GSOC2016: Improvements in RTEMS Tracing Framework
Mon May 30 05:08:54 UTC 2016
On 30/05/2016 13:51, vivek kukreja wrote:
> The init.c file for capture example doesnt include confdefs.h. Are there any other examples i can look at?
The capture init.c in the testsuite includes system.h. I suggest you
take a look in that file.
> The ctrace command(specifically rtems_capture_print_trace_records function) calls rtems_capture_read to read records from cpu buffers which returns RTEMS_UNSATISFIED.
Why does that function return that status code?
