[PATCH 04/15] posix: Remove dead code and shrink comment
Fri May 20 14:09:03 UTC 2016
I think it is fine. The OmniORB had a problem with the dead code in place.
On 20/05/16 16:05, Gedare Bloom wrote:
> Calling out to Sambeet to note that this patch is removing a comment
> about OmniORB that may be relevant to his work this summer.
> On Fri, May 20, 2016 at 9:33 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>>   cpukit/posix/src/mutexinit.c | 38 +++-----------------------------------
>>   1 file changed, 3 insertions(+), 35 deletions(-)
>> diff --git a/cpukit/posix/src/mutexinit.c b/cpukit/posix/src/mutexinit.c
>> index 1888699..8de76d0 100644
>> --- a/cpukit/posix/src/mutexinit.c
>> +++ b/cpukit/posix/src/mutexinit.c
>> @@ -46,49 +46,17 @@ int pthread_mutex_init(
>>       return EINVAL;
>> -   *  This code should eventually be removed.
>> -   *  Although the POSIX specification says:
>> +   *  The POSIX specification says:
>>      *  "Attempting to initialize an already initialized mutex results
>>      *  in undefined behavior."
>>      *  Trying to keep the caller from doing the create when *mutex
>>      *  is actually a valid ID causes grief.  All it takes is the wrong
>> -   *  value in an uninitialized variable to make this fail.  As best
>> -   *  I can tell, RTEMS was the only pthread implementation to choose
>> -   *  this option for "undefined behavior" and doing so has created
>> -   *  portability problems.  In particular, Rosimildo DaSilva
>> -   *  <rdasilva at connecttel.com> saw seemingly random failures in the
>> -   *  RTEMS port of omniORB2 when this code was enabled.
>> +   *  value in an uninitialized variable to make this fail.
>> -   *  Joel Sherrill <joel at OARcorp.com>     14 May 1999
>> -   *  NOTE: Be careful to avoid infinite recursion on call to this
>> -   *        routine in _POSIX_Mutex_Get.
>> +   *  Thus, we do not look at *mutex.
>> -  #if 0
>> -    POSIX_Mutex_Control *mutex_in_use;
>> -    Objects_Locations    location;
>> -    if ( *mutex != PTHREAD_MUTEX_INITIALIZER ) {
>> -      /* EBUSY if *mutex is a valid id */
>> -      mutex_in_use = _POSIX_Mutex_Get( mutex, &location );
>> -      switch ( location ) {
>> -        case OBJECTS_LOCAL:
>> -          _Objects_Put( &mutex_in_use->Object );
>> -          return EBUSY;
>> -        #if defined(RTEMS_MULTIPROCESSING)
>> -          case OBJECTS_REMOTE:
>> -        #endif
>> -        case OBJECTS_ERROR:
>> -          break;
>> -  #endif
>>     if ( !the_attr->is_initialized )
>>       return EINVAL;
>> 1.8.4.5
>> devel mailing list
>> devel at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
