LM3S69xx BSP Qemu Error
Wed May 25 05:30:10 UTC 2016
On 24/05/16 18:53, Olufowobi, Habeeb wrote:
> Hi,
> I was able to successfully built the lm3s69xx BSP. While I tried
> running the hello.exe on qemu, I got the following hardware error.
> Warning: nic stellaris_enet.0 has no peer
> qemu: hardware error: ssys_read: Bad offset 0x6c
> CPU #0:
> R00=00000000 R01=00000000 R02=87800800 R03=c1000000
> R04=400fe000 R05=400fe000 R06=07802810 R07=07802810
> R08=00000000 R09=00000000 R10=00000000 R11=00000000
> R12=00000000 R13=200010d8 R14=000003b5 R15=000003b4
> PSR=60000173 -ZC- T svc32
> FPSCR: 00000000
> Aborted (core dumped)
> I am not able to apply the patches in the BSP because they do not
> apply to the current qemu.
> I hope someone can assist on how to resolve this.
You can check out the version mentioned in the REAME and then do a git
rebase to the Qemu master (or use the old version of Qemu for this BSP).
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
