[PATCH 3/3] score: Add Status_Control for all APIs
Wed May 25 14:37:07 UTC 2016
These seem good. Not able to look thoroughly, but fairly mechanical.
On Wed, May 25, 2016 at 9:48 AM, Sebastian Huber
> Unify the status codes of the Classic and POSIX API to use the new enum
> Status_Control.  This eliminates the Thread_Control::Wait::timeout_code
> field and the timeout parameter of _Thread_queue_Enqueue_critical() and
> _MPCI_Send_request_packet().  It gets rid of the status code translation
> tables and instead uses simple bit operations to get the status for a
> particular API.  This enables translation of status code constants at
> compile time.  Add _Thread_Wait_get_status() to avoid direct access of
> thread internal data structures.
>  cpukit/libnetworking/rtems/rtems_glue.c            |  16 +--
>  cpukit/posix/Makefile.am                           |  13 +-
>  cpukit/posix/include/rtems/posix/barrierimpl.h     |  14 --
>  cpukit/posix/include/rtems/posix/mqueueimpl.h      |   8 --
>  cpukit/posix/include/rtems/posix/muteximpl.h       |  42 ------
>  cpukit/posix/include/rtems/posix/posixapi.h        |  25 ++++
>  cpukit/posix/include/rtems/posix/rwlockimpl.h      |  23 ----
>  cpukit/posix/include/rtems/posix/semaphoreimpl.h   |  27 ----
>  cpukit/posix/include/rtems/posix/spinlockimpl.h    |  14 --
>  cpukit/posix/src/condwaitsupp.c                    |  33 +++--
>  cpukit/posix/src/mqueuerecvsupp.c                  |  12 +-
>  cpukit/posix/src/mqueuesendsupp.c                  |  15 +--
>  cpukit/posix/src/mqueuetranslatereturncode.c       |  65 ---------
>  cpukit/posix/src/mutexlocksupp.c                   |  12 +-
>  cpukit/posix/src/mutextranslatereturncode.c        |  31 -----
>  cpukit/posix/src/mutexunlock.c                     |   5 +-
>  cpukit/posix/src/nanosleep.c                       |   3 +-
>  cpukit/posix/src/pbarriertranslatereturncode.c     |  61 ---------
>  cpukit/posix/src/pbarrierwait.c                    |  24 +---
>  cpukit/posix/src/prwlockrdlock.c                   |  12 +-
>  cpukit/posix/src/prwlocktimedrdlock.c              |  33 ++---
>  cpukit/posix/src/prwlocktimedwrlock.c              |  33 ++---
>  cpukit/posix/src/prwlocktranslatereturncode.c      |  47 -------
>  cpukit/posix/src/prwlocktryrdlock.c                |  12 +-
>  cpukit/posix/src/prwlocktrywrlock.c                |  12 +-
>  cpukit/posix/src/prwlockunlock.c                   |   5 +-
>  cpukit/posix/src/prwlockwrlock.c                   |  15 +--
>  cpukit/posix/src/psignalunblockthread.c            |   6 +-
>  cpukit/posix/src/pspinlock.c                       |   7 +-
>  cpukit/posix/src/pspinlocktranslatereturncode.c    |  50 -------
>  cpukit/posix/src/pspintrylock.c                    |   7 +-
>  cpukit/posix/src/pspinunlock.c                     |   7 +-
>  cpukit/posix/src/pthreadjoin.c                     |   5 +-
>  cpukit/posix/src/semaphoretranslatereturncode.c    |  31 -----
>  cpukit/posix/src/semaphorewaitsupp.c               |  20 +--
>  cpukit/posix/src/sempost.c                         |  12 +-
>  cpukit/posix/src/sigtimedwait.c                    |  22 ++--
>  cpukit/rtems/Makefile.am                           |   3 -
>  cpukit/rtems/include/rtems/rtems/barrierimpl.h     |  14 --
>  cpukit/rtems/include/rtems/rtems/eventimpl.h       |   2 +-
>  cpukit/rtems/include/rtems/rtems/messageimpl.h     |  14 --
>  cpukit/rtems/include/rtems/rtems/semimpl.h         |  76 -----------
>  cpukit/rtems/include/rtems/rtems/statusimpl.h      |  15 +++
>  cpukit/rtems/src/barriertranslatereturncode.c      |  45 -------
>  cpukit/rtems/src/barrierwait.c                     |  12 +-
>  cpukit/rtems/src/eventmp.c                         |   8 +-
>  cpukit/rtems/src/eventreceive.c                    |   4 +-
>  cpukit/rtems/src/eventseize.c                      |  20 +--
>  cpukit/rtems/src/msgmp.c                           |  16 +--
>  cpukit/rtems/src/msgqbroadcast.c                   |   9 +-
>  cpukit/rtems/src/msgqreceive.c                     |   8 +-
>  cpukit/rtems/src/msgqsend.c                        |  15 +--
>  cpukit/rtems/src/msgqtranslatereturncode.c         |  65 ---------
>  cpukit/rtems/src/msgqurgent.c                      |  15 +--
>  cpukit/rtems/src/partmp.c                          |  17 ++-
>  cpukit/rtems/src/regiongetsegment.c                |   6 +-
>  cpukit/rtems/src/regionprocessqueue.c              |   3 +-
>  cpukit/rtems/src/semcreate.c                       |  25 ++--
>  cpukit/rtems/src/semdelete.c                       |  11 +-
>  cpukit/rtems/src/semflush.c                        |   2 +-
>  cpukit/rtems/src/semmp.c                           |  15 ++-
>  cpukit/rtems/src/semobtain.c                       |  31 ++---
>  cpukit/rtems/src/semrelease.c                      |  23 ++--
>  cpukit/rtems/src/semtranslatereturncode.c          |  41 ------
>  cpukit/rtems/src/signalmp.c                        |   8 +-
>  cpukit/rtems/src/systemeventreceive.c              |   4 +-
>  cpukit/rtems/src/taskmp.c                          |   9 +-
>  cpukit/score/Makefile.am                           |   1 +
>  cpukit/score/include/rtems/score/corebarrierimpl.h |  42 +-----
>  cpukit/score/include/rtems/score/coremsgimpl.h     |  45 +------
>  cpukit/score/include/rtems/score/coremuteximpl.h   | 146 +++++++--------------
>  cpukit/score/include/rtems/score/corerwlockimpl.h  |  32 +----
>  cpukit/score/include/rtems/score/coresemimpl.h     |  69 ++--------
>  .../score/include/rtems/score/corespinlockimpl.h   |  36 +----
>  cpukit/score/include/rtems/score/mpciimpl.h        |  11 +-
>  cpukit/score/include/rtems/score/mrsp.h            |  31 +----
>  cpukit/score/include/rtems/score/mrspimpl.h        |  49 ++++---
>  cpukit/score/include/rtems/score/status.h          | 129 ++++++++++++++++++
>  cpukit/score/include/rtems/score/thread.h          |   5 -
>  cpukit/score/include/rtems/score/threadimpl.h      |  22 ++--
>  cpukit/score/include/rtems/score/threadqimpl.h     |  40 +++++-
>  cpukit/score/preinstall.am                         |   4 +
>  cpukit/score/src/condition.c                       |   6 +-
>  cpukit/score/src/corebarrier.c                     |  11 --
>  cpukit/score/src/corebarrierwait.c                 |   9 +-
>  cpukit/score/src/coremsgbroadcast.c                |   6 +-
>  cpukit/score/src/coremsgclose.c                    |   2 +-
>  cpukit/score/src/coremsgseize.c                    |  16 +--
>  cpukit/score/src/coremsgsubmit.c                   |  19 ++-
>  cpukit/score/src/coremutex.c                       |  28 +---
>  cpukit/score/src/coremutexseize.c                  |   5 +-
>  cpukit/score/src/coremutexsurrender.c              |  14 +-
>  cpukit/score/src/corerwlockobtainread.c            |  17 +--
>  cpukit/score/src/corerwlockobtainwrite.c           |  14 +-
>  cpukit/score/src/corerwlockrelease.c               |   8 +-
>  cpukit/score/src/coresem.c                         |  22 ----
>  cpukit/score/src/corespinlockrelease.c             |   6 +-
>  cpukit/score/src/corespinlockwait.c                |  10 +-
>  cpukit/score/src/futex.c                           |   3 +-
>  cpukit/score/src/mpci.c                            |  14 +-
>  cpukit/score/src/mutex.c                           |   7 +-
>  cpukit/score/src/semaphore.c                       |   3 +-
>  cpukit/score/src/threadmp.c                        |   1 -
>  cpukit/score/src/threadqenqueue.c                  |   4 +-
>  cpukit/score/src/threadqflush.c                    |  27 ++++
>  cpukit/score/src/threadrestart.c                   |  10 +-
>  cpukit/score/src/threadtimeout.c                   |   3 +-
>  testsuites/sptests/spintrcritical10/init.c         |  22 ++--
>  testsuites/sptests/spintrcritical20/init.c         |  14 +-
>  109 files changed, 707 insertions(+), 1571 deletions(-)
>  delete mode 100644 cpukit/posix/src/mqueuetranslatereturncode.c
>  delete mode 100644 cpukit/posix/src/mutextranslatereturncode.c
>  delete mode 100644 cpukit/posix/src/pbarriertranslatereturncode.c
>  delete mode 100644 cpukit/posix/src/prwlocktranslatereturncode.c
>  delete mode 100644 cpukit/posix/src/pspinlocktranslatereturncode.c
>  delete mode 100644 cpukit/posix/src/semaphoretranslatereturncode.c
>  delete mode 100644 cpukit/rtems/src/barriertranslatereturncode.c
>  delete mode 100644 cpukit/rtems/src/msgqtranslatereturncode.c
>  delete mode 100644 cpukit/rtems/src/semtranslatereturncode.c
>  create mode 100644 cpukit/score/include/rtems/score/status.h
