Driver complaint to SD Host Controller Specification 3.0
    Mudit Jain
    muditjain18011995 at gmail.com
    Thu May 26 14:06:44 UTC 2016
Hi Sebastian & Andre,
In the last IRC meeting, Gedare had mentioned that you have previously
worked on the SD card driver.
I was working on the SD Card driver for Rpi.
I was going through the driver code that has been ported. I was able to
browse and get a top level overview regarding the ported driver using the
documentation for the APIs used from FreeBSD.
The driver is working for the powerpc/qoriq BSP.
I wanted to know which SDHC is present on that BSP and to which
specification was the driver tailored to?
RPi has a SD host controller that is complaint to Specification 3.0. Thus I
was following this link :
https://www.sdcard.org/downloads/pls/pdf/partA2_300.pdf.
Andre, were the previous commits regarding the reset logic done based on
this specification ? I wanted to clarify that that function logics that are
to be implemented will be based on this specification ?
Thanks
Mudit
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160526/60d65400/attachment.html>
