[PATCH 05/12] score: Add semaphore variants
Fri May 27 13:50:34 UTC 2016
 cpukit/posix/include/rtems/posix/semaphoreimpl.h |  2 +
 cpukit/posix/src/semaphorecreatesupp.c           |  6 +--
 cpukit/posix/src/semaphoredeletesupp.c           |  6 ++-
 cpukit/posix/src/semaphorewaitsupp.c             |  1 +
 cpukit/posix/src/sempost.c                       |  1 +
 cpukit/rtems/include/rtems/rtems/sem.h           | 18 +++++++
 cpukit/rtems/include/rtems/rtems/semimpl.h       | 25 +++++++++
 cpukit/rtems/src/semcreate.c                     | 31 ++++++-----
 cpukit/rtems/src/semdelete.c                     | 68 ++++++++++++++----------
 cpukit/rtems/src/semflush.c                      | 54 +++++++++----------
 cpukit/rtems/src/semobtain.c                     | 59 ++++++++++----------
 cpukit/rtems/src/semrelease.c                    | 44 +++++++--------
 cpukit/score/include/rtems/score/coresem.h       | 17 ------
 cpukit/score/include/rtems/score/coresemimpl.h   | 54 ++++++++++---------
 cpukit/score/src/coresem.c                       | 11 +---
 cpukit/score/src/mpci.c                          | 11 +++-
 16 files changed, 227 insertions(+), 181 deletions(-)
diff --git a/cpukit/posix/include/rtems/posix/semaphoreimpl.h b/cpukit/posix/include/rtems/posix/semaphoreimpl.h
index 1521ead..17d3f64 100644
--- a/cpukit/posix/include/rtems/posix/semaphoreimpl.h
+++ b/cpukit/posix/include/rtems/posix/semaphoreimpl.h
@@ -34,6 +34,8 @@ extern "C" {
 extern Objects_Information _POSIX_Semaphore_Information;
+#define POSIX_SEMAPHORE_TQ_OPERATIONS &_Thread_queue_Operations_FIFO
 RTEMS_INLINE_ROUTINE POSIX_Semaphore_Control *
   _POSIX_Semaphore_Allocate_unprotected( void )
diff --git a/cpukit/posix/src/semaphorecreatesupp.c b/cpukit/posix/src/semaphorecreatesupp.c
index 79db888..d66e194 100644
--- a/cpukit/posix/src/semaphorecreatesupp.c
+++ b/cpukit/posix/src/semaphorecreatesupp.c
@@ -92,11 +92,7 @@ int _POSIX_Semaphore_Create_support(
    *  thing is certain, no matter what we decide, it won't be
    *  the same as  all other POSIX implementations. :)
-  _CORE_semaphore_Initialize(
-    &the_semaphore->Semaphore,
-    CORE_SEMAPHORE_DISCIPLINES_FIFO,
-    value
+  _CORE_semaphore_Initialize( &the_semaphore->Semaphore, value );
    *  Make the semaphore available for use.
diff --git a/cpukit/posix/src/semaphoredeletesupp.c b/cpukit/posix/src/semaphoredeletesupp.c
index 2d39b2a..325e4a6 100644
--- a/cpukit/posix/src/semaphoredeletesupp.c
+++ b/cpukit/posix/src/semaphoredeletesupp.c
@@ -27,7 +27,11 @@ void _POSIX_Semaphore_Delete(
   if ( !the_semaphore->linked && !the_semaphore->open_count ) {
     _Objects_Close( &_POSIX_Semaphore_Information, &the_semaphore->Object );
-    _CORE_semaphore_Destroy( &the_semaphore->Semaphore, queue_context );
+    _CORE_semaphore_Destroy(
+      &the_semaphore->Semaphore,
+      POSIX_SEMAPHORE_TQ_OPERATIONS,
+      queue_context
     _POSIX_Semaphore_Free( the_semaphore );
   } else {
     _CORE_semaphore_Release( &the_semaphore->Semaphore, queue_context );
diff --git a/cpukit/posix/src/semaphorewaitsupp.c b/cpukit/posix/src/semaphorewaitsupp.c
index d8e0d69..9ba8d55 100644
--- a/cpukit/posix/src/semaphorewaitsupp.c
+++ b/cpukit/posix/src/semaphorewaitsupp.c
@@ -43,6 +43,7 @@ int _POSIX_Semaphore_Wait_support(
   status = _CORE_semaphore_Seize(
     _Thread_Executing,
     blocking,
     timeout,
diff --git a/cpukit/posix/src/sempost.c b/cpukit/posix/src/sempost.c
index 322663b..da2b1a5 100644
--- a/cpukit/posix/src/sempost.c
+++ b/cpukit/posix/src/sempost.c
@@ -40,6 +40,7 @@ int sem_post(
   status = _CORE_semaphore_Surrender(
     SEM_VALUE_MAX,
     &queue_context
diff --git a/cpukit/rtems/include/rtems/rtems/sem.h b/cpukit/rtems/include/rtems/rtems/sem.h
index 2c99f57..fe74f44 100644
--- a/cpukit/rtems/include/rtems/rtems/sem.h
+++ b/cpukit/rtems/include/rtems/rtems/sem.h
@@ -97,6 +97,24 @@ typedef struct {
   } Core_control;
+   * @brief The semaphore variant.
+   * @see Semaphore_Variant.
+  unsigned int variant : 3;
+   * @brief The semaphore thread queue discipline.
+   * @see Semaphore_Discipline.
+  unsigned int discipline : 1;
+#if defined(RTEMS_MULTIPROCESSING)
+  unsigned int is_global : 1;
+#endif
    *  This is the Classic API attribute provided to the create directive.
    *  It is translated into behavioral attributes on the SuperCore Semaphore
    *  or Mutex instance.
diff --git a/cpukit/rtems/include/rtems/rtems/semimpl.h b/cpukit/rtems/include/rtems/rtems/semimpl.h
index a498927..813f885 100644
--- a/cpukit/rtems/include/rtems/rtems/semimpl.h
+++ b/cpukit/rtems/include/rtems/rtems/semimpl.h
@@ -26,12 +26,37 @@
 extern "C" {
 #endif
+typedef enum {
+  SEMAPHORE_VARIANT_MUTEX,
+  SEMAPHORE_VARIANT_COUNTING
+#if defined(RTEMS_SMP)
+  SEMAPHORE_VARIANT_MRSP
+#endif
+} Semaphore_Variant;
+typedef enum {
+  SEMAPHORE_DISCIPLINE_PRIORITY,
+  SEMAPHORE_DISCIPLINE_FIFO
+} Semaphore_Discipline;
  *  The following defines the information control block used to manage
  *  this class of objects.
 extern Objects_Information _Semaphore_Information;
+RTEMS_INLINE_ROUTINE const Thread_queue_Operations *_Semaphore_Get_operations(
+  const Semaphore_Control *the_semaphore
+  if ( the_semaphore->discipline == SEMAPHORE_DISCIPLINE_PRIORITY ) {
+    return &_Thread_queue_Operations_priority;
+  } else {
+    return &_Thread_queue_Operations_FIFO;
  *  @brief Allocates a semaphore control block from
  *  the inactive chain of free semaphore control blocks.
diff --git a/cpukit/rtems/src/semcreate.c b/cpukit/rtems/src/semcreate.c
index 83d46b6..be8f9f5 100644
--- a/cpukit/rtems/src/semcreate.c
+++ b/cpukit/rtems/src/semcreate.c
@@ -61,10 +61,9 @@ rtems_status_code rtems_semaphore_create(
   rtems_id            *id
-  Semaphore_Control          *the_semaphore;
-  CORE_mutex_Attributes       the_mutex_attr;
-  CORE_semaphore_Disciplines  semaphore_discipline;
-  Status_Control              status;
+  Semaphore_Control     *the_semaphore;
+  CORE_mutex_Attributes  the_mutex_attr;
+  Status_Control         status;
   if ( !rtems_is_name_valid( name ) )
     return RTEMS_INVALID_NAME;
@@ -125,6 +124,8 @@ rtems_status_code rtems_semaphore_create(
+  the_semaphore->is_global = _Attributes_Is_global( attribute_set );
   if ( _Attributes_Is_global( attribute_set ) &&
        ! ( _Objects_MP_Allocate_and_open( &_Semaphore_Information, name,
                             the_semaphore->Object.id, false ) ) ) {
@@ -136,29 +137,25 @@ rtems_status_code rtems_semaphore_create(
   the_semaphore->attribute_set = attribute_set;
+  if ( _Attributes_Is_priority( attribute_set ) ) {
+    the_semaphore->discipline = SEMAPHORE_DISCIPLINE_PRIORITY;
+  } else {
+    the_semaphore->discipline = SEMAPHORE_DISCIPLINE_FIFO;
    *  Initialize it as a counting semaphore.
   if ( _Attributes_Is_counting_semaphore( attribute_set ) ) {
-    if ( _Attributes_Is_priority( attribute_set ) )
-      semaphore_discipline = CORE_SEMAPHORE_DISCIPLINES_PRIORITY;
-    else
-      semaphore_discipline = CORE_SEMAPHORE_DISCIPLINES_FIFO;
-     *  The following are just to make Purify happy.
-    the_mutex_attr.lock_nesting_behavior = CORE_MUTEX_NESTING_ACQUIRES;
-    the_mutex_attr.priority_ceiling = PRIORITY_MINIMUM;
+    the_semaphore->variant = SEMAPHORE_VARIANT_COUNTING;
       &the_semaphore->Core_control.semaphore,
-      semaphore_discipline,
       count
     status = STATUS_SUCCESSFUL;
   } else if ( _Attributes_Is_multiprocessor_resource_sharing( attribute_set ) ) {
+    the_semaphore->variant = SEMAPHORE_VARIANT_MRSP;
     status = _MRSP_Initialize(
       &the_semaphore->Core_control.mrsp,
       priority_ceiling,
@@ -167,6 +164,8 @@ rtems_status_code rtems_semaphore_create(
 #endif
   } else {
+    the_semaphore->variant = SEMAPHORE_VARIANT_MUTEX;
      *  It is either simple binary semaphore or a more powerful mutex
      *  style binary semaphore.  This is the mutex style.
diff --git a/cpukit/rtems/src/semdelete.c b/cpukit/rtems/src/semdelete.c
index 16889cd..45c356f 100644
--- a/cpukit/rtems/src/semdelete.c
+++ b/cpukit/rtems/src/semdelete.c
@@ -53,22 +53,27 @@ rtems_status_code rtems_semaphore_delete(
     &queue_context.Lock_context
+  switch ( the_semaphore->variant ) {
+    case SEMAPHORE_VARIANT_MUTEX:
+      if (
+        _CORE_mutex_Is_locked( &the_semaphore->Core_control.mutex )
+          && !_Attributes_Is_simple_binary_semaphore( attribute_set )
+        status = STATUS_RESOURCE_IN_USE;
+      } else {
+        status = STATUS_SUCCESSFUL;
+      break;
-  if ( _Attributes_Is_multiprocessor_resource_sharing( attribute_set ) ) {
-    status = _MRSP_Can_destroy( &the_semaphore->Core_control.mrsp );
-  } else
+    case SEMAPHORE_VARIANT_MRSP:
+      status = _MRSP_Can_destroy( &the_semaphore->Core_control.mrsp );
+      break;
 #endif
-  if ( !_Attributes_Is_counting_semaphore( attribute_set ) ) {
-    if (
-      _CORE_mutex_Is_locked( &the_semaphore->Core_control.mutex )
-        && !_Attributes_Is_simple_binary_semaphore( attribute_set )
-      status = STATUS_RESOURCE_IN_USE;
-    } else {
+    default:
+      _Assert( the_semaphore->variant == SEMAPHORE_VARIANT_COUNTING );
-  } else {
-    status = STATUS_SUCCESSFUL;
+      break;
   if ( status != STATUS_SUCCESSFUL ) {
@@ -82,27 +87,32 @@ rtems_status_code rtems_semaphore_delete(
   _Objects_Close( &_Semaphore_Information, &the_semaphore->Object );
+      _CORE_mutex_Flush(
+        &the_semaphore->Core_control.mutex,
+        _Thread_queue_Flush_status_object_was_deleted,
+        &queue_context
+      _CORE_mutex_Destroy( &the_semaphore->Core_control.mutex );
+      break;
-    _MRSP_Destroy( &the_semaphore->Core_control.mrsp, &queue_context );
-  } else
+      _MRSP_Destroy( &the_semaphore->Core_control.mrsp, &queue_context );
+      break;
 #endif
-    _CORE_mutex_Flush(
-      &the_semaphore->Core_control.mutex,
-      _Thread_queue_Flush_status_object_was_deleted,
-      &queue_context
-    _CORE_mutex_Destroy( &the_semaphore->Core_control.mutex );
-  } else {
-      &the_semaphore->Core_control.semaphore,
-      &queue_context
+    default:
+        &the_semaphore->Core_control.semaphore,
+        _Semaphore_Get_operations( the_semaphore ),
+        &queue_context
+      break;
-  if ( _Attributes_Is_global( attribute_set ) ) {
+  if ( the_semaphore->is_global ) {
     _Objects_MP_Close( &_Semaphore_Information, id );
diff --git a/cpukit/rtems/src/semflush.c b/cpukit/rtems/src/semflush.c
index 07d4aa9..f768bbd 100644
--- a/cpukit/rtems/src/semflush.c
+++ b/cpukit/rtems/src/semflush.c
@@ -19,13 +19,11 @@
 #endif
-#include <rtems/rtems/attrimpl.h>
 rtems_status_code rtems_semaphore_flush( rtems_id id )
   Thread_queue_Context  queue_context;
-  rtems_attribute       attribute_set;
   the_semaphore = _Semaphore_Get( id, &queue_context );
@@ -39,38 +37,40 @@ rtems_status_code rtems_semaphore_flush( rtems_id id )
     return RTEMS_INVALID_ID;
-  attribute_set = the_semaphore->attribute_set;
+  _Thread_queue_Acquire_critical(
+    &the_semaphore->Core_control.Wait_queue,
+    &queue_context.Lock_context
   _Thread_queue_Context_set_MP_callout(
     &queue_context,
     _Semaphore_MP_Send_object_was_deleted
-    _ISR_lock_ISR_enable( &queue_context.Lock_context );
-    return RTEMS_NOT_DEFINED;
-  } else
+      _Thread_queue_Release(
+      return RTEMS_NOT_DEFINED;
 #endif
-    _CORE_mutex_Acquire_critical(
-      &queue_context
-      _Thread_queue_Flush_status_unavailable,
-      &queue_context
-  } else {
-    _CORE_semaphore_Acquire_critical(
-      &queue_context
-    _CORE_semaphore_Flush(
-      &queue_context
+        _Thread_queue_Flush_status_unavailable,
+        &queue_context
+      break;
+    default:
+      _CORE_semaphore_Flush(
+        &queue_context
+      break;
   return RTEMS_SUCCESSFUL;
diff --git a/cpukit/rtems/src/semobtain.c b/cpukit/rtems/src/semobtain.c
index 8cb195c..00474da 100644
--- a/cpukit/rtems/src/semobtain.c
+++ b/cpukit/rtems/src/semobtain.c
@@ -54,7 +54,6 @@ rtems_status_code rtems_semaphore_obtain(
   Thread_Control       *executing;
   bool                  wait;
@@ -69,36 +68,40 @@ rtems_status_code rtems_semaphore_obtain(
   executing = _Thread_Executing;
   wait = !_Options_Is_no_wait( option_set );
-    status = _MRSP_Seize(
-      &the_semaphore->Core_control.mrsp,
-      executing,
-      wait,
-      timeout,
-      &queue_context
-  } else
+      status = _MRSP_Seize(
+        &the_semaphore->Core_control.mrsp,
+        executing,
+        wait,
+        timeout,
+        &queue_context
+      break;
 #endif
-    status = _CORE_mutex_Seize(
-      executing,
-      wait,
-      timeout,
-      &queue_context
-  } else {
-    /* must be a counting semaphore */
-    status = _CORE_semaphore_Seize(
-      executing,
-      wait,
-      timeout,
-      &queue_context
+      status = _CORE_mutex_Seize(
+        executing,
+        wait,
+        timeout,
+        &queue_context
+      break;
+    default:
+      status = _CORE_semaphore_Seize(
+        executing,
+        wait,
+        timeout,
+        &queue_context
+      break;
   return _Status_Get( status );
diff --git a/cpukit/rtems/src/semrelease.c b/cpukit/rtems/src/semrelease.c
index 10fe743..d18901a 100644
--- a/cpukit/rtems/src/semrelease.c
+++ b/cpukit/rtems/src/semrelease.c
@@ -22,14 +22,12 @@
 #endif
 #include <rtems/rtems/statusimpl.h>
 rtems_status_code rtems_semaphore_release( rtems_id id )
@@ -47,27 +45,31 @@ rtems_status_code rtems_semaphore_release( rtems_id id )
     _Semaphore_Core_mutex_mp_support
-    status = _MRSP_Surrender(
-      _Thread_Executing,
-      &queue_context
-  } else
+      status = _MRSP_Surrender(
+        _Thread_Executing,
+        &queue_context
+      break;
 #endif
-    status = _CORE_mutex_Surrender(
-      &queue_context
-  } else {
-    status = _CORE_semaphore_Surrender(
-      UINT32_MAX,
-      &queue_context
+      status = _CORE_mutex_Surrender(
+        &queue_context
+      break;
+    default:
+      status = _CORE_semaphore_Surrender(
+        UINT32_MAX,
+        &queue_context
+      break;
diff --git a/cpukit/score/include/rtems/score/coresem.h b/cpukit/score/include/rtems/score/coresem.h
index 84fde0b..f9d3ac8 100644
--- a/cpukit/score/include/rtems/score/coresem.h
+++ b/cpukit/score/include/rtems/score/coresem.h
@@ -38,18 +38,6 @@ extern "C" {
- *  Blocking disciplines for a semaphore.
-typedef enum {
-  /** This specifies that threads will wait for the semaphore in FIFO order. */
-   *  priority order.
-  CORE_SEMAPHORE_DISCIPLINES_PRIORITY
-}   CORE_semaphore_Disciplines;
  *  The following defines the control block used to manage each
  *  counting semaphore.
@@ -59,11 +47,6 @@ typedef struct {
   Thread_queue_Control        Wait_queue;
-   * @brief The thread queue operations according to the blocking discipline.
-  const Thread_queue_Operations *operations;
   /** This element contains the current count of this semaphore. */
   uint32_t                    count;
 }   CORE_semaphore_Control;
diff --git a/cpukit/score/include/rtems/score/coresemimpl.h b/cpukit/score/include/rtems/score/coresemimpl.h
index a55089e..24d8c51 100644
--- a/cpukit/score/include/rtems/score/coresemimpl.h
+++ b/cpukit/score/include/rtems/score/coresemimpl.h
@@ -46,13 +46,11 @@ extern "C" {
  *  This routine initializes the semaphore based on the parameters passed.
  *  @param[in] the_semaphore is the semaphore to initialize
- *  @param[in] discipline the blocking discipline
  *  @param[in] initial_value is the initial count of the semaphore
 void _CORE_semaphore_Initialize(
-  CORE_semaphore_Control     *the_semaphore,
-  CORE_semaphore_Disciplines  discipline,
-  uint32_t                    initial_value
+  CORE_semaphore_Control *the_semaphore,
+  uint32_t                initial_value
 RTEMS_INLINE_ROUTINE void _CORE_semaphore_Acquire_critical(
@@ -78,13 +76,14 @@ RTEMS_INLINE_ROUTINE void _CORE_semaphore_Release(
 RTEMS_INLINE_ROUTINE void _CORE_semaphore_Destroy(
-  Thread_queue_Context   *queue_context
+  const Thread_queue_Operations *operations,
+  Thread_queue_Context          *queue_context
   _Thread_queue_Flush_critical(
     &the_semaphore->Wait_queue.Queue,
-    the_semaphore->operations,
+    operations,
     queue_context
@@ -99,15 +98,17 @@ RTEMS_INLINE_ROUTINE void _CORE_semaphore_Destroy(
  *  given to that task.  Otherwise, the unit will be returned to the semaphore.
  *  @param[in] the_semaphore is the semaphore to surrender
+ *  @param[in] operations The thread queue operations.
  *  @param[in] queue_context is a temporary variable used to contain the ISR
  *        disable level cookie
  *  @retval an indication of whether the routine succeeded or failed
 RTEMS_INLINE_ROUTINE Status_Control _CORE_semaphore_Surrender(
-  uint32_t                 maximum_count,
+  uint32_t                       maximum_count,
   Thread_Control *the_thread;
@@ -119,12 +120,12 @@ RTEMS_INLINE_ROUTINE Status_Control _CORE_semaphore_Surrender(
   the_thread = _Thread_queue_First_locked(
     &the_semaphore->Wait_queue,
+    operations
   if ( the_thread != NULL ) {
     _Thread_queue_Extract_critical(
+      operations,
       the_thread,
       queue_context
@@ -141,13 +142,14 @@ RTEMS_INLINE_ROUTINE Status_Control _CORE_semaphore_Surrender(
 RTEMS_INLINE_ROUTINE void _CORE_semaphore_Flush(
+    operations,
     queue_context
@@ -161,7 +163,7 @@ RTEMS_INLINE_ROUTINE void _CORE_semaphore_Flush(
  * @return the current count of this semaphore
 RTEMS_INLINE_ROUTINE uint32_t  _CORE_semaphore_Get_count(
+  const CORE_semaphore_Control *the_semaphore
   return the_semaphore->count;
@@ -174,23 +176,23 @@ RTEMS_INLINE_ROUTINE uint32_t  _CORE_semaphore_Get_count(
  * available.
  * @param[in] the_semaphore is the semaphore to obtain
- * @param[in,out] executing The currently executing thread.
+ * @param[in] executing The currently executing thread.
  * @param[in] wait is true if the thread is willing to wait
  * @param[in] timeout is the maximum number of ticks to block
- * @note There is currently no MACRO version of this routine.
 RTEMS_INLINE_ROUTINE Status_Control _CORE_semaphore_Seize(
-  Thread_Control         *executing,
-  bool                    wait,
-  Watchdog_Interval       timeout,
+  Thread_Control                *executing,
+  bool                           wait,
+  Watchdog_Interval              timeout,
-  /* disabled when you get here */
+  _Assert( _ISR_Get_level() != 0 );
   _CORE_semaphore_Acquire_critical( the_semaphore, queue_context );
   if ( the_semaphore->count != 0 ) {
@@ -207,7 +209,7 @@ RTEMS_INLINE_ROUTINE Status_Control _CORE_semaphore_Seize(
   _Thread_queue_Context_set_expected_level( queue_context, 1 );
   _Thread_queue_Enqueue_critical(
+    operations,
     executing,
     STATES_WAITING_FOR_SEMAPHORE,
     timeout,
diff --git a/cpukit/score/src/coresem.c b/cpukit/score/src/coresem.c
index 2bdd81c..e928f3d 100644
--- a/cpukit/score/src/coresem.c
+++ b/cpukit/score/src/coresem.c
@@ -21,18 +21,11 @@
 #include <rtems/score/coresemimpl.h>
   the_semaphore->count = initial_value;
   _Thread_queue_Initialize( &the_semaphore->Wait_queue );
-  if ( discipline == CORE_SEMAPHORE_DISCIPLINES_PRIORITY ) {
-    the_semaphore->operations = &_Thread_queue_Operations_priority;
-  } else {
-    the_semaphore->operations = &_Thread_queue_Operations_FIFO;
diff --git a/cpukit/score/src/mpci.c b/cpukit/score/src/mpci.c
index 1e26b1f..721868e 100644
--- a/cpukit/score/src/mpci.c
+++ b/cpukit/score/src/mpci.c
@@ -35,6 +35,8 @@ RTEMS_STATIC_ASSERT(
   MPCI_Internal_packet
+#define MPCI_SEMAPHORE_TQ_OPERATIONS &_Thread_queue_Operations_FIFO
 bool _System_state_Is_multiprocessing;
 rtems_multiprocessing_table *_Configuration_MP_table;
@@ -119,7 +121,6 @@ static void _MPCI_Handler_initialization( void )
     &_MPCI_Semaphore,
     0                         /* initial_value */
@@ -334,6 +335,7 @@ void _MPCI_Receive_server(
     _ISR_lock_ISR_disable( &queue_context.Lock_context );
       &_MPCI_Semaphore,
+      MPCI_SEMAPHORE_TQ_OPERATIONS,
       executing,
       true,
       WATCHDOG_NO_TIMEOUT,
@@ -372,7 +374,12 @@ void _MPCI_Announce ( void )
-  (void) _CORE_semaphore_Surrender( &_MPCI_Semaphore, UINT32_MAX, &queue_context );
+  (void) _CORE_semaphore_Surrender(
+    &_MPCI_Semaphore,
+    UINT32_MAX,
+    &queue_context
 void _MPCI_Internal_packets_Send_process_packet (
1.8.4.5
