[PATCH 1/9] cpukit, testsuite: Add rtems_printf and rtems_printer support.
Tue May 24 05:13:13 UTC 2016
On 23/05/2016 22:37, Gedare Bloom wrote:
> How does this affect user applications?
It should not but if a user has an application that is using the plugin
interface there is a struct name change. The previous struct ended in
'_t' and that is reserved for POSIX plus the name included _printk_ and
it is a plugin interface for printf, printk, fprintf and fiprintf (I
think). The change for a user is simple and should be stable from here on.
The rtems_printf interface can become a documented interface and we can
maintain it. The previous interface was functionally fine and is pretty
much as it was but it's user interface needed some rework, which is what
I have done. For example there was no easy way to test if a plugin was
present and if not present dropped all output.
Going forward there is a benefit for small memory devices and there is a
case for printf possibly mapping to rtems_vprintf for those BSPs. I am
not yet sure how this would be managed but it could be via SYSINT and
confdefs.h. Defining a stable way to manage this sort of things removes
the need for users to handle it in their applications.
