[PATCH 11/12] posix: Delete POSIX_Mutex_Protocol::process_shared
Fri May 27 13:50:40 UTC 2016
 cpukit/posix/include/rtems/posix/mutex.h | 2 --
 cpukit/posix/src/mutexinit.c             | 2 --
 2 files changed, 4 deletions(-)
diff --git a/cpukit/posix/include/rtems/posix/mutex.h b/cpukit/posix/include/rtems/posix/mutex.h
index bc8e529..e1dfa34 100644
--- a/cpukit/posix/include/rtems/posix/mutex.h
+++ b/cpukit/posix/include/rtems/posix/mutex.h
@@ -20,7 +20,6 @@
 #define _RTEMS_POSIX_MUTEX_H
 #include <rtems/score/coremutex.h>
-#include <pthread.h>
 #ifdef __cplusplus
 extern "C" {
@@ -43,7 +42,6 @@ extern "C" {
 typedef struct {
    Objects_Control     Object;
    CORE_mutex_Control  Mutex;
-   int                 process_shared;
 }  POSIX_Mutex_Control;
diff --git a/cpukit/posix/src/mutexinit.c b/cpukit/posix/src/mutexinit.c
index 8de76d0..d90b391 100644
--- a/cpukit/posix/src/mutexinit.c
+++ b/cpukit/posix/src/mutexinit.c
@@ -117,8 +117,6 @@ int pthread_mutex_init(
     return EAGAIN;
-  the_mutex->process_shared = the_attr->process_shared;
   the_mutex_attr = &the_mutex->Mutex.Attributes;
   if ( the_attr->type == PTHREAD_MUTEX_RECURSIVE )
1.8.4.5
