GSOC2016: Improvements in RTEMS Tracing Framework
Fri May 27 22:57:18 UTC 2016
On 26/05/2016 10:46 PM, vivek kukreja wrote:
> I'm facing a problem with function tracing. I made changes to rtems-tld
Can you please send me a diff off-line? Thanks.
> command to ouput a CTF metadata file but i need sizes of arguments and
> return values at compile-time to be put in the metadata file.
I am not sure about this. I will ask the maintainers.
> For now i have yet to put actual variable sizes. Any recommendations how
> to go about it?
No yet. I would like to understand the flow of data and how the metadata
is used by CTF.
> We could use shared libraries or gdb along with
> fileio-wrapper.o to identify variables and sizes from symbol table.
We need a host based solution.
> Also, my tasks for this week include tracing user-extensions and
> converting them to CTF.
> I followed the tutorial on
> https://ftp.rtems.org/pub/rtems/people/chrisj/capture/capture-pc586.txt
> to run capture.exe example but failed.
> Is building grub image necessary?
It is only needed to use the PC BSP.
> Trying to run the example fo xilinx_zynq_a9_qemu bsp directly on Qemu doesn't seem to work.
What does not work?
> RMON task
> is visible in the init tasks list but 'ctset RMON' command fails. Any
> suggestions how to make this work?
Does this mean the exe is running but something else is going wrong?
