[PATCH v2 7/7] arm/raspberrypi: add fbcons support for rpi bsp
ppisa4lists at pikron.com
Sun May 22 00:13:10 UTC 2016
c/src/lib/libbsp/arm/raspberrypi/Makefile.am | 4 +-
.../arm/raspberrypi/console/console-config.c | 12 +-
.../arm/raspberrypi/console/console_select.c | 113 +++++++++++++
c/src/lib/libbsp/arm/raspberrypi/console/fbcons.c | 177 +++++++++++++++++++++
c/src/lib/libbsp/arm/raspberrypi/console/fbcons.h | 47 ++++++
c/src/lib/libbsp/arm/raspberrypi/include/bsp.h | 3 +
c/src/lib/libbsp/arm/raspberrypi/preinstall.am | 4 +
.../libbsp/arm/raspberrypi/startup/bspstarthooks.c | 4 +
8 files changed, 362 insertions(+), 2 deletions(-)
create mode 100644 c/src/lib/libbsp/arm/raspberrypi/console/console_select.c
create mode 100644 c/src/lib/libbsp/arm/raspberrypi/console/fbcons.c
create mode 100644 c/src/lib/libbsp/arm/raspberrypi/console/fbcons.h
diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
index f5b87ab..e115745 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
+++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
@@ -53,6 +53,7 @@ include_bsp_HEADERS += include/spi.h
include_bsp_HEADERS += include/mailbox.h
include_bsp_HEADERS += include/vc.h
include_bsp_HEADERS += include/rpi-fb.h
+include_bsp_HEADERS += console/fbcons.h
include_libcpu_HEADERS = ../../../libcpu/arm/shared/include/cache_.h \
../../../libcpu/arm/shared/include/arm-cp15.h
@@ -113,11 +114,12 @@ libbsp_a_SOURCES += irq/irq.c
libbsp_a_SOURCES += ../../shared/console.c
libbsp_a_SOURCES += ../../shared/console_control.c
libbsp_a_SOURCES += ../../shared/console_read.c
-libbsp_a_SOURCES += ../../shared/console_select.c
libbsp_a_SOURCES += ../../shared/console_write.c
libbsp_a_SOURCES += console/console-config.c
+libbsp_a_SOURCES += console/console_select.c
libbsp_a_SOURCES += console/usart.c
libbsp_a_SOURCES += console/fb.c
+libbsp_a_SOURCES += console/fbcons.c
libbsp_a_SOURCES += console/outch.c
# Mailbox
diff --git a/c/src/lib/libbsp/arm/raspberrypi/console/console-config.c b/c/src/lib/libbsp/arm/raspberrypi/console/console-config.c
index b948b77..dfb9826 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/console/console-config.c
+++ b/c/src/lib/libbsp/arm/raspberrypi/console/console-config.c
@@ -7,6 +7,8 @@
+ * Copyright (c) 2015 Yang Qiao
+ * based on work by:
* Copyright (c) 2013 Alan Cudmore
* The license and distribution terms for this file may be
@@ -24,6 +26,7 @@
#include <bsp/irq.h>
#include <bsp/usart.h>
#include <bsp/raspberrypi.h>
+#include <bsp/fbcons.h>
console_tbl Console_Configuration_Ports [] = {
@@ -36,7 +39,14 @@ console_tbl Console_Configuration_Ports [] = {
.ulCtrlPort2 = 0,
.ulClock = USART0_DEFAULT_BAUD,
.ulIntVector = BCM2835_IRQ_ID_UART
+ .sDeviceName ="/dev/fbcons",
+ .deviceType = SERIAL_CUSTOM,
+ .pDeviceFns = &fbcons_fns,
+ .deviceProbe = fbcons_probe,
+ .pDeviceFlow = NULL,
#define PORT_COUNT \
diff --git a/c/src/lib/libbsp/arm/raspberrypi/console/console_select.c b/c/src/lib/libbsp/arm/raspberrypi/console/console_select.c
new file mode 100644
index 0000000..c038cd9
--- /dev/null
+++ b/c/src/lib/libbsp/arm/raspberrypi/console/console_select.c
@@ -0,0 +1,113 @@
+ * @file
+ * @ingroup raspberrypi_console
+ * @brief console select
+ * http://www.rtems.org/license/LICENSE
+#include <bsp.h>
+#include <bsp/fatal.h>
+#include <rtems/libio.h>
+#include <stdlib.h>
+#include <assert.h>
+#include <termios.h>
+#include <rtems/termiostypes.h>
+#include <libchip/serial.h>
+#include "../../../shared/console_private.h"
+#include <bsp/rpi-fb.h>
+rtems_device_minor_number BSPPrintkPort = 0;
+ * Method to return true if the device associated with the
+ * minor number probs available.
+static bool bsp_Is_Available( rtems_device_minor_number minor )
+ console_tbl *cptr = Console_Port_Tbl[ minor ];
+ * First perform the configuration dependent probe, then the
+ * device dependent probe
+ if ( ( !cptr->deviceProbe || cptr->deviceProbe( minor ) ) &&
+ cptr->pDeviceFns->deviceProbe( minor ) ) {
+ return true;
+ return false;
+ * Method to return the first available device.
+static rtems_device_minor_number bsp_First_Available_Device( void )
+ rtems_device_minor_number minor;
+ for ( minor = 0; minor < Console_Port_Count; minor++ ) {
+ return minor;
+ * Error No devices were found. We will want to bail here.
+ bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
+void bsp_console_select( void )
+ * Reset Console_Port_Minor and
+ * BSPPrintkPort here if desired.
+ * This default version allows the bsp to set these
+ * values at creation and will not touch them again
+ * unless the selected port number is not available.
+ const char *opt;
+ Console_Port_Minor = BSP_CONSOLE_UART0;
+ BSPPrintkPort = BSP_CONSOLE_UART0;
+ opt = rpi_cmdline_get_arg( "--console=" );
+ if ( opt ) {
+ if ( strncmp( opt, "fbcons", sizeof( "fbcons" - 1 ) ) == 0 ) {
+ if ( rpi_video_is_initialized() > 0 ) {
+ Console_Port_Minor = BSP_CONSOLE_FB;
+ BSPPrintkPort = BSP_CONSOLE_FB;
+ * If the device that was selected isn't available then
+ * let the user know and select the first available device.
+ if ( !bsp_Is_Available( Console_Port_Minor ) ) {
+ Console_Port_Minor = bsp_First_Available_Device();
diff --git a/c/src/lib/libbsp/arm/raspberrypi/console/fbcons.c b/c/src/lib/libbsp/arm/raspberrypi/console/fbcons.c
index 0000000..3669ba4
--- /dev/null
+++ b/c/src/lib/libbsp/arm/raspberrypi/console/fbcons.c
@@ -0,0 +1,177 @@
+ * @file
+ * @brief framebuffer graphic console support.
+#include <rtems.h>
+#include <libchip/sersupp.h>
+#include <bsp.h>
+#include <bsp/vc.h>
+ * fbcons_init
+ * This function initializes the fb console to a quiecsent state.
+static void fbcons_init( int minor )
+ * fbcons_open
+ * This function opens a port for communication.
+ * Default state is 9600 baud, 8 bits, No parity, and 1 stop bit.
+static int fbcons_open(
+ int major,
+ int minor,
+ void *arg
+ return RTEMS_SUCCESSFUL;
+ * fbcons_close
+ * This function shuts down the requested port.
+static int fbcons_close(
+ int major,
+ int minor,
+ void *arg
+ return ( RTEMS_SUCCESSFUL );
+ * fbcons_write_polled
+ * This routine polls out the requested character.
+static void fbcons_write_polled(
+ int minor,
+ char c
+ rpi_fb_outch( c );
+ if ( c == '\n' )
+ rpi_fb_outch( '\r' ); /* LF = LF + CR */
+ * fbcons_write_support_polled
+ * Console Termios output entry point when using polled output.
+static ssize_t fbcons_write_support_polled(
+ int minor,
+ const char *buf,
+ size_t len
+ int nwrite = 0;
+ * poll each byte in the string out of the port.
+ while ( nwrite < len ) {
+ fbcons_write_polled( minor, *buf++ );
+ nwrite++;
+ * return the number of bytes written.
+ return nwrite;
+ * fbcons_inbyte_nonblocking_polled
+ * Console Termios polling input entry point.
+static int fbcons_inbyte_nonblocking_polled( int minor )
+ // if( rtems_kbpoll() ) {
+ // int c = getch();
+ // return c;
+ return -1;
+ * fbcons_set_attributes
+ * This function sets the UART channel to reflect the requested termios
+ * port settings.
+static int fbcons_set_attributes(
+ int minor,
+ const struct termios *t
+ return 0;
+bool fbcons_probe( int minor )
+ // rtems_status_code status;
+ static bool firstTime = true;
+ static bool ret = false;
+ * keyboard interrupt should be registered when the keyboard is available
+ if ( firstTime ) {
+ if ( !rpi_fb_hdmi_is_present() ) {
+ ret = false;
+ } else {
+ ret = true;
+ firstTime = false;
+ return ret;
+const console_fns fbcons_fns =
+ .deviceProbe = libchip_serial_default_probe, /* deviceProbe */
+ .deviceFirstOpen = fbcons_open, /* deviceFirstOpen */
+ .deviceLastClose = fbcons_close, /* deviceLastClose */
+ .deviceRead = fbcons_inbyte_nonblocking_polled, /* deviceRead */
+ .deviceWrite = fbcons_write_support_polled, /* deviceWrite */
+ .deviceInitialize = fbcons_init, /* deviceInitialize */
+ .deviceWritePolled = fbcons_write_polled, /* deviceWritePolled */
+ .deviceSetAttributes = fbcons_set_attributes, /* deviceSetAttributes */
+ .deviceOutputUsesInterrupts = FALSE, /* deviceOutputUsesInterrupts*/
diff --git a/c/src/lib/libbsp/arm/raspberrypi/console/fbcons.h b/c/src/lib/libbsp/arm/raspberrypi/console/fbcons.h
index 0000000..d0e1266
--- /dev/null
+++ b/c/src/lib/libbsp/arm/raspberrypi/console/fbcons.h
@@ -0,0 +1,47 @@
+ * @file
+#ifndef _FBCONS_H_
+#define _FBCONS_H_
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * This is the ASCII for "PI" in the upper word and 2835
+ * in the lower which should be unique enough to
+ * distinguish this type of serial device from others.
+#define FB_CONSOLE 0x50492835
+bool fbcons_probe( int minor );
+ * Driver function table
+extern const console_fns fbcons_fns;
+#ifdef __cplusplus
+#endif
+#endif /* _FBCONS_H_ */
diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/bsp.h b/c/src/lib/libbsp/arm/raspberrypi/include/bsp.h
index 67df810..5241979 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/include/bsp.h
+++ b/c/src/lib/libbsp/arm/raspberrypi/include/bsp.h
@@ -38,6 +38,9 @@ extern "C" {
#define BSP_GPIO_PINS_PER_BANK 32
#define BSP_GPIO_PINS_PER_SELECT_BANK 10
+#define BSP_CONSOLE_UART0 0
+#define BSP_CONSOLE_FB 1
void rpi_init_cmdline(void);
const char *rpi_cmdline_get_cached(void);
const char *rpi_cmdline_get_raw(void);
diff --git a/c/src/lib/libbsp/arm/raspberrypi/preinstall.am b/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
index cbfa79f..e6f0ca0 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
+++ b/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
@@ -158,6 +158,10 @@ $(PROJECT_INCLUDE)/bsp/rpi-fb.h: include/rpi-fb.h $(PROJECT_INCLUDE)/bsp/$(dirst
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/rpi-fb.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/rpi-fb.h
+$(PROJECT_INCLUDE)/bsp/fbcons.h: console/fbcons.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/fbcons.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/fbcons.h
$(PROJECT_INCLUDE)/libcpu/cache_.h: ../../../libcpu/arm/shared/include/cache_.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/cache_.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/cache_.h
diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c b/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
index d44be03..0a90e7a 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
+++ b/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
@@ -27,6 +27,8 @@
#include <bsp/mm.h>
#include <libcpu/arm-cp15.h>
+#include <bsp.h>
void BSP_START_TEXT_SECTION bsp_start_hook_0(void)
@@ -71,4 +73,6 @@ void BSP_START_TEXT_SECTION bsp_start_hook_1(void)
bsp_start_copy_sections();
bsp_memory_management_initialize();
bsp_start_clear_bss();
+ rpi_video_init();
1.9.1
