Ada support on gcc-6 broken again
Fri May 27 15:23:49 UTC 2016
----- Joel Sherrill <joel at rtems.org> schrieb:
> Did it again. :(
> Two days of moving with a rental truck must have be rusty. :(
> On Fri, May 27, 2016 at 9:08 AM, Jan Sommer <soja-lists at aries.uberspace.de>
> wrote:
> > Am 2016-05-27 14:44, schrieb Joel Sherrill:
> >> On May 27, 2016 7:17 AM, "Jan Sommer" <soja-lists at aries.uberspace.de>
> > It probably should have a gcc ticket.
> >> Could we keep the fix as a patch until the gcc-version of the RSB
> >> includes it natively?
> >> I don't think the RSB builds Ada unless Chris slipped one by me. So it
> >> doesn't matter unless it impacts other languages.
> > That's how I build the Ada compiler atm.
> > First the standard toolchain, then rtems, then toolchain with --with-ada
> > switch.
> I think you can now build standard tool chain with Ada and then RTEMS.
> Sebastian worked to get the FreeBSD networking .h files that are from POSIX
> into newlib. That was the missing piece before and why you needed RTEMS
> built in the middle.
> If this doesn't work, then we want to know why. It would be a huge
> improvement
> to be able to do it in one sweep.
No, we stopped to work on this since Chris was not so fond of it.  I still think its an improvement to move the POSIX header files to Newlib.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
