCESSING)
-  OBJECTS_REMOTE = 2,         /* object is remote */
-#endif
-  OBJECTS_LOCAL  = 0,         /* object is local */
-  OBJECTS_ERROR  = 1          /* id was invalid */
-} Objects_Locations;
  *  The following type defines the callout used when a local task
@@ -543,35 +530,6 @@ Objects_Name_or_id_lookup_errors _Objects_Id_to_name (
- *  @brief Maps object ids to object control blocks.
- *  This function maps object ids to object control blocks.
- *  If id corresponds to a local object, then it returns
- *  the_object control pointer which maps to id and location
- *  is set to OBJECTS_LOCAL.  If the object class supports global
- *  objects and the object id is global and resides on a remote
- *  node, then location is set to OBJECTS_REMOTE, and the_object
- *  is undefined.  Otherwise, location is set to OBJECTS_ERROR
- *  and the_object is undefined.
- *  @param[in] information points to an object class information block.
- *  @param[in] id is the Id of the object whose name we are locating.
- *  @param[in] location will contain an indication of success or failure.
- *  @param[in] lock_context is the previous interrupt state being turned.
- *  @retval This method returns one of the values from the
- *          @ref Objects_Name_or_id_lookup_errors enumeration to indicate
- *          successful or failure.  On success @a name will contain the name of
- *          the requested object.
-Objects_Control *_Objects_Get_isr_disable(
-  Objects_Information *information,
-  Objects_Id           id,
-  Objects_Locations   *location,
-  ISR_lock_Context    *lock_context
  * @brief Maps the specified object identifier to the associated local object
  * control block.
diff --git a/cpukit/score/src/objectgetisr.c b/cpukit/score/src/objectgetisr.c
deleted file mode 100644
index 71f62fe..0000000
--- a/cpukit/score/src/objectgetisr.c
+++ /dev/null
@@ -1,55 +0,0 @@
- *  @file
- *  @brief Object Get Isr Disable
- *  @ingroup ScoreObject
- *  COPYRIGHT (c) 1989-1999.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#if HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <rtems/score/objectimpl.h>
-  Objects_Id           id,
-  Objects_Control *the_object;
-  uint32_t         index;
-  index = id - information->minimum_id + 1;
-  if ( information->maximum >= index ) {
-    _ISR_lock_ISR_disable( lock_context );
-    if ( (the_object = information->local_table[ index ]) != NULL ) {
-      *location = OBJECTS_LOCAL;
-      return the_object;
-    _ISR_lock_ISR_enable( lock_context );
-    *location = OBJECTS_ERROR;
-    return NULL;
-  if ( _Objects_MP_Is_remote( id, information ) ) {
-    *location = OBJECTS_REMOTE;
-#endif
-  return NULL;
1.8.4.5
