LM3S69xx BSP Qemu Error
Olufowobi, Habeeb
habeeb.olufowobi at bison.howard.edu
Thu May 26 16:39:43 UTC 2016
Hi Sebastian,
The Qemu version mentioned in the ReadMe file does not exist in the Qemu
repository. I have tried several old version of Qemu (1.0.1, 1.0, 1.0-rc3,
1.0-rc4, 1.1-rc1, 1.1) with and without the patches. Some build
successfully but got the same error message as above while other builds
failed.
Also, I have tried using the old qemu-git-1.cfg file for the builds since
the file was updated by Chris on 2016/03/18 but none of it able to resolve
the errors at the moment.
Can you please assist me in finding the version of Qemu mentioned?
Thanks
Best regards,
Habeeb
On Wed, May 25, 2016 at 1:30 AM, Sebastian Huber <
> On 24/05/16 18:53, Olufowobi, Habeeb wrote:
>> Hi,
>> I was able to successfully built the lm3s69xx BSP. While I tried running
>> the hello.exe on qemu, I got the following hardware error.
>> Warning: nic stellaris_enet.0 has no peer
>> qemu: hardware error: ssys_read: Bad offset 0x6c
>> CPU #0:
>> R00=00000000 R01=00000000 R02=87800800 R03=c1000000
>> R04=400fe000 R05=400fe000 R06=07802810 R07=07802810
>> R08=00000000 R09=00000000 R10=00000000 R11=00000000
>> R12=00000000 R13=200010d8 R14=000003b5 R15=000003b4
>> PSR=60000173 -ZC- T svc32
>> FPSCR: 00000000
>> Aborted (core dumped)
>> I am not able to apply the patches in the BSP because they do not apply
>> to the current qemu.
>> I hope someone can assist on how to resolve this.
> You can check out the version mentioned in the REAME and then do a git
> rebase to the Qemu master (or use the old version of Qemu for this BSP).
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160526/263735e3/attachment.html>
