[PATCH 05/15] score: Delete unused _Objects_Get_local_object()
Fri May 20 13:33:42 UTC 2016
 cpukit/score/include/rtems/score/objectimpl.h | 27 ---------------------------
 1 file changed, 27 deletions(-)
diff --git a/cpukit/score/include/rtems/score/objectimpl.h b/cpukit/score/include/rtems/score/objectimpl.h
index 4049bdc..52b6ab3 100644
--- a/cpukit/score/include/rtems/score/objectimpl.h
+++ b/cpukit/score/include/rtems/score/objectimpl.h
@@ -840,33 +840,6 @@ RTEMS_INLINE_ROUTINE bool _Objects_Are_ids_equal(
- * This function returns a pointer to the local_table object
- * referenced by the index.
- * @param[in] information points to an Object Information Table
- * @param[in] index is the index of the object the caller wants to access
- * @return This method returns a pointer to a local object or NULL if the
- *         index is invalid and RTEMS_DEBUG is enabled.
-RTEMS_INLINE_ROUTINE Objects_Control *_Objects_Get_local_object(
-  Objects_Information *information,
-  uint16_t             index
-   * This routine is ONLY to be called from places in the code
-   * where the Id is known to be good.  Therefore, this should NOT
-   * occur in normal situations.
-  #if defined(RTEMS_DEBUG)
-    if ( index > information->maximum )
-      return NULL;
-  #endif
-  return information->local_table[ index ];
  * This function sets the pointer to the local_table object
1.8.4.5
