[PATCH 5/5] score: Move thread queue MP callout to context
Sebastian Huber
Tue May 24 12:07:15 UTC 2016
Drop the multiprocessing (MP) dependent callout parameter from the
thread queue extract, dequeue, flush and unblock methods. Merge this
parameter with the lock context into new structure Thread_queue_Context.
This helps to gets rid of the conditionally compiled method call
helpers.
cpukit/libnetworking/rtems/rtems_glue.c | 15 +-
cpukit/posix/include/rtems/posix/barrierimpl.h | 7 +-
cpukit/posix/include/rtems/posix/condimpl.h | 15 +-
cpukit/posix/include/rtems/posix/mqueueimpl.h | 14 +-
cpukit/posix/include/rtems/posix/muteximpl.h | 4 +-
cpukit/posix/include/rtems/posix/posixapi.h | 8 +-
cpukit/posix/include/rtems/posix/rwlockimpl.h | 4 +-
cpukit/posix/include/rtems/posix/semaphoreimpl.h | 9 +-
cpukit/posix/src/conddestroy.c | 10 +-
cpukit/posix/src/condget.c | 6 +-
cpukit/posix/src/condsignalsupp.c | 11 +-
cpukit/posix/src/condwaitsupp.c | 21 +-
cpukit/posix/src/mqueueclose.c | 10 +-
cpukit/posix/src/mqueuedeletesupp.c | 10 +-
cpukit/posix/src/mqueuegetattr.c | 10 +-
cpukit/posix/src/mqueuenotify.c | 16 +-
cpukit/posix/src/mqueuerecvsupp.c | 14 +-
cpukit/posix/src/mqueuesendsupp.c | 13 +-
cpukit/posix/src/mqueuesetattr.c | 10 +-
cpukit/posix/src/mqueueunlink.c | 6 +-
cpukit/posix/src/mutexdestroy.c | 14 +-
cpukit/posix/src/mutexget.c | 6 +-
cpukit/posix/src/mutexgetprioceiling.c | 10 +-
cpukit/posix/src/mutexlocksupp.c | 10 +-
cpukit/posix/src/mutexsetprioceiling.c | 7 +-
cpukit/posix/src/mutexunlock.c | 14 +-
cpukit/posix/src/pbarrierdestroy.c | 10 +-
cpukit/posix/src/pbarrierwait.c | 7 +-
cpukit/posix/src/prwlockdestroy.c | 10 +-
cpukit/posix/src/prwlockinit.c | 6 +-
cpukit/posix/src/prwlockrdlock.c | 6 +-
cpukit/posix/src/prwlocktimedrdlock.c | 6 +-
cpukit/posix/src/prwlocktimedwrlock.c | 6 +-
cpukit/posix/src/prwlocktryrdlock.c | 6 +-
cpukit/posix/src/prwlocktrywrlock.c | 6 +-
cpukit/posix/src/prwlockunlock.c | 6 +-
cpukit/posix/src/prwlockwrlock.c | 6 +-
cpukit/posix/src/semaphoredeletesupp.c | 10 +-
cpukit/posix/src/semaphorewaitsupp.c | 6 +-
cpukit/posix/src/semclose.c | 8 +-
cpukit/posix/src/semdestroy.c | 10 +-
cpukit/posix/src/semgetvalue.c | 15 +-
cpukit/posix/src/sempost.c | 7 +-
cpukit/posix/src/semunlink.c | 8 +-
cpukit/rtems/include/rtems/rtems/barrierimpl.h | 7 +-
cpukit/rtems/include/rtems/rtems/messageimpl.h | 21 +-
cpukit/rtems/include/rtems/rtems/semimpl.h | 21 +-
cpukit/rtems/src/barrierdelete.c | 10 +-
cpukit/rtems/src/barrierrelease.c | 11 +-
cpukit/rtems/src/barrierwait.c | 11 +-
cpukit/rtems/src/msgmp.c | 12 +-
cpukit/rtems/src/msgqbroadcast.c | 11 +-
cpukit/rtems/src/msgqdelete.c | 13 +-
cpukit/rtems/src/msgqflush.c | 6 +-
cpukit/rtems/src/msgqgetnumberpending.c | 8 +-
cpukit/rtems/src/msgqreceive.c | 8 +-
cpukit/rtems/src/msgqsend.c | 13 +-
cpukit/rtems/src/msgqurgent.c | 13 +-
cpukit/rtems/src/semdelete.c | 30 +-
cpukit/rtems/src/semflush.c | 24 +-
cpukit/rtems/src/semobtain.c | 18 +-
cpukit/rtems/src/semrelease.c | 16 +-
cpukit/rtems/src/semsetpriority.c | 28 +-
cpukit/score/include/rtems/score/corebarrierimpl.h | 150 +++------
cpukit/score/include/rtems/score/coremsg.h | 2 +-
cpukit/score/include/rtems/score/coremsgimpl.h | 341 ++++++---------------
cpukit/score/include/rtems/score/coremuteximpl.h | 135 ++++----
cpukit/score/include/rtems/score/corerwlockimpl.h | 42 +--
cpukit/score/include/rtems/score/coresemimpl.h | 166 +++++-----
cpukit/score/include/rtems/score/mrspimpl.h | 97 +++---
cpukit/score/include/rtems/score/threadq.h | 12 +
cpukit/score/include/rtems/score/threadqimpl.h | 191 +++++-------
cpukit/score/src/apimutexlock.c | 9 +-
cpukit/score/src/apimutexunlock.c | 15 +-
cpukit/score/src/condition.c | 36 +--
cpukit/score/src/corebarrier.c | 6 +-
cpukit/score/src/corebarrierrelease.c | 10 +-
cpukit/score/src/corebarrierwait.c | 21 +-
cpukit/score/src/coremsgbroadcast.c | 18 +-
cpukit/score/src/coremsgclose.c | 16 +-
cpukit/score/src/coremsgflush.c | 6 +-
cpukit/score/src/coremsgseize.c | 14 +-
cpukit/score/src/coremsgsubmit.c | 26 +-
cpukit/score/src/coremutex.c | 12 +-
cpukit/score/src/coremutexsurrender.c | 27 +-
cpukit/score/src/corerwlockobtainread.c | 20 +-
cpukit/score/src/corerwlockobtainwrite.c | 18 +-
cpukit/score/src/corerwlockrelease.c | 19 +-
cpukit/score/src/coresem.c | 12 +-
cpukit/score/src/futex.c | 31 +-
cpukit/score/src/mpci.c | 19 +-
cpukit/score/src/mutex.c | 49 +--
cpukit/score/src/semaphore.c | 14 +-
cpukit/score/src/threadqenqueue.c | 51 +--
cpukit/score/src/threadqflush.c | 27 +-
cpukit/score/src/threadrestart.c | 31 +-
testsuites/sptests/spintrcritical22/init.c | 6 +-
testsuites/tmtests/tm26/task1.c | 11 +-
98 files changed, 1048 insertions(+), 1306 deletions(-)
diff --git a/cpukit/libnetworking/rtems/rtems_glue.c b/cpukit/libnetworking/rtems/rtems_glue.c
index 9ece2b1..edf551e 100644
--- a/cpukit/libnetworking/rtems/rtems_glue.c
+++ b/cpukit/libnetworking/rtems/rtems_glue.c
@@ -371,18 +371,19 @@ void
rtems_bsdnet_semaphore_obtain (void)
#ifdef RTEMS_FAST_MUTEX
- ISR_lock_Context lock_context;
+ Thread_queue_Context queue_context;
Thread_Control *executing;
- _ISR_lock_ISR_disable(&lock_context);
if (!the_networkSemaphore)
rtems_panic ("rtems-net: network sema obtain: network not initialised\n");
+ _Thread_queue_Context_initialize(&queue_context, NULL);
+ _ISR_lock_ISR_disable(&queue_context.Lock_context);
executing = _Thread_Executing;
_CORE_mutex_Seize (
&the_networkSemaphore->Core_control.mutex,
executing,
1, /* wait */
0, /* forever */
- &lock_context
+ &queue_context
if (executing->Wait.return_code)
rtems_panic ("rtems-net: can't obtain network sema: %d\n",
@@ -404,16 +405,16 @@ void
rtems_bsdnet_semaphore_release (void)
CORE_mutex_Status status;
status = _CORE_mutex_Surrender (
- NULL,
- &lock_context
+ &queue_context
if (status != CORE_MUTEX_STATUS_SUCCESSFUL)
rtems_panic ("rtems-net: can't release network sema: %i\n");
diff --git a/cpukit/posix/include/rtems/posix/barrierimpl.h b/cpukit/posix/include/rtems/posix/barrierimpl.h
index 5173531..e04f135 100644
--- a/cpukit/posix/include/rtems/posix/barrierimpl.h
+++ b/cpukit/posix/include/rtems/posix/barrierimpl.h
@@ -77,14 +77,15 @@ RTEMS_INLINE_ROUTINE void _POSIX_Barrier_Free (
_Objects_Free( &_POSIX_Barrier_Information, &the_barrier->Object );
-RTEMS_INLINE_ROUTINE POSIX_Barrier_Control *_POSIX_Barrier_Get (
+RTEMS_INLINE_ROUTINE POSIX_Barrier_Control *_POSIX_Barrier_Get(
const pthread_barrier_t *barrier,
- ISR_lock_Context *lock_context
+ Thread_queue_Context *queue_context
+ _Thread_queue_Context_initialize( queue_context, NULL );
return (POSIX_Barrier_Control *) _Objects_Get(
(Objects_Id) *barrier,
- lock_context,
+ &queue_context->Lock_context,
diff --git a/cpukit/posix/include/rtems/posix/condimpl.h b/cpukit/posix/include/rtems/posix/condimpl.h
index b178869..736f06b 100644
--- a/cpukit/posix/include/rtems/posix/condimpl.h
+++ b/cpukit/posix/include/rtems/posix/condimpl.h
@@ -63,18 +63,21 @@ RTEMS_INLINE_ROUTINE void _POSIX_Condition_variables_Destroy(
RTEMS_INLINE_ROUTINE void _POSIX_Condition_variables_Acquire_critical(
POSIX_Condition_variables_Control *the_cond,
- _Thread_queue_Acquire_critical( &the_cond->Wait_queue, lock_context );
+ _Thread_queue_Acquire_critical(
+ &the_cond->Wait_queue,
RTEMS_INLINE_ROUTINE void _POSIX_Condition_variables_Release(
- _Thread_queue_Release( &the_cond->Wait_queue, lock_context );
+ _Thread_queue_Release( &the_cond->Wait_queue, &queue_context->Lock_context );
@@ -107,8 +110,8 @@ RTEMS_INLINE_ROUTINE void _POSIX_Condition_variables_Free (
POSIX_Condition_variables_Control *_POSIX_Condition_variables_Get(
- pthread_cond_t *cond,
+ pthread_cond_t *cond,
diff --git a/cpukit/posix/include/rtems/posix/mqueueimpl.h b/cpukit/posix/include/rtems/posix/mqueueimpl.h
index 3185970..2317358 100644
--- a/cpukit/posix/include/rtems/posix/mqueueimpl.h
+++ b/cpukit/posix/include/rtems/posix/mqueueimpl.h
@@ -43,7 +43,7 @@ extern Objects_Information _POSIX_Message_queue_Information;
void _POSIX_Message_queue_Delete(
POSIX_Message_queue_Control *the_mq,
@@ -107,12 +107,16 @@ RTEMS_INLINE_ROUTINE void _POSIX_Message_queue_Free(
RTEMS_INLINE_ROUTINE POSIX_Message_queue_Control *_POSIX_Message_queue_Get(
- Objects_Id id,
+ Objects_Id id,
- return (POSIX_Message_queue_Control *)
- _Objects_Get( id, lock_context, &_POSIX_Message_queue_Information );
+ return (POSIX_Message_queue_Control *) _Objects_Get(
+ id,
+ &_POSIX_Message_queue_Information
diff --git a/cpukit/posix/include/rtems/posix/muteximpl.h b/cpukit/posix/include/rtems/posix/muteximpl.h
index 7627d3d..4c7852b 100644
--- a/cpukit/posix/include/rtems/posix/muteximpl.h
+++ b/cpukit/posix/include/rtems/posix/muteximpl.h
@@ -127,8 +127,8 @@ RTEMS_INLINE_ROUTINE int _POSIX_Mutex_Translate_core_mutex_return_code(
* @note: This version of the method uses an interrupt critical section.
POSIX_Mutex_Control *_POSIX_Mutex_Get(
- pthread_mutex_t *mutex,
+ pthread_mutex_t *mutex,
RTEMS_INLINE_ROUTINE POSIX_Mutex_Control *_POSIX_Mutex_Get_no_protection(
diff --git a/cpukit/posix/include/rtems/posix/posixapi.h b/cpukit/posix/include/rtems/posix/posixapi.h
index a16b6ad..a5afe92 100644
--- a/cpukit/posix/include/rtems/posix/posixapi.h
+++ b/cpukit/posix/include/rtems/posix/posixapi.h
@@ -71,7 +71,7 @@ RTEMS_INLINE_ROUTINE int _POSIX_Get_by_name_error(
#define _POSIX_Get_object_body( \
type, \
id, \
- lock_context, \
+ queue_context, \
info, \
initializer, \
init \
@@ -80,14 +80,16 @@ RTEMS_INLINE_ROUTINE int _POSIX_Get_by_name_error(
if ( id == NULL ) { \
return NULL; \
- the_object = _Objects_Get( (Objects_Id) *id, lock_context, info ); \
+ the_object = \
+ _Objects_Get( (Objects_Id) *id, &queue_context->Lock_context, info ); \
if ( the_object == NULL ) { \
_Once_Lock(); \
if ( *id == initializer ) { \
init( id, NULL ); \
_Once_Unlock(); \
+ the_object = \
return (type *) the_object
diff --git a/cpukit/posix/include/rtems/posix/rwlockimpl.h b/cpukit/posix/include/rtems/posix/rwlockimpl.h
index 6f3088e..4ab9395 100644
--- a/cpukit/posix/include/rtems/posix/rwlockimpl.h
+++ b/cpukit/posix/include/rtems/posix/rwlockimpl.h
@@ -87,8 +87,8 @@ RTEMS_INLINE_ROUTINE void _POSIX_RWLock_Free (
POSIX_RWLock_Control *_POSIX_RWLock_Get(
- pthread_rwlock_t *rwlock,
+ pthread_rwlock_t *rwlock,
#ifdef __cplusplus
diff --git a/cpukit/posix/include/rtems/posix/semaphoreimpl.h b/cpukit/posix/include/rtems/posix/semaphoreimpl.h
index 402329a..10d7cee 100644
--- a/cpukit/posix/include/rtems/posix/semaphoreimpl.h
+++ b/cpukit/posix/include/rtems/posix/semaphoreimpl.h
@@ -61,13 +61,14 @@ RTEMS_INLINE_ROUTINE void _POSIX_Semaphore_Free (
RTEMS_INLINE_ROUTINE POSIX_Semaphore_Control *_POSIX_Semaphore_Get(
- const sem_t *id,
+ const sem_t *id,
return (POSIX_Semaphore_Control *) _Objects_Get(
(Objects_Id) *id,
- lock_context,
&_POSIX_Semaphore_Information
@@ -93,7 +94,7 @@ int _POSIX_Semaphore_Create_support(
void _POSIX_Semaphore_Delete(
POSIX_Semaphore_Control *the_semaphore,
diff --git a/cpukit/posix/src/conddestroy.c b/cpukit/posix/src/conddestroy.c
index d47c6b2..a2c8dc1 100644
--- a/cpukit/posix/src/conddestroy.c
+++ b/cpukit/posix/src/conddestroy.c
@@ -29,20 +29,20 @@ int pthread_cond_destroy(
POSIX_Condition_variables_Control *the_cond;
_Objects_Allocator_lock();
- the_cond = _POSIX_Condition_variables_Get( cond, &lock_context );
+ the_cond = _POSIX_Condition_variables_Get( cond, &queue_context );
if ( the_cond == NULL ) {
_Objects_Allocator_unlock();
return EINVAL;
- _POSIX_Condition_variables_Acquire_critical( the_cond, &lock_context );
+ _POSIX_Condition_variables_Acquire_critical( the_cond, &queue_context );
if ( !_Thread_queue_Is_empty( &the_cond->Wait_queue.Queue ) ) {
- _POSIX_Condition_variables_Release( the_cond, &lock_context );
+ _POSIX_Condition_variables_Release( the_cond, &queue_context );
return EBUSY;
@@ -51,7 +51,7 @@ int pthread_cond_destroy(
&_POSIX_Condition_variables_Information,
&the_cond->Object
_POSIX_Condition_variables_Destroy( the_cond );
_POSIX_Condition_variables_Free( the_cond );
diff --git a/cpukit/posix/src/condget.c b/cpukit/posix/src/condget.c
index 5676de8..5b086ef 100644
--- a/cpukit/posix/src/condget.c
+++ b/cpukit/posix/src/condget.c
@@ -15,14 +15,14 @@
#include <rtems/posix/posixapi.h>
POSIX_Condition_variables_Control,
cond,
- lock_context,
+ queue_context,
PTHREAD_COND_INITIALIZER,
pthread_cond_init
diff --git a/cpukit/posix/src/condsignalsupp.c b/cpukit/posix/src/condsignalsupp.c
index 38aa053..e42476e 100644
--- a/cpukit/posix/src/condsignalsupp.c
+++ b/cpukit/posix/src/condsignalsupp.c
@@ -36,15 +36,15 @@ int _POSIX_Condition_variables_Signal_support(
do {
return EINVAL;
the_thread = _Thread_queue_First_locked(
@@ -56,12 +56,11 @@ int _POSIX_Condition_variables_Signal_support(
&the_cond->Wait_queue.Queue,
POSIX_CONDITION_VARIABLES_TQ_OPERATIONS,
the_thread,
- NULL,
- &lock_context
+ &queue_context
} else {
the_cond->mutex = POSIX_CONDITION_VARIABLES_NO_MUTEX;
} while ( is_broadcast && the_thread != NULL );
diff --git a/cpukit/posix/src/condwaitsupp.c b/cpukit/posix/src/condwaitsupp.c
index 11b0587..4e89ef0 100644
--- a/cpukit/posix/src/condwaitsupp.c
+++ b/cpukit/posix/src/condwaitsupp.c
@@ -35,7 +35,7 @@ int _POSIX_Condition_variables_Wait_support(
POSIX_Mutex_Control *the_mutex;
int status;
int mutex_status;
CORE_mutex_Status core_mutex_status;
@@ -46,25 +46,25 @@ int _POSIX_Condition_variables_Wait_support(
return EINVAL;
return EINVAL;
if (
the_cond->mutex != POSIX_CONDITION_VARIABLES_NO_MUTEX
&& the_cond->mutex != *mutex
return EINVAL;
the_cond->mutex = *mutex;
- cpu_self = _Thread_Dispatch_disable_critical( &lock_context );
+ cpu_self = _Thread_Dispatch_disable_critical( &queue_context.Lock_context );
executing = _Per_CPU_Get_executing( cpu_self );
@@ -78,7 +78,7 @@ int _POSIX_Condition_variables_Wait_support(
the_mutex == NULL
|| !_CORE_mutex_Is_owner( &the_mutex->Mutex, executing )
_Thread_Dispatch_enable( cpu_self );
return EPERM;
@@ -92,18 +92,17 @@ int _POSIX_Condition_variables_Wait_support(
STATES_WAITING_FOR_CONDITION_VARIABLE,
timeout,
ETIMEDOUT,
- &lock_context
+ &queue_context.Lock_context
} else {
executing->Wait.return_code = ETIMEDOUT;
- _ISR_lock_ISR_disable( &lock_context );
+ _ISR_lock_ISR_disable( &queue_context.Lock_context );
core_mutex_status = _CORE_mutex_Surrender(
&the_mutex->Mutex,
- NULL,
- &lock_context
+ &queue_context
_Assert( core_mutex_status == CORE_MUTEX_STATUS_SUCCESSFUL );
(void) core_mutex_status;
diff --git a/cpukit/posix/src/mqueueclose.c b/cpukit/posix/src/mqueueclose.c
index 28a7d16..60d3ce3 100644
--- a/cpukit/posix/src/mqueueclose.c
+++ b/cpukit/posix/src/mqueueclose.c
@@ -42,10 +42,10 @@ int mq_close(
POSIX_Message_queue_Control *the_mq;
- the_mq = _POSIX_Message_queue_Get( mqdes, &lock_context );
+ the_mq = _POSIX_Message_queue_Get( mqdes, &queue_context );
if ( the_mq == NULL ) {
@@ -54,17 +54,17 @@ int mq_close(
_CORE_message_queue_Acquire_critical(
&the_mq->Message_queue,
- &lock_context
+ &queue_context
if ( the_mq->open_count == 0 ) {
- _CORE_message_queue_Release( &the_mq->Message_queue, &lock_context );
+ _CORE_message_queue_Release( &the_mq->Message_queue, &queue_context );
rtems_set_errno_and_return_minus_one( EBADF );
the_mq->open_count -= 1;
- _POSIX_Message_queue_Delete( the_mq, &lock_context );
+ _POSIX_Message_queue_Delete( the_mq, &queue_context );
return 0;
diff --git a/cpukit/posix/src/mqueuedeletesupp.c b/cpukit/posix/src/mqueuedeletesupp.c
index 485136c..850707a 100644
--- a/cpukit/posix/src/mqueuedeletesupp.c
+++ b/cpukit/posix/src/mqueuedeletesupp.c
@@ -22,17 +22,13 @@
if ( !the_mq->linked && the_mq->open_count == 0 ) {
- _CORE_message_queue_Close(
- &the_mq->Message_queue,
- NULL, /* no MP support */
- lock_context
+ _CORE_message_queue_Close( &the_mq->Message_queue, queue_context );
_POSIX_Message_queue_Free( the_mq );
} else {
- _CORE_message_queue_Release( &the_mq->Message_queue, lock_context );
+ _CORE_message_queue_Release( &the_mq->Message_queue, queue_context );
diff --git a/cpukit/posix/src/mqueuegetattr.c b/cpukit/posix/src/mqueuegetattr.c
index dae14e3..5efcc0b 100644
--- a/cpukit/posix/src/mqueuegetattr.c
+++ b/cpukit/posix/src/mqueuegetattr.c
@@ -42,13 +42,13 @@ int mq_getattr(
if ( mqstat == NULL ) {
rtems_set_errno_and_return_minus_one( EINVAL );
@@ -56,11 +56,11 @@ int mq_getattr(
- &lock_context
+ &queue_context
@@ -72,6 +72,6 @@ int mq_getattr(
mqstat->mq_maxmsg = the_mq->Message_queue.maximum_pending_messages;
mqstat->mq_curmsgs = the_mq->Message_queue.number_of_pending_messages;
return 0;
diff --git a/cpukit/posix/src/mqueuenotify.c b/cpukit/posix/src/mqueuenotify.c
index adcfdcb..a1f9a08 100644
--- a/cpukit/posix/src/mqueuenotify.c
+++ b/cpukit/posix/src/mqueuenotify.c
@@ -24,7 +24,7 @@
static void _POSIX_Message_queue_Notify_handler(
CORE_message_queue_Control *the_message_queue,
@@ -38,7 +38,7 @@ static void _POSIX_Message_queue_Notify_handler(
signo = the_mq->notification.sigev_signo;
_CORE_message_queue_Set_notify( &the_mq->Message_queue, NULL );
kill( getpid(), signo );
@@ -49,9 +49,9 @@ int mq_notify(
@@ -59,17 +59,17 @@ int mq_notify(
- &lock_context
+ &queue_context
if ( notification != NULL ) {
if ( _CORE_message_queue_Is_notify_enabled( &the_mq->Message_queue ) ) {
rtems_set_errno_and_return_minus_one( EBUSY );
@@ -83,6 +83,6 @@ int mq_notify(
return 0;
diff --git a/cpukit/posix/src/mqueuerecvsupp.c b/cpukit/posix/src/mqueuerecvsupp.c
index b5a790a..541786a 100644
--- a/cpukit/posix/src/mqueuerecvsupp.c
+++ b/cpukit/posix/src/mqueuerecvsupp.c
@@ -44,24 +44,24 @@ ssize_t _POSIX_Message_queue_Receive_support(
size_t length_out;
bool do_wait;
if ( ( the_mq->oflag & O_ACCMODE ) == O_WRONLY ) {
- _ISR_lock_ISR_enable( &lock_context );
+ _ISR_lock_ISR_enable( &queue_context.Lock_context );
if ( msg_len < the_mq->Message_queue.maximum_message_size ) {
rtems_set_errno_and_return_minus_one( EMSGSIZE );
@@ -83,11 +83,11 @@ ssize_t _POSIX_Message_queue_Receive_support(
- &lock_context
+ &queue_context
@@ -102,7 +102,7 @@ ssize_t _POSIX_Message_queue_Receive_support(
&length_out,
do_wait,
timeout,
- &lock_context
+ &queue_context
if ( msg_prio != NULL ) {
diff --git a/cpukit/posix/src/mqueuesendsupp.c b/cpukit/posix/src/mqueuesendsupp.c
index 1053df9..e9848c2 100644
--- a/cpukit/posix/src/mqueuesendsupp.c
+++ b/cpukit/posix/src/mqueuesendsupp.c
@@ -44,7 +44,7 @@ int _POSIX_Message_queue_Send_support(
CORE_message_queue_Status msg_status;
bool do_wait;
@@ -58,14 +58,14 @@ int _POSIX_Message_queue_Send_support(
if ( ( the_mq->oflag & O_ACCMODE ) == O_RDONLY ) {
@@ -80,11 +80,11 @@ int _POSIX_Message_queue_Send_support(
- &lock_context
+ &queue_context
@@ -97,11 +97,10 @@ int _POSIX_Message_queue_Send_support(
executing,
msg_ptr,
msg_len,
- NULL,
_POSIX_Message_queue_Priority_to_core( msg_prio ),
do_wait,
timeout,
- &lock_context
+ &queue_context
diff --git a/cpukit/posix/src/mqueuesetattr.c b/cpukit/posix/src/mqueuesetattr.c
index dfd9bab..fc9fc75 100644
--- a/cpukit/posix/src/mqueuesetattr.c
+++ b/cpukit/posix/src/mqueuesetattr.c
@@ -27,13 +27,13 @@ int mq_setattr(
@@ -41,11 +41,11 @@ int mq_setattr(
- &lock_context
+ &queue_context
@@ -62,6 +62,6 @@ int mq_setattr(
the_mq->oflag = mqstat->mq_flags;
return 0;
diff --git a/cpukit/posix/src/mqueueunlink.c b/cpukit/posix/src/mqueueunlink.c
index dc485ba..812f249 100644
--- a/cpukit/posix/src/mqueueunlink.c
+++ b/cpukit/posix/src/mqueueunlink.c
@@ -30,7 +30,7 @@ int mq_unlink(
Objects_Get_by_name_error error;
@@ -42,10 +42,10 @@ int mq_unlink(
_POSIX_Message_queue_Namespace_remove( the_mq );
- _CORE_message_queue_Acquire( &the_mq->Message_queue, &lock_context );
+ _CORE_message_queue_Acquire( &the_mq->Message_queue, &queue_context );
the_mq->linked = false;
return 0;
diff --git a/cpukit/posix/src/mutexdestroy.c b/cpukit/posix/src/mutexdestroy.c
index 640acc0..7fda7d3 100644
--- a/cpukit/posix/src/mutexdestroy.c
+++ b/cpukit/posix/src/mutexdestroy.c
@@ -28,16 +28,16 @@ int pthread_mutex_destroy(
- POSIX_Mutex_Control *the_mutex;
- int eno;
+ POSIX_Mutex_Control *the_mutex;
+ int eno;
- the_mutex = _POSIX_Mutex_Get( mutex, &lock_context );
+ the_mutex = _POSIX_Mutex_Get( mutex, &queue_context );
if ( the_mutex != NULL ) {
- _CORE_mutex_Acquire_critical( &the_mutex->Mutex, &lock_context );
+ _CORE_mutex_Acquire_critical( &the_mutex->Mutex, &queue_context );
* XXX: There is an error for the mutex being locked
@@ -46,12 +46,12 @@ int pthread_mutex_destroy(
if ( !_CORE_mutex_Is_locked( &the_mutex->Mutex ) ) {
_Objects_Close( &_POSIX_Mutex_Information, &the_mutex->Object );
- _CORE_mutex_Release( &the_mutex->Mutex, &lock_context );
+ _CORE_mutex_Release( &the_mutex->Mutex, &queue_context );
_CORE_mutex_Destroy( &the_mutex->Mutex );
_POSIX_Mutex_Free( the_mutex );
eno = 0;
} else {
eno = EBUSY;
} else {
diff --git a/cpukit/posix/src/mutexget.c b/cpukit/posix/src/mutexget.c
index f8f0033..e90c41c 100644
--- a/cpukit/posix/src/mutexget.c
+++ b/cpukit/posix/src/mutexget.c
@@ -22,14 +22,14 @@
POSIX_Mutex_Control,
mutex,
- lock_context,
+ queue_context,
PTHREAD_MUTEX_INITIALIZER,
pthread_mutex_init
diff --git a/cpukit/posix/src/mutexgetprioceiling.c b/cpukit/posix/src/mutexgetprioceiling.c
index 232b2e2..268457a 100644
--- a/cpukit/posix/src/mutexgetprioceiling.c
+++ b/cpukit/posix/src/mutexgetprioceiling.c
@@ -30,26 +30,26 @@ int pthread_mutex_getprioceiling(
int *prioceiling
if ( prioceiling == NULL ) {
return EINVAL;
if ( the_mutex == NULL ) {
return EINVAL;
*prioceiling = _POSIX_Priority_From_core(
the_mutex->Mutex.Attributes.priority_ceiling
return 0;
diff --git a/cpukit/posix/src/mutexlocksupp.c b/cpukit/posix/src/mutexlocksupp.c
index 0c70cf0..f17269b 100644
--- a/cpukit/posix/src/mutexlocksupp.c
+++ b/cpukit/posix/src/mutexlocksupp.c
@@ -28,11 +28,11 @@ int _POSIX_Mutex_Lock_support(
Watchdog_Interval timeout
- Thread_Control *executing;
+ Thread_Control *executing;
return EINVAL;
@@ -44,7 +44,7 @@ int _POSIX_Mutex_Lock_support(
executing,
blocking,
timeout,
- &lock_context
+ &queue_context
return _POSIX_Mutex_Translate_core_mutex_return_code(
(CORE_mutex_Status) executing->Wait.return_code
diff --git a/cpukit/posix/src/mutexsetprioceiling.c b/cpukit/posix/src/mutexsetprioceiling.c
index f29c0ad..09554f8 100644
--- a/cpukit/posix/src/mutexsetprioceiling.c
+++ b/cpukit/posix/src/mutexsetprioceiling.c
@@ -33,7 +33,7 @@ int pthread_mutex_setprioceiling(
register POSIX_Mutex_Control *the_mutex;
Priority_Control the_priority;
if ( !old_ceiling )
return EINVAL;
@@ -57,7 +57,7 @@ int pthread_mutex_setprioceiling(
* NOTE: This makes it easier to get 100% binary coverage since the
* bad Id case is handled by the switch.
return EINVAL;
@@ -73,8 +73,7 @@ int pthread_mutex_setprioceiling(
&the_mutex->Mutex,
- NULL,
- &lock_context
+ &queue_context
return 0;
diff --git a/cpukit/posix/src/mutexunlock.c b/cpukit/posix/src/mutexunlock.c
index 94fcc63..ff7fc1c 100644
--- a/cpukit/posix/src/mutexunlock.c
+++ b/cpukit/posix/src/mutexunlock.c
@@ -30,20 +30,16 @@ int pthread_mutex_unlock(
- CORE_mutex_Status status;
+ CORE_mutex_Status status;
return EINVAL;
- status = _CORE_mutex_Surrender(
- &the_mutex->Mutex,
- NULL,
- &lock_context
+ status = _CORE_mutex_Surrender( &the_mutex->Mutex, &queue_context );
return _POSIX_Mutex_Translate_core_mutex_return_code( status );
diff --git a/cpukit/posix/src/pbarrierdestroy.c b/cpukit/posix/src/pbarrierdestroy.c
index 709644b..8f85762 100644
--- a/cpukit/posix/src/pbarrierdestroy.c
+++ b/cpukit/posix/src/pbarrierdestroy.c
@@ -36,30 +36,30 @@ int pthread_barrier_destroy(
POSIX_Barrier_Control *the_barrier;
if ( barrier == NULL ) {
return EINVAL;
- the_barrier = _POSIX_Barrier_Get( barrier, &lock_context );
+ the_barrier = _POSIX_Barrier_Get( barrier, &queue_context );
if ( the_barrier == NULL ) {
return EINVAL;
- _CORE_barrier_Acquire_critical( &the_barrier->Barrier, &lock_context );
+ _CORE_barrier_Acquire_critical( &the_barrier->Barrier, &queue_context );
if ( the_barrier->Barrier.number_of_waiting_threads != 0 ) {
- _CORE_barrier_Release( &the_barrier->Barrier, &lock_context );
+ _CORE_barrier_Release( &the_barrier->Barrier, &queue_context );
return EBUSY;
_Objects_Close( &_POSIX_Barrier_Information, &the_barrier->Object );
_POSIX_Barrier_Free( the_barrier );
return 0;
diff --git a/cpukit/posix/src/pbarrierwait.c b/cpukit/posix/src/pbarrierwait.c
index adfd40d..522c18e 100644
--- a/cpukit/posix/src/pbarrierwait.c
+++ b/cpukit/posix/src/pbarrierwait.c
@@ -37,14 +37,14 @@ int pthread_barrier_wait(
return EINVAL;
return EINVAL;
@@ -56,8 +56,7 @@ int pthread_barrier_wait(
executing,
true,
0,
- NULL,
- &lock_context
+ &queue_context
return _POSIX_Barrier_Translate_core_barrier_return_code(
diff --git a/cpukit/posix/src/prwlockdestroy.c b/cpukit/posix/src/prwlockdestroy.c
index 6f9eec8..0ced556 100644
--- a/cpukit/posix/src/prwlockdestroy.c
+++ b/cpukit/posix/src/prwlockdestroy.c
@@ -24,24 +24,24 @@ int pthread_rwlock_destroy(
POSIX_RWLock_Control *the_rwlock;
- the_rwlock = _POSIX_RWLock_Get( rwlock, &lock_context );
+ the_rwlock = _POSIX_RWLock_Get( rwlock, &queue_context );
if ( the_rwlock == NULL ) {
return EINVAL;
- _CORE_RWLock_Acquire_critical( &the_rwlock->RWLock, &lock_context );
+ _CORE_RWLock_Acquire_critical( &the_rwlock->RWLock, &queue_context );
* If there is at least one thread waiting, then do not delete it.
if ( !_Thread_queue_Is_empty( &the_rwlock->RWLock.Wait_queue.Queue ) ) {
- _CORE_RWLock_Release( &the_rwlock->RWLock, &lock_context );
+ _CORE_RWLock_Release( &the_rwlock->RWLock, &queue_context );
return EBUSY;
@@ -51,7 +51,7 @@ int pthread_rwlock_destroy(
_Objects_Close( &_POSIX_RWLock_Information, &the_rwlock->Object );
_POSIX_RWLock_Free( the_rwlock );
return 0;
diff --git a/cpukit/posix/src/prwlockinit.c b/cpukit/posix/src/prwlockinit.c
index fcf4e29..34ab1ae 100644
--- a/cpukit/posix/src/prwlockinit.c
+++ b/cpukit/posix/src/prwlockinit.c
@@ -24,14 +24,14 @@
POSIX_RWLock_Control,
rwlock,
- lock_context,
+ queue_context,
PTHREAD_RWLOCK_INITIALIZER,
pthread_rwlock_init
diff --git a/cpukit/posix/src/prwlockrdlock.c b/cpukit/posix/src/prwlockrdlock.c
index 3459399..e59aaf9 100644
--- a/cpukit/posix/src/prwlockrdlock.c
+++ b/cpukit/posix/src/prwlockrdlock.c
@@ -25,10 +25,10 @@ int pthread_rwlock_rdlock(
return EINVAL;
@@ -40,7 +40,7 @@ int pthread_rwlock_rdlock(
executing,
true, /* we are willing to wait forever */
0,
- &lock_context
+ &queue_context
return _POSIX_RWLock_Translate_core_RWLock_return_code(
(CORE_RWLock_Status) executing->Wait.return_code
diff --git a/cpukit/posix/src/prwlocktimedrdlock.c b/cpukit/posix/src/prwlocktimedrdlock.c
index 829e169..9e84943 100644
--- a/cpukit/posix/src/prwlocktimedrdlock.c
+++ b/cpukit/posix/src/prwlocktimedrdlock.c
@@ -27,7 +27,7 @@ int pthread_rwlock_timedrdlock(
Watchdog_Interval ticks;
bool do_wait;
TOD_Absolute_timeout_conversion_results status;
@@ -49,7 +49,7 @@ int pthread_rwlock_timedrdlock(
status = _TOD_Absolute_timeout_to_ticks( abstime, &ticks );
do_wait = ( status == TOD_ABSOLUTE_TIMEOUT_IS_IN_FUTURE );
return EINVAL;
@@ -61,7 +61,7 @@ int pthread_rwlock_timedrdlock(
executing,
do_wait,
ticks,
- &lock_context
+ &queue_context
if (
diff --git a/cpukit/posix/src/prwlocktimedwrlock.c b/cpukit/posix/src/prwlocktimedwrlock.c
index 1258c2b..6be8397 100644
--- a/cpukit/posix/src/prwlocktimedwrlock.c
+++ b/cpukit/posix/src/prwlocktimedwrlock.c
@@ -29,7 +29,7 @@ int pthread_rwlock_timedwrlock(
bool do_wait;
@@ -51,7 +51,7 @@ int pthread_rwlock_timedwrlock(
return EINVAL;
@@ -63,7 +63,7 @@ int pthread_rwlock_timedwrlock(
executing,
do_wait,
ticks,
- &lock_context
+ &queue_context
if (
diff --git a/cpukit/posix/src/prwlocktryrdlock.c b/cpukit/posix/src/prwlocktryrdlock.c
index a73d122..1a7cf9e 100644
--- a/cpukit/posix/src/prwlocktryrdlock.c
+++ b/cpukit/posix/src/prwlocktryrdlock.c
@@ -25,10 +25,10 @@ int pthread_rwlock_tryrdlock(
return EINVAL;
@@ -40,7 +40,7 @@ int pthread_rwlock_tryrdlock(
executing,
false, /* do not wait for the rwlock */
0,
- &lock_context
+ &queue_context
diff --git a/cpukit/posix/src/prwlocktrywrlock.c b/cpukit/posix/src/prwlocktrywrlock.c
index a44a54f..b6031f9 100644
--- a/cpukit/posix/src/prwlocktrywrlock.c
+++ b/cpukit/posix/src/prwlocktrywrlock.c
@@ -25,10 +25,10 @@ int pthread_rwlock_trywrlock(
return EINVAL;
@@ -40,7 +40,7 @@ int pthread_rwlock_trywrlock(
executing,
false, /* we are not willing to wait */
0,
- &lock_context
+ &queue_context
diff --git a/cpukit/posix/src/prwlockunlock.c b/cpukit/posix/src/prwlockunlock.c
index bf6b4de..dd4337d 100644
--- a/cpukit/posix/src/prwlockunlock.c
+++ b/cpukit/posix/src/prwlockunlock.c
@@ -27,15 +27,15 @@ int pthread_rwlock_unlock(
CORE_RWLock_Status status;
return EINVAL;
- status = _CORE_RWLock_Surrender( &the_rwlock->RWLock, &lock_context );
+ status = _CORE_RWLock_Surrender( &the_rwlock->RWLock, &queue_context );
return _POSIX_RWLock_Translate_core_RWLock_return_code( status );
diff --git a/cpukit/posix/src/prwlockwrlock.c b/cpukit/posix/src/prwlockwrlock.c
index 5683163..84a4e0f 100644
--- a/cpukit/posix/src/prwlockwrlock.c
+++ b/cpukit/posix/src/prwlockwrlock.c
@@ -32,10 +32,10 @@ int pthread_rwlock_wrlock(
return EINVAL;
@@ -47,7 +47,7 @@ int pthread_rwlock_wrlock(
executing,
true, /* do not timeout -- wait forever */
0,
- &lock_context
+ &queue_context
diff --git a/cpukit/posix/src/semaphoredeletesupp.c b/cpukit/posix/src/semaphoredeletesupp.c
index c205b12..2d39b2a 100644
--- a/cpukit/posix/src/semaphoredeletesupp.c
+++ b/cpukit/posix/src/semaphoredeletesupp.c
@@ -22,18 +22,14 @@
if ( !the_semaphore->linked && !the_semaphore->open_count ) {
_Objects_Close( &_POSIX_Semaphore_Information, &the_semaphore->Object );
- _CORE_semaphore_Destroy(
- &the_semaphore->Semaphore,
- NULL,
- lock_context
+ _CORE_semaphore_Destroy( &the_semaphore->Semaphore, queue_context );
_POSIX_Semaphore_Free( the_semaphore );
} else {
- _CORE_semaphore_Release( &the_semaphore->Semaphore, lock_context );
+ _CORE_semaphore_Release( &the_semaphore->Semaphore, queue_context );
diff --git a/cpukit/posix/src/semaphorewaitsupp.c b/cpukit/posix/src/semaphorewaitsupp.c
index f08efa8..9382107 100644
--- a/cpukit/posix/src/semaphorewaitsupp.c
+++ b/cpukit/posix/src/semaphorewaitsupp.c
@@ -32,9 +32,9 @@ int _POSIX_Semaphore_Wait_support(
POSIX_Semaphore_Control *the_semaphore;
- the_semaphore = _POSIX_Semaphore_Get( sem, &lock_context );
+ the_semaphore = _POSIX_Semaphore_Get( sem, &queue_context );
if ( the_semaphore == NULL ) {
@@ -47,7 +47,7 @@ int _POSIX_Semaphore_Wait_support(
executing,
blocking,
timeout,
- &lock_context
+ &queue_context
if ( executing->Wait.return_code == CORE_SEMAPHORE_STATUS_SUCCESSFUL ) {
diff --git a/cpukit/posix/src/semclose.c b/cpukit/posix/src/semclose.c
index 3f18ff1..ebcf7a2 100644
--- a/cpukit/posix/src/semclose.c
+++ b/cpukit/posix/src/semclose.c
@@ -27,10 +27,10 @@ int sem_close(
@@ -39,10 +39,10 @@ int sem_close(
_CORE_semaphore_Acquire_critical(
- &lock_context
+ &queue_context
the_semaphore->open_count -= 1;
- _POSIX_Semaphore_Delete( the_semaphore, &lock_context );
+ _POSIX_Semaphore_Delete( the_semaphore, &queue_context );
return 0;
diff --git a/cpukit/posix/src/semdestroy.c b/cpukit/posix/src/semdestroy.c
index 5264472..8b81470 100644
--- a/cpukit/posix/src/semdestroy.c
+++ b/cpukit/posix/src/semdestroy.c
@@ -27,10 +27,10 @@ int sem_destroy(
@@ -39,17 +39,17 @@ int sem_destroy(
- &lock_context
+ &queue_context
if ( the_semaphore->named ) {
/* Undefined operation on a named semaphore */
- _CORE_semaphore_Release( &the_semaphore->Semaphore, &lock_context );
+ _CORE_semaphore_Release( &the_semaphore->Semaphore, &queue_context );
return 0;
diff --git a/cpukit/posix/src/semgetvalue.c b/cpukit/posix/src/semgetvalue.c
index 63e3823..1b75294 100644
--- a/cpukit/posix/src/semgetvalue.c
+++ b/cpukit/posix/src/semgetvalue.c
@@ -28,20 +28,21 @@ int sem_getvalue(
- * Assume a relaxed atomic load of the value on SMP configurations.
- * Thus, there is no need to acquire a lock.
+ _CORE_semaphore_Acquire_critical(
+ &the_semaphore->Semaphore,
+ &queue_context
*sval = _CORE_semaphore_Get_count( &the_semaphore->Semaphore );
return 0;
diff --git a/cpukit/posix/src/sempost.c b/cpukit/posix/src/sempost.c
index 313ff3c..86d2f5a 100644
--- a/cpukit/posix/src/sempost.c
+++ b/cpukit/posix/src/sempost.c
@@ -27,9 +27,9 @@ int sem_post(
@@ -37,8 +37,7 @@ int sem_post(
_CORE_semaphore_Surrender(
- NULL,
- &lock_context
+ &queue_context
return 0;
diff --git a/cpukit/posix/src/semunlink.c b/cpukit/posix/src/semunlink.c
index 665aa73..6ba1df1 100644
--- a/cpukit/posix/src/semunlink.c
+++ b/cpukit/posix/src/semunlink.c
@@ -28,7 +28,7 @@ int sem_unlink(
@@ -40,10 +40,10 @@ int sem_unlink(
_POSIX_Semaphore_Namespace_remove( the_semaphore );
- _CORE_semaphore_Acquire_critical( &the_semaphore->Semaphore, &lock_context );
+ _CORE_semaphore_Acquire_critical( &the_semaphore->Semaphore, &queue_context );
the_semaphore->linked = false;
return 0;
diff --git a/cpukit/rtems/include/rtems/rtems/barrierimpl.h b/cpukit/rtems/include/rtems/rtems/barrierimpl.h
index 39632fc..0eaadfc 100644
--- a/cpukit/rtems/include/rtems/rtems/barrierimpl.h
+++ b/cpukit/rtems/include/rtems/rtems/barrierimpl.h
@@ -70,12 +70,13 @@ RTEMS_INLINE_ROUTINE void _Barrier_Free (
RTEMS_INLINE_ROUTINE Barrier_Control *_Barrier_Get(
- Objects_Id id,
+ Objects_Id id,
return (Barrier_Control *)
- _Objects_Get( id, lock_context, &_Barrier_Information );
+ _Objects_Get( id, &queue_context->Lock_context, &_Barrier_Information );
diff --git a/cpukit/rtems/include/rtems/rtems/messageimpl.h b/cpukit/rtems/include/rtems/rtems/messageimpl.h
index 199af1c..d6217f1 100644
--- a/cpukit/rtems/include/rtems/rtems/messageimpl.h
+++ b/cpukit/rtems/include/rtems/rtems/messageimpl.h
@@ -101,18 +101,31 @@ RTEMS_INLINE_ROUTINE void _Message_queue_Free (
_Objects_Free( &_Message_queue_Information, &the_message_queue->Object );
-RTEMS_INLINE_ROUTINE Message_queue_Control * _Message_queue_Get(
- Objects_Id id,
+RTEMS_INLINE_ROUTINE Message_queue_Control *_Message_queue_Do_get(
+ Objects_Id id,
+#if defined(RTEMS_MULTIPROCESSING)
+ Thread_queue_MP_callout mp_callout
+#endif
+ _Thread_queue_Context_initialize( queue_context, mp_callout );
return (Message_queue_Control *) _Objects_Get(
id,
- lock_context,
+ #define _Message_queue_Get( id, queue_context, mp_callout ) \
+ _Message_queue_Do_get( id, queue_context, mp_callout )
+#else
+ _Message_queue_Do_get( id, queue_context )
+#endif
RTEMS_INLINE_ROUTINE Message_queue_Control *_Message_queue_Allocate( void )
diff --git a/cpukit/rtems/include/rtems/rtems/semimpl.h b/cpukit/rtems/include/rtems/rtems/semimpl.h
index ac55bc7..c23bef9 100644
--- a/cpukit/rtems/include/rtems/rtems/semimpl.h
+++ b/cpukit/rtems/include/rtems/rtems/semimpl.h
@@ -134,18 +134,31 @@ RTEMS_INLINE_ROUTINE void _Semaphore_Free (
_Objects_Free( &_Semaphore_Information, &the_semaphore->Object );
-RTEMS_INLINE_ROUTINE Semaphore_Control *_Semaphore_Get(
- Objects_Id id,
+RTEMS_INLINE_ROUTINE Semaphore_Control *_Semaphore_Do_get(
+ Objects_Id id,
+#endif
return (Semaphore_Control *) _Objects_Get(
id,
- lock_context,
+ #define _Semaphore_Get( id, queue_context, mp_callout ) \
+ _Semaphore_Do_get( id, queue_context, mp_callout )
+#else
+ _Semaphore_Do_get( id, queue_context )
+#endif
#ifdef __cplusplus
#endif
diff --git a/cpukit/rtems/src/barrierdelete.c b/cpukit/rtems/src/barrierdelete.c
index 05d6a3f..3d57908 100644
--- a/cpukit/rtems/src/barrierdelete.c
+++ b/cpukit/rtems/src/barrierdelete.c
@@ -24,20 +24,20 @@ rtems_status_code rtems_barrier_delete(
rtems_id id
- Barrier_Control *the_barrier;
+ Barrier_Control *the_barrier;
- the_barrier = _Barrier_Get( id, &lock_context );
+ the_barrier = _Barrier_Get( id, &queue_context );
return RTEMS_INVALID_ID;
_Objects_Close( &_Barrier_Information, &the_barrier->Object );
- _CORE_barrier_Flush( &the_barrier->Barrier, NULL, &lock_context );
+ _CORE_barrier_Flush( &the_barrier->Barrier, &queue_context );
return RTEMS_SUCCESSFUL;
diff --git a/cpukit/rtems/src/barrierrelease.c b/cpukit/rtems/src/barrierrelease.c
index 2c7d222..2c7f72d 100644
--- a/cpukit/rtems/src/barrierrelease.c
+++ b/cpukit/rtems/src/barrierrelease.c
@@ -25,24 +25,23 @@ rtems_status_code rtems_barrier_release(
uint32_t *released
if ( released == NULL ) {
return RTEMS_INVALID_ADDRESS;
*released = _CORE_barrier_Surrender(
- NULL,
- &lock_context
+ &queue_context
diff --git a/cpukit/rtems/src/barrierwait.c b/cpukit/rtems/src/barrierwait.c
index 7f463aa..6e13375 100644
--- a/cpukit/rtems/src/barrierwait.c
+++ b/cpukit/rtems/src/barrierwait.c
@@ -27,11 +27,11 @@ rtems_status_code rtems_barrier_wait(
rtems_interval timeout
@@ -43,8 +43,7 @@ rtems_status_code rtems_barrier_wait(
executing,
true,
timeout,
- NULL,
- &lock_context
+ &queue_context
return _Barrier_Translate_core_barrier_return_code(
diff --git a/cpukit/rtems/src/msgmp.c b/cpukit/rtems/src/msgmp.c
index c336ba4..d8077a7 100644
--- a/cpukit/rtems/src/msgmp.c
+++ b/cpukit/rtems/src/msgmp.c
@@ -576,17 +576,7 @@ void _Message_queue_MP_Send_extract_proxy (
- * _Message_queue_Core_message_queue_mp_support
- * Input parameters:
- * the_thread - the remote thread the message was submitted to
- * id - id of the message queue
- * Output parameters: NONE
-void _Message_queue_Core_message_queue_mp_support (
+void _Message_queue_Core_message_queue_mp_support(
Thread_Control *the_thread,
Objects_Id id
diff --git a/cpukit/rtems/src/msgqbroadcast.c b/cpukit/rtems/src/msgqbroadcast.c
index 45d9097..75f9d60 100644
--- a/cpukit/rtems/src/msgqbroadcast.c
+++ b/cpukit/rtems/src/msgqbroadcast.c
@@ -28,7 +28,7 @@ rtems_status_code rtems_message_queue_broadcast(
Message_queue_Control *the_message_queue;
CORE_message_queue_Status status;
if ( buffer == NULL ) {
@@ -39,7 +39,11 @@ rtems_status_code rtems_message_queue_broadcast(
- the_message_queue = _Message_queue_Get( id, &lock_context );
+ the_message_queue = _Message_queue_Get(
+ id,
+ &queue_context,
+ _Message_queue_Core_message_queue_mp_support
if ( the_message_queue == NULL ) {
@@ -53,9 +57,8 @@ rtems_status_code rtems_message_queue_broadcast(
&the_message_queue->message_queue,
buffer,
size,
- _Message_queue_Core_message_queue_mp_support,
count,
- &lock_context
+ &queue_context
return _Message_queue_Translate_core_message_queue_return_code( status );
diff --git a/cpukit/rtems/src/msgqdelete.c b/cpukit/rtems/src/msgqdelete.c
index c39cfea..94175e6 100644
--- a/cpukit/rtems/src/msgqdelete.c
+++ b/cpukit/rtems/src/msgqdelete.c
@@ -26,10 +26,14 @@ rtems_status_code rtems_message_queue_delete(
+ id,
+ &queue_context,
+ _Message_queue_MP_Send_object_was_deleted
@@ -45,15 +49,14 @@ rtems_status_code rtems_message_queue_delete(
- &lock_context
+ &queue_context
_Objects_Close( &_Message_queue_Information, &the_message_queue->Object );
- _Message_queue_MP_Send_object_was_deleted,
- &lock_context
+ &queue_context
diff --git a/cpukit/rtems/src/msgqflush.c b/cpukit/rtems/src/msgqflush.c
index baca176..b4419d1 100644
--- a/cpukit/rtems/src/msgqflush.c
+++ b/cpukit/rtems/src/msgqflush.c
@@ -26,13 +26,13 @@ rtems_status_code rtems_message_queue_flush(
if ( count == NULL ) {
+ the_message_queue = _Message_queue_Get( id, &queue_context, NULL );
@@ -44,7 +44,7 @@ rtems_status_code rtems_message_queue_flush(
*count = _CORE_message_queue_Flush(
- &lock_context
+ &queue_context
diff --git a/cpukit/rtems/src/msgqgetnumberpending.c b/cpukit/rtems/src/msgqgetnumberpending.c
index f655c0b..d2f7820 100644
--- a/cpukit/rtems/src/msgqgetnumberpending.c
+++ b/cpukit/rtems/src/msgqgetnumberpending.c
@@ -26,13 +26,13 @@ rtems_status_code rtems_message_queue_get_number_pending(
@@ -44,12 +44,12 @@ rtems_status_code rtems_message_queue_get_number_pending(
- &lock_context
+ &queue_context
*count = the_message_queue->message_queue.number_of_pending_messages;
- &lock_context
+ &queue_context
diff --git a/cpukit/rtems/src/msgqreceive.c b/cpukit/rtems/src/msgqreceive.c
index dada8df..6ed3d25 100644
--- a/cpukit/rtems/src/msgqreceive.c
+++ b/cpukit/rtems/src/msgqreceive.c
@@ -32,7 +32,7 @@ rtems_status_code rtems_message_queue_receive(
@@ -43,7 +43,7 @@ rtems_status_code rtems_message_queue_receive(
@@ -55,7 +55,7 @@ rtems_status_code rtems_message_queue_receive(
- &lock_context
+ &queue_context
@@ -66,7 +66,7 @@ rtems_status_code rtems_message_queue_receive(
size,
!_Options_Is_no_wait( option_set ),
timeout,
- &lock_context
+ &queue_context
diff --git a/cpukit/rtems/src/msgqsend.c b/cpukit/rtems/src/msgqsend.c
index c306deb..c5bde9d 100644
--- a/cpukit/rtems/src/msgqsend.c
+++ b/cpukit/rtems/src/msgqsend.c
@@ -27,14 +27,18 @@ rtems_status_code rtems_message_queue_send(
+ id,
+ &queue_context,
@@ -46,16 +50,15 @@ rtems_status_code rtems_message_queue_send(
- &lock_context
+ &queue_context
status = _CORE_message_queue_Send(
buffer,
size,
false, /* sender does not block */
0, /* no timeout */
- &lock_context
+ &queue_context
diff --git a/cpukit/rtems/src/msgqurgent.c b/cpukit/rtems/src/msgqurgent.c
index 56522a1..add5f09 100644
--- a/cpukit/rtems/src/msgqurgent.c
+++ b/cpukit/rtems/src/msgqurgent.c
@@ -27,14 +27,18 @@ rtems_status_code rtems_message_queue_urgent(
+ id,
+ &queue_context,
@@ -46,16 +50,15 @@ rtems_status_code rtems_message_queue_urgent(
- &lock_context
+ &queue_context
status = _CORE_message_queue_Urgent(
buffer,
size,
0, /* no timeout */
- &lock_context
+ &queue_context
diff --git a/cpukit/rtems/src/semdelete.c b/cpukit/rtems/src/semdelete.c
index cf22838..023a57c 100644
--- a/cpukit/rtems/src/semdelete.c
+++ b/cpukit/rtems/src/semdelete.c
@@ -25,12 +25,16 @@ rtems_status_code rtems_semaphore_delete(
rtems_id id
- Semaphore_Control *the_semaphore;
- rtems_attribute attribute_set;
+ Semaphore_Control *the_semaphore;
+ rtems_attribute attribute_set;
- the_semaphore = _Semaphore_Get( id, &lock_context );
+ the_semaphore = _Semaphore_Get(
+ id,
+ &queue_context,
+ _Semaphore_MP_Send_object_was_deleted
@@ -52,13 +56,13 @@ rtems_status_code rtems_semaphore_delete(
_MRSP_Acquire_critical(
&the_semaphore->Core_control.mrsp,
- &lock_context
+ &queue_context
mrsp_status = _MRSP_Can_destroy( &the_semaphore->Core_control.mrsp );
if ( mrsp_status != MRSP_SUCCESSFUL ) {
_MRSP_Release(
- &lock_context
+ &queue_context
return _Semaphore_Translate_MRSP_status_code( mrsp_status );
@@ -68,7 +72,7 @@ rtems_status_code rtems_semaphore_delete(
if ( !_Attributes_Is_counting_semaphore( attribute_set ) ) {
&the_semaphore->Core_control.mutex,
- &lock_context
+ &queue_context
if (
@@ -77,7 +81,7 @@ rtems_status_code rtems_semaphore_delete(
- &lock_context
+ &queue_context
return RTEMS_RESOURCE_IN_USE;
@@ -85,7 +89,7 @@ rtems_status_code rtems_semaphore_delete(
} else {
&the_semaphore->Core_control.semaphore,
- &lock_context
+ &queue_context
@@ -93,22 +97,20 @@ rtems_status_code rtems_semaphore_delete(
#if defined(RTEMS_SMP)
if ( _Attributes_Is_multiprocessor_resource_sharing( attribute_set ) ) {
- _MRSP_Destroy( &the_semaphore->Core_control.mrsp, &lock_context );
+ _MRSP_Destroy( &the_semaphore->Core_control.mrsp, &queue_context );
} else
#endif
_CORE_mutex_Flush(
_CORE_mutex_Was_deleted,
- _Semaphore_MP_Send_object_was_deleted,
- &lock_context
+ &queue_context
_CORE_mutex_Destroy( &the_semaphore->Core_control.mutex );
} else {
- &lock_context
+ &queue_context
diff --git a/cpukit/rtems/src/semflush.c b/cpukit/rtems/src/semflush.c
index 73e9ad0..b18de6d 100644
--- a/cpukit/rtems/src/semflush.c
+++ b/cpukit/rtems/src/semflush.c
@@ -23,11 +23,15 @@
rtems_status_code rtems_semaphore_flush( rtems_id id )
+ id,
+ &queue_context,
@@ -43,30 +47,28 @@ rtems_status_code rtems_semaphore_flush( rtems_id id )
return RTEMS_NOT_DEFINED;
} else
#endif
- &lock_context
+ &queue_context
_CORE_mutex_Flush(
_CORE_mutex_Unsatisfied_nowait,
- &lock_context
+ &queue_context
} else {
- &lock_context
+ &queue_context
_CORE_semaphore_Flush(
- &lock_context
+ &queue_context
diff --git a/cpukit/rtems/src/semobtain.c b/cpukit/rtems/src/semobtain.c
index 3cf780a..6d994f4 100644
--- a/cpukit/rtems/src/semobtain.c
+++ b/cpukit/rtems/src/semobtain.c
@@ -38,13 +38,13 @@ rtems_status_code rtems_semaphore_obtain(
- bool wait;
+ bool wait;
+ the_semaphore = _Semaphore_Get( id, &queue_context, NULL );
@@ -66,7 +66,7 @@ rtems_status_code rtems_semaphore_obtain(
executing,
wait,
timeout,
- &lock_context
+ &queue_context
} else
@@ -77,7 +77,7 @@ rtems_status_code rtems_semaphore_obtain(
executing,
wait,
timeout,
- &lock_context
+ &queue_context
return _Semaphore_Translate_core_mutex_return_code(
@@ -90,7 +90,7 @@ rtems_status_code rtems_semaphore_obtain(
executing,
wait,
timeout,
- &lock_context
+ &queue_context
return _Semaphore_Translate_core_semaphore_return_code(
diff --git a/cpukit/rtems/src/semrelease.c b/cpukit/rtems/src/semrelease.c
index c39455c..197e4d8 100644
--- a/cpukit/rtems/src/semrelease.c
+++ b/cpukit/rtems/src/semrelease.c
@@ -30,9 +30,13 @@ rtems_status_code rtems_semaphore_release( rtems_id id )
CORE_mutex_Status mutex_status;
CORE_semaphore_Status semaphore_status;
+ id,
+ &queue_context,
+ _Semaphore_Core_mutex_mp_support
@@ -50,7 +54,7 @@ rtems_status_code rtems_semaphore_release( rtems_id id )
mrsp_status = _MRSP_Surrender(
_Thread_Executing,
- &lock_context
+ &queue_context
} else
@@ -58,15 +62,13 @@ rtems_status_code rtems_semaphore_release( rtems_id id )
- _Semaphore_Core_mutex_mp_support,
- &lock_context
+ &queue_context
return _Semaphore_Translate_core_mutex_return_code( mutex_status );
} else {
semaphore_status = _CORE_semaphore_Surrender(
- &lock_context
+ &queue_context
return _Semaphore_Translate_core_semaphore_return_code( semaphore_status );
diff --git a/cpukit/rtems/src/semsetpriority.c b/cpukit/rtems/src/semsetpriority.c
index 18fb66a..4deee3d 100644
--- a/cpukit/rtems/src/semsetpriority.c
+++ b/cpukit/rtems/src/semsetpriority.c
@@ -22,11 +22,11 @@
static rtems_status_code _Semaphore_Set_priority(
- Semaphore_Control *the_semaphore,
- rtems_id scheduler_id,
- rtems_task_priority new_priority,
- rtems_task_priority *old_priority_p,
+ Semaphore_Control *the_semaphore,
+ rtems_id scheduler_id,
+ rtems_task_priority new_priority,
+ rtems_task_priority *old_priority_p,
rtems_status_code sc;
@@ -40,7 +40,7 @@ static rtems_status_code _Semaphore_Set_priority(
MRSP_Control *mrsp = &the_semaphore->Core_control.mrsp;
uint32_t scheduler_index = _Scheduler_Get_index_by_id( scheduler_id );
- _MRSP_Acquire_critical( mrsp, lock_context );
+ _MRSP_Acquire_critical( mrsp, queue_context );
old_priority = _MRSP_Get_ceiling_priority( mrsp, scheduler_index );
@@ -48,7 +48,7 @@ static rtems_status_code _Semaphore_Set_priority(
_MRSP_Set_ceiling_priority( mrsp, scheduler_index, new_priority );
- _MRSP_Release( mrsp, lock_context );
+ _MRSP_Release( mrsp, queue_context );
sc = RTEMS_SUCCESSFUL;
} else
@@ -56,7 +56,7 @@ static rtems_status_code _Semaphore_Set_priority(
if ( _Attributes_Is_priority_ceiling( attribute_set ) ) {
CORE_mutex_Control *mutex = &the_semaphore->Core_control.mutex;
- _CORE_mutex_Acquire_critical( mutex, lock_context );
+ _CORE_mutex_Acquire_critical( mutex, queue_context );
old_priority = mutex->Attributes.priority_ceiling;
@@ -64,11 +64,11 @@ static rtems_status_code _Semaphore_Set_priority(
mutex->Attributes.priority_ceiling = new_priority;
- _CORE_mutex_Release( mutex, lock_context );
+ _CORE_mutex_Release( mutex, queue_context );
} else {
- _ISR_lock_ISR_enable( lock_context );
+ _ISR_lock_ISR_enable( &queue_context->Lock_context );
old_priority = 0;
@@ -87,8 +87,8 @@ rtems_status_code rtems_semaphore_set_priority(
if ( new_priority != RTEMS_CURRENT_PRIORITY &&
!_RTEMS_tasks_Priority_is_valid( new_priority ) ) {
@@ -103,7 +103,7 @@ rtems_status_code rtems_semaphore_set_priority(
- the_semaphore = _Semaphore_Get( semaphore_id, &lock_context );
+ the_semaphore = _Semaphore_Get( semaphore_id, &queue_context, NULL );
@@ -120,6 +120,6 @@ rtems_status_code rtems_semaphore_set_priority(
scheduler_id,
new_priority,
old_priority,
- &lock_context
+ &queue_context
diff --git a/cpukit/score/include/rtems/score/corebarrierimpl.h b/cpukit/score/include/rtems/score/corebarrierimpl.h
index d5133cd..051990e 100644
--- a/cpukit/score/include/rtems/score/corebarrierimpl.h
+++ b/cpukit/score/include/rtems/score/corebarrierimpl.h
@@ -84,31 +84,26 @@ RTEMS_INLINE_ROUTINE void _CORE_barrier_Destroy(
RTEMS_INLINE_ROUTINE void _CORE_barrier_Acquire_critical(
CORE_barrier_Control *the_barrier,
- _Thread_queue_Acquire_critical( &the_barrier->Wait_queue, lock_context );
+ &the_barrier->Wait_queue,
RTEMS_INLINE_ROUTINE void _CORE_barrier_Release(
- _Thread_queue_Release( &the_barrier->Wait_queue, lock_context );
-void _CORE_barrier_Do_seize(
- CORE_barrier_Control *the_barrier,
- Thread_Control *executing,
- bool wait,
- Watchdog_Interval timeout,
-#if defined(RTEMS_MULTIPROCESSING)
- Thread_queue_MP_callout mp_callout,
-#endif
* @brief Wait for the barrier.
@@ -127,48 +122,18 @@ void _CORE_barrier_Do_seize(
* @note Status is returned via the thread control block.
- #define _CORE_barrier_Seize( \
- the_barrier, \
- executing, \
- wait, \
- timeout, \
- mp_callout, \
- lock_context \
- _CORE_barrier_Do_seize( \
- the_barrier, \
- executing, \
- wait, \
- timeout, \
- mp_callout, \
- lock_context \
-#else
- the_barrier, \
- executing, \
- wait, \
- timeout, \
- mp_callout, \
- lock_context \
- the_barrier, \
- executing, \
- wait, \
- timeout, \
- lock_context \
-#endif
+void _CORE_barrier_Seize(
+ CORE_barrier_Control *the_barrier,
+ Thread_Control *executing,
+ bool wait,
+ Watchdog_Interval timeout,
-uint32_t _CORE_barrier_Do_surrender(
+uint32_t _CORE_barrier_Do_flush(
Thread_queue_Flush_filter filter,
-#endif
@@ -183,62 +148,35 @@ uint32_t _CORE_barrier_Do_surrender(
* @retval the number of unblocked threads
- #define _CORE_barrier_Surrender( \
- the_barrier, \
- mp_callout, \
- lock_context \
- _CORE_barrier_Do_surrender( \
- the_barrier, \
- _Thread_queue_Flush_default_filter, \
- mp_callout, \
- lock_context \
-#else
- the_barrier, \
- mp_callout, \
- lock_context \
- the_barrier, \
- lock_context \
-#endif
+RTEMS_INLINE_ROUTINE uint32_t _CORE_barrier_Surrender(
+ return _CORE_barrier_Do_flush(
+ the_barrier,
+ _Thread_queue_Flush_default_filter,
+ queue_context
Thread_Control *_CORE_barrier_Was_deleted(
- Thread_Control *the_thread,
- Thread_queue_Queue *queue,
+ Thread_Control *the_thread,
+ Thread_queue_Queue *queue,
-/* Must be a macro due to the multiprocessing dependent parameters */
- #define _CORE_barrier_Flush( \
- the_barrier, \
- mp_callout, \
- lock_context \
- the_barrier, \
- _CORE_barrier_Was_deleted, \
- mp_callout, \
- lock_context \
-#else
- the_barrier, \
- mp_callout, \
- lock_context \
- the_barrier, \
- lock_context \
-#endif
+RTEMS_INLINE_ROUTINE void _CORE_barrier_Flush(
+ _CORE_barrier_Do_flush(
+ the_barrier,
+ _CORE_barrier_Was_deleted,
+ queue_context
* This function returns true if the automatic release attribute is
diff --git a/cpukit/score/include/rtems/score/coremsg.h b/cpukit/score/include/rtems/score/coremsg.h
index af42e7d..8d25529 100644
--- a/cpukit/score/include/rtems/score/coremsg.h
+++ b/cpukit/score/include/rtems/score/coremsg.h
@@ -122,7 +122,7 @@ typedef enum {
typedef void (*CORE_message_queue_Notify_Handler)(
CORE_message_queue_Control *,
#endif
diff --git a/cpukit/score/include/rtems/score/coremsgimpl.h b/cpukit/score/include/rtems/score/coremsgimpl.h
index a93da03..c90cb72 100644
--- a/cpukit/score/include/rtems/score/coremsgimpl.h
+++ b/cpukit/score/include/rtems/score/coremsgimpl.h
@@ -128,14 +128,6 @@ bool _CORE_message_queue_Initialize(
size_t maximum_message_size
-void _CORE_message_queue_Do_close(
- CORE_message_queue_Control *the_message_queue,
-#endif
* @brief Close a message queue.
@@ -147,33 +139,13 @@ void _CORE_message_queue_Do_close(
* flushing @a the_message_queue's task wait queue.
* @param[in] the_message_queue points to the message queue to close
- * @param[in] mp_callout is the routine to call for each thread
- * that is extracted from the set of waiting threads
- * @param[in] lock_context The lock context of the
+ * @param[in] queue_context The thread queue context used for
* _CORE_message_queue_Acquire() or _CORE_message_queue_Acquire_critical().
- #define _CORE_message_queue_Close( \
- the_message_queue, \
- mp_callout, \
- lock_context \
- _CORE_message_queue_Do_close( \
- mp_callout, \
- lock_context \
-#else
- mp_callout, \
- lock_context \
- lock_context \
-#endif
+void _CORE_message_queue_Close(
+ CORE_message_queue_Control *the_message_queue,
* @brief Flush pending messages.
@@ -186,13 +158,13 @@ void _CORE_message_queue_Do_close(
* number of messages flushed from the queue is returned.
* @param[in] the_message_queue points to the message queue to flush
- * @param[in] lock_context The lock context of the interrupt disable.
+ * @param[in] queue_context The thread queue context with interrupts disabled.
* @retval This method returns the number of message pending messages flushed.
uint32_t _CORE_message_queue_Flush(
#if defined(FUNCTIONALITY_NOT_CURRENTLY_USED_BY_ANY_API)
@@ -212,17 +184,6 @@ uint32_t _CORE_message_queue_Flush(
#endif
-CORE_message_queue_Status _CORE_message_queue_Do_broadcast(
- const void *buffer,
- size_t size,
-#endif
- uint32_t *count,
* @brief Broadcast a message to the message queue.
@@ -236,61 +197,19 @@ CORE_message_queue_Status _CORE_message_queue_Do_broadcast(
* @param[in] buffer is the starting address of the message to broadcast
* @param[in] size is the size of the message being broadcast
- * @param[in] mp_callout is the routine to invoke if
- * a thread that is unblocked is actually a remote thread.
* @param[out] count points to the variable that will contain the
* number of tasks that are sent this message
+ * _CORE_message_queue_Acquire() or _CORE_message_queue_Acquire_critical().
* @retval @a *count will contain the number of messages sent
* @retval indication of the successful completion or reason for failure
- #define _CORE_message_queue_Broadcast( \
- buffer, \
- size, \
- mp_callout, \
- count, \
- lock_context \
- _CORE_message_queue_Do_broadcast( \
- buffer, \
- size, \
- mp_callout, \
- count, \
- lock_context \
-#else
- buffer, \
- size, \
- mp_callout, \
- count, \
- lock_context \
- buffer, \
- size, \
- count, \
- lock_context \
-#endif
-CORE_message_queue_Status _CORE_message_queue_Do_submit(
- size_t size,
-#endif
- CORE_message_queue_Submit_types submit_type,
- bool wait,
+CORE_message_queue_Status _CORE_message_queue_Broadcast(
+ const void *buffer,
+ size_t size,
+ uint32_t *count,
@@ -306,63 +225,26 @@ CORE_message_queue_Status _CORE_message_queue_Do_submit(
* @param[in] buffer is the starting address of the message to send
* @param[in] size is the size of the message being send
* @param[in] submit_type determines whether the message is prepended,
* appended, or enqueued in priority order.
* @param[in] wait indicates whether the calling thread is willing to block
* if the message queue is full.
* @param[in] timeout is the maximum number of clock ticks that the calling
* thread is willing to block if the message queue is full.
- #define _CORE_message_queue_Submit( \
- executing, \
- buffer, \
- size, \
- mp_callout, \
- submit_type, \
- wait, \
- timeout, \
- lock_context \
- _CORE_message_queue_Do_submit( \
- executing, \
- buffer, \
- size, \
- mp_callout, \
- submit_type, \
- wait, \
- timeout, \
- lock_context \
-#else
- executing, \
- buffer, \
- size, \
- mp_callout, \
- submit_type, \
- wait, \
- timeout, \
- lock_context \
- executing, \
- buffer, \
- size, \
- submit_type, \
- wait, \
- timeout, \
- lock_context \
-#endif
+CORE_message_queue_Status _CORE_message_queue_Submit(
+ size_t size,
+ CORE_message_queue_Submit_types submit_type,
+ bool wait,
* @brief Size a message from the message queue.
@@ -385,7 +267,8 @@ CORE_message_queue_Status _CORE_message_queue_Do_submit(
* if the message queue is empty.
* thread is willing to block if the message queue is empty.
* @retval indication of the successful completion or reason for failure.
* On success, the location pointed to @a size_p will contain the
@@ -398,13 +281,13 @@ CORE_message_queue_Status _CORE_message_queue_Do_submit(
* + wait
void _CORE_message_queue_Seize(
- void *buffer,
- size_t *size_p,
- bool wait,
+ void *buffer,
+ size_t *size_p,
+ bool wait,
@@ -428,76 +311,79 @@ void _CORE_message_queue_Insert_message(
- * This routine sends a message to the end of the specified message queue.
-#define _CORE_message_queue_Send( \
- buffer, \
- size, \
- mp_callout, \
- wait, \
- timeout, \
- lock_context \
- _CORE_message_queue_Submit( \
- _Thread_Executing, \
- buffer, \
- size, \
- mp_callout, \
- CORE_MESSAGE_QUEUE_SEND_REQUEST, \
- wait, \
- timeout, \
- lock_context \
+RTEMS_INLINE_ROUTINE CORE_message_queue_Status _CORE_message_queue_Send(
+ size_t size,
+ bool wait,
+ return _CORE_message_queue_Submit(
+ the_message_queue,
+ _Thread_Executing,
+ buffer,
+ size,
+ CORE_MESSAGE_QUEUE_SEND_REQUEST,
+ wait,
+ timeout,
+ queue_context
- * This routine sends a message to the front of the specified message queue.
-#define _CORE_message_queue_Urgent( \
- buffer, \
- size, \
- mp_callout, \
- wait, \
- timeout, \
- lock_context \
- buffer, \
- size, \
- mp_callout, \
- CORE_MESSAGE_QUEUE_URGENT_REQUEST, \
- wait,\
- timeout, \
- lock_context \
+RTEMS_INLINE_ROUTINE CORE_message_queue_Status _CORE_message_queue_Urgent(
+ size_t size,
+ bool wait,
+ buffer,
+ size,
+ CORE_MESSAGE_QUEUE_URGENT_REQUEST,
+ wait,
+ timeout,
+ queue_context
RTEMS_INLINE_ROUTINE void _CORE_message_queue_Acquire(
- _Thread_queue_Acquire( &the_message_queue->Wait_queue, lock_context );
+ _Thread_queue_Acquire(
+ &the_message_queue->Wait_queue,
RTEMS_INLINE_ROUTINE void _CORE_message_queue_Acquire_critical(
- _Thread_queue_Acquire_critical( &the_message_queue->Wait_queue, lock_context );
RTEMS_INLINE_ROUTINE void _CORE_message_queue_Release(
- _Thread_queue_Release( &the_message_queue->Wait_queue, lock_context );
@@ -599,15 +485,12 @@ RTEMS_INLINE_ROUTINE
do { } while ( 0 )
#endif
-RTEMS_INLINE_ROUTINE Thread_Control *_CORE_message_queue_Do_dequeue_receiver(
+RTEMS_INLINE_ROUTINE Thread_Control *_CORE_message_queue_Dequeue_receiver(
const void *buffer,
size_t size,
-#endif
Thread_Control *the_thread;
@@ -649,48 +532,12 @@ RTEMS_INLINE_ROUTINE Thread_Control *_CORE_message_queue_Do_dequeue_receiver(
&the_message_queue->Wait_queue.Queue,
the_message_queue->operations,
the_thread,
- mp_callout,
- lock_context
+ queue_context
return the_thread;
- #define _CORE_message_queue_Dequeue_receiver( \
- buffer, \
- size, \
- mp_callout, \
- submit_type, \
- lock_context \
- _CORE_message_queue_Do_dequeue_receiver( \
- buffer, \
- size, \
- mp_callout, \
- submit_type, \
- lock_context \
-#else
- buffer, \
- size, \
- mp_callout, \
- submit_type, \
- lock_context \
- buffer, \
- size, \
- submit_type, \
- lock_context \
-#endif
#ifdef __cplusplus
diff --git a/cpukit/score/include/rtems/score/coremuteximpl.h b/cpukit/score/include/rtems/score/coremuteximpl.h
index 4531e46..a32022a 100644
--- a/cpukit/score/include/rtems/score/coremuteximpl.h
+++ b/cpukit/score/include/rtems/score/coremuteximpl.h
@@ -107,19 +107,25 @@ RTEMS_INLINE_ROUTINE void _CORE_mutex_Destroy( CORE_mutex_Control *the_mutex )
RTEMS_INLINE_ROUTINE void _CORE_mutex_Acquire_critical(
- CORE_mutex_Control *the_mutex,
+ CORE_mutex_Control *the_mutex,
- _Thread_queue_Acquire_critical( &the_mutex->Wait_queue, lock_context );
+ &the_mutex->Wait_queue,
RTEMS_INLINE_ROUTINE void _CORE_mutex_Release(
- _Thread_queue_Release( &the_mutex->Wait_queue, lock_context );
@@ -219,7 +225,7 @@ RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_priority_ceiling(
* @param[in,out] executing The currently executing thread.
* @param[in,out] the_mutex is the mutex to attempt to lock
- * @param[in] lock_context is the interrupt level
+ * @param[in] queue_context is the interrupt level
* @retval This routine returns 0 if "trylock" can resolve whether or not
* the mutex is immediately obtained or there was an error attempting to
@@ -227,9 +233,9 @@ RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_priority_ceiling(
* the mutex and will have to block to do so.
RTEMS_INLINE_ROUTINE int _CORE_mutex_Seize_interrupt_trylock(
/* disabled when you get here */
@@ -244,7 +250,7 @@ RTEMS_INLINE_ROUTINE int _CORE_mutex_Seize_interrupt_trylock(
if ( !_CORE_mutex_Is_priority_ceiling( &the_mutex->Attributes ) ) {
- _CORE_mutex_Release( the_mutex, lock_context );
+ _CORE_mutex_Release( the_mutex, queue_context );
return 0;
} /* else must be CORE_MUTEX_DISCIPLINES_PRIORITY_CEILING
@@ -258,15 +264,17 @@ RTEMS_INLINE_ROUTINE int _CORE_mutex_Seize_interrupt_trylock(
ceiling = the_mutex->Attributes.priority_ceiling;
current = executing->current_priority;
if ( current == ceiling ) {
return 0;
if ( current > ceiling ) {
Per_CPU_Control *cpu_self;
- cpu_self = _Thread_Dispatch_disable_critical( lock_context );
_Thread_Raise_priority( executing, ceiling );
return 0;
@@ -276,7 +284,7 @@ RTEMS_INLINE_ROUTINE int _CORE_mutex_Seize_interrupt_trylock(
the_mutex->holder = NULL;
the_mutex->nest_count = 0; /* undo locking above */
executing->resource_count--; /* undo locking above */
return 0;
@@ -292,12 +300,12 @@ RTEMS_INLINE_ROUTINE int _CORE_mutex_Seize_interrupt_trylock(
switch ( the_mutex->Attributes.lock_nesting_behavior ) {
case CORE_MUTEX_NESTING_ACQUIRES:
the_mutex->nest_count++;
return 0;
#if defined(RTEMS_POSIX_API)
case CORE_MUTEX_NESTING_IS_ERROR:
executing->Wait.return_code = CORE_MUTEX_STATUS_NESTING_NOT_ALLOWED;
return 0;
#endif
case CORE_MUTEX_NESTING_BLOCKS:
@@ -322,7 +330,7 @@ RTEMS_INLINE_ROUTINE int _CORE_mutex_Seize_interrupt_trylock(
* @param[in] the_mutex is the mutex to attempt to lock
* @param[in] wait is true if the thread is willing to wait
* @param[in] timeout is the maximum number of ticks to block
- * @param[in] lock_context is a temporary variable used to contain the ISR
+ * @param[in] queue_context is a temporary variable used to contain the ISR
* disable level cookie
* @note If the mutex is called from an interrupt service routine,
@@ -339,11 +347,11 @@ RTEMS_INLINE_ROUTINE int _CORE_mutex_Seize_interrupt_trylock(
* then they are blocked.
RTEMS_INLINE_ROUTINE void _CORE_mutex_Seize(
- bool wait,
+ bool wait,
if ( _CORE_mutex_Check_dispatch_for_seize( wait ) ) {
@@ -353,10 +361,12 @@ RTEMS_INLINE_ROUTINE void _CORE_mutex_Seize(
INTERNAL_ERROR_MUTEX_OBTAIN_FROM_BAD_STATE
- _CORE_mutex_Acquire_critical( the_mutex, lock_context );
- if ( _CORE_mutex_Seize_interrupt_trylock( the_mutex, executing, lock_context ) ) {
+ _CORE_mutex_Acquire_critical( the_mutex, queue_context );
+ if (
+ _CORE_mutex_Seize_interrupt_trylock( the_mutex, executing, queue_context )
if ( !wait ) {
CORE_MUTEX_STATUS_UNSATISFIED_NOWAIT;
} else {
@@ -364,69 +374,42 @@ RTEMS_INLINE_ROUTINE void _CORE_mutex_Seize(
the_mutex,
executing,
timeout,
- lock_context
-CORE_mutex_Status _CORE_mutex_Do_surrender(
-#endif
+CORE_mutex_Status _CORE_mutex_Surrender(
- #define _CORE_mutex_Surrender( \
- the_mutex, \
- mp_callout, \
- lock_context \
- _CORE_mutex_Do_surrender( \
- the_mutex, \
- mp_callout, \
- lock_context \
-#else
- the_mutex, \
- mp_callout, \
- lock_context \
- the_mutex, \
- lock_context \
-#endif
Thread_Control *_CORE_mutex_Was_deleted(
Thread_Control *_CORE_mutex_Unsatisfied_nowait(
-#define _CORE_mutex_Flush( \
- the_mutex, \
- filter, \
- mp_callout, \
- lock_context \
- _Thread_queue_Flush_critical( \
- &( the_mutex )->Wait_queue.Queue, \
- ( the_mutex )->operations, \
- filter, \
- mp_callout, \
- lock_context \
+RTEMS_INLINE_ROUTINE void _CORE_mutex_Flush(
+ Thread_queue_Flush_filter filter,
+ _Thread_queue_Flush_critical(
+ &the_mutex->Wait_queue.Queue,
+ the_mutex->operations,
+ filter,
+ queue_context
RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_owner(
const CORE_mutex_Control *the_mutex,
diff --git a/cpukit/score/include/rtems/score/corerwlockimpl.h b/cpukit/score/include/rtems/score/corerwlockimpl.h
index ed59d69..67084c1 100644
--- a/cpukit/score/include/rtems/score/corerwlockimpl.h
+++ b/cpukit/score/include/rtems/score/corerwlockimpl.h
@@ -87,19 +87,25 @@ RTEMS_INLINE_ROUTINE void _CORE_RWLock_Destroy(
RTEMS_INLINE_ROUTINE void _CORE_RWLock_Acquire_critical(
- CORE_RWLock_Control *the_rwlock,
+ CORE_RWLock_Control *the_rwlock,
- _Thread_queue_Acquire_critical( &the_rwlock->Wait_queue, lock_context );
+ &the_rwlock->Wait_queue,
RTEMS_INLINE_ROUTINE void _CORE_RWLock_Release(
- _Thread_queue_Release( &the_rwlock->Wait_queue, lock_context );
@@ -116,11 +122,11 @@ RTEMS_INLINE_ROUTINE void _CORE_RWLock_Release(
void _CORE_RWLock_Seize_for_reading(
- bool wait,
+ bool wait,
@@ -136,11 +142,11 @@ void _CORE_RWLock_Seize_for_reading(
void _CORE_RWLock_Seize_for_writing(
- bool wait,
+ bool wait,
@@ -154,8 +160,8 @@ void _CORE_RWLock_Seize_for_writing(
* @retval Status is returned to indicate successful or failure.
CORE_RWLock_Status _CORE_RWLock_Surrender(
diff --git a/cpukit/score/include/rtems/score/coresemimpl.h b/cpukit/score/include/rtems/score/coresemimpl.h
index 0e04cc9..1660c1d 100644
--- a/cpukit/score/include/rtems/score/coresemimpl.h
+++ b/cpukit/score/include/rtems/score/coresemimpl.h
@@ -88,54 +88,68 @@ void _CORE_semaphore_Initialize(
RTEMS_INLINE_ROUTINE void _CORE_semaphore_Acquire_critical(
CORE_semaphore_Control *the_semaphore,
- _Thread_queue_Acquire_critical( &the_semaphore->Wait_queue, lock_context );
+ &the_semaphore->Wait_queue,
RTEMS_INLINE_ROUTINE void _CORE_semaphore_Release(
- _Thread_queue_Release( &the_semaphore->Wait_queue, lock_context );
Thread_Control *_CORE_semaphore_Was_deleted(
Thread_Control *_CORE_semaphore_Unsatisfied_nowait(
-#define _CORE_semaphore_Destroy( \
- the_semaphore, \
- mp_callout, \
- lock_context \
- do { \
- &( the_semaphore )->Wait_queue.Queue, \
- ( the_semaphore )->operations, \
- _CORE_semaphore_Was_deleted, \
- mp_callout, \
- lock_context \
- _Thread_queue_Destroy( &( the_semaphore )->Wait_queue ); \
- } while ( 0 )
+RTEMS_INLINE_ROUTINE void _CORE_semaphore_Destroy(
+ CORE_semaphore_Control *the_semaphore,
+ &the_semaphore->Wait_queue.Queue,
+ the_semaphore->operations,
+ _CORE_semaphore_Was_deleted,
+ queue_context
+ _Thread_queue_Destroy( &the_semaphore->Wait_queue );
-RTEMS_INLINE_ROUTINE CORE_semaphore_Status _CORE_semaphore_Do_surrender(
+ * @brief Surrender a unit to a semaphore.
+ * This routine frees a unit to the semaphore. If a task was blocked waiting
+ * for a unit from this semaphore, then that task will be readied and the unit
+ * given to that task. Otherwise, the unit will be returned to the semaphore.
+ * @param[in] the_semaphore is the semaphore to surrender
+ * disable level cookie
+ * @retval an indication of whether the routine succeeded or failed
+RTEMS_INLINE_ROUTINE CORE_semaphore_Status _CORE_semaphore_Surrender(
-#endif
- ISR_lock_Context *lock_context
+ Thread_queue_Context *queue_context
@@ -143,7 +157,7 @@ RTEMS_INLINE_ROUTINE CORE_semaphore_Status _CORE_semaphore_Do_surrender(
status = CORE_SEMAPHORE_STATUS_SUCCESSFUL;
- _CORE_semaphore_Acquire_critical( the_semaphore, lock_context );
+ _CORE_semaphore_Acquire_critical( the_semaphore, queue_context );
@@ -154,8 +168,7 @@ RTEMS_INLINE_ROUTINE CORE_semaphore_Status _CORE_semaphore_Do_surrender(
the_thread,
- mp_callout,
- lock_context
+ queue_context
} else {
if ( the_semaphore->count < UINT32_MAX )
@@ -163,65 +176,24 @@ RTEMS_INLINE_ROUTINE CORE_semaphore_Status _CORE_semaphore_Do_surrender(
else
status = CORE_SEMAPHORE_MAXIMUM_COUNT_EXCEEDED;
- _CORE_semaphore_Release( the_semaphore, lock_context );
+ _CORE_semaphore_Release( the_semaphore, queue_context );
return status;
- * @brief Surrender a unit to a semaphore.
- * This routine frees a unit to the semaphore. If a task was blocked waiting
- * for a unit from this semaphore, then that task will be readied and the unit
- * given to that task. Otherwise, the unit will be returned to the semaphore.
- * @param[in] the_semaphore is the semaphore to surrender
- * @param[in] mp_callout is the routine to invoke if the
- * thread unblocked is remote
- * disable level cookie
- * @retval an indication of whether the routine succeeded or failed
- #define _CORE_semaphore_Surrender( \
- the_semaphore, \
- mp_callout, \
- lock_context \
- _CORE_semaphore_Do_surrender( \
- the_semaphore, \
- mp_callout, \
- lock_context \
-#else
- the_semaphore, \
- mp_callout, \
- lock_context \
- the_semaphore, \
- lock_context \
-#endif
-#define _CORE_semaphore_Flush( \
- the_semaphore, \
- mp_callout, \
- lock_context \
- do { \
- _CORE_semaphore_Unsatisfied_nowait, \
- mp_callout, \
- lock_context \
- } while ( 0 )
+RTEMS_INLINE_ROUTINE void _CORE_semaphore_Flush(
+ _CORE_semaphore_Unsatisfied_nowait,
+ queue_context
* This routine returns the current count associated with the semaphore.
@@ -247,31 +219,31 @@ RTEMS_INLINE_ROUTINE uint32_t _CORE_semaphore_Get_count(
* @note There is currently no MACRO version of this routine.
RTEMS_INLINE_ROUTINE void _CORE_semaphore_Seize(
- CORE_semaphore_Control *the_semaphore,
- bool wait,
+ bool wait,
executing->Wait.return_code = CORE_SEMAPHORE_STATUS_SUCCESSFUL;
if ( the_semaphore->count != 0 ) {
the_semaphore->count -= 1;
return;
if ( !wait ) {
executing->Wait.return_code = CORE_SEMAPHORE_STATUS_UNSATISFIED_NOWAIT;
return;
@@ -283,7 +255,7 @@ RTEMS_INLINE_ROUTINE void _CORE_semaphore_Seize(
STATES_WAITING_FOR_SEMAPHORE,
timeout,
CORE_SEMAPHORE_TIMEOUT,
- lock_context
+ &queue_context->Lock_context
diff --git a/cpukit/score/include/rtems/score/mrspimpl.h b/cpukit/score/include/rtems/score/mrspimpl.h
index d5cf55d..5173343 100644
--- a/cpukit/score/include/rtems/score/mrspimpl.h
+++ b/cpukit/score/include/rtems/score/mrspimpl.h
@@ -54,19 +54,19 @@ RTEMS_INLINE_ROUTINE void _MRSP_Giant_release( ISR_lock_Context *lock_context )
RTEMS_INLINE_ROUTINE void _MRSP_Acquire_critical(
- MRSP_Control *mrsp,
+ MRSP_Control *mrsp,
- _ISR_lock_Acquire( &mrsp->Lock, lock_context );
+ _ISR_lock_Acquire( &mrsp->Lock, &queue_context->Lock_context );
RTEMS_INLINE_ROUTINE void _MRSP_Release(
- _ISR_lock_Release_and_ISR_enable( &mrsp->Lock, lock_context );
+ _ISR_lock_Release_and_ISR_enable( &mrsp->Lock, &queue_context->Lock_context );
RTEMS_INLINE_ROUTINE bool _MRSP_Restore_priority_filter(
@@ -104,11 +104,11 @@ RTEMS_INLINE_ROUTINE void _MRSP_Restore_priority(
RTEMS_INLINE_ROUTINE void _MRSP_Claim_ownership(
- Thread_Control *new_owner,
- Priority_Control initial_priority,
- Priority_Control ceiling_priority,
+ Thread_Control *new_owner,
+ Priority_Control initial_priority,
+ Priority_Control ceiling_priority,
@@ -118,8 +118,8 @@ RTEMS_INLINE_ROUTINE void _MRSP_Claim_ownership(
mrsp->initial_priority_of_owner = initial_priority;
_Scheduler_Thread_change_help_state( new_owner, SCHEDULER_HELP_ACTIVE_OWNER );
+ cpu_self = _Thread_Dispatch_disable_critical( &queue_context->Lock_context );
_Thread_Raise_priority( new_owner, ceiling_priority );
@@ -180,10 +180,11 @@ RTEMS_INLINE_ROUTINE void _MRSP_Timeout( Watchdog_Control *watchdog )
MRSP_Rival *rival = RTEMS_CONTAINER_OF( watchdog, MRSP_Rival, Watchdog );
MRSP_Control *mrsp = rival->resource;
Thread_Control *thread = rival->thread;
- ISR_lock_Context lock_context;
+ Thread_queue_Context queue_context;
- _MRSP_Acquire_critical( mrsp, &lock_context );
+ _Thread_queue_Context_initialize( &queue_context, NULL );
+ _MRSP_Acquire_critical( mrsp, &queue_context );
if ( rival->status == MRSP_WAIT_FOR_OWNERSHIP ) {
ISR_lock_Context giant_lock_context;
@@ -200,20 +201,20 @@ RTEMS_INLINE_ROUTINE void _MRSP_Timeout( Watchdog_Control *watchdog )
rival->status = MRSP_TIMEOUT;
- _MRSP_Release( mrsp, &lock_context );
+ _MRSP_Release( mrsp, &queue_context );
} else {
RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Wait_for_ownership(
- Resource_Node *owner,
+ Resource_Node *owner,
MRSP_Status status;
@@ -243,8 +244,8 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Wait_for_ownership(
_MRSP_Giant_release( &giant_lock_context );
_Thread_Raise_priority( executing, ceiling_priority );
@@ -286,11 +287,11 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Wait_for_ownership(
RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Seize(
- bool wait,
+ bool wait,
MRSP_Status status;
@@ -306,11 +307,11 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Seize(
Resource_Node *owner;
if ( !priority_ok) {
return MRSP_INVALID_PRIORITY;
owner = _Resource_Get_owner( &mrsp->Resource );
if ( owner == NULL ) {
@@ -318,7 +319,7 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Seize(
executing,
initial_priority,
ceiling_priority,
- lock_context
+ queue_context
status = MRSP_SUCCESSFUL;
} else if (
@@ -332,10 +333,10 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Seize(
initial_priority,
ceiling_priority,
timeout,
- lock_context
+ queue_context
} else {
/* Not available, nested access or deadlock */
status = MRSP_UNSATISFIED;
@@ -344,9 +345,9 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Seize(
RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Surrender(
Priority_Control initial_priority;
@@ -354,7 +355,7 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Surrender(
if ( _Resource_Get_owner( &mrsp->Resource ) != &executing->Resource_node ) {
return MRSP_NOT_OWNER_OF_RESOURCE;
@@ -364,13 +365,13 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Surrender(
return MRSP_INCORRECT_STATE;
initial_priority = mrsp->initial_priority_of_owner;
_MRSP_Giant_acquire( &giant_lock_context );
@@ -405,8 +406,8 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Surrender(
_MRSP_Restore_priority( executing, initial_priority );
@@ -425,11 +426,11 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Can_destroy( MRSP_Control *mrsp )
RTEMS_INLINE_ROUTINE void _MRSP_Destroy(
_ISR_lock_Destroy( &mrsp->Lock );
_Workspace_Free( mrsp->ceiling_priorities );
diff --git a/cpukit/score/include/rtems/score/threadq.h b/cpukit/score/include/rtems/score/threadq.h
index 7ada3fc..27af89f 100644
--- a/cpukit/score/include/rtems/score/threadq.h
+++ b/cpukit/score/include/rtems/score/threadq.h
@@ -58,6 +58,18 @@ typedef void ( *Thread_queue_MP_callout )(
#endif
+ * @brief Thread queue context for the thread queue methods.
+ * @see _Thread_queue_Context_initialize().
+typedef struct {
+ ISR_lock_Context Lock_context;
+ Thread_queue_MP_callout mp_callout;
+#endif
+} Thread_queue_Context;
* @brief Thread priority queue.
typedef struct {
diff --git a/cpukit/score/include/rtems/score/threadqimpl.h b/cpukit/score/include/rtems/score/threadqimpl.h
index 011c410..752e13e 100644
--- a/cpukit/score/include/rtems/score/threadqimpl.h
+++ b/cpukit/score/include/rtems/score/threadqimpl.h
@@ -53,6 +53,49 @@ typedef struct {
#endif
} Thread_queue_Syslock_queue;
+RTEMS_INLINE_ROUTINE void _Thread_queue_Do_context_initialize(
+#endif
+ queue_context->mp_callout = mp_callout;
+#else
+ (void) queue_context;
+#endif
+ * @brief Initializes a thread queue context.
+ * @param queue_context The thread queue context to initialize.
+ * @param mp_callout Callout to unblock the thread in case it is actually a
+ * thread proxy. This parameter is only used on multiprocessing
+ * configurations. Used by thread queue extract and unblock methods for
+ * objects with multiprocessing (MP) support.
+ #define _Thread_queue_Context_initialize( \
+ queue_context, \
+ mp_callout \
+ _Thread_queue_Do_context_initialize( \
+ queue_context, \
+ mp_callout \
+#else
+ queue_context, \
+ mp_callout \
+ queue_context \
+#endif
RTEMS_INLINE_ROUTINE void _Thread_queue_Heads_initialize(
Thread_queue_Heads *heads
@@ -344,7 +387,7 @@ bool _Thread_queue_Do_extract_locked(
+ const Thread_queue_Context *queue_context
#endif
@@ -358,9 +401,8 @@ bool _Thread_queue_Do_extract_locked(
* @param[in] queue The actual thread queue.
* @param[in] operations The thread queue operations.
* @param[in] the_thread The thread to extract.
- * @param[in] mp_callout Callout to unblock the thread in case it is actually a
- * thread proxy. This parameter is only used on multiprocessing
- * configurations.
+ * @param[in] queue_context The thread queue context. This parameter is only
+ * used on multiprocessing configurations.
* @return Returns the unblock indicator for _Thread_queue_Unblock_critical().
* True indicates, that this thread must be unblocked by the scheduler later in
@@ -375,20 +417,20 @@ bool _Thread_queue_Do_extract_locked(
unblock, \
queue, \
the_thread, \
- mp_callout \
+ queue_context \
_Thread_queue_Do_extract_locked( \
unblock, \
queue, \
the_thread, \
- mp_callout \
+ queue_context \
#else
#define _Thread_queue_Extract_locked( \
unblock, \
queue, \
the_thread, \
- mp_callout \
+ queue_context \
unblock, \
@@ -418,16 +460,6 @@ void _Thread_queue_Unblock_critical(
-void _Thread_queue_Do_extract_critical(
- const Thread_queue_Operations *operations,
-#endif
* @brief Extracts the thread from the thread queue and unblocks it.
@@ -450,10 +482,11 @@ void _Thread_queue_Do_extract_critical(
* void _Mutex_Release( Mutex *mutex )
- * ISR_lock_Context lock_context;
- * Thread_Control *first;
+ * Thread_queue_Context queue_context;
+ * Thread_Control *first;
- * _Thread_queue_Acquire( &mutex->Queue, &lock_context );
+ * _Thread_queue_Context_initialize( &queue_context, NULL );
+ * _Thread_queue_Acquire( &mutex->Queue, &queue_context.Lock_context );
* first = _Thread_queue_First_locked( &mutex->Queue );
* mutex->owner = first;
@@ -463,9 +496,7 @@ void _Thread_queue_Do_extract_critical(
* &mutex->Queue.Queue,
* mutex->Queue.operations,
* first,
- * NULL,
- * 0,
- * &lock_context
+ * &queue_context
* @endcode
@@ -473,41 +504,14 @@ void _Thread_queue_Do_extract_critical(
- * configurations.
- * @param[in] lock_context The lock context of the lock acquire.
+ * @param[in] queue_context The thread queue context of the lock acquire.
- #define _Thread_queue_Extract_critical( \
- queue, \
- operations, \
- the_thread, \
- mp_callout, \
- lock_context \
- _Thread_queue_Do_extract_critical( \
- queue, \
- operations, \
- the_thread, \
- mp_callout, \
- lock_context \
-#else
- queue, \
- operations, \
- the_thread, \
- mp_callout, \
- lock_context \
- queue, \
- operations, \
- the_thread, \
- lock_context \
-#endif
+void _Thread_queue_Extract_critical(
+ const Thread_queue_Operations *operations,
* @brief Extracts thread from thread queue.
@@ -592,9 +596,10 @@ Thread_Control *_Thread_queue_First(
* optimize for architectures that use the same register for the first
* parameter and the return value.
* @param queue The actual thread queue.
- * @param lock_context The lock context of the lock acquire. May be used to
- * pass additional data to the filter function via an overlay structure. The
- * filter function should not release or acquire the thread queue lock.
+ * @param queue_context The thread queue context of the lock acquire. May be
+ * used to pass additional data to the filter function via an overlay
+ * structure. The filter function should not release or acquire the thread
+ * queue lock.
* @retval the_thread Extract this thread.
* @retval NULL Do not extract this thread and stop the thread queue flush
@@ -602,9 +607,9 @@ Thread_Control *_Thread_queue_First(
* operation.
typedef Thread_Control *( *Thread_queue_Flush_filter )(
@@ -612,24 +617,14 @@ typedef Thread_Control *( *Thread_queue_Flush_filter )(
* @param the_thread The thread to extract.
* @param queue Unused.
- * @param lock_context Unused.
+ * @param queue_context Unused.
Thread_Control *_Thread_queue_Flush_default_filter(
-size_t _Thread_queue_Do_flush_critical(
- Thread_queue_Flush_filter filter,
-#endif
@@ -647,41 +642,19 @@ size_t _Thread_queue_Do_flush_critical(
* the thread queue lock, for example to set the thread wait return code.
* The return value of the filter function controls if the thread queue flush
* operation should stop or continue.
- * @param mp_callout Callout to extract the proxy of a remote thread. This
- * parameter is only used on multiprocessing configurations.
+ * queue lock.
* @return The count of extracted threads.
- #define _Thread_queue_Flush_critical( \
- queue, \
- operations, \
- filter, \
- mp_callout, \
- lock_context \
- _Thread_queue_Do_flush_critical( \
- queue, \
- operations, \
- filter, \
- mp_callout, \
- lock_context \
-#else
- queue, \
- operations, \
- filter, \
- mp_callout, \
- lock_context \
- queue, \
- operations, \
- filter, \
- lock_context \
-#endif
+size_t _Thread_queue_Flush_critical(
void _Thread_queue_Initialize( Thread_queue_Control *the_thread_queue );
diff --git a/cpukit/score/src/apimutexlock.c b/cpukit/score/src/apimutexlock.c
index 79729d4..11d12c5 100644
--- a/cpukit/score/src/apimutexlock.c
+++ b/cpukit/score/src/apimutexlock.c
@@ -25,20 +25,21 @@
void _API_Mutex_Lock( API_Mutex_Control *the_mutex )
- Thread_Life_state previous_thread_life_state;
+ Thread_Life_state previous_thread_life_state;
previous_thread_life_state =
_Thread_Set_life_protection( THREAD_LIFE_PROTECTED );
- _ISR_lock_ISR_disable( &lock_context );
+ _ISR_lock_ISR_disable( &queue_context.Lock_context );
_CORE_mutex_Seize(
&the_mutex->Mutex,
_Thread_Executing,
true,
0,
- &lock_context
+ &queue_context
if ( the_mutex->Mutex.nest_count == 1 ) {
diff --git a/cpukit/score/src/apimutexunlock.c b/cpukit/score/src/apimutexunlock.c
index 082961f..f0f114e 100644
--- a/cpukit/score/src/apimutexunlock.c
+++ b/cpukit/score/src/apimutexunlock.c
@@ -24,19 +24,16 @@
void _API_Mutex_Unlock( API_Mutex_Control *the_mutex )
- bool restore_thread_life_protection;
+ bool restore_thread_life_protection;
previous_thread_life_state = the_mutex->previous_thread_life_state;
restore_thread_life_protection = the_mutex->Mutex.nest_count == 1;
- _CORE_mutex_Surrender(
- NULL,
- &lock_context
+ _CORE_mutex_Surrender( &the_mutex->Mutex, &queue_context );
if ( restore_thread_life_protection ) {
_Thread_Set_life_protection( previous_thread_life_state );
diff --git a/cpukit/score/src/condition.c b/cpukit/score/src/condition.c
index fcd93b2..c0320b2 100644
--- a/cpukit/score/src/condition.c
+++ b/cpukit/score/src/condition.c
@@ -220,54 +220,54 @@ int _Condition_Wait_recursive_timed(
typedef struct {
- ISR_lock_Context Base;
- int count;
-} Condition_Lock_context;
+ Thread_queue_Context Base;
+ int count;
+} Condition_Context;
static Thread_Control *_Condition_Flush_filter(
- Condition_Lock_context *condition_lock_context;
+ Condition_Context *context;
- condition_lock_context = (Condition_Lock_context *) lock_context;
+ context = (Condition_Context *) queue_context;
- if ( condition_lock_context->count <= 0 ) {
+ if ( context->count <= 0 ) {
return NULL;
- --condition_lock_context->count;
+ --context->count;
return the_thread;
static void _Condition_Wake( struct _Condition_Control *_condition, int count )
- Condition_Control *condition;
- Condition_Lock_context lock_context;
+ Condition_Control *condition;
+ Condition_Context context;
condition = _Condition_Get( _condition );
- _ISR_lock_ISR_disable( &lock_context.Base );
- _Condition_Queue_acquire_critical( condition, &lock_context.Base );
+ _Thread_queue_Context_initialize( &context.Base, NULL );
+ _ISR_lock_ISR_disable( &context.Base.Lock_context );
+ _Condition_Queue_acquire_critical( condition, &context.Base.Lock_context );
* In common uses cases of condition variables there are normally no threads
* on the queue, so check this condition early.
if ( __predict_true( _Thread_queue_Is_empty( &condition->Queue.Queue ) ) ) {
- _Condition_Queue_release( condition, &lock_context.Base );
+ _Condition_Queue_release( condition, &context.Base.Lock_context );
return;
- lock_context.count = count;
+ context.count = count;
&condition->Queue.Queue,
CONDITION_TQ_OPERATIONS,
_Condition_Flush_filter,
- NULL,
- &lock_context.Base
+ &context.Base
diff --git a/cpukit/score/src/corebarrier.c b/cpukit/score/src/corebarrier.c
index 3cb7906..a32f88c 100644
--- a/cpukit/score/src/corebarrier.c
+++ b/cpukit/score/src/corebarrier.c
@@ -33,9 +33,9 @@ void _CORE_barrier_Initialize(
the_thread->Wait.return_code = CORE_BARRIER_WAS_DELETED;
diff --git a/cpukit/score/src/corebarrierrelease.c b/cpukit/score/src/corebarrierrelease.c
index c9c80f4..8a23856 100644
--- a/cpukit/score/src/corebarrierrelease.c
+++ b/cpukit/score/src/corebarrierrelease.c
@@ -21,13 +21,10 @@
#include <rtems/score/corebarrierimpl.h>
-#endif
the_barrier->number_of_waiting_threads = 0;
@@ -35,7 +32,6 @@ uint32_t _CORE_barrier_Do_surrender(
&the_barrier->Wait_queue.Queue,
CORE_BARRIER_TQ_OPERATIONS,
filter,
- mp_callout,
- lock_context
+ queue_context
diff --git a/cpukit/score/src/corebarrierwait.c b/cpukit/score/src/corebarrierwait.c
index 54e9096..33f1718 100644
--- a/cpukit/score/src/corebarrierwait.c
+++ b/cpukit/score/src/corebarrierwait.c
@@ -21,22 +21,19 @@
- bool wait,
-#endif
+ bool wait,
uint32_t number_of_waiting_threads;
executing->Wait.return_code = CORE_BARRIER_STATUS_SUCCESSFUL;
- _CORE_barrier_Acquire_critical( the_barrier, lock_context );
+ _CORE_barrier_Acquire_critical( the_barrier, queue_context );
number_of_waiting_threads = the_barrier->number_of_waiting_threads;
++number_of_waiting_threads;
@@ -46,7 +43,7 @@ void _CORE_barrier_Do_seize(
&& number_of_waiting_threads == the_barrier->Attributes.maximum_count
executing->Wait.return_code = CORE_BARRIER_STATUS_AUTOMATICALLY_RELEASED;
- _CORE_barrier_Surrender( the_barrier, mp_callout, lock_context );
+ _CORE_barrier_Surrender( the_barrier, queue_context );
} else {
the_barrier->number_of_waiting_threads = number_of_waiting_threads;
_Thread_queue_Enqueue_critical(
@@ -56,7 +53,7 @@ void _CORE_barrier_Do_seize(
STATES_WAITING_FOR_BARRIER,
timeout,
CORE_BARRIER_TIMEOUT,
- lock_context
diff --git a/cpukit/score/src/coremsgbroadcast.c b/cpukit/score/src/coremsgbroadcast.c
index a7a962f..23dd343 100644
--- a/cpukit/score/src/coremsgbroadcast.c
+++ b/cpukit/score/src/coremsgbroadcast.c
@@ -21,28 +21,25 @@
const void *buffer,
size_t size,
-#endif
uint32_t *count,
uint32_t number_broadcasted;
if ( size > the_message_queue->maximum_message_size ) {
return CORE_MESSAGE_QUEUE_STATUS_INVALID_SIZE;
number_broadcasted = 0;
- _CORE_message_queue_Acquire_critical( the_message_queue, lock_context );
+ _CORE_message_queue_Acquire_critical( the_message_queue, queue_context );
while (
( the_thread =
@@ -50,18 +47,17 @@ CORE_message_queue_Status _CORE_message_queue_Do_broadcast(
the_message_queue,
buffer,
size,
- mp_callout,
0,
- lock_context
+ queue_context
number_broadcasted += 1;
- _CORE_message_queue_Acquire( the_message_queue, lock_context );
+ _CORE_message_queue_Acquire( the_message_queue, queue_context );
- _CORE_message_queue_Release( the_message_queue, lock_context );
+ _CORE_message_queue_Release( the_message_queue, queue_context );
*count = number_broadcasted;
return CORE_MESSAGE_QUEUE_STATUS_SUCCESSFUL;
diff --git a/cpukit/score/src/coremsgclose.c b/cpukit/score/src/coremsgclose.c
index 1951e9f..e24d756 100644
--- a/cpukit/score/src/coremsgclose.c
+++ b/cpukit/score/src/coremsgclose.c
@@ -22,9 +22,9 @@
static Thread_Control *_CORE_message_queue_Was_deleted(
the_thread->Wait.return_code = CORE_MESSAGE_QUEUE_STATUS_WAS_DELETED;
@@ -32,12 +32,9 @@ static Thread_Control *_CORE_message_queue_Was_deleted(
return the_thread;
-#endif
@@ -50,8 +47,7 @@ void _CORE_message_queue_Do_close(
_CORE_message_queue_Was_deleted,
- mp_callout,
- lock_context
+ queue_context
(void) _Workspace_Free( the_message_queue->message_buffers );
diff --git a/cpukit/score/src/coremsgflush.c b/cpukit/score/src/coremsgflush.c
index 38f26b7..e5b51f9 100644
--- a/cpukit/score/src/coremsgflush.c
+++ b/cpukit/score/src/coremsgflush.c
@@ -23,7 +23,7 @@
Chain_Node *inactive_head;
@@ -59,7 +59,7 @@ uint32_t _CORE_message_queue_Flush(
* fixed execution time that only deals with pending messages.
count = the_message_queue->number_of_pending_messages;
if ( count != 0 ) {
@@ -78,6 +78,6 @@ uint32_t _CORE_message_queue_Flush(
_Chain_Initialize_empty( &the_message_queue->Pending_messages );
return count;
diff --git a/cpukit/score/src/coremsgseize.c b/cpukit/score/src/coremsgseize.c
index fcc95a7..b05ddd6 100644
--- a/cpukit/score/src/coremsgseize.c
+++ b/cpukit/score/src/coremsgseize.c
@@ -24,7 +24,6 @@
-#include <rtems/score/wkspace.h>
@@ -33,7 +32,7 @@ void _CORE_message_queue_Seize(
size_t *size_p,
bool wait,
CORE_message_queue_Buffer_control *the_message;
@@ -58,7 +57,7 @@ void _CORE_message_queue_Seize(
* So return immediately.
_CORE_message_queue_Free_message_buffer(the_message_queue, the_message);
return;
#else
@@ -80,7 +79,7 @@ void _CORE_message_queue_Seize(
the_message_queue,
the_message
return;
@@ -100,8 +99,7 @@ void _CORE_message_queue_Seize(
the_thread,
- NULL,
- lock_context
+ queue_context
return;
@@ -109,7 +107,7 @@ void _CORE_message_queue_Seize(
if ( !wait ) {
executing->Wait.return_code = CORE_MESSAGE_QUEUE_STATUS_UNSATISFIED_NOWAIT;
return;
@@ -125,6 +123,6 @@ void _CORE_message_queue_Seize(
STATES_WAITING_FOR_MESSAGE,
timeout,
CORE_MESSAGE_QUEUE_STATUS_TIMEOUT,
- lock_context
diff --git a/cpukit/score/src/coremsgsubmit.c b/cpukit/score/src/coremsgsubmit.c
index 82cfa1a..06fd698 100644
--- a/cpukit/score/src/coremsgsubmit.c
+++ b/cpukit/score/src/coremsgsubmit.c
@@ -25,25 +25,22 @@
const void *buffer,
size_t size,
-#endif
bool wait,
@@ -55,9 +52,8 @@ CORE_message_queue_Status _CORE_message_queue_Do_submit(
the_message_queue,
buffer,
size,
- mp_callout,
submit_type,
- lock_context
+ queue_context
if ( the_thread != NULL ) {
@@ -90,20 +86,20 @@ CORE_message_queue_Status _CORE_message_queue_Do_submit(
( *the_message_queue->notify_handler )(
the_message_queue,
- lock_context
+ queue_context
} else {
#else
#endif
#if !defined(RTEMS_SCORE_COREMSG_ENABLE_BLOCKING_SEND)
return CORE_MESSAGE_QUEUE_STATUS_TOO_MANY;
#else
@@ -112,7 +108,7 @@ CORE_message_queue_Status _CORE_message_queue_Do_submit(
* on the queue.
if ( !wait ) {
@@ -121,7 +117,7 @@ CORE_message_queue_Status _CORE_message_queue_Do_submit(
* deadly to block in an ISR.
if ( _ISR_Is_in_progress() ) {
return CORE_MESSAGE_QUEUE_STATUS_UNSATISFIED;
@@ -142,7 +138,7 @@ CORE_message_queue_Status _CORE_message_queue_Do_submit(
timeout,
- lock_context
return CORE_MESSAGE_QUEUE_STATUS_UNSATISFIED_WAIT;
#endif
diff --git a/cpukit/score/src/coremutex.c b/cpukit/score/src/coremutex.c
index ea5e759..ecca244 100644
--- a/cpukit/score/src/coremutex.c
+++ b/cpukit/score/src/coremutex.c
@@ -92,9 +92,9 @@ CORE_mutex_Status _CORE_mutex_Initialize(
the_thread->Wait.return_code = CORE_MUTEX_WAS_DELETED;
@@ -103,9 +103,9 @@ Thread_Control *_CORE_mutex_Was_deleted(
the_thread->Wait.return_code = CORE_MUTEX_STATUS_UNSATISFIED_NOWAIT;
diff --git a/cpukit/score/src/coremutexsurrender.c b/cpukit/score/src/coremutexsurrender.c
index 746fee1..040a580 100644
--- a/cpukit/score/src/coremutexsurrender.c
+++ b/cpukit/score/src/coremutexsurrender.c
@@ -23,12 +23,9 @@
-#endif
@@ -46,17 +43,17 @@ CORE_mutex_Status _CORE_mutex_Do_surrender(
if ( the_mutex->Attributes.only_owner_release ) {
if ( !_Thread_Is_executing( holder ) ) {
return CORE_MUTEX_STATUS_NOT_OWNER_OF_RESOURCE;
/* XXX already unlocked -- not right status */
if ( !the_mutex->nest_count ) {
return CORE_MUTEX_STATUS_SUCCESSFUL;
@@ -71,12 +68,12 @@ CORE_mutex_Status _CORE_mutex_Do_surrender(
#if defined(RTEMS_DEBUG)
/* should never occur */
return CORE_MUTEX_STATUS_NESTING_NOT_ALLOWED;
#endif
@@ -84,7 +81,7 @@ CORE_mutex_Status _CORE_mutex_Do_surrender(
break;
#else
/* must be CORE_MUTEX_NESTING_ACQUIRES or we wouldn't be here */
#endif
@@ -126,7 +123,7 @@ CORE_mutex_Status _CORE_mutex_Do_surrender(
the_thread,
- mp_callout
+ queue_context
@@ -155,10 +152,10 @@ CORE_mutex_Status _CORE_mutex_Do_surrender(
unblock,
the_thread,
- lock_context
} else {
diff --git a/cpukit/score/src/corerwlockobtainread.c b/cpukit/score/src/corerwlockobtainread.c
index fcbaf4a..639ea70 100644
--- a/cpukit/score/src/corerwlockobtainread.c
+++ b/cpukit/score/src/corerwlockobtainread.c
@@ -24,11 +24,11 @@
- bool wait,
+ bool wait,
@@ -37,13 +37,13 @@ void _CORE_RWLock_Seize_for_reading(
* If any thread is waiting, then we wait.
- _CORE_RWLock_Acquire_critical( the_rwlock, lock_context );
+ _CORE_RWLock_Acquire_critical( the_rwlock, queue_context );
switch ( the_rwlock->current_state ) {
case CORE_RWLOCK_UNLOCKED:
the_rwlock->current_state = CORE_RWLOCK_LOCKED_FOR_READING;
the_rwlock->number_of_readers += 1;
- _CORE_RWLock_Release( the_rwlock, lock_context );
+ _CORE_RWLock_Release( the_rwlock, queue_context );
executing->Wait.return_code = CORE_RWLOCK_SUCCESSFUL;
return;
@@ -55,7 +55,7 @@ void _CORE_RWLock_Seize_for_reading(
if ( !waiter ) {
return;
@@ -70,7 +70,7 @@ void _CORE_RWLock_Seize_for_reading(
if ( !wait ) {
executing->Wait.return_code = CORE_RWLOCK_UNAVAILABLE;
return;
@@ -89,6 +89,6 @@ void _CORE_RWLock_Seize_for_reading(
STATES_WAITING_FOR_RWLOCK,
timeout,
CORE_RWLOCK_TIMEOUT,
- lock_context
diff --git a/cpukit/score/src/corerwlockobtainwrite.c b/cpukit/score/src/corerwlockobtainwrite.c
index e1bb1bd..a7d1bb1 100644
--- a/cpukit/score/src/corerwlockobtainwrite.c
+++ b/cpukit/score/src/corerwlockobtainwrite.c
@@ -24,11 +24,11 @@
- bool wait,
+ bool wait,
@@ -38,12 +38,12 @@ void _CORE_RWLock_Seize_for_writing(
the_rwlock->current_state = CORE_RWLOCK_LOCKED_FOR_WRITING;
return;
@@ -57,7 +57,7 @@ void _CORE_RWLock_Seize_for_writing(
if ( !wait ) {
return;
@@ -76,6 +76,6 @@ void _CORE_RWLock_Seize_for_writing(
timeout,
- lock_context
diff --git a/cpukit/score/src/corerwlockrelease.c b/cpukit/score/src/corerwlockrelease.c
index 6f76aad..81e01d1 100644
--- a/cpukit/score/src/corerwlockrelease.c
+++ b/cpukit/score/src/corerwlockrelease.c
@@ -35,9 +35,9 @@ static bool _CORE_RWLock_Is_waiting_for_reading(
static Thread_Control *_CORE_RWLock_Flush_filter(
CORE_RWLock_Control *the_rwlock;
@@ -74,8 +74,8 @@ static Thread_Control *_CORE_RWLock_Flush_filter(
@@ -85,11 +85,11 @@ CORE_RWLock_Status _CORE_RWLock_Surrender(
if ( the_rwlock->current_state == CORE_RWLOCK_UNLOCKED){
/* This is an error at the caller site */
return CORE_RWLOCK_SUCCESSFUL;
@@ -98,7 +98,7 @@ CORE_RWLock_Status _CORE_RWLock_Surrender(
if ( the_rwlock->number_of_readers != 0 ) {
/* must be unlocked again */
@@ -119,8 +119,7 @@ CORE_RWLock_Status _CORE_RWLock_Surrender(
&the_rwlock->Wait_queue.Queue,
CORE_RWLOCK_TQ_OPERATIONS,
_CORE_RWLock_Flush_filter,
- NULL,
- lock_context
+ queue_context
diff --git a/cpukit/score/src/coresem.c b/cpukit/score/src/coresem.c
index 02a3837..c94f2b7 100644
--- a/cpukit/score/src/coresem.c
+++ b/cpukit/score/src/coresem.c
@@ -38,9 +38,9 @@ void _CORE_semaphore_Initialize(
the_thread->Wait.return_code = CORE_SEMAPHORE_WAS_DELETED;
@@ -49,9 +49,9 @@ Thread_Control *_CORE_semaphore_Was_deleted(
the_thread->Wait.return_code = CORE_SEMAPHORE_STATUS_UNSATISFIED_NOWAIT;
diff --git a/cpukit/score/src/futex.c b/cpukit/score/src/futex.c
index 66085a8..d7945d1 100644
--- a/cpukit/score/src/futex.c
+++ b/cpukit/score/src/futex.c
@@ -104,25 +104,25 @@ int _Futex_Wait( struct _Futex_Control *_futex, int *uaddr, int val )
typedef struct {
- int count;
-} Futex_Lock_context;
+ int count;
+} Futex_Context;
static Thread_Control *_Futex_Flush_filter(
- Futex_Lock_context *futex_lock_context;
+ Futex_Context *context;
- futex_lock_context = (Futex_Lock_context *) lock_context;
+ context = (Futex_Context *) queue_context;
- if ( futex_lock_context->count <= 0 ) {
return NULL;
- --futex_lock_context->count;
+ --context->count;
return the_thread;
@@ -130,10 +130,10 @@ static Thread_Control *_Futex_Flush_filter(
int _Futex_Wake( struct _Futex_Control *_futex, int count )
Futex_Control *futex;
- Futex_Lock_context lock_context;
+ Futex_Context context;
futex = _Futex_Get( _futex );
- _Futex_Queue_acquire( futex, &lock_context.Base );
+ _Futex_Queue_acquire( futex, &context.Base.Lock_context );
* For some synchronization objects like barriers the _Futex_Wake() must be
@@ -141,17 +141,16 @@ int _Futex_Wake( struct _Futex_Control *_futex, int count )
* check this condition early.
if ( __predict_true( _Thread_queue_Is_empty( &futex->Queue.Queue ) ) ) {
- _Futex_Queue_release( futex, &lock_context.Base );
+ _Futex_Queue_release( futex, &context.Base.Lock_context );
return 0;
return (int) _Thread_queue_Flush_critical(
&futex->Queue.Queue,
FUTEX_TQ_OPERATIONS,
_Futex_Flush_filter,
- NULL,
+ &context.Base
diff --git a/cpukit/score/src/mpci.c b/cpukit/score/src/mpci.c
index 0b51e38..4022a80 100644
--- a/cpukit/score/src/mpci.c
+++ b/cpukit/score/src/mpci.c
@@ -321,24 +321,25 @@ void _MPCI_Receive_server(
- MP_packet_Prefix *the_packet;
- MPCI_Packet_processor the_function;
- Thread_Control *executing;
+ MP_packet_Prefix *the_packet;
+ MPCI_Packet_processor the_function;
+ Thread_Control *executing;
executing = _Thread_Get_executing();
for ( ; ; ) {
executing->receive_packet = NULL;
&_MPCI_Semaphore,
executing,
true,
WATCHDOG_NO_TIMEOUT,
- &lock_context
+ &queue_context
for ( ; ; ) {
@@ -370,10 +371,10 @@ void _MPCI_Receive_server(
void _MPCI_Announce ( void )
- (void) _CORE_semaphore_Surrender( &_MPCI_Semaphore, 0, &lock_context );
+ (void) _CORE_semaphore_Surrender( &_MPCI_Semaphore, &queue_context );
void _MPCI_Internal_packets_Send_process_packet (
diff --git a/cpukit/score/src/mutex.c b/cpukit/score/src/mutex.c
index e27075e..0b12232 100644
--- a/cpukit/score/src/mutex.c
+++ b/cpukit/score/src/mutex.c
@@ -125,11 +125,11 @@ static void _Mutex_Acquire_slow(
static void _Mutex_Release_slow(
- Mutex_Control *mutex,
- Thread_queue_Heads *heads,
- bool keep_priority,
+ Mutex_Control *mutex,
+ Thread_queue_Heads *heads,
+ bool keep_priority,
if (heads != NULL) {
@@ -146,17 +146,17 @@ static void _Mutex_Release_slow(
operations,
first,
- NULL
+ queue_context
_Thread_queue_Boost_priority( &mutex->Queue.Queue, first );
unblock,
first,
- lock_context
} else {
- _Mutex_Queue_release( mutex, lock_context);
+ _Mutex_Queue_release( mutex, &queue_context->Lock_context );
if ( !keep_priority ) {
@@ -169,9 +169,9 @@ static void _Mutex_Release_slow(
static void _Mutex_Release_critical(
Thread_queue_Heads *heads;
@@ -193,14 +193,14 @@ static void _Mutex_Release_critical(
|| !executing->priority_restore_hint;
if ( __predict_true( heads == NULL && keep_priority ) ) {
- _Mutex_Queue_release( mutex, lock_context );
} else {
mutex,
executing,
heads,
keep_priority,
- lock_context
+ queue_context
@@ -297,16 +297,17 @@ int _Mutex_Try_acquire( struct _Mutex_Control *_mutex )
void _Mutex_Release( struct _Mutex_Control *_mutex )
- Mutex_Control *mutex;
+ Mutex_Control *mutex;
mutex = _Mutex_Get( _mutex );
- executing = _Mutex_Queue_acquire( mutex, &lock_context );
+ executing = _Mutex_Queue_acquire( mutex, &queue_context.Lock_context );
_Assert( mutex->owner == executing );
- _Mutex_Release_critical( mutex, executing, &lock_context );
+ _Mutex_Release_critical( mutex, executing, &queue_context );
static Mutex_recursive_Control *_Mutex_recursive_Get(
@@ -426,23 +427,27 @@ int _Mutex_recursive_Try_acquire( struct _Mutex_recursive_Control *_mutex )
void _Mutex_recursive_Release( struct _Mutex_recursive_Control *_mutex )
Mutex_recursive_Control *mutex;
unsigned int nest_level;
mutex = _Mutex_recursive_Get( _mutex );
- executing = _Mutex_Queue_acquire( &mutex->Mutex, &lock_context );
+ &mutex->Mutex,
+ &queue_context.Lock_context
_Assert( mutex->Mutex.owner == executing );
nest_level = mutex->nest_level;
if ( __predict_true( nest_level == 0 ) ) {
- _Mutex_Release_critical( &mutex->Mutex, executing, &lock_context );
+ _Mutex_Release_critical( &mutex->Mutex, executing, &queue_context );
} else {
mutex->nest_level = nest_level - 1;
- _Mutex_Queue_release( &mutex->Mutex, &lock_context );
+ _Mutex_Queue_release( &mutex->Mutex, &queue_context.Lock_context );
diff --git a/cpukit/score/src/semaphore.c b/cpukit/score/src/semaphore.c
index 4e70b79..3d0d5f5 100644
--- a/cpukit/score/src/semaphore.c
+++ b/cpukit/score/src/semaphore.c
@@ -110,18 +110,19 @@ void _Semaphore_Wait( struct _Semaphore_Control *_sem )
void _Semaphore_Post( struct _Semaphore_Control *_sem )
- Semaphore_Control *sem;
- Thread_queue_Heads *heads;
+ Semaphore_Control *sem;
+ Thread_queue_Heads *heads;
sem = _Semaphore_Get( _sem );
- _Semaphore_Queue_acquire( sem, &lock_context );
+ _Semaphore_Queue_acquire( sem, &queue_context.Lock_context );
heads = sem->Queue.Queue.heads;
if ( heads == NULL ) {
_Assert( sem->count < UINT_MAX );
++sem->count;
- _Semaphore_Queue_release( sem, &lock_context );
+ _Semaphore_Queue_release( sem, &queue_context.Lock_context );
} else {
const Thread_queue_Operations *operations;
@@ -133,8 +134,7 @@ void _Semaphore_Post( struct _Semaphore_Control *_sem )
&sem->Queue.Queue,
operations,
first,
- NULL,
- &lock_context
+ &queue_context
diff --git a/cpukit/score/src/threadqenqueue.c b/cpukit/score/src/threadqenqueue.c
index cda7c86..a1a37e1 100644
--- a/cpukit/score/src/threadqenqueue.c
+++ b/cpukit/score/src/threadqenqueue.c
@@ -99,7 +99,7 @@ bool _Thread_queue_Do_extract_locked(
#endif
@@ -108,12 +108,13 @@ bool _Thread_queue_Do_extract_locked(
if ( !_Objects_Is_local_id( the_thread->Object.id ) ) {
- Thread_Proxy_control *the_proxy;
- _Assert( mp_callout != NULL );
+ Thread_Proxy_control *the_proxy;
the_proxy = (Thread_Proxy_control *) the_thread;
- the_proxy->thread_queue_callout = mp_callout;
+ mp_callout = queue_context->mp_callout;
+ _Assert( mp_callout != NULL );
+ the_proxy->thread_queue_callout = queue_context->mp_callout;
#endif
@@ -164,14 +165,11 @@ void _Thread_queue_Unblock_critical(
-#endif
bool unblock;
@@ -180,24 +178,28 @@ void _Thread_queue_Do_extract_critical(
queue,
operations,
the_thread,
- mp_callout
+ queue_context
unblock,
queue,
the_thread,
- lock_context
void _Thread_queue_Extract( Thread_Control *the_thread )
- void *lock;
- Thread_queue_Queue *queue;
+ void *lock;
+ Thread_queue_Queue *queue;
- lock = _Thread_Lock_acquire( the_thread, &lock_context );
+ &queue_context,
+ _Thread_queue_MP_callout_do_nothing
+ lock = _Thread_Lock_acquire( the_thread, &queue_context.Lock_context );
queue = the_thread->Wait.queue;
@@ -208,11 +210,10 @@ void _Thread_queue_Extract( Thread_Control *the_thread )
queue,
the_thread->Wait.operations,
the_thread,
- _Thread_queue_MP_callout_do_nothing,
- &lock_context
+ &queue_context
} else {
- _Thread_Lock_release( lock, &lock_context );
+ _Thread_Lock_release( lock, &queue_context.Lock_context );
@@ -225,10 +226,11 @@ Thread_Control *_Thread_queue_Do_dequeue(
#endif
- Thread_Control *the_thread;
+ Thread_Control *the_thread;
- _Thread_queue_Acquire( the_thread_queue, &lock_context );
+ _Thread_queue_Context_initialize( &queue_context, mp_callout );
+ _Thread_queue_Acquire( the_thread_queue, &queue_context.Lock_context );
the_thread = _Thread_queue_First_locked( the_thread_queue, operations );
@@ -239,11 +241,10 @@ Thread_Control *_Thread_queue_Do_dequeue(
&the_thread_queue->Queue,
operations,
the_thread,
- mp_callout,
- &lock_context
+ &queue_context
} else {
- _Thread_queue_Release( the_thread_queue, &lock_context );
+ _Thread_queue_Release( the_thread_queue, &queue_context.Lock_context );
return the_thread;
diff --git a/cpukit/score/src/threadqflush.c b/cpukit/score/src/threadqflush.c
index 0413388..8b23194 100644
--- a/cpukit/score/src/threadqflush.c
+++ b/cpukit/score/src/threadqflush.c
@@ -21,24 +21,21 @@
(void) queue;
- (void) lock_context;
return the_thread;
-#endif
size_t flushed;
@@ -60,7 +57,7 @@ size_t _Thread_queue_Do_flush_critical(
first = ( *operations->first )( heads );
- first = ( *filter )( first, queue, lock_context );
+ first = ( *filter )( first, queue, queue_context );
if ( first == NULL ) {
break;
@@ -69,7 +66,7 @@ size_t _Thread_queue_Do_flush_critical(
queue,
operations,
first,
- mp_callout
+ queue_context
if ( do_unblock ) {
_Chain_Append_unprotected( &unblock, &first->Wait.Node.Chain );
@@ -84,8 +81,10 @@ size_t _Thread_queue_Do_flush_critical(
if ( node != tail ) {
- _Thread_queue_Queue_release( queue, lock_context );
+ _Thread_queue_Queue_release( queue, &queue_context->Lock_context );
do {
@@ -100,7 +99,7 @@ size_t _Thread_queue_Do_flush_critical(
_Thread_Dispatch_enable( cpu_self );
} else {
return flushed;
diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
index 30536f7..52d68de 100644
--- a/cpukit/score/src/threadrestart.c
+++ b/cpukit/score/src/threadrestart.c
@@ -87,24 +87,24 @@ static void _Thread_Raise_real_priority(
typedef struct {
- void *exit_value;
+ void *exit_value;
#endif
-} Thread_Join_lock_context;
+} Thread_Join_context;
static Thread_Control *_Thread_Join_flush_filter(
- Thread_Join_lock_context *join_lock_context;
+ Thread_Join_context *join_context;
- join_lock_context = (Thread_Join_lock_context *) lock_context;
+ join_context = (Thread_Join_context *) queue_context;
- the_thread->Wait.return_argument = join_lock_context->exit_value;
+ the_thread->Wait.return_argument = join_context->exit_value;
return the_thread;
@@ -112,13 +112,17 @@ static Thread_Control *_Thread_Join_flush_filter(
static void _Thread_Wake_up_joining_threads( Thread_Control *the_thread )
- Thread_Join_lock_context join_lock_context;
+ Thread_Join_context join_context;
- join_lock_context.exit_value = the_thread->Life.exit_value;
+ join_context.exit_value = the_thread->Life.exit_value;
#endif
- _Thread_State_acquire( the_thread, &join_lock_context.Base );
+ _Thread_queue_Context_initialize( &join_context.Base, NULL );
+ &the_thread->Join_queue,
+ &join_context.Base.Lock_context
&the_thread->Join_queue.Queue,
THREAD_JOIN_TQ_OPERATIONS,
@@ -127,8 +131,7 @@ static void _Thread_Wake_up_joining_threads( Thread_Control *the_thread )
#else
#endif
- NULL,
- &join_lock_context.Base
diff --git a/testsuites/sptests/spintrcritical22/init.c b/testsuites/sptests/spintrcritical22/init.c
index b5044d9..3670d1a 100644
--- a/testsuites/sptests/spintrcritical22/init.c
+++ b/testsuites/sptests/spintrcritical22/init.c
@@ -33,12 +33,12 @@ static test_context ctx_instance;
static Semaphore_Control *get_semaphore_control(rtems_id id)
- sem = _Semaphore_Get(id, &lock_context);
+ sem = _Semaphore_Get(id, &queue_context, NULL);
rtems_test_assert(sem != NULL);
- _ISR_lock_ISR_enable(&lock_context);
+ _ISR_lock_ISR_enable(&queue_context.Lock_context);
return sem;
diff --git a/testsuites/tmtests/tm26/task1.c b/testsuites/tmtests/tm26/task1.c
index da37eee..68cb246 100644
--- a/testsuites/tmtests/tm26/task1.c
+++ b/testsuites/tmtests/tm26/task1.c
@@ -477,9 +477,10 @@ rtems_task Floating_point_task_2(
void complete_test( void )
- uint32_t index;
- rtems_id task_id;
+ uint32_t index;
+ rtems_id task_id;
+ ISR_lock_Context lock_context;
benchmark_timer_initialize();
thread_resume( Middle_tcb );
@@ -513,8 +514,8 @@ void complete_test( void )
for ( index=1 ; index <= OPERATION_COUNT ; index++ ) {
- (void) _Semaphore_Get( Semaphore_id, &lock_context );
- _ISR_lock_ISR_enable( &lock_context );
+ (void) _Semaphore_Get( Semaphore_id, &queue_context, NULL );
+ _ISR_lock_ISR_enable( &queue_context.Lock_context );
semaphore_get_time = benchmark_timer_read();
1.8.4.5
