[PATCH 5/5] score: Move thread queue MP callout to context
Gedare Bloom
gedare at rtems.org
Wed May 25 01:38:10 UTC 2016
I guess this means 1 more word of storage per thread queue in the MP
case, and 1 more dereference for each lock context access? It seems
reasonable.
On Tue, May 24, 2016 at 8:07 AM, Sebastian Huber
> Drop the multiprocessing (MP) dependent callout parameter from the
> thread queue extract, dequeue, flush and unblock methods. Merge this
> parameter with the lock context into new structure Thread_queue_Context.
> This helps to gets rid of the conditionally compiled method call
> helpers.
> cpukit/libnetworking/rtems/rtems_glue.c | 15 +-
> cpukit/posix/include/rtems/posix/barrierimpl.h | 7 +-
> cpukit/posix/include/rtems/posix/condimpl.h | 15 +-
> cpukit/posix/include/rtems/posix/mqueueimpl.h | 14 +-
> cpukit/posix/include/rtems/posix/muteximpl.h | 4 +-
> cpukit/posix/include/rtems/posix/posixapi.h | 8 +-
> cpukit/posix/include/rtems/posix/rwlockimpl.h | 4 +-
> cpukit/posix/include/rtems/posix/semaphoreimpl.h | 9 +-
> cpukit/posix/src/conddestroy.c | 10 +-
> cpukit/posix/src/condget.c | 6 +-
> cpukit/posix/src/condsignalsupp.c | 11 +-
> cpukit/posix/src/condwaitsupp.c | 21 +-
> cpukit/posix/src/mqueueclose.c | 10 +-
> cpukit/posix/src/mqueuedeletesupp.c | 10 +-
> cpukit/posix/src/mqueuegetattr.c | 10 +-
> cpukit/posix/src/mqueuenotify.c | 16 +-
> cpukit/posix/src/mqueuerecvsupp.c | 14 +-
> cpukit/posix/src/mqueuesendsupp.c | 13 +-
> cpukit/posix/src/mqueuesetattr.c | 10 +-
> cpukit/posix/src/mqueueunlink.c | 6 +-
> cpukit/posix/src/mutexdestroy.c | 14 +-
> cpukit/posix/src/mutexget.c | 6 +-
> cpukit/posix/src/mutexgetprioceiling.c | 10 +-
> cpukit/posix/src/mutexlocksupp.c | 10 +-
> cpukit/posix/src/mutexsetprioceiling.c | 7 +-
> cpukit/posix/src/mutexunlock.c | 14 +-
> cpukit/posix/src/pbarrierdestroy.c | 10 +-
> cpukit/posix/src/pbarrierwait.c | 7 +-
> cpukit/posix/src/prwlockdestroy.c | 10 +-
> cpukit/posix/src/prwlockinit.c | 6 +-
> cpukit/posix/src/prwlockrdlock.c | 6 +-
> cpukit/posix/src/prwlocktimedrdlock.c | 6 +-
> cpukit/posix/src/prwlocktimedwrlock.c | 6 +-
> cpukit/posix/src/prwlocktryrdlock.c | 6 +-
> cpukit/posix/src/prwlocktrywrlock.c | 6 +-
> cpukit/posix/src/prwlockunlock.c | 6 +-
> cpukit/posix/src/prwlockwrlock.c | 6 +-
> cpukit/posix/src/semaphoredeletesupp.c | 10 +-
> cpukit/posix/src/semaphorewaitsupp.c | 6 +-
> cpukit/posix/src/semclose.c | 8 +-
> cpukit/posix/src/semdestroy.c | 10 +-
> cpukit/posix/src/semgetvalue.c | 15 +-
> cpukit/posix/src/sempost.c | 7 +-
> cpukit/posix/src/semunlink.c | 8 +-
> cpukit/rtems/include/rtems/rtems/barrierimpl.h | 7 +-
> cpukit/rtems/include/rtems/rtems/messageimpl.h | 21 +-
> cpukit/rtems/include/rtems/rtems/semimpl.h | 21 +-
> cpukit/rtems/src/barrierdelete.c | 10 +-
> cpukit/rtems/src/barrierrelease.c | 11 +-
> cpukit/rtems/src/barrierwait.c | 11 +-
> cpukit/rtems/src/msgmp.c | 12 +-
> cpukit/rtems/src/msgqbroadcast.c | 11 +-
> cpukit/rtems/src/msgqdelete.c | 13 +-
> cpukit/rtems/src/msgqflush.c | 6 +-
> cpukit/rtems/src/msgqgetnumberpending.c | 8 +-
> cpukit/rtems/src/msgqreceive.c | 8 +-
> cpukit/rtems/src/msgqsend.c | 13 +-
> cpukit/rtems/src/msgqurgent.c | 13 +-
> cpukit/rtems/src/semdelete.c | 30 +-
> cpukit/rtems/src/semflush.c | 24 +-
> cpukit/rtems/src/semobtain.c | 18 +-
> cpukit/rtems/src/semrelease.c | 16 +-
> cpukit/rtems/src/semsetpriority.c | 28 +-
> cpukit/score/include/rtems/score/corebarrierimpl.h | 150 +++------
> cpukit/score/include/rtems/score/coremsg.h | 2 +-
> cpukit/score/include/rtems/score/coremsgimpl.h | 341 ++++++---------------
> cpukit/score/include/rtems/score/coremuteximpl.h | 135 ++++----
> cpukit/score/include/rtems/score/corerwlockimpl.h | 42 +--
> cpukit/score/include/rtems/score/coresemimpl.h | 166 +++++-----
> cpukit/score/include/rtems/score/mrspimpl.h | 97 +++---
> cpukit/score/include/rtems/score/threadq.h | 12 +
> cpukit/score/include/rtems/score/threadqimpl.h | 191 +++++-------
> cpukit/score/src/apimutexlock.c | 9 +-
> cpukit/score/src/apimutexunlock.c | 15 +-
> cpukit/score/src/condition.c | 36 +--
> cpukit/score/src/corebarrier.c | 6 +-
> cpukit/score/src/corebarrierrelease.c | 10 +-
> cpukit/score/src/corebarrierwait.c | 21 +-
> cpukit/score/src/coremsgbroadcast.c | 18 +-
> cpukit/score/src/coremsgclose.c | 16 +-
> cpukit/score/src/coremsgflush.c | 6 +-
> cpukit/score/src/coremsgseize.c | 14 +-
> cpukit/score/src/coremsgsubmit.c | 26 +-
> cpukit/score/src/coremutex.c | 12 +-
> cpukit/score/src/coremutexsurrender.c | 27 +-
> cpukit/score/src/corerwlockobtainread.c | 20 +-
> cpukit/score/src/corerwlockobtainwrite.c | 18 +-
> cpukit/score/src/corerwlockrelease.c | 19 +-
> cpukit/score/src/coresem.c | 12 +-
> cpukit/score/src/futex.c | 31 +-
> cpukit/score/src/mpci.c | 19 +-
> cpukit/score/src/mutex.c | 49 +--
> cpukit/score/src/semaphore.c | 14 +-
> cpukit/score/src/threadqenqueue.c | 51 +--
> cpukit/score/src/threadqflush.c | 27 +-
> cpukit/score/src/threadrestart.c | 31 +-
> testsuites/sptests/spintrcritical22/init.c | 6 +-
> testsuites/tmtests/tm26/task1.c | 11 +-
> 98 files changed, 1048 insertions(+), 1306 deletions(-)
> diff --git a/cpukit/libnetworking/rtems/rtems_glue.c b/cpukit/libnetworking/rtems/rtems_glue.c
> index 9ece2b1..edf551e 100644
> --- a/cpukit/libnetworking/rtems/rtems_glue.c
> +++ b/cpukit/libnetworking/rtems/rtems_glue.c
> @@ -371,18 +371,19 @@ void
> rtems_bsdnet_semaphore_obtain (void)
> #ifdef RTEMS_FAST_MUTEX
> - ISR_lock_Context lock_context;
> + Thread_queue_Context queue_context;
> Thread_Control *executing;
> - _ISR_lock_ISR_disable(&lock_context);
> if (!the_networkSemaphore)
> rtems_panic ("rtems-net: network sema obtain: network not initialised\n");
> + _Thread_queue_Context_initialize(&queue_context, NULL);
> + _ISR_lock_ISR_disable(&queue_context.Lock_context);
> executing = _Thread_Executing;
> _CORE_mutex_Seize (
> &the_networkSemaphore->Core_control.mutex,
> executing,
> 1, /* wait */
> 0, /* forever */
> - &lock_context
> + &queue_context
> if (executing->Wait.return_code)
> rtems_panic ("rtems-net: can't obtain network sema: %d\n",
> @@ -404,16 +405,16 @@ void
> rtems_bsdnet_semaphore_release (void)
> CORE_mutex_Status status;
> status = _CORE_mutex_Surrender (
> - NULL,
> - &lock_context
> + &queue_context
> if (status != CORE_MUTEX_STATUS_SUCCESSFUL)
> rtems_panic ("rtems-net: can't release network sema: %i\n");
> diff --git a/cpukit/posix/include/rtems/posix/barrierimpl.h b/cpukit/posix/include/rtems/posix/barrierimpl.h
> index 5173531..e04f135 100644
> --- a/cpukit/posix/include/rtems/posix/barrierimpl.h
> +++ b/cpukit/posix/include/rtems/posix/barrierimpl.h
> @@ -77,14 +77,15 @@ RTEMS_INLINE_ROUTINE void _POSIX_Barrier_Free (
> _Objects_Free( &_POSIX_Barrier_Information, &the_barrier->Object );
> -RTEMS_INLINE_ROUTINE POSIX_Barrier_Control *_POSIX_Barrier_Get (
> +RTEMS_INLINE_ROUTINE POSIX_Barrier_Control *_POSIX_Barrier_Get(
> const pthread_barrier_t *barrier,
> - ISR_lock_Context *lock_context
> + Thread_queue_Context *queue_context
> + _Thread_queue_Context_initialize( queue_context, NULL );
> return (POSIX_Barrier_Control *) _Objects_Get(
> (Objects_Id) *barrier,
> - lock_context,
> + &queue_context->Lock_context,
> diff --git a/cpukit/posix/include/rtems/posix/condimpl.h b/cpukit/posix/include/rtems/posix/condimpl.h
> index b178869..736f06b 100644
> --- a/cpukit/posix/include/rtems/posix/condimpl.h
> +++ b/cpukit/posix/include/rtems/posix/condimpl.h
> @@ -63,18 +63,21 @@ RTEMS_INLINE_ROUTINE void _POSIX_Condition_variables_Destroy(
> RTEMS_INLINE_ROUTINE void _POSIX_Condition_variables_Acquire_critical(
> POSIX_Condition_variables_Control *the_cond,
> - _Thread_queue_Acquire_critical( &the_cond->Wait_queue, lock_context );
> + _Thread_queue_Acquire_critical(
> + &the_cond->Wait_queue,
> RTEMS_INLINE_ROUTINE void _POSIX_Condition_variables_Release(
> - _Thread_queue_Release( &the_cond->Wait_queue, lock_context );
> + _Thread_queue_Release( &the_cond->Wait_queue, &queue_context->Lock_context );
> @@ -107,8 +110,8 @@ RTEMS_INLINE_ROUTINE void _POSIX_Condition_variables_Free (
> POSIX_Condition_variables_Control *_POSIX_Condition_variables_Get(
> - pthread_cond_t *cond,
> + pthread_cond_t *cond,
> diff --git a/cpukit/posix/include/rtems/posix/mqueueimpl.h b/cpukit/posix/include/rtems/posix/mqueueimpl.h
> index 3185970..2317358 100644
> --- a/cpukit/posix/include/rtems/posix/mqueueimpl.h
> +++ b/cpukit/posix/include/rtems/posix/mqueueimpl.h
> @@ -43,7 +43,7 @@ extern Objects_Information _POSIX_Message_queue_Information;
> void _POSIX_Message_queue_Delete(
> POSIX_Message_queue_Control *the_mq,
> @@ -107,12 +107,16 @@ RTEMS_INLINE_ROUTINE void _POSIX_Message_queue_Free(
> RTEMS_INLINE_ROUTINE POSIX_Message_queue_Control *_POSIX_Message_queue_Get(
> - Objects_Id id,
> + Objects_Id id,
> - return (POSIX_Message_queue_Control *)
> - _Objects_Get( id, lock_context, &_POSIX_Message_queue_Information );
> + return (POSIX_Message_queue_Control *) _Objects_Get(
> + id,
> + &_POSIX_Message_queue_Information
> diff --git a/cpukit/posix/include/rtems/posix/muteximpl.h b/cpukit/posix/include/rtems/posix/muteximpl.h
> index 7627d3d..4c7852b 100644
> --- a/cpukit/posix/include/rtems/posix/muteximpl.h
> +++ b/cpukit/posix/include/rtems/posix/muteximpl.h
> @@ -127,8 +127,8 @@ RTEMS_INLINE_ROUTINE int _POSIX_Mutex_Translate_core_mutex_return_code(
> * @note: This version of the method uses an interrupt critical section.
> POSIX_Mutex_Control *_POSIX_Mutex_Get(
> - pthread_mutex_t *mutex,
> + pthread_mutex_t *mutex,
> RTEMS_INLINE_ROUTINE POSIX_Mutex_Control *_POSIX_Mutex_Get_no_protection(
> diff --git a/cpukit/posix/include/rtems/posix/posixapi.h b/cpukit/posix/include/rtems/posix/posixapi.h
> index a16b6ad..a5afe92 100644
> --- a/cpukit/posix/include/rtems/posix/posixapi.h
> +++ b/cpukit/posix/include/rtems/posix/posixapi.h
> @@ -71,7 +71,7 @@ RTEMS_INLINE_ROUTINE int _POSIX_Get_by_name_error(
> #define _POSIX_Get_object_body( \
> type, \
> id, \
> - lock_context, \
> + queue_context, \
> info, \
> initializer, \
> init \
> @@ -80,14 +80,16 @@ RTEMS_INLINE_ROUTINE int _POSIX_Get_by_name_error(
> if ( id == NULL ) { \
> return NULL; \
> - the_object = _Objects_Get( (Objects_Id) *id, lock_context, info ); \
> + the_object = \
> + _Objects_Get( (Objects_Id) *id, &queue_context->Lock_context, info ); \
> if ( the_object == NULL ) { \
> _Once_Lock(); \
> if ( *id == initializer ) { \
> init( id, NULL ); \
> _Once_Unlock(); \
> + the_object = \
> return (type *) the_object
> diff --git a/cpukit/posix/include/rtems/posix/rwlockimpl.h b/cpukit/posix/include/rtems/posix/rwlockimpl.h
> index 6f3088e..4ab9395 100644
> --- a/cpukit/posix/include/rtems/posix/rwlockimpl.h
> +++ b/cpukit/posix/include/rtems/posix/rwlockimpl.h
> @@ -87,8 +87,8 @@ RTEMS_INLINE_ROUTINE void _POSIX_RWLock_Free (
> POSIX_RWLock_Control *_POSIX_RWLock_Get(
> - pthread_rwlock_t *rwlock,
> + pthread_rwlock_t *rwlock,
> #ifdef __cplusplus
> diff --git a/cpukit/posix/include/rtems/posix/semaphoreimpl.h b/cpukit/posix/include/rtems/posix/semaphoreimpl.h
> index 402329a..10d7cee 100644
> --- a/cpukit/posix/include/rtems/posix/semaphoreimpl.h
> +++ b/cpukit/posix/include/rtems/posix/semaphoreimpl.h
> @@ -61,13 +61,14 @@ RTEMS_INLINE_ROUTINE void _POSIX_Semaphore_Free (
> RTEMS_INLINE_ROUTINE POSIX_Semaphore_Control *_POSIX_Semaphore_Get(
> - const sem_t *id,
> + const sem_t *id,
> return (POSIX_Semaphore_Control *) _Objects_Get(
> (Objects_Id) *id,
> - lock_context,
> &_POSIX_Semaphore_Information
> @@ -93,7 +94,7 @@ int _POSIX_Semaphore_Create_support(
> void _POSIX_Semaphore_Delete(
> POSIX_Semaphore_Control *the_semaphore,
> diff --git a/cpukit/posix/src/conddestroy.c b/cpukit/posix/src/conddestroy.c
> index d47c6b2..a2c8dc1 100644
> --- a/cpukit/posix/src/conddestroy.c
> +++ b/cpukit/posix/src/conddestroy.c
> @@ -29,20 +29,20 @@ int pthread_cond_destroy(
> POSIX_Condition_variables_Control *the_cond;
> _Objects_Allocator_lock();
> - the_cond = _POSIX_Condition_variables_Get( cond, &lock_context );
> + the_cond = _POSIX_Condition_variables_Get( cond, &queue_context );
> if ( the_cond == NULL ) {
> _Objects_Allocator_unlock();
> return EINVAL;
> - _POSIX_Condition_variables_Acquire_critical( the_cond, &lock_context );
> + _POSIX_Condition_variables_Acquire_critical( the_cond, &queue_context );
> if ( !_Thread_queue_Is_empty( &the_cond->Wait_queue.Queue ) ) {
> - _POSIX_Condition_variables_Release( the_cond, &lock_context );
> + _POSIX_Condition_variables_Release( the_cond, &queue_context );
> return EBUSY;
> @@ -51,7 +51,7 @@ int pthread_cond_destroy(
> &_POSIX_Condition_variables_Information,
> &the_cond->Object
> _POSIX_Condition_variables_Destroy( the_cond );
> _POSIX_Condition_variables_Free( the_cond );
> diff --git a/cpukit/posix/src/condget.c b/cpukit/posix/src/condget.c
> index 5676de8..5b086ef 100644
> --- a/cpukit/posix/src/condget.c
> +++ b/cpukit/posix/src/condget.c
> @@ -15,14 +15,14 @@
> #include <rtems/posix/posixapi.h>
> POSIX_Condition_variables_Control,
> cond,
> - lock_context,
> + queue_context,
> PTHREAD_COND_INITIALIZER,
> pthread_cond_init
> diff --git a/cpukit/posix/src/condsignalsupp.c b/cpukit/posix/src/condsignalsupp.c
> index 38aa053..e42476e 100644
> --- a/cpukit/posix/src/condsignalsupp.c
> +++ b/cpukit/posix/src/condsignalsupp.c
> @@ -36,15 +36,15 @@ int _POSIX_Condition_variables_Signal_support(
> do {
> return EINVAL;
> the_thread = _Thread_queue_First_locked(
> @@ -56,12 +56,11 @@ int _POSIX_Condition_variables_Signal_support(
> &the_cond->Wait_queue.Queue,
> POSIX_CONDITION_VARIABLES_TQ_OPERATIONS,
> the_thread,
> - NULL,
> - &lock_context
> + &queue_context
> } else {
> the_cond->mutex = POSIX_CONDITION_VARIABLES_NO_MUTEX;
> } while ( is_broadcast && the_thread != NULL );
> diff --git a/cpukit/posix/src/condwaitsupp.c b/cpukit/posix/src/condwaitsupp.c
> index 11b0587..4e89ef0 100644
> --- a/cpukit/posix/src/condwaitsupp.c
> +++ b/cpukit/posix/src/condwaitsupp.c
> @@ -35,7 +35,7 @@ int _POSIX_Condition_variables_Wait_support(
> POSIX_Mutex_Control *the_mutex;
> int status;
> int mutex_status;
> CORE_mutex_Status core_mutex_status;
> @@ -46,25 +46,25 @@ int _POSIX_Condition_variables_Wait_support(
> return EINVAL;
> return EINVAL;
> if (
> the_cond->mutex != POSIX_CONDITION_VARIABLES_NO_MUTEX
> && the_cond->mutex != *mutex
> return EINVAL;
> the_cond->mutex = *mutex;
> - cpu_self = _Thread_Dispatch_disable_critical( &lock_context );
> + cpu_self = _Thread_Dispatch_disable_critical( &queue_context.Lock_context );
> executing = _Per_CPU_Get_executing( cpu_self );
> @@ -78,7 +78,7 @@ int _POSIX_Condition_variables_Wait_support(
> the_mutex == NULL
> || !_CORE_mutex_Is_owner( &the_mutex->Mutex, executing )
> _Thread_Dispatch_enable( cpu_self );
> return EPERM;
> @@ -92,18 +92,17 @@ int _POSIX_Condition_variables_Wait_support(
> STATES_WAITING_FOR_CONDITION_VARIABLE,
> timeout,
> ETIMEDOUT,
> - &lock_context
> + &queue_context.Lock_context
> } else {
> executing->Wait.return_code = ETIMEDOUT;
> - _ISR_lock_ISR_disable( &lock_context );
> + _ISR_lock_ISR_disable( &queue_context.Lock_context );
> core_mutex_status = _CORE_mutex_Surrender(
> &the_mutex->Mutex,
> - NULL,
> - &lock_context
> + &queue_context
> _Assert( core_mutex_status == CORE_MUTEX_STATUS_SUCCESSFUL );
> (void) core_mutex_status;
> diff --git a/cpukit/posix/src/mqueueclose.c b/cpukit/posix/src/mqueueclose.c
> index 28a7d16..60d3ce3 100644
> --- a/cpukit/posix/src/mqueueclose.c
> +++ b/cpukit/posix/src/mqueueclose.c
> @@ -42,10 +42,10 @@ int mq_close(
> POSIX_Message_queue_Control *the_mq;
> - the_mq = _POSIX_Message_queue_Get( mqdes, &lock_context );
> + the_mq = _POSIX_Message_queue_Get( mqdes, &queue_context );
> if ( the_mq == NULL ) {
> @@ -54,17 +54,17 @@ int mq_close(
> _CORE_message_queue_Acquire_critical(
> &the_mq->Message_queue,
> - &lock_context
> + &queue_context
> if ( the_mq->open_count == 0 ) {
> - _CORE_message_queue_Release( &the_mq->Message_queue, &lock_context );
> + _CORE_message_queue_Release( &the_mq->Message_queue, &queue_context );
> rtems_set_errno_and_return_minus_one( EBADF );
> the_mq->open_count -= 1;
> - _POSIX_Message_queue_Delete( the_mq, &lock_context );
> + _POSIX_Message_queue_Delete( the_mq, &queue_context );
> return 0;
> diff --git a/cpukit/posix/src/mqueuedeletesupp.c b/cpukit/posix/src/mqueuedeletesupp.c
> index 485136c..850707a 100644
> --- a/cpukit/posix/src/mqueuedeletesupp.c
> +++ b/cpukit/posix/src/mqueuedeletesupp.c
> @@ -22,17 +22,13 @@
> if ( !the_mq->linked && the_mq->open_count == 0 ) {
> - _CORE_message_queue_Close(
> - &the_mq->Message_queue,
> - NULL, /* no MP support */
> - lock_context
> + _CORE_message_queue_Close( &the_mq->Message_queue, queue_context );
> _POSIX_Message_queue_Free( the_mq );
> } else {
> - _CORE_message_queue_Release( &the_mq->Message_queue, lock_context );
> + _CORE_message_queue_Release( &the_mq->Message_queue, queue_context );
> diff --git a/cpukit/posix/src/mqueuegetattr.c b/cpukit/posix/src/mqueuegetattr.c
> index dae14e3..5efcc0b 100644
> --- a/cpukit/posix/src/mqueuegetattr.c
> +++ b/cpukit/posix/src/mqueuegetattr.c
> @@ -42,13 +42,13 @@ int mq_getattr(
> if ( mqstat == NULL ) {
> rtems_set_errno_and_return_minus_one( EINVAL );
> @@ -56,11 +56,11 @@ int mq_getattr(
> - &lock_context
> + &queue_context
> @@ -72,6 +72,6 @@ int mq_getattr(
> mqstat->mq_maxmsg = the_mq->Message_queue.maximum_pending_messages;
> mqstat->mq_curmsgs = the_mq->Message_queue.number_of_pending_messages;
> return 0;
> diff --git a/cpukit/posix/src/mqueuenotify.c b/cpukit/posix/src/mqueuenotify.c
> index adcfdcb..a1f9a08 100644
> --- a/cpukit/posix/src/mqueuenotify.c
> +++ b/cpukit/posix/src/mqueuenotify.c
> @@ -24,7 +24,7 @@
> static void _POSIX_Message_queue_Notify_handler(
> CORE_message_queue_Control *the_message_queue,
> @@ -38,7 +38,7 @@ static void _POSIX_Message_queue_Notify_handler(
> signo = the_mq->notification.sigev_signo;
> _CORE_message_queue_Set_notify( &the_mq->Message_queue, NULL );
> kill( getpid(), signo );
> @@ -49,9 +49,9 @@ int mq_notify(
> @@ -59,17 +59,17 @@ int mq_notify(
> - &lock_context
> + &queue_context
> if ( notification != NULL ) {
> if ( _CORE_message_queue_Is_notify_enabled( &the_mq->Message_queue ) ) {
> rtems_set_errno_and_return_minus_one( EBUSY );
> @@ -83,6 +83,6 @@ int mq_notify(
> return 0;
> diff --git a/cpukit/posix/src/mqueuerecvsupp.c b/cpukit/posix/src/mqueuerecvsupp.c
> index b5a790a..541786a 100644
> --- a/cpukit/posix/src/mqueuerecvsupp.c
> +++ b/cpukit/posix/src/mqueuerecvsupp.c
> @@ -44,24 +44,24 @@ ssize_t _POSIX_Message_queue_Receive_support(
> size_t length_out;
> bool do_wait;
> if ( ( the_mq->oflag & O_ACCMODE ) == O_WRONLY ) {
> - _ISR_lock_ISR_enable( &lock_context );
> + _ISR_lock_ISR_enable( &queue_context.Lock_context );
> if ( msg_len < the_mq->Message_queue.maximum_message_size ) {
> rtems_set_errno_and_return_minus_one( EMSGSIZE );
> @@ -83,11 +83,11 @@ ssize_t _POSIX_Message_queue_Receive_support(
> - &lock_context
> + &queue_context
> @@ -102,7 +102,7 @@ ssize_t _POSIX_Message_queue_Receive_support(
> &length_out,
> do_wait,
> timeout,
> - &lock_context
> + &queue_context
> if ( msg_prio != NULL ) {
> diff --git a/cpukit/posix/src/mqueuesendsupp.c b/cpukit/posix/src/mqueuesendsupp.c
> index 1053df9..e9848c2 100644
> --- a/cpukit/posix/src/mqueuesendsupp.c
> +++ b/cpukit/posix/src/mqueuesendsupp.c
> @@ -44,7 +44,7 @@ int _POSIX_Message_queue_Send_support(
> CORE_message_queue_Status msg_status;
> bool do_wait;
> @@ -58,14 +58,14 @@ int _POSIX_Message_queue_Send_support(
> if ( ( the_mq->oflag & O_ACCMODE ) == O_RDONLY ) {
> @@ -80,11 +80,11 @@ int _POSIX_Message_queue_Send_support(
> - &lock_context
> + &queue_context
> @@ -97,11 +97,10 @@ int _POSIX_Message_queue_Send_support(
> executing,
> msg_ptr,
> msg_len,
> - NULL,
> _POSIX_Message_queue_Priority_to_core( msg_prio ),
> do_wait,
> timeout,
> - &lock_context
> + &queue_context
> diff --git a/cpukit/posix/src/mqueuesetattr.c b/cpukit/posix/src/mqueuesetattr.c
> index dfd9bab..fc9fc75 100644
> --- a/cpukit/posix/src/mqueuesetattr.c
> +++ b/cpukit/posix/src/mqueuesetattr.c
> @@ -27,13 +27,13 @@ int mq_setattr(
> @@ -41,11 +41,11 @@ int mq_setattr(
> - &lock_context
> + &queue_context
> @@ -62,6 +62,6 @@ int mq_setattr(
> the_mq->oflag = mqstat->mq_flags;
> return 0;
> diff --git a/cpukit/posix/src/mqueueunlink.c b/cpukit/posix/src/mqueueunlink.c
> index dc485ba..812f249 100644
> --- a/cpukit/posix/src/mqueueunlink.c
> +++ b/cpukit/posix/src/mqueueunlink.c
> @@ -30,7 +30,7 @@ int mq_unlink(
> Objects_Get_by_name_error error;
> @@ -42,10 +42,10 @@ int mq_unlink(
> _POSIX_Message_queue_Namespace_remove( the_mq );
> - _CORE_message_queue_Acquire( &the_mq->Message_queue, &lock_context );
> + _CORE_message_queue_Acquire( &the_mq->Message_queue, &queue_context );
> the_mq->linked = false;
> return 0;
> diff --git a/cpukit/posix/src/mutexdestroy.c b/cpukit/posix/src/mutexdestroy.c
> index 640acc0..7fda7d3 100644
> --- a/cpukit/posix/src/mutexdestroy.c
> +++ b/cpukit/posix/src/mutexdestroy.c
> @@ -28,16 +28,16 @@ int pthread_mutex_destroy(
> - POSIX_Mutex_Control *the_mutex;
> - int eno;
> + POSIX_Mutex_Control *the_mutex;
> + int eno;
> - the_mutex = _POSIX_Mutex_Get( mutex, &lock_context );
> + the_mutex = _POSIX_Mutex_Get( mutex, &queue_context );
> if ( the_mutex != NULL ) {
> - _CORE_mutex_Acquire_critical( &the_mutex->Mutex, &lock_context );
> + _CORE_mutex_Acquire_critical( &the_mutex->Mutex, &queue_context );
> * XXX: There is an error for the mutex being locked
> @@ -46,12 +46,12 @@ int pthread_mutex_destroy(
> if ( !_CORE_mutex_Is_locked( &the_mutex->Mutex ) ) {
> _Objects_Close( &_POSIX_Mutex_Information, &the_mutex->Object );
> - _CORE_mutex_Release( &the_mutex->Mutex, &lock_context );
> + _CORE_mutex_Release( &the_mutex->Mutex, &queue_context );
> _CORE_mutex_Destroy( &the_mutex->Mutex );
> _POSIX_Mutex_Free( the_mutex );
> eno = 0;
> } else {
> eno = EBUSY;
> } else {
> diff --git a/cpukit/posix/src/mutexget.c b/cpukit/posix/src/mutexget.c
> index f8f0033..e90c41c 100644
> --- a/cpukit/posix/src/mutexget.c
> +++ b/cpukit/posix/src/mutexget.c
> @@ -22,14 +22,14 @@
> POSIX_Mutex_Control,
> mutex,
> - lock_context,
> + queue_context,
> PTHREAD_MUTEX_INITIALIZER,
> pthread_mutex_init
> diff --git a/cpukit/posix/src/mutexgetprioceiling.c b/cpukit/posix/src/mutexgetprioceiling.c
> index 232b2e2..268457a 100644
> --- a/cpukit/posix/src/mutexgetprioceiling.c
> +++ b/cpukit/posix/src/mutexgetprioceiling.c
> @@ -30,26 +30,26 @@ int pthread_mutex_getprioceiling(
> int *prioceiling
> if ( prioceiling == NULL ) {
> return EINVAL;
> if ( the_mutex == NULL ) {
> return EINVAL;
> *prioceiling = _POSIX_Priority_From_core(
> the_mutex->Mutex.Attributes.priority_ceiling
> return 0;
> diff --git a/cpukit/posix/src/mutexlocksupp.c b/cpukit/posix/src/mutexlocksupp.c
> index 0c70cf0..f17269b 100644
> --- a/cpukit/posix/src/mutexlocksupp.c
> +++ b/cpukit/posix/src/mutexlocksupp.c
> @@ -28,11 +28,11 @@ int _POSIX_Mutex_Lock_support(
> Watchdog_Interval timeout
> - Thread_Control *executing;
> + Thread_Control *executing;
> return EINVAL;
> @@ -44,7 +44,7 @@ int _POSIX_Mutex_Lock_support(
> executing,
> blocking,
> timeout,
> - &lock_context
> + &queue_context
> return _POSIX_Mutex_Translate_core_mutex_return_code(
> (CORE_mutex_Status) executing->Wait.return_code
> diff --git a/cpukit/posix/src/mutexsetprioceiling.c b/cpukit/posix/src/mutexsetprioceiling.c
> index f29c0ad..09554f8 100644
> --- a/cpukit/posix/src/mutexsetprioceiling.c
> +++ b/cpukit/posix/src/mutexsetprioceiling.c
> @@ -33,7 +33,7 @@ int pthread_mutex_setprioceiling(
> register POSIX_Mutex_Control *the_mutex;
> Priority_Control the_priority;
> if ( !old_ceiling )
> return EINVAL;
> @@ -57,7 +57,7 @@ int pthread_mutex_setprioceiling(
> * NOTE: This makes it easier to get 100% binary coverage since the
> * bad Id case is handled by the switch.
> return EINVAL;
> @@ -73,8 +73,7 @@ int pthread_mutex_setprioceiling(
> &the_mutex->Mutex,
> - NULL,
> - &lock_context
> + &queue_context
> return 0;
> diff --git a/cpukit/posix/src/mutexunlock.c b/cpukit/posix/src/mutexunlock.c
> index 94fcc63..ff7fc1c 100644
> --- a/cpukit/posix/src/mutexunlock.c
> +++ b/cpukit/posix/src/mutexunlock.c
> @@ -30,20 +30,16 @@ int pthread_mutex_unlock(
> - CORE_mutex_Status status;
> + CORE_mutex_Status status;
> return EINVAL;
> - status = _CORE_mutex_Surrender(
> - &the_mutex->Mutex,
> - NULL,
> - &lock_context
> + status = _CORE_mutex_Surrender( &the_mutex->Mutex, &queue_context );
> return _POSIX_Mutex_Translate_core_mutex_return_code( status );
> diff --git a/cpukit/posix/src/pbarrierdestroy.c b/cpukit/posix/src/pbarrierdestroy.c
> index 709644b..8f85762 100644
> --- a/cpukit/posix/src/pbarrierdestroy.c
> +++ b/cpukit/posix/src/pbarrierdestroy.c
> @@ -36,30 +36,30 @@ int pthread_barrier_destroy(
> POSIX_Barrier_Control *the_barrier;
> if ( barrier == NULL ) {
> return EINVAL;
> - the_barrier = _POSIX_Barrier_Get( barrier, &lock_context );
> + the_barrier = _POSIX_Barrier_Get( barrier, &queue_context );
> if ( the_barrier == NULL ) {
> return EINVAL;
> - _CORE_barrier_Acquire_critical( &the_barrier->Barrier, &lock_context );
> + _CORE_barrier_Acquire_critical( &the_barrier->Barrier, &queue_context );
> if ( the_barrier->Barrier.number_of_waiting_threads != 0 ) {
> - _CORE_barrier_Release( &the_barrier->Barrier, &lock_context );
> + _CORE_barrier_Release( &the_barrier->Barrier, &queue_context );
> return EBUSY;
> _Objects_Close( &_POSIX_Barrier_Information, &the_barrier->Object );
> _POSIX_Barrier_Free( the_barrier );
> return 0;
> diff --git a/cpukit/posix/src/pbarrierwait.c b/cpukit/posix/src/pbarrierwait.c
> index adfd40d..522c18e 100644
> --- a/cpukit/posix/src/pbarrierwait.c
> +++ b/cpukit/posix/src/pbarrierwait.c
> @@ -37,14 +37,14 @@ int pthread_barrier_wait(
> return EINVAL;
> return EINVAL;
> @@ -56,8 +56,7 @@ int pthread_barrier_wait(
> executing,
> true,
> 0,
> - NULL,
> - &lock_context
> + &queue_context
> return _POSIX_Barrier_Translate_core_barrier_return_code(
> diff --git a/cpukit/posix/src/prwlockdestroy.c b/cpukit/posix/src/prwlockdestroy.c
> index 6f9eec8..0ced556 100644
> --- a/cpukit/posix/src/prwlockdestroy.c
> +++ b/cpukit/posix/src/prwlockdestroy.c
> @@ -24,24 +24,24 @@ int pthread_rwlock_destroy(
> POSIX_RWLock_Control *the_rwlock;
> - the_rwlock = _POSIX_RWLock_Get( rwlock, &lock_context );
> + the_rwlock = _POSIX_RWLock_Get( rwlock, &queue_context );
> if ( the_rwlock == NULL ) {
> return EINVAL;
> - _CORE_RWLock_Acquire_critical( &the_rwlock->RWLock, &lock_context );
> + _CORE_RWLock_Acquire_critical( &the_rwlock->RWLock, &queue_context );
> * If there is at least one thread waiting, then do not delete it.
> if ( !_Thread_queue_Is_empty( &the_rwlock->RWLock.Wait_queue.Queue ) ) {
> - _CORE_RWLock_Release( &the_rwlock->RWLock, &lock_context );
> + _CORE_RWLock_Release( &the_rwlock->RWLock, &queue_context );
> return EBUSY;
> @@ -51,7 +51,7 @@ int pthread_rwlock_destroy(
> _Objects_Close( &_POSIX_RWLock_Information, &the_rwlock->Object );
> _POSIX_RWLock_Free( the_rwlock );
> return 0;
> diff --git a/cpukit/posix/src/prwlockinit.c b/cpukit/posix/src/prwlockinit.c
> index fcf4e29..34ab1ae 100644
> --- a/cpukit/posix/src/prwlockinit.c
> +++ b/cpukit/posix/src/prwlockinit.c
> @@ -24,14 +24,14 @@
> POSIX_RWLock_Control,
> rwlock,
> - lock_context,
> + queue_context,
> PTHREAD_RWLOCK_INITIALIZER,
> pthread_rwlock_init
> diff --git a/cpukit/posix/src/prwlockrdlock.c b/cpukit/posix/src/prwlockrdlock.c
> index 3459399..e59aaf9 100644
> --- a/cpukit/posix/src/prwlockrdlock.c
> +++ b/cpukit/posix/src/prwlockrdlock.c
> @@ -25,10 +25,10 @@ int pthread_rwlock_rdlock(
> return EINVAL;
> @@ -40,7 +40,7 @@ int pthread_rwlock_rdlock(
> executing,
> true, /* we are willing to wait forever */
> 0,
> - &lock_context
> + &queue_context
> return _POSIX_RWLock_Translate_core_RWLock_return_code(
> (CORE_RWLock_Status) executing->Wait.return_code
> diff --git a/cpukit/posix/src/prwlocktimedrdlock.c b/cpukit/posix/src/prwlocktimedrdlock.c
> index 829e169..9e84943 100644
> --- a/cpukit/posix/src/prwlocktimedrdlock.c
> +++ b/cpukit/posix/src/prwlocktimedrdlock.c
> @@ -27,7 +27,7 @@ int pthread_rwlock_timedrdlock(
> Watchdog_Interval ticks;
> bool do_wait;
> TOD_Absolute_timeout_conversion_results status;
> @@ -49,7 +49,7 @@ int pthread_rwlock_timedrdlock(
> status = _TOD_Absolute_timeout_to_ticks( abstime, &ticks );
> do_wait = ( status == TOD_ABSOLUTE_TIMEOUT_IS_IN_FUTURE );
> return EINVAL;
> @@ -61,7 +61,7 @@ int pthread_rwlock_timedrdlock(
> executing,
> do_wait,
> ticks,
> - &lock_context
> + &queue_context
> if (
> diff --git a/cpukit/posix/src/prwlocktimedwrlock.c b/cpukit/posix/src/prwlocktimedwrlock.c
> index 1258c2b..6be8397 100644
> --- a/cpukit/posix/src/prwlocktimedwrlock.c
> +++ b/cpukit/posix/src/prwlocktimedwrlock.c
> @@ -29,7 +29,7 @@ int pthread_rwlock_timedwrlock(
> bool do_wait;
> @@ -51,7 +51,7 @@ int pthread_rwlock_timedwrlock(
> return EINVAL;
> @@ -63,7 +63,7 @@ int pthread_rwlock_timedwrlock(
> executing,
> do_wait,
> ticks,
> - &lock_context
> + &queue_context
> if (
> diff --git a/cpukit/posix/src/prwlocktryrdlock.c b/cpukit/posix/src/prwlocktryrdlock.c
> index a73d122..1a7cf9e 100644
> --- a/cpukit/posix/src/prwlocktryrdlock.c
> +++ b/cpukit/posix/src/prwlocktryrdlock.c
> @@ -25,10 +25,10 @@ int pthread_rwlock_tryrdlock(
> return EINVAL;
> @@ -40,7 +40,7 @@ int pthread_rwlock_tryrdlock(
> executing,
> false, /* do not wait for the rwlock */
> 0,
> - &lock_context
> + &queue_context
> diff --git a/cpukit/posix/src/prwlocktrywrlock.c b/cpukit/posix/src/prwlocktrywrlock.c
> index a44a54f..b6031f9 100644
> --- a/cpukit/posix/src/prwlocktrywrlock.c
> +++ b/cpukit/posix/src/prwlocktrywrlock.c
> @@ -25,10 +25,10 @@ int pthread_rwlock_trywrlock(
> return EINVAL;
> @@ -40,7 +40,7 @@ int pthread_rwlock_trywrlock(
> executing,
> false, /* we are not willing to wait */
> 0,
> - &lock_context
> + &queue_context
> diff --git a/cpukit/posix/src/prwlockunlock.c b/cpukit/posix/src/prwlockunlock.c
> index bf6b4de..dd4337d 100644
> --- a/cpukit/posix/src/prwlockunlock.c
> +++ b/cpukit/posix/src/prwlockunlock.c
> @@ -27,15 +27,15 @@ int pthread_rwlock_unlock(
> CORE_RWLock_Status status;
> return EINVAL;
> - status = _CORE_RWLock_Surrender( &the_rwlock->RWLock, &lock_context );
> + status = _CORE_RWLock_Surrender( &the_rwlock->RWLock, &queue_context );
> return _POSIX_RWLock_Translate_core_RWLock_return_code( status );
> diff --git a/cpukit/posix/src/prwlockwrlock.c b/cpukit/posix/src/prwlockwrlock.c
> index 5683163..84a4e0f 100644
> --- a/cpukit/posix/src/prwlockwrlock.c
> +++ b/cpukit/posix/src/prwlockwrlock.c
> @@ -32,10 +32,10 @@ int pthread_rwlock_wrlock(
> return EINVAL;
> @@ -47,7 +47,7 @@ int pthread_rwlock_wrlock(
> executing,
> true, /* do not timeout -- wait forever */
> 0,
> - &lock_context
> + &queue_context
> diff --git a/cpukit/posix/src/semaphoredeletesupp.c b/cpukit/posix/src/semaphoredeletesupp.c
> index c205b12..2d39b2a 100644
> --- a/cpukit/posix/src/semaphoredeletesupp.c
> +++ b/cpukit/posix/src/semaphoredeletesupp.c
> @@ -22,18 +22,14 @@
> if ( !the_semaphore->linked && !the_semaphore->open_count ) {
> _Objects_Close( &_POSIX_Semaphore_Information, &the_semaphore->Object );
> - _CORE_semaphore_Destroy(
> - &the_semaphore->Semaphore,
> - NULL,
> - lock_context
> + _CORE_semaphore_Destroy( &the_semaphore->Semaphore, queue_context );
> _POSIX_Semaphore_Free( the_semaphore );
> } else {
> - _CORE_semaphore_Release( &the_semaphore->Semaphore, lock_context );
> + _CORE_semaphore_Release( &the_semaphore->Semaphore, queue_context );
> diff --git a/cpukit/posix/src/semaphorewaitsupp.c b/cpukit/posix/src/semaphorewaitsupp.c
> index f08efa8..9382107 100644
> --- a/cpukit/posix/src/semaphorewaitsupp.c
> +++ b/cpukit/posix/src/semaphorewaitsupp.c
> @@ -32,9 +32,9 @@ int _POSIX_Semaphore_Wait_support(
> POSIX_Semaphore_Control *the_semaphore;
> - the_semaphore = _POSIX_Semaphore_Get( sem, &lock_context );
> + the_semaphore = _POSIX_Semaphore_Get( sem, &queue_context );
> if ( the_semaphore == NULL ) {
> @@ -47,7 +47,7 @@ int _POSIX_Semaphore_Wait_support(
> executing,
> blocking,
> timeout,
> - &lock_context
> + &queue_context
> if ( executing->Wait.return_code == CORE_SEMAPHORE_STATUS_SUCCESSFUL ) {
> diff --git a/cpukit/posix/src/semclose.c b/cpukit/posix/src/semclose.c
> index 3f18ff1..ebcf7a2 100644
> --- a/cpukit/posix/src/semclose.c
> +++ b/cpukit/posix/src/semclose.c
> @@ -27,10 +27,10 @@ int sem_close(
> @@ -39,10 +39,10 @@ int sem_close(
> _CORE_semaphore_Acquire_critical(
> - &lock_context
> + &queue_context
> the_semaphore->open_count -= 1;
> - _POSIX_Semaphore_Delete( the_semaphore, &lock_context );
> + _POSIX_Semaphore_Delete( the_semaphore, &queue_context );
> return 0;
> diff --git a/cpukit/posix/src/semdestroy.c b/cpukit/posix/src/semdestroy.c
> index 5264472..8b81470 100644
> --- a/cpukit/posix/src/semdestroy.c
> +++ b/cpukit/posix/src/semdestroy.c
> @@ -27,10 +27,10 @@ int sem_destroy(
> @@ -39,17 +39,17 @@ int sem_destroy(
> - &lock_context
> + &queue_context
> if ( the_semaphore->named ) {
> /* Undefined operation on a named semaphore */
> - _CORE_semaphore_Release( &the_semaphore->Semaphore, &lock_context );
> + _CORE_semaphore_Release( &the_semaphore->Semaphore, &queue_context );
> return 0;
> diff --git a/cpukit/posix/src/semgetvalue.c b/cpukit/posix/src/semgetvalue.c
> index 63e3823..1b75294 100644
> --- a/cpukit/posix/src/semgetvalue.c
> +++ b/cpukit/posix/src/semgetvalue.c
> @@ -28,20 +28,21 @@ int sem_getvalue(
> - * Assume a relaxed atomic load of the value on SMP configurations.
> - * Thus, there is no need to acquire a lock.
> + _CORE_semaphore_Acquire_critical(
> + &the_semaphore->Semaphore,
> + &queue_context
> *sval = _CORE_semaphore_Get_count( &the_semaphore->Semaphore );
> return 0;
> diff --git a/cpukit/posix/src/sempost.c b/cpukit/posix/src/sempost.c
> index 313ff3c..86d2f5a 100644
> --- a/cpukit/posix/src/sempost.c
> +++ b/cpukit/posix/src/sempost.c
> @@ -27,9 +27,9 @@ int sem_post(
> @@ -37,8 +37,7 @@ int sem_post(
> _CORE_semaphore_Surrender(
> - NULL,
> - &lock_context
> + &queue_context
> return 0;
> diff --git a/cpukit/posix/src/semunlink.c b/cpukit/posix/src/semunlink.c
> index 665aa73..6ba1df1 100644
> --- a/cpukit/posix/src/semunlink.c
> +++ b/cpukit/posix/src/semunlink.c
> @@ -28,7 +28,7 @@ int sem_unlink(
> @@ -40,10 +40,10 @@ int sem_unlink(
> _POSIX_Semaphore_Namespace_remove( the_semaphore );
> - _CORE_semaphore_Acquire_critical( &the_semaphore->Semaphore, &lock_context );
> + _CORE_semaphore_Acquire_critical( &the_semaphore->Semaphore, &queue_context );
> the_semaphore->linked = false;
> return 0;
> diff --git a/cpukit/rtems/include/rtems/rtems/barrierimpl.h b/cpukit/rtems/include/rtems/rtems/barrierimpl.h
> index 39632fc..0eaadfc 100644
> --- a/cpukit/rtems/include/rtems/rtems/barrierimpl.h
> +++ b/cpukit/rtems/include/rtems/rtems/barrierimpl.h
> @@ -70,12 +70,13 @@ RTEMS_INLINE_ROUTINE void _Barrier_Free (
> RTEMS_INLINE_ROUTINE Barrier_Control *_Barrier_Get(
> - Objects_Id id,
> + Objects_Id id,
> return (Barrier_Control *)
> - _Objects_Get( id, lock_context, &_Barrier_Information );
> + _Objects_Get( id, &queue_context->Lock_context, &_Barrier_Information );
> diff --git a/cpukit/rtems/include/rtems/rtems/messageimpl.h b/cpukit/rtems/include/rtems/rtems/messageimpl.h
> index 199af1c..d6217f1 100644
> --- a/cpukit/rtems/include/rtems/rtems/messageimpl.h
> +++ b/cpukit/rtems/include/rtems/rtems/messageimpl.h
> @@ -101,18 +101,31 @@ RTEMS_INLINE_ROUTINE void _Message_queue_Free (
> _Objects_Free( &_Message_queue_Information, &the_message_queue->Object );
> -RTEMS_INLINE_ROUTINE Message_queue_Control * _Message_queue_Get(
> - Objects_Id id,
> +RTEMS_INLINE_ROUTINE Message_queue_Control *_Message_queue_Do_get(
> + Objects_Id id,
> +#if defined(RTEMS_MULTIPROCESSING)
> + Thread_queue_MP_callout mp_callout
> +#endif
> + _Thread_queue_Context_initialize( queue_context, mp_callout );
> return (Message_queue_Control *) _Objects_Get(
> id,
> - lock_context,
> + #define _Message_queue_Get( id, queue_context, mp_callout ) \
> + _Message_queue_Do_get( id, queue_context, mp_callout )
> +#else
> + _Message_queue_Do_get( id, queue_context )
> +#endif
> RTEMS_INLINE_ROUTINE Message_queue_Control *_Message_queue_Allocate( void )
> diff --git a/cpukit/rtems/include/rtems/rtems/semimpl.h b/cpukit/rtems/include/rtems/rtems/semimpl.h
> index ac55bc7..c23bef9 100644
> --- a/cpukit/rtems/include/rtems/rtems/semimpl.h
> +++ b/cpukit/rtems/include/rtems/rtems/semimpl.h
> @@ -134,18 +134,31 @@ RTEMS_INLINE_ROUTINE void _Semaphore_Free (
> _Objects_Free( &_Semaphore_Information, &the_semaphore->Object );
> -RTEMS_INLINE_ROUTINE Semaphore_Control *_Semaphore_Get(
> - Objects_Id id,
> +RTEMS_INLINE_ROUTINE Semaphore_Control *_Semaphore_Do_get(
> + Objects_Id id,
> +#endif
> return (Semaphore_Control *) _Objects_Get(
> id,
> - lock_context,
> + #define _Semaphore_Get( id, queue_context, mp_callout ) \
> + _Semaphore_Do_get( id, queue_context, mp_callout )
> +#else
> + _Semaphore_Do_get( id, queue_context )
> +#endif
> #ifdef __cplusplus
> #endif
> diff --git a/cpukit/rtems/src/barrierdelete.c b/cpukit/rtems/src/barrierdelete.c
> index 05d6a3f..3d57908 100644
> --- a/cpukit/rtems/src/barrierdelete.c
> +++ b/cpukit/rtems/src/barrierdelete.c
> @@ -24,20 +24,20 @@ rtems_status_code rtems_barrier_delete(
> rtems_id id
> - Barrier_Control *the_barrier;
> + Barrier_Control *the_barrier;
> - the_barrier = _Barrier_Get( id, &lock_context );
> + the_barrier = _Barrier_Get( id, &queue_context );
> return RTEMS_INVALID_ID;
> _Objects_Close( &_Barrier_Information, &the_barrier->Object );
> - _CORE_barrier_Flush( &the_barrier->Barrier, NULL, &lock_context );
> + _CORE_barrier_Flush( &the_barrier->Barrier, &queue_context );
> return RTEMS_SUCCESSFUL;
> diff --git a/cpukit/rtems/src/barrierrelease.c b/cpukit/rtems/src/barrierrelease.c
> index 2c7d222..2c7f72d 100644
> --- a/cpukit/rtems/src/barrierrelease.c
> +++ b/cpukit/rtems/src/barrierrelease.c
> @@ -25,24 +25,23 @@ rtems_status_code rtems_barrier_release(
> uint32_t *released
> if ( released == NULL ) {
> return RTEMS_INVALID_ADDRESS;
> *released = _CORE_barrier_Surrender(
> - NULL,
> - &lock_context
> + &queue_context
> diff --git a/cpukit/rtems/src/barrierwait.c b/cpukit/rtems/src/barrierwait.c
> index 7f463aa..6e13375 100644
> --- a/cpukit/rtems/src/barrierwait.c
> +++ b/cpukit/rtems/src/barrierwait.c
> @@ -27,11 +27,11 @@ rtems_status_code rtems_barrier_wait(
> rtems_interval timeout
> @@ -43,8 +43,7 @@ rtems_status_code rtems_barrier_wait(
> executing,
> true,
> timeout,
> - NULL,
> - &lock_context
> + &queue_context
> return _Barrier_Translate_core_barrier_return_code(
> diff --git a/cpukit/rtems/src/msgmp.c b/cpukit/rtems/src/msgmp.c
> index c336ba4..d8077a7 100644
> --- a/cpukit/rtems/src/msgmp.c
> +++ b/cpukit/rtems/src/msgmp.c
> @@ -576,17 +576,7 @@ void _Message_queue_MP_Send_extract_proxy (
> - * _Message_queue_Core_message_queue_mp_support
> - * Input parameters:
> - * the_thread - the remote thread the message was submitted to
> - * id - id of the message queue
> - * Output parameters: NONE
> -void _Message_queue_Core_message_queue_mp_support (
> +void _Message_queue_Core_message_queue_mp_support(
> Thread_Control *the_thread,
> Objects_Id id
> diff --git a/cpukit/rtems/src/msgqbroadcast.c b/cpukit/rtems/src/msgqbroadcast.c
> index 45d9097..75f9d60 100644
> --- a/cpukit/rtems/src/msgqbroadcast.c
> +++ b/cpukit/rtems/src/msgqbroadcast.c
> @@ -28,7 +28,7 @@ rtems_status_code rtems_message_queue_broadcast(
> Message_queue_Control *the_message_queue;
> CORE_message_queue_Status status;
> if ( buffer == NULL ) {
> @@ -39,7 +39,11 @@ rtems_status_code rtems_message_queue_broadcast(
> - the_message_queue = _Message_queue_Get( id, &lock_context );
> + the_message_queue = _Message_queue_Get(
> + id,
> + &queue_context,
> + _Message_queue_Core_message_queue_mp_support
> if ( the_message_queue == NULL ) {
> @@ -53,9 +57,8 @@ rtems_status_code rtems_message_queue_broadcast(
> &the_message_queue->message_queue,
> buffer,
> size,
> - _Message_queue_Core_message_queue_mp_support,
> count,
> - &lock_context
> + &queue_context
> return _Message_queue_Translate_core_message_queue_return_code( status );
> diff --git a/cpukit/rtems/src/msgqdelete.c b/cpukit/rtems/src/msgqdelete.c
> index c39cfea..94175e6 100644
> --- a/cpukit/rtems/src/msgqdelete.c
> +++ b/cpukit/rtems/src/msgqdelete.c
> @@ -26,10 +26,14 @@ rtems_status_code rtems_message_queue_delete(
> + id,
> + &queue_context,
> + _Message_queue_MP_Send_object_was_deleted
> @@ -45,15 +49,14 @@ rtems_status_code rtems_message_queue_delete(
> - &lock_context
> + &queue_context
> _Objects_Close( &_Message_queue_Information, &the_message_queue->Object );
> - _Message_queue_MP_Send_object_was_deleted,
> - &lock_context
> + &queue_context
> diff --git a/cpukit/rtems/src/msgqflush.c b/cpukit/rtems/src/msgqflush.c
> index baca176..b4419d1 100644
> --- a/cpukit/rtems/src/msgqflush.c
> +++ b/cpukit/rtems/src/msgqflush.c
> @@ -26,13 +26,13 @@ rtems_status_code rtems_message_queue_flush(
> if ( count == NULL ) {
> + the_message_queue = _Message_queue_Get( id, &queue_context, NULL );
> @@ -44,7 +44,7 @@ rtems_status_code rtems_message_queue_flush(
> *count = _CORE_message_queue_Flush(
> - &lock_context
> + &queue_context
> diff --git a/cpukit/rtems/src/msgqgetnumberpending.c b/cpukit/rtems/src/msgqgetnumberpending.c
> index f655c0b..d2f7820 100644
> --- a/cpukit/rtems/src/msgqgetnumberpending.c
> +++ b/cpukit/rtems/src/msgqgetnumberpending.c
> @@ -26,13 +26,13 @@ rtems_status_code rtems_message_queue_get_number_pending(
> @@ -44,12 +44,12 @@ rtems_status_code rtems_message_queue_get_number_pending(
> - &lock_context
> + &queue_context
> *count = the_message_queue->message_queue.number_of_pending_messages;
> - &lock_context
> + &queue_context
> diff --git a/cpukit/rtems/src/msgqreceive.c b/cpukit/rtems/src/msgqreceive.c
> index dada8df..6ed3d25 100644
> --- a/cpukit/rtems/src/msgqreceive.c
> +++ b/cpukit/rtems/src/msgqreceive.c
> @@ -32,7 +32,7 @@ rtems_status_code rtems_message_queue_receive(
> @@ -43,7 +43,7 @@ rtems_status_code rtems_message_queue_receive(
> @@ -55,7 +55,7 @@ rtems_status_code rtems_message_queue_receive(
> - &lock_context
> + &queue_context
> @@ -66,7 +66,7 @@ rtems_status_code rtems_message_queue_receive(
> size,
> !_Options_Is_no_wait( option_set ),
> timeout,
> - &lock_context
> + &queue_context
> diff --git a/cpukit/rtems/src/msgqsend.c b/cpukit/rtems/src/msgqsend.c
> index c306deb..c5bde9d 100644
> --- a/cpukit/rtems/src/msgqsend.c
> +++ b/cpukit/rtems/src/msgqsend.c
> @@ -27,14 +27,18 @@ rtems_status_code rtems_message_queue_send(
> + id,
> + &queue_context,
> @@ -46,16 +50,15 @@ rtems_status_code rtems_message_queue_send(
> - &lock_context
> + &queue_context
> status = _CORE_message_queue_Send(
> buffer,
> size,
> false, /* sender does not block */
> 0, /* no timeout */
> - &lock_context
> + &queue_context
> diff --git a/cpukit/rtems/src/msgqurgent.c b/cpukit/rtems/src/msgqurgent.c
> index 56522a1..add5f09 100644
> --- a/cpukit/rtems/src/msgqurgent.c
> +++ b/cpukit/rtems/src/msgqurgent.c
> @@ -27,14 +27,18 @@ rtems_status_code rtems_message_queue_urgent(
> + id,
> + &queue_context,
> @@ -46,16 +50,15 @@ rtems_status_code rtems_message_queue_urgent(
> - &lock_context
> + &queue_context
> status = _CORE_message_queue_Urgent(
> buffer,
> size,
> 0, /* no timeout */
> - &lock_context
> + &queue_context
> diff --git a/cpukit/rtems/src/semdelete.c b/cpukit/rtems/src/semdelete.c
> index cf22838..023a57c 100644
> --- a/cpukit/rtems/src/semdelete.c
> +++ b/cpukit/rtems/src/semdelete.c
> @@ -25,12 +25,16 @@ rtems_status_code rtems_semaphore_delete(
> rtems_id id
> - Semaphore_Control *the_semaphore;
> - rtems_attribute attribute_set;
> + Semaphore_Control *the_semaphore;
> + rtems_attribute attribute_set;
> - the_semaphore = _Semaphore_Get( id, &lock_context );
> + the_semaphore = _Semaphore_Get(
> + id,
> + &queue_context,
> + _Semaphore_MP_Send_object_was_deleted
> @@ -52,13 +56,13 @@ rtems_status_code rtems_semaphore_delete(
> _MRSP_Acquire_critical(
> &the_semaphore->Core_control.mrsp,
> - &lock_context
> + &queue_context
> mrsp_status = _MRSP_Can_destroy( &the_semaphore->Core_control.mrsp );
> if ( mrsp_status != MRSP_SUCCESSFUL ) {
> _MRSP_Release(
> - &lock_context
> + &queue_context
> return _Semaphore_Translate_MRSP_status_code( mrsp_status );
> @@ -68,7 +72,7 @@ rtems_status_code rtems_semaphore_delete(
> if ( !_Attributes_Is_counting_semaphore( attribute_set ) ) {
> &the_semaphore->Core_control.mutex,
> - &lock_context
> + &queue_context
> if (
> @@ -77,7 +81,7 @@ rtems_status_code rtems_semaphore_delete(
> - &lock_context
> + &queue_context
> return RTEMS_RESOURCE_IN_USE;
> @@ -85,7 +89,7 @@ rtems_status_code rtems_semaphore_delete(
> } else {
> &the_semaphore->Core_control.semaphore,
> - &lock_context
> + &queue_context
> @@ -93,22 +97,20 @@ rtems_status_code rtems_semaphore_delete(
> #if defined(RTEMS_SMP)
> if ( _Attributes_Is_multiprocessor_resource_sharing( attribute_set ) ) {
> - _MRSP_Destroy( &the_semaphore->Core_control.mrsp, &lock_context );
> + _MRSP_Destroy( &the_semaphore->Core_control.mrsp, &queue_context );
> } else
> #endif
> _CORE_mutex_Flush(
> _CORE_mutex_Was_deleted,
> - _Semaphore_MP_Send_object_was_deleted,
> - &lock_context
> + &queue_context
> _CORE_mutex_Destroy( &the_semaphore->Core_control.mutex );
> } else {
> - &lock_context
> + &queue_context
> diff --git a/cpukit/rtems/src/semflush.c b/cpukit/rtems/src/semflush.c
> index 73e9ad0..b18de6d 100644
> --- a/cpukit/rtems/src/semflush.c
> +++ b/cpukit/rtems/src/semflush.c
> @@ -23,11 +23,15 @@
> rtems_status_code rtems_semaphore_flush( rtems_id id )
> + id,
> + &queue_context,
> @@ -43,30 +47,28 @@ rtems_status_code rtems_semaphore_flush( rtems_id id )
> return RTEMS_NOT_DEFINED;
> } else
> #endif
> - &lock_context
> + &queue_context
> _CORE_mutex_Flush(
> _CORE_mutex_Unsatisfied_nowait,
> - &lock_context
> + &queue_context
> } else {
> - &lock_context
> + &queue_context
> _CORE_semaphore_Flush(
> - &lock_context
> + &queue_context
> diff --git a/cpukit/rtems/src/semobtain.c b/cpukit/rtems/src/semobtain.c
> index 3cf780a..6d994f4 100644
> --- a/cpukit/rtems/src/semobtain.c
> +++ b/cpukit/rtems/src/semobtain.c
> @@ -38,13 +38,13 @@ rtems_status_code rtems_semaphore_obtain(
> - bool wait;
> + bool wait;
> + the_semaphore = _Semaphore_Get( id, &queue_context, NULL );
> @@ -66,7 +66,7 @@ rtems_status_code rtems_semaphore_obtain(
> executing,
> wait,
> timeout,
> - &lock_context
> + &queue_context
> } else
> @@ -77,7 +77,7 @@ rtems_status_code rtems_semaphore_obtain(
> executing,
> wait,
> timeout,
> - &lock_context
> + &queue_context
> return _Semaphore_Translate_core_mutex_return_code(
> @@ -90,7 +90,7 @@ rtems_status_code rtems_semaphore_obtain(
> executing,
> wait,
> timeout,
> - &lock_context
> + &queue_context
> return _Semaphore_Translate_core_semaphore_return_code(
> diff --git a/cpukit/rtems/src/semrelease.c b/cpukit/rtems/src/semrelease.c
> index c39455c..197e4d8 100644
> --- a/cpukit/rtems/src/semrelease.c
> +++ b/cpukit/rtems/src/semrelease.c
> @@ -30,9 +30,13 @@ rtems_status_code rtems_semaphore_release( rtems_id id )
> CORE_mutex_Status mutex_status;
> CORE_semaphore_Status semaphore_status;
> + id,
> + &queue_context,
> + _Semaphore_Core_mutex_mp_support
> @@ -50,7 +54,7 @@ rtems_status_code rtems_semaphore_release( rtems_id id )
> mrsp_status = _MRSP_Surrender(
> _Thread_Executing,
> - &lock_context
> + &queue_context
> } else
> @@ -58,15 +62,13 @@ rtems_status_code rtems_semaphore_release( rtems_id id )
> - _Semaphore_Core_mutex_mp_support,
> - &lock_context
> + &queue_context
> return _Semaphore_Translate_core_mutex_return_code( mutex_status );
> } else {
> semaphore_status = _CORE_semaphore_Surrender(
> - &lock_context
> + &queue_context
> return _Semaphore_Translate_core_semaphore_return_code( semaphore_status );
> diff --git a/cpukit/rtems/src/semsetpriority.c b/cpukit/rtems/src/semsetpriority.c
> index 18fb66a..4deee3d 100644
> --- a/cpukit/rtems/src/semsetpriority.c
> +++ b/cpukit/rtems/src/semsetpriority.c
> @@ -22,11 +22,11 @@
> #include <rtems/score/schedulerimpl.h>
> static rtems_status_code _Semaphore_Set_priority(
> - Semaphore_Control *the_semaphore,
> - rtems_id scheduler_id,
> - rtems_task_priority new_priority,
> - rtems_task_priority *old_priority_p,
> + Semaphore_Control *the_semaphore,
> + rtems_id scheduler_id,
> + rtems_task_priority new_priority,
> + rtems_task_priority *old_priority_p,
> rtems_status_code sc;
> @@ -40,7 +40,7 @@ static rtems_status_code _Semaphore_Set_priority(
> MRSP_Control *mrsp = &the_semaphore->Core_control.mrsp;
> uint32_t scheduler_index = _Scheduler_Get_index_by_id( scheduler_id );
> - _MRSP_Acquire_critical( mrsp, lock_context );
> + _MRSP_Acquire_critical( mrsp, queue_context );
> old_priority = _MRSP_Get_ceiling_priority( mrsp, scheduler_index );
> @@ -48,7 +48,7 @@ static rtems_status_code _Semaphore_Set_priority(
> _MRSP_Set_ceiling_priority( mrsp, scheduler_index, new_priority );
> - _MRSP_Release( mrsp, lock_context );
> + _MRSP_Release( mrsp, queue_context );
> sc = RTEMS_SUCCESSFUL;
> } else
> @@ -56,7 +56,7 @@ static rtems_status_code _Semaphore_Set_priority(
> if ( _Attributes_Is_priority_ceiling( attribute_set ) ) {
> CORE_mutex_Control *mutex = &the_semaphore->Core_control.mutex;
> - _CORE_mutex_Acquire_critical( mutex, lock_context );
> + _CORE_mutex_Acquire_critical( mutex, queue_context );
> old_priority = mutex->Attributes.priority_ceiling;
> @@ -64,11 +64,11 @@ static rtems_status_code _Semaphore_Set_priority(
> mutex->Attributes.priority_ceiling = new_priority;
> - _CORE_mutex_Release( mutex, lock_context );
> + _CORE_mutex_Release( mutex, queue_context );
> } else {
> - _ISR_lock_ISR_enable( lock_context );
> + _ISR_lock_ISR_enable( &queue_context->Lock_context );
> old_priority = 0;
> @@ -87,8 +87,8 @@ rtems_status_code rtems_semaphore_set_priority(
> if ( new_priority != RTEMS_CURRENT_PRIORITY &&
> !_RTEMS_tasks_Priority_is_valid( new_priority ) ) {
> @@ -103,7 +103,7 @@ rtems_status_code rtems_semaphore_set_priority(
> - the_semaphore = _Semaphore_Get( semaphore_id, &lock_context );
> + the_semaphore = _Semaphore_Get( semaphore_id, &queue_context, NULL );
> @@ -120,6 +120,6 @@ rtems_status_code rtems_semaphore_set_priority(
> scheduler_id,
> new_priority,
> old_priority,
> - &lock_context
> + &queue_context
> diff --git a/cpukit/score/include/rtems/score/corebarrierimpl.h b/cpukit/score/include/rtems/score/corebarrierimpl.h
> index d5133cd..051990e 100644
> --- a/cpukit/score/include/rtems/score/corebarrierimpl.h
> +++ b/cpukit/score/include/rtems/score/corebarrierimpl.h
> @@ -84,31 +84,26 @@ RTEMS_INLINE_ROUTINE void _CORE_barrier_Destroy(
> RTEMS_INLINE_ROUTINE void _CORE_barrier_Acquire_critical(
> CORE_barrier_Control *the_barrier,
> - _Thread_queue_Acquire_critical( &the_barrier->Wait_queue, lock_context );
> + &the_barrier->Wait_queue,
> RTEMS_INLINE_ROUTINE void _CORE_barrier_Release(
> - _Thread_queue_Release( &the_barrier->Wait_queue, lock_context );
> -void _CORE_barrier_Do_seize(
> - CORE_barrier_Control *the_barrier,
> - Thread_Control *executing,
> - bool wait,
> - Watchdog_Interval timeout,
> -#if defined(RTEMS_MULTIPROCESSING)
> - Thread_queue_MP_callout mp_callout,
> -#endif
> * @brief Wait for the barrier.
> @@ -127,48 +122,18 @@ void _CORE_barrier_Do_seize(
> * @note Status is returned via the thread control block.
> - #define _CORE_barrier_Seize( \
> - the_barrier, \
> - executing, \
> - wait, \
> - timeout, \
> - mp_callout, \
> - lock_context \
> - _CORE_barrier_Do_seize( \
> - the_barrier, \
> - executing, \
> - wait, \
> - timeout, \
> - mp_callout, \
> - lock_context \
> -#else
> - the_barrier, \
> - executing, \
> - wait, \
> - timeout, \
> - mp_callout, \
> - lock_context \
> - the_barrier, \
> - executing, \
> - wait, \
> - timeout, \
> - lock_context \
> -#endif
> +void _CORE_barrier_Seize(
> + CORE_barrier_Control *the_barrier,
> + Thread_Control *executing,
> + bool wait,
> + Watchdog_Interval timeout,
> -uint32_t _CORE_barrier_Do_surrender(
> +uint32_t _CORE_barrier_Do_flush(
> Thread_queue_Flush_filter filter,
> -#endif
> @@ -183,62 +148,35 @@ uint32_t _CORE_barrier_Do_surrender(
> * @retval the number of unblocked threads
> - #define _CORE_barrier_Surrender( \
> - the_barrier, \
> - mp_callout, \
> - lock_context \
> - _CORE_barrier_Do_surrender( \
> - the_barrier, \
> - _Thread_queue_Flush_default_filter, \
> - mp_callout, \
> - lock_context \
> -#else
> - the_barrier, \
> - mp_callout, \
> - lock_context \
> - the_barrier, \
> - lock_context \
> -#endif
> +RTEMS_INLINE_ROUTINE uint32_t _CORE_barrier_Surrender(
> + return _CORE_barrier_Do_flush(
> + the_barrier,
> + _Thread_queue_Flush_default_filter,
> + queue_context
> Thread_Control *_CORE_barrier_Was_deleted(
> - Thread_Control *the_thread,
> - Thread_queue_Queue *queue,
> + Thread_Control *the_thread,
> + Thread_queue_Queue *queue,
> -/* Must be a macro due to the multiprocessing dependent parameters */
> - #define _CORE_barrier_Flush( \
> - the_barrier, \
> - mp_callout, \
> - lock_context \
> - the_barrier, \
> - _CORE_barrier_Was_deleted, \
> - mp_callout, \
> - lock_context \
> -#else
> - the_barrier, \
> - mp_callout, \
> - lock_context \
> - the_barrier, \
> - lock_context \
> -#endif
> +RTEMS_INLINE_ROUTINE void _CORE_barrier_Flush(
> + _CORE_barrier_Do_flush(
> + the_barrier,
> + _CORE_barrier_Was_deleted,
> + queue_context
> * This function returns true if the automatic release attribute is
> diff --git a/cpukit/score/include/rtems/score/coremsg.h b/cpukit/score/include/rtems/score/coremsg.h
> index af42e7d..8d25529 100644
> --- a/cpukit/score/include/rtems/score/coremsg.h
> +++ b/cpukit/score/include/rtems/score/coremsg.h
> @@ -122,7 +122,7 @@ typedef enum {
> typedef void (*CORE_message_queue_Notify_Handler)(
> CORE_message_queue_Control *,
> #endif
> diff --git a/cpukit/score/include/rtems/score/coremsgimpl.h b/cpukit/score/include/rtems/score/coremsgimpl.h
> index a93da03..c90cb72 100644
> --- a/cpukit/score/include/rtems/score/coremsgimpl.h
> +++ b/cpukit/score/include/rtems/score/coremsgimpl.h
> @@ -128,14 +128,6 @@ bool _CORE_message_queue_Initialize(
> size_t maximum_message_size
> -void _CORE_message_queue_Do_close(
> - CORE_message_queue_Control *the_message_queue,
> -#endif
> * @brief Close a message queue.
> @@ -147,33 +139,13 @@ void _CORE_message_queue_Do_close(
> * flushing @a the_message_queue's task wait queue.
> * @param[in] the_message_queue points to the message queue to close
> - * @param[in] mp_callout is the routine to call for each thread
> - * that is extracted from the set of waiting threads
> - * @param[in] lock_context The lock context of the
> + * @param[in] queue_context The thread queue context used for
> * _CORE_message_queue_Acquire() or _CORE_message_queue_Acquire_critical().
> - #define _CORE_message_queue_Close( \
> - the_message_queue, \
> - mp_callout, \
> - lock_context \
> - _CORE_message_queue_Do_close( \
> - mp_callout, \
> - lock_context \
> -#else
> - mp_callout, \
> - lock_context \
> - lock_context \
> -#endif
> +void _CORE_message_queue_Close(
> + CORE_message_queue_Control *the_message_queue,
> * @brief Flush pending messages.
> @@ -186,13 +158,13 @@ void _CORE_message_queue_Do_close(
> * number of messages flushed from the queue is returned.
> * @param[in] the_message_queue points to the message queue to flush
> - * @param[in] lock_context The lock context of the interrupt disable.
> + * @param[in] queue_context The thread queue context with interrupts disabled.
> * @retval This method returns the number of message pending messages flushed.
> uint32_t _CORE_message_queue_Flush(
> #if defined(FUNCTIONALITY_NOT_CURRENTLY_USED_BY_ANY_API)
> @@ -212,17 +184,6 @@ uint32_t _CORE_message_queue_Flush(
> #endif
> -CORE_message_queue_Status _CORE_message_queue_Do_broadcast(
> - const void *buffer,
> - size_t size,
> -#endif
> - uint32_t *count,
> * @brief Broadcast a message to the message queue.
> @@ -236,61 +197,19 @@ CORE_message_queue_Status _CORE_message_queue_Do_broadcast(
> * @param[in] buffer is the starting address of the message to broadcast
> * @param[in] size is the size of the message being broadcast
> - * @param[in] mp_callout is the routine to invoke if
> - * a thread that is unblocked is actually a remote thread.
> * @param[out] count points to the variable that will contain the
> * number of tasks that are sent this message
> + * _CORE_message_queue_Acquire() or _CORE_message_queue_Acquire_critical().
> * @retval @a *count will contain the number of messages sent
> * @retval indication of the successful completion or reason for failure
> - #define _CORE_message_queue_Broadcast( \
> - buffer, \
> - size, \
> - mp_callout, \
> - count, \
> - lock_context \
> - _CORE_message_queue_Do_broadcast( \
> - buffer, \
> - size, \
> - mp_callout, \
> - count, \
> - lock_context \
> -#else
> - buffer, \
> - size, \
> - mp_callout, \
> - count, \
> - lock_context \
> - buffer, \
> - size, \
> - count, \
> - lock_context \
> -#endif
> -CORE_message_queue_Status _CORE_message_queue_Do_submit(
> - size_t size,
> -#endif
> - CORE_message_queue_Submit_types submit_type,
> - bool wait,
> +CORE_message_queue_Status _CORE_message_queue_Broadcast(
> + const void *buffer,
> + size_t size,
> + uint32_t *count,
> @@ -306,63 +225,26 @@ CORE_message_queue_Status _CORE_message_queue_Do_submit(
> * @param[in] buffer is the starting address of the message to send
> * @param[in] size is the size of the message being send
> * @param[in] submit_type determines whether the message is prepended,
> * appended, or enqueued in priority order.
> * @param[in] wait indicates whether the calling thread is willing to block
> * if the message queue is full.
> * @param[in] timeout is the maximum number of clock ticks that the calling
> * thread is willing to block if the message queue is full.
> - #define _CORE_message_queue_Submit( \
> - executing, \
> - buffer, \
> - size, \
> - mp_callout, \
> - submit_type, \
> - wait, \
> - timeout, \
> - lock_context \
> - _CORE_message_queue_Do_submit( \
> - executing, \
> - buffer, \
> - size, \
> - mp_callout, \
> - submit_type, \
> - wait, \
> - timeout, \
> - lock_context \
> -#else
> - executing, \
> - buffer, \
> - size, \
> - mp_callout, \
> - submit_type, \
> - wait, \
> - timeout, \
> - lock_context \
> - executing, \
> - buffer, \
> - size, \
> - submit_type, \
> - wait, \
> - timeout, \
> - lock_context \
> -#endif
> +CORE_message_queue_Status _CORE_message_queue_Submit(
> + size_t size,
> + CORE_message_queue_Submit_types submit_type,
> + bool wait,
> * @brief Size a message from the message queue.
> @@ -385,7 +267,8 @@ CORE_message_queue_Status _CORE_message_queue_Do_submit(
> * if the message queue is empty.
> * thread is willing to block if the message queue is empty.
> * @retval indication of the successful completion or reason for failure.
> * On success, the location pointed to @a size_p will contain the
> @@ -398,13 +281,13 @@ CORE_message_queue_Status _CORE_message_queue_Do_submit(
> * + wait
> void _CORE_message_queue_Seize(
> - void *buffer,
> - size_t *size_p,
> - bool wait,
> + void *buffer,
> + size_t *size_p,
> + bool wait,
> @@ -428,76 +311,79 @@ void _CORE_message_queue_Insert_message(
> - * This routine sends a message to the end of the specified message queue.
> -#define _CORE_message_queue_Send( \
> - buffer, \
> - size, \
> - mp_callout, \
> - wait, \
> - timeout, \
> - lock_context \
> - _CORE_message_queue_Submit( \
> - _Thread_Executing, \
> - buffer, \
> - size, \
> - mp_callout, \
> - CORE_MESSAGE_QUEUE_SEND_REQUEST, \
> - wait, \
> - timeout, \
> - lock_context \
> +RTEMS_INLINE_ROUTINE CORE_message_queue_Status _CORE_message_queue_Send(
> + size_t size,
> + bool wait,
> + return _CORE_message_queue_Submit(
> + the_message_queue,
> + _Thread_Executing,
> + buffer,
> + size,
> + CORE_MESSAGE_QUEUE_SEND_REQUEST,
> + wait,
> + timeout,
> + queue_context
> - * This routine sends a message to the front of the specified message queue.
> -#define _CORE_message_queue_Urgent( \
> - buffer, \
> - size, \
> - mp_callout, \
> - wait, \
> - timeout, \
> - lock_context \
> - buffer, \
> - size, \
> - mp_callout, \
> - CORE_MESSAGE_QUEUE_URGENT_REQUEST, \
> - wait,\
> - timeout, \
> - lock_context \
> +RTEMS_INLINE_ROUTINE CORE_message_queue_Status _CORE_message_queue_Urgent(
> + size_t size,
> + bool wait,
> + buffer,
> + size,
> + CORE_MESSAGE_QUEUE_URGENT_REQUEST,
> + wait,
> + timeout,
> + queue_context
> RTEMS_INLINE_ROUTINE void _CORE_message_queue_Acquire(
> - _Thread_queue_Acquire( &the_message_queue->Wait_queue, lock_context );
> + _Thread_queue_Acquire(
> + &the_message_queue->Wait_queue,
> RTEMS_INLINE_ROUTINE void _CORE_message_queue_Acquire_critical(
> - _Thread_queue_Acquire_critical( &the_message_queue->Wait_queue, lock_context );
> RTEMS_INLINE_ROUTINE void _CORE_message_queue_Release(
> - _Thread_queue_Release( &the_message_queue->Wait_queue, lock_context );
> @@ -599,15 +485,12 @@ RTEMS_INLINE_ROUTINE
> do { } while ( 0 )
> #endif
> -RTEMS_INLINE_ROUTINE Thread_Control *_CORE_message_queue_Do_dequeue_receiver(
> +RTEMS_INLINE_ROUTINE Thread_Control *_CORE_message_queue_Dequeue_receiver(
> const void *buffer,
> size_t size,
> -#endif
> Thread_Control *the_thread;
> @@ -649,48 +532,12 @@ RTEMS_INLINE_ROUTINE Thread_Control *_CORE_message_queue_Do_dequeue_receiver(
> &the_message_queue->Wait_queue.Queue,
> the_message_queue->operations,
> the_thread,
> - mp_callout,
> - lock_context
> + queue_context
> return the_thread;
> - #define _CORE_message_queue_Dequeue_receiver( \
> - buffer, \
> - size, \
> - mp_callout, \
> - submit_type, \
> - lock_context \
> - _CORE_message_queue_Do_dequeue_receiver( \
> - buffer, \
> - size, \
> - mp_callout, \
> - submit_type, \
> - lock_context \
> -#else
> - buffer, \
> - size, \
> - mp_callout, \
> - submit_type, \
> - lock_context \
> - buffer, \
> - size, \
> - submit_type, \
> - lock_context \
> -#endif
> #ifdef __cplusplus
> diff --git a/cpukit/score/include/rtems/score/coremuteximpl.h b/cpukit/score/include/rtems/score/coremuteximpl.h
> index 4531e46..a32022a 100644
> --- a/cpukit/score/include/rtems/score/coremuteximpl.h
> +++ b/cpukit/score/include/rtems/score/coremuteximpl.h
> @@ -107,19 +107,25 @@ RTEMS_INLINE_ROUTINE void _CORE_mutex_Destroy( CORE_mutex_Control *the_mutex )
> RTEMS_INLINE_ROUTINE void _CORE_mutex_Acquire_critical(
> - CORE_mutex_Control *the_mutex,
> + CORE_mutex_Control *the_mutex,
> - _Thread_queue_Acquire_critical( &the_mutex->Wait_queue, lock_context );
> + &the_mutex->Wait_queue,
> RTEMS_INLINE_ROUTINE void _CORE_mutex_Release(
> - _Thread_queue_Release( &the_mutex->Wait_queue, lock_context );
> @@ -219,7 +225,7 @@ RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_priority_ceiling(
> * @param[in,out] executing The currently executing thread.
> * @param[in,out] the_mutex is the mutex to attempt to lock
> - * @param[in] lock_context is the interrupt level
> + * @param[in] queue_context is the interrupt level
> * @retval This routine returns 0 if "trylock" can resolve whether or not
> * the mutex is immediately obtained or there was an error attempting to
> @@ -227,9 +233,9 @@ RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_priority_ceiling(
> * the mutex and will have to block to do so.
> RTEMS_INLINE_ROUTINE int _CORE_mutex_Seize_interrupt_trylock(
> /* disabled when you get here */
> @@ -244,7 +250,7 @@ RTEMS_INLINE_ROUTINE int _CORE_mutex_Seize_interrupt_trylock(
> if ( !_CORE_mutex_Is_priority_ceiling( &the_mutex->Attributes ) ) {
> - _CORE_mutex_Release( the_mutex, lock_context );
> + _CORE_mutex_Release( the_mutex, queue_context );
> return 0;
> } /* else must be CORE_MUTEX_DISCIPLINES_PRIORITY_CEILING
> @@ -258,15 +264,17 @@ RTEMS_INLINE_ROUTINE int _CORE_mutex_Seize_interrupt_trylock(
> ceiling = the_mutex->Attributes.priority_ceiling;
> current = executing->current_priority;
> if ( current == ceiling ) {
> return 0;
> if ( current > ceiling ) {
> Per_CPU_Control *cpu_self;
> - cpu_self = _Thread_Dispatch_disable_critical( lock_context );
> _Thread_Raise_priority( executing, ceiling );
> return 0;
> @@ -276,7 +284,7 @@ RTEMS_INLINE_ROUTINE int _CORE_mutex_Seize_interrupt_trylock(
> the_mutex->holder = NULL;
> the_mutex->nest_count = 0; /* undo locking above */
> executing->resource_count--; /* undo locking above */
> return 0;
> @@ -292,12 +300,12 @@ RTEMS_INLINE_ROUTINE int _CORE_mutex_Seize_interrupt_trylock(
> switch ( the_mutex->Attributes.lock_nesting_behavior ) {
> case CORE_MUTEX_NESTING_ACQUIRES:
> the_mutex->nest_count++;
> return 0;
> #if defined(RTEMS_POSIX_API)
> case CORE_MUTEX_NESTING_IS_ERROR:
> executing->Wait.return_code = CORE_MUTEX_STATUS_NESTING_NOT_ALLOWED;
> return 0;
> #endif
> case CORE_MUTEX_NESTING_BLOCKS:
> @@ -322,7 +330,7 @@ RTEMS_INLINE_ROUTINE int _CORE_mutex_Seize_interrupt_trylock(
> * @param[in] the_mutex is the mutex to attempt to lock
> * @param[in] wait is true if the thread is willing to wait
> * @param[in] timeout is the maximum number of ticks to block
> - * @param[in] lock_context is a temporary variable used to contain the ISR
> + * @param[in] queue_context is a temporary variable used to contain the ISR
> * disable level cookie
> * @note If the mutex is called from an interrupt service routine,
> @@ -339,11 +347,11 @@ RTEMS_INLINE_ROUTINE int _CORE_mutex_Seize_interrupt_trylock(
> * then they are blocked.
> RTEMS_INLINE_ROUTINE void _CORE_mutex_Seize(
> - bool wait,
> + bool wait,
> if ( _CORE_mutex_Check_dispatch_for_seize( wait ) ) {
> @@ -353,10 +361,12 @@ RTEMS_INLINE_ROUTINE void _CORE_mutex_Seize(
> INTERNAL_ERROR_MUTEX_OBTAIN_FROM_BAD_STATE
> - _CORE_mutex_Acquire_critical( the_mutex, lock_context );
> - if ( _CORE_mutex_Seize_interrupt_trylock( the_mutex, executing, lock_context ) ) {
> + _CORE_mutex_Acquire_critical( the_mutex, queue_context );
> + if (
> + _CORE_mutex_Seize_interrupt_trylock( the_mutex, executing, queue_context )
> if ( !wait ) {
> CORE_MUTEX_STATUS_UNSATISFIED_NOWAIT;
> } else {
> @@ -364,69 +374,42 @@ RTEMS_INLINE_ROUTINE void _CORE_mutex_Seize(
> the_mutex,
> executing,
> timeout,
> - lock_context
> -CORE_mutex_Status _CORE_mutex_Do_surrender(
> -#endif
> +CORE_mutex_Status _CORE_mutex_Surrender(
> - #define _CORE_mutex_Surrender( \
> - the_mutex, \
> - mp_callout, \
> - lock_context \
> - _CORE_mutex_Do_surrender( \
> - the_mutex, \
> - mp_callout, \
> - lock_context \
> -#else
> - the_mutex, \
> - mp_callout, \
> - lock_context \
> - the_mutex, \
> - lock_context \
> -#endif
> Thread_Control *_CORE_mutex_Was_deleted(
> Thread_Control *_CORE_mutex_Unsatisfied_nowait(
> -#define _CORE_mutex_Flush( \
> - the_mutex, \
> - filter, \
> - mp_callout, \
> - lock_context \
> - _Thread_queue_Flush_critical( \
> - &( the_mutex )->Wait_queue.Queue, \
> - ( the_mutex )->operations, \
> - filter, \
> - mp_callout, \
> - lock_context \
> +RTEMS_INLINE_ROUTINE void _CORE_mutex_Flush(
> + Thread_queue_Flush_filter filter,
> + _Thread_queue_Flush_critical(
> + &the_mutex->Wait_queue.Queue,
> + the_mutex->operations,
> + filter,
> + queue_context
> RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_owner(
> const CORE_mutex_Control *the_mutex,
> diff --git a/cpukit/score/include/rtems/score/corerwlockimpl.h b/cpukit/score/include/rtems/score/corerwlockimpl.h
> index ed59d69..67084c1 100644
> --- a/cpukit/score/include/rtems/score/corerwlockimpl.h
> +++ b/cpukit/score/include/rtems/score/corerwlockimpl.h
> @@ -87,19 +87,25 @@ RTEMS_INLINE_ROUTINE void _CORE_RWLock_Destroy(
> RTEMS_INLINE_ROUTINE void _CORE_RWLock_Acquire_critical(
> - CORE_RWLock_Control *the_rwlock,
> + CORE_RWLock_Control *the_rwlock,
> - _Thread_queue_Acquire_critical( &the_rwlock->Wait_queue, lock_context );
> + &the_rwlock->Wait_queue,
> RTEMS_INLINE_ROUTINE void _CORE_RWLock_Release(
> - _Thread_queue_Release( &the_rwlock->Wait_queue, lock_context );
> @@ -116,11 +122,11 @@ RTEMS_INLINE_ROUTINE void _CORE_RWLock_Release(
> void _CORE_RWLock_Seize_for_reading(
> - bool wait,
> + bool wait,
> @@ -136,11 +142,11 @@ void _CORE_RWLock_Seize_for_reading(
> void _CORE_RWLock_Seize_for_writing(
> - bool wait,
> + bool wait,
> @@ -154,8 +160,8 @@ void _CORE_RWLock_Seize_for_writing(
> * @retval Status is returned to indicate successful or failure.
> CORE_RWLock_Status _CORE_RWLock_Surrender(
> diff --git a/cpukit/score/include/rtems/score/coresemimpl.h b/cpukit/score/include/rtems/score/coresemimpl.h
> index 0e04cc9..1660c1d 100644
> --- a/cpukit/score/include/rtems/score/coresemimpl.h
> +++ b/cpukit/score/include/rtems/score/coresemimpl.h
> @@ -88,54 +88,68 @@ void _CORE_semaphore_Initialize(
> RTEMS_INLINE_ROUTINE void _CORE_semaphore_Acquire_critical(
> CORE_semaphore_Control *the_semaphore,
> - _Thread_queue_Acquire_critical( &the_semaphore->Wait_queue, lock_context );
> + &the_semaphore->Wait_queue,
> RTEMS_INLINE_ROUTINE void _CORE_semaphore_Release(
> - _Thread_queue_Release( &the_semaphore->Wait_queue, lock_context );
> Thread_Control *_CORE_semaphore_Was_deleted(
> Thread_Control *_CORE_semaphore_Unsatisfied_nowait(
> -#define _CORE_semaphore_Destroy( \
> - the_semaphore, \
> - mp_callout, \
> - lock_context \
> - do { \
> - &( the_semaphore )->Wait_queue.Queue, \
> - ( the_semaphore )->operations, \
> - _CORE_semaphore_Was_deleted, \
> - mp_callout, \
> - lock_context \
> - _Thread_queue_Destroy( &( the_semaphore )->Wait_queue ); \
> - } while ( 0 )
> +RTEMS_INLINE_ROUTINE void _CORE_semaphore_Destroy(
> + CORE_semaphore_Control *the_semaphore,
> + &the_semaphore->Wait_queue.Queue,
> + the_semaphore->operations,
> + _CORE_semaphore_Was_deleted,
> + queue_context
> + _Thread_queue_Destroy( &the_semaphore->Wait_queue );
> -RTEMS_INLINE_ROUTINE CORE_semaphore_Status _CORE_semaphore_Do_surrender(
> + * @brief Surrender a unit to a semaphore.
> + * This routine frees a unit to the semaphore. If a task was blocked waiting
> + * for a unit from this semaphore, then that task will be readied and the unit
> + * given to that task. Otherwise, the unit will be returned to the semaphore.
> + * @param[in] the_semaphore is the semaphore to surrender
> + * disable level cookie
> + * @retval an indication of whether the routine succeeded or failed
> +RTEMS_INLINE_ROUTINE CORE_semaphore_Status _CORE_semaphore_Surrender(
> -#endif
> - ISR_lock_Context *lock_context
> + Thread_queue_Context *queue_context
> @@ -143,7 +157,7 @@ RTEMS_INLINE_ROUTINE CORE_semaphore_Status _CORE_semaphore_Do_surrender(
> status = CORE_SEMAPHORE_STATUS_SUCCESSFUL;
> - _CORE_semaphore_Acquire_critical( the_semaphore, lock_context );
> + _CORE_semaphore_Acquire_critical( the_semaphore, queue_context );
> @@ -154,8 +168,7 @@ RTEMS_INLINE_ROUTINE CORE_semaphore_Status _CORE_semaphore_Do_surrender(
> the_thread,
> - mp_callout,
> - lock_context
> + queue_context
> } else {
> if ( the_semaphore->count < UINT32_MAX )
> @@ -163,65 +176,24 @@ RTEMS_INLINE_ROUTINE CORE_semaphore_Status _CORE_semaphore_Do_surrender(
> else
> status = CORE_SEMAPHORE_MAXIMUM_COUNT_EXCEEDED;
> - _CORE_semaphore_Release( the_semaphore, lock_context );
> + _CORE_semaphore_Release( the_semaphore, queue_context );
> return status;
> - * @brief Surrender a unit to a semaphore.
> - * This routine frees a unit to the semaphore. If a task was blocked waiting
> - * for a unit from this semaphore, then that task will be readied and the unit
> - * given to that task. Otherwise, the unit will be returned to the semaphore.
> - * @param[in] the_semaphore is the semaphore to surrender
> - * @param[in] mp_callout is the routine to invoke if the
> - * thread unblocked is remote
> - * disable level cookie
> - * @retval an indication of whether the routine succeeded or failed
> - #define _CORE_semaphore_Surrender( \
> - the_semaphore, \
> - mp_callout, \
> - lock_context \
> - _CORE_semaphore_Do_surrender( \
> - the_semaphore, \
> - mp_callout, \
> - lock_context \
> -#else
> - the_semaphore, \
> - mp_callout, \
> - lock_context \
> - the_semaphore, \
> - lock_context \
> -#endif
> -#define _CORE_semaphore_Flush( \
> - the_semaphore, \
> - mp_callout, \
> - lock_context \
> - do { \
> - _CORE_semaphore_Unsatisfied_nowait, \
> - mp_callout, \
> - lock_context \
> - } while ( 0 )
> +RTEMS_INLINE_ROUTINE void _CORE_semaphore_Flush(
> + _CORE_semaphore_Unsatisfied_nowait,
> + queue_context
> * This routine returns the current count associated with the semaphore.
> @@ -247,31 +219,31 @@ RTEMS_INLINE_ROUTINE uint32_t _CORE_semaphore_Get_count(
> * @note There is currently no MACRO version of this routine.
> RTEMS_INLINE_ROUTINE void _CORE_semaphore_Seize(
> - CORE_semaphore_Control *the_semaphore,
> - bool wait,
> + bool wait,
> executing->Wait.return_code = CORE_SEMAPHORE_STATUS_SUCCESSFUL;
> if ( the_semaphore->count != 0 ) {
> the_semaphore->count -= 1;
> return;
> if ( !wait ) {
> executing->Wait.return_code = CORE_SEMAPHORE_STATUS_UNSATISFIED_NOWAIT;
> return;
> @@ -283,7 +255,7 @@ RTEMS_INLINE_ROUTINE void _CORE_semaphore_Seize(
> STATES_WAITING_FOR_SEMAPHORE,
> timeout,
> CORE_SEMAPHORE_TIMEOUT,
> - lock_context
> + &queue_context->Lock_context
> diff --git a/cpukit/score/include/rtems/score/mrspimpl.h b/cpukit/score/include/rtems/score/mrspimpl.h
> index d5cf55d..5173343 100644
> --- a/cpukit/score/include/rtems/score/mrspimpl.h
> +++ b/cpukit/score/include/rtems/score/mrspimpl.h
> @@ -54,19 +54,19 @@ RTEMS_INLINE_ROUTINE void _MRSP_Giant_release( ISR_lock_Context *lock_context )
> RTEMS_INLINE_ROUTINE void _MRSP_Acquire_critical(
> - MRSP_Control *mrsp,
> + MRSP_Control *mrsp,
> - _ISR_lock_Acquire( &mrsp->Lock, lock_context );
> + _ISR_lock_Acquire( &mrsp->Lock, &queue_context->Lock_context );
> RTEMS_INLINE_ROUTINE void _MRSP_Release(
> - _ISR_lock_Release_and_ISR_enable( &mrsp->Lock, lock_context );
> + _ISR_lock_Release_and_ISR_enable( &mrsp->Lock, &queue_context->Lock_context );
> RTEMS_INLINE_ROUTINE bool _MRSP_Restore_priority_filter(
> @@ -104,11 +104,11 @@ RTEMS_INLINE_ROUTINE void _MRSP_Restore_priority(
> RTEMS_INLINE_ROUTINE void _MRSP_Claim_ownership(
> - Thread_Control *new_owner,
> - Priority_Control initial_priority,
> - Priority_Control ceiling_priority,
> + Thread_Control *new_owner,
> + Priority_Control initial_priority,
> + Priority_Control ceiling_priority,
> @@ -118,8 +118,8 @@ RTEMS_INLINE_ROUTINE void _MRSP_Claim_ownership(
> mrsp->initial_priority_of_owner = initial_priority;
> _Scheduler_Thread_change_help_state( new_owner, SCHEDULER_HELP_ACTIVE_OWNER );
> + cpu_self = _Thread_Dispatch_disable_critical( &queue_context->Lock_context );
> _Thread_Raise_priority( new_owner, ceiling_priority );
> @@ -180,10 +180,11 @@ RTEMS_INLINE_ROUTINE void _MRSP_Timeout( Watchdog_Control *watchdog )
> MRSP_Rival *rival = RTEMS_CONTAINER_OF( watchdog, MRSP_Rival, Watchdog );
> MRSP_Control *mrsp = rival->resource;
> Thread_Control *thread = rival->thread;
> - ISR_lock_Context lock_context;
> + Thread_queue_Context queue_context;
> - _MRSP_Acquire_critical( mrsp, &lock_context );
> + _Thread_queue_Context_initialize( &queue_context, NULL );
> + _MRSP_Acquire_critical( mrsp, &queue_context );
> if ( rival->status == MRSP_WAIT_FOR_OWNERSHIP ) {
> ISR_lock_Context giant_lock_context;
> @@ -200,20 +201,20 @@ RTEMS_INLINE_ROUTINE void _MRSP_Timeout( Watchdog_Control *watchdog )
> rival->status = MRSP_TIMEOUT;
> - _MRSP_Release( mrsp, &lock_context );
> + _MRSP_Release( mrsp, &queue_context );
> } else {
> RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Wait_for_ownership(
> - Resource_Node *owner,
> + Resource_Node *owner,
> MRSP_Status status;
> @@ -243,8 +244,8 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Wait_for_ownership(
> _MRSP_Giant_release( &giant_lock_context );
> _Thread_Raise_priority( executing, ceiling_priority );
> @@ -286,11 +287,11 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Wait_for_ownership(
> RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Seize(
> - bool wait,
> + bool wait,
> MRSP_Status status;
> @@ -306,11 +307,11 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Seize(
> Resource_Node *owner;
> if ( !priority_ok) {
> return MRSP_INVALID_PRIORITY;
> owner = _Resource_Get_owner( &mrsp->Resource );
> if ( owner == NULL ) {
> @@ -318,7 +319,7 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Seize(
> executing,
> initial_priority,
> ceiling_priority,
> - lock_context
> + queue_context
> status = MRSP_SUCCESSFUL;
> } else if (
> @@ -332,10 +333,10 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Seize(
> initial_priority,
> ceiling_priority,
> timeout,
> - lock_context
> + queue_context
> } else {
> /* Not available, nested access or deadlock */
> status = MRSP_UNSATISFIED;
> @@ -344,9 +345,9 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Seize(
> RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Surrender(
> Priority_Control initial_priority;
> @@ -354,7 +355,7 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Surrender(
> if ( _Resource_Get_owner( &mrsp->Resource ) != &executing->Resource_node ) {
> return MRSP_NOT_OWNER_OF_RESOURCE;
> @@ -364,13 +365,13 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Surrender(
> return MRSP_INCORRECT_STATE;
> initial_priority = mrsp->initial_priority_of_owner;
> _MRSP_Giant_acquire( &giant_lock_context );
> @@ -405,8 +406,8 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Surrender(
> _MRSP_Restore_priority( executing, initial_priority );
> @@ -425,11 +426,11 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Can_destroy( MRSP_Control *mrsp )
> RTEMS_INLINE_ROUTINE void _MRSP_Destroy(
> _ISR_lock_Destroy( &mrsp->Lock );
> _Workspace_Free( mrsp->ceiling_priorities );
> diff --git a/cpukit/score/include/rtems/score/threadq.h b/cpukit/score/include/rtems/score/threadq.h
> index 7ada3fc..27af89f 100644
> --- a/cpukit/score/include/rtems/score/threadq.h
> +++ b/cpukit/score/include/rtems/score/threadq.h
> @@ -58,6 +58,18 @@ typedef void ( *Thread_queue_MP_callout )(
> #endif
> + * @brief Thread queue context for the thread queue methods.
> + * @see _Thread_queue_Context_initialize().
> +typedef struct {
> + ISR_lock_Context Lock_context;
> + Thread_queue_MP_callout mp_callout;
> +#endif
> +} Thread_queue_Context;
> * @brief Thread priority queue.
> typedef struct {
> diff --git a/cpukit/score/include/rtems/score/threadqimpl.h b/cpukit/score/include/rtems/score/threadqimpl.h
> index 011c410..752e13e 100644
> --- a/cpukit/score/include/rtems/score/threadqimpl.h
> +++ b/cpukit/score/include/rtems/score/threadqimpl.h
> @@ -53,6 +53,49 @@ typedef struct {
> #endif
> } Thread_queue_Syslock_queue;
> +RTEMS_INLINE_ROUTINE void _Thread_queue_Do_context_initialize(
> +#endif
> + queue_context->mp_callout = mp_callout;
> +#else
> + (void) queue_context;
> +#endif
> + * @brief Initializes a thread queue context.
> + * @param queue_context The thread queue context to initialize.
> + * @param mp_callout Callout to unblock the thread in case it is actually a
> + * thread proxy. This parameter is only used on multiprocessing
> + * configurations. Used by thread queue extract and unblock methods for
> + * objects with multiprocessing (MP) support.
> + #define _Thread_queue_Context_initialize( \
> + queue_context, \
> + mp_callout \
> + _Thread_queue_Do_context_initialize( \
> + queue_context, \
> + mp_callout \
> +#else
> + queue_context, \
> + mp_callout \
> + queue_context \
> +#endif
> RTEMS_INLINE_ROUTINE void _Thread_queue_Heads_initialize(
> Thread_queue_Heads *heads
> @@ -344,7 +387,7 @@ bool _Thread_queue_Do_extract_locked(
> + const Thread_queue_Context *queue_context
> #endif
> @@ -358,9 +401,8 @@ bool _Thread_queue_Do_extract_locked(
> * @param[in] queue The actual thread queue.
> * @param[in] operations The thread queue operations.
> * @param[in] the_thread The thread to extract.
> - * @param[in] mp_callout Callout to unblock the thread in case it is actually a
> - * thread proxy. This parameter is only used on multiprocessing
> - * configurations.
> + * @param[in] queue_context The thread queue context. This parameter is only
> + * used on multiprocessing configurations.
> * @return Returns the unblock indicator for _Thread_queue_Unblock_critical().
> * True indicates, that this thread must be unblocked by the scheduler later in
> @@ -375,20 +417,20 @@ bool _Thread_queue_Do_extract_locked(
> unblock, \
> queue, \
> the_thread, \
> - mp_callout \
> + queue_context \
> _Thread_queue_Do_extract_locked( \
> unblock, \
> queue, \
> the_thread, \
> - mp_callout \
> + queue_context \
> #else
> #define _Thread_queue_Extract_locked( \
> unblock, \
> queue, \
> the_thread, \
> - mp_callout \
> + queue_context \
> unblock, \
> @@ -418,16 +460,6 @@ void _Thread_queue_Unblock_critical(
> -void _Thread_queue_Do_extract_critical(
> - const Thread_queue_Operations *operations,
> -#endif
> * @brief Extracts the thread from the thread queue and unblocks it.
> @@ -450,10 +482,11 @@ void _Thread_queue_Do_extract_critical(
> * void _Mutex_Release( Mutex *mutex )
> - * ISR_lock_Context lock_context;
> - * Thread_Control *first;
> + * Thread_queue_Context queue_context;
> + * Thread_Control *first;
> - * _Thread_queue_Acquire( &mutex->Queue, &lock_context );
> + * _Thread_queue_Context_initialize( &queue_context, NULL );
> + * _Thread_queue_Acquire( &mutex->Queue, &queue_context.Lock_context );
> * first = _Thread_queue_First_locked( &mutex->Queue );
> * mutex->owner = first;
> @@ -463,9 +496,7 @@ void _Thread_queue_Do_extract_critical(
> * &mutex->Queue.Queue,
> * mutex->Queue.operations,
> * first,
> - * NULL,
> - * 0,
> - * &lock_context
> + * &queue_context
> * @endcode
> @@ -473,41 +504,14 @@ void _Thread_queue_Do_extract_critical(
> - * configurations.
> - * @param[in] lock_context The lock context of the lock acquire.
> + * @param[in] queue_context The thread queue context of the lock acquire.
> - #define _Thread_queue_Extract_critical( \
> - queue, \
> - operations, \
> - the_thread, \
> - mp_callout, \
> - lock_context \
> - _Thread_queue_Do_extract_critical( \
> - queue, \
> - operations, \
> - the_thread, \
> - mp_callout, \
> - lock_context \
> -#else
> - queue, \
> - operations, \
> - the_thread, \
> - mp_callout, \
> - lock_context \
> - queue, \
> - operations, \
> - the_thread, \
> - lock_context \
> -#endif
> +void _Thread_queue_Extract_critical(
> + const Thread_queue_Operations *operations,
> * @brief Extracts thread from thread queue.
> @@ -592,9 +596,10 @@ Thread_Control *_Thread_queue_First(
> * optimize for architectures that use the same register for the first
> * parameter and the return value.
> * @param queue The actual thread queue.
> - * @param lock_context The lock context of the lock acquire. May be used to
> - * pass additional data to the filter function via an overlay structure. The
> - * filter function should not release or acquire the thread queue lock.
> + * @param queue_context The thread queue context of the lock acquire. May be
> + * used to pass additional data to the filter function via an overlay
> + * structure. The filter function should not release or acquire the thread
> + * queue lock.
> * @retval the_thread Extract this thread.
> * @retval NULL Do not extract this thread and stop the thread queue flush
> @@ -602,9 +607,9 @@ Thread_Control *_Thread_queue_First(
> * operation.
> typedef Thread_Control *( *Thread_queue_Flush_filter )(
> @@ -612,24 +617,14 @@ typedef Thread_Control *( *Thread_queue_Flush_filter )(
> * @param the_thread The thread to extract.
> * @param queue Unused.
> - * @param lock_context Unused.
> + * @param queue_context Unused.
> Thread_Control *_Thread_queue_Flush_default_filter(
> -size_t _Thread_queue_Do_flush_critical(
> - Thread_queue_Flush_filter filter,
> -#endif
> @@ -647,41 +642,19 @@ size_t _Thread_queue_Do_flush_critical(
> * the thread queue lock, for example to set the thread wait return code.
> * The return value of the filter function controls if the thread queue flush
> * operation should stop or continue.
> - * @param mp_callout Callout to extract the proxy of a remote thread. This
> - * parameter is only used on multiprocessing configurations.
> + * queue lock.
> * @return The count of extracted threads.
> - #define _Thread_queue_Flush_critical( \
> - queue, \
> - operations, \
> - filter, \
> - mp_callout, \
> - lock_context \
> - _Thread_queue_Do_flush_critical( \
> - queue, \
> - operations, \
> - filter, \
> - mp_callout, \
> - lock_context \
> -#else
> - queue, \
> - operations, \
> - filter, \
> - mp_callout, \
> - lock_context \
> - queue, \
> - operations, \
> - filter, \
> - lock_context \
> -#endif
> +size_t _Thread_queue_Flush_critical(
> void _Thread_queue_Initialize( Thread_queue_Control *the_thread_queue );
> diff --git a/cpukit/score/src/apimutexlock.c b/cpukit/score/src/apimutexlock.c
> index 79729d4..11d12c5 100644
> --- a/cpukit/score/src/apimutexlock.c
> +++ b/cpukit/score/src/apimutexlock.c
> @@ -25,20 +25,21 @@
> void _API_Mutex_Lock( API_Mutex_Control *the_mutex )
> - Thread_Life_state previous_thread_life_state;
> + Thread_Life_state previous_thread_life_state;
> previous_thread_life_state =
> _Thread_Set_life_protection( THREAD_LIFE_PROTECTED );
> - _ISR_lock_ISR_disable( &lock_context );
> + _ISR_lock_ISR_disable( &queue_context.Lock_context );
> _CORE_mutex_Seize(
> &the_mutex->Mutex,
> _Thread_Executing,
> true,
> 0,
> - &lock_context
> + &queue_context
> if ( the_mutex->Mutex.nest_count == 1 ) {
> diff --git a/cpukit/score/src/apimutexunlock.c b/cpukit/score/src/apimutexunlock.c
> index 082961f..f0f114e 100644
> --- a/cpukit/score/src/apimutexunlock.c
> +++ b/cpukit/score/src/apimutexunlock.c
> @@ -24,19 +24,16 @@
> void _API_Mutex_Unlock( API_Mutex_Control *the_mutex )
> - bool restore_thread_life_protection;
> + bool restore_thread_life_protection;
> previous_thread_life_state = the_mutex->previous_thread_life_state;
> restore_thread_life_protection = the_mutex->Mutex.nest_count == 1;
> - _CORE_mutex_Surrender(
> - NULL,
> - &lock_context
> + _CORE_mutex_Surrender( &the_mutex->Mutex, &queue_context );
> if ( restore_thread_life_protection ) {
> _Thread_Set_life_protection( previous_thread_life_state );
> diff --git a/cpukit/score/src/condition.c b/cpukit/score/src/condition.c
> index fcd93b2..c0320b2 100644
> --- a/cpukit/score/src/condition.c
> +++ b/cpukit/score/src/condition.c
> @@ -220,54 +220,54 @@ int _Condition_Wait_recursive_timed(
> typedef struct {
> - ISR_lock_Context Base;
> - int count;
> -} Condition_Lock_context;
> + Thread_queue_Context Base;
> + int count;
> +} Condition_Context;
> static Thread_Control *_Condition_Flush_filter(
> - Condition_Lock_context *condition_lock_context;
> + Condition_Context *context;
> - condition_lock_context = (Condition_Lock_context *) lock_context;
> + context = (Condition_Context *) queue_context;
> - if ( condition_lock_context->count <= 0 ) {
> + if ( context->count <= 0 ) {
> return NULL;
> - --condition_lock_context->count;
> + --context->count;
> return the_thread;
> static void _Condition_Wake( struct _Condition_Control *_condition, int count )
> - Condition_Control *condition;
> - Condition_Lock_context lock_context;
> + Condition_Control *condition;
> + Condition_Context context;
> condition = _Condition_Get( _condition );
> - _ISR_lock_ISR_disable( &lock_context.Base );
> - _Condition_Queue_acquire_critical( condition, &lock_context.Base );
> + _Thread_queue_Context_initialize( &context.Base, NULL );
> + _ISR_lock_ISR_disable( &context.Base.Lock_context );
> + _Condition_Queue_acquire_critical( condition, &context.Base.Lock_context );
> * In common uses cases of condition variables there are normally no threads
> * on the queue, so check this condition early.
> if ( __predict_true( _Thread_queue_Is_empty( &condition->Queue.Queue ) ) ) {
> - _Condition_Queue_release( condition, &lock_context.Base );
> + _Condition_Queue_release( condition, &context.Base.Lock_context );
> return;
> - lock_context.count = count;
> + context.count = count;
> &condition->Queue.Queue,
> CONDITION_TQ_OPERATIONS,
> _Condition_Flush_filter,
> - NULL,
> - &lock_context.Base
> + &context.Base
> diff --git a/cpukit/score/src/corebarrier.c b/cpukit/score/src/corebarrier.c
> index 3cb7906..a32f88c 100644
> --- a/cpukit/score/src/corebarrier.c
> +++ b/cpukit/score/src/corebarrier.c
> @@ -33,9 +33,9 @@ void _CORE_barrier_Initialize(
> the_thread->Wait.return_code = CORE_BARRIER_WAS_DELETED;
> diff --git a/cpukit/score/src/corebarrierrelease.c b/cpukit/score/src/corebarrierrelease.c
> index c9c80f4..8a23856 100644
> --- a/cpukit/score/src/corebarrierrelease.c
> +++ b/cpukit/score/src/corebarrierrelease.c
> @@ -21,13 +21,10 @@
> #include <rtems/score/corebarrierimpl.h>
> -#endif
> the_barrier->number_of_waiting_threads = 0;
> @@ -35,7 +32,6 @@ uint32_t _CORE_barrier_Do_surrender(
> &the_barrier->Wait_queue.Queue,
> CORE_BARRIER_TQ_OPERATIONS,
> filter,
> - mp_callout,
> - lock_context
> + queue_context
> diff --git a/cpukit/score/src/corebarrierwait.c b/cpukit/score/src/corebarrierwait.c
> index 54e9096..33f1718 100644
> --- a/cpukit/score/src/corebarrierwait.c
> +++ b/cpukit/score/src/corebarrierwait.c
> @@ -21,22 +21,19 @@
> #include <rtems/score/statesimpl.h>
> - bool wait,
> -#endif
> + bool wait,
> uint32_t number_of_waiting_threads;
> executing->Wait.return_code = CORE_BARRIER_STATUS_SUCCESSFUL;
> - _CORE_barrier_Acquire_critical( the_barrier, lock_context );
> + _CORE_barrier_Acquire_critical( the_barrier, queue_context );
> number_of_waiting_threads = the_barrier->number_of_waiting_threads;
> ++number_of_waiting_threads;
> @@ -46,7 +43,7 @@ void _CORE_barrier_Do_seize(
> && number_of_waiting_threads == the_barrier->Attributes.maximum_count
> executing->Wait.return_code = CORE_BARRIER_STATUS_AUTOMATICALLY_RELEASED;
> - _CORE_barrier_Surrender( the_barrier, mp_callout, lock_context );
> + _CORE_barrier_Surrender( the_barrier, queue_context );
> } else {
> the_barrier->number_of_waiting_threads = number_of_waiting_threads;
> _Thread_queue_Enqueue_critical(
> @@ -56,7 +53,7 @@ void _CORE_barrier_Do_seize(
> STATES_WAITING_FOR_BARRIER,
> timeout,
> CORE_BARRIER_TIMEOUT,
> - lock_context
> diff --git a/cpukit/score/src/coremsgbroadcast.c b/cpukit/score/src/coremsgbroadcast.c
> index a7a962f..23dd343 100644
> --- a/cpukit/score/src/coremsgbroadcast.c
> +++ b/cpukit/score/src/coremsgbroadcast.c
> @@ -21,28 +21,25 @@
> #include <rtems/score/coremsgimpl.h>
> #include <rtems/score/objectimpl.h>
> const void *buffer,
> size_t size,
> -#endif
> uint32_t *count,
> uint32_t number_broadcasted;
> if ( size > the_message_queue->maximum_message_size ) {
> return CORE_MESSAGE_QUEUE_STATUS_INVALID_SIZE;
> number_broadcasted = 0;
> - _CORE_message_queue_Acquire_critical( the_message_queue, lock_context );
> + _CORE_message_queue_Acquire_critical( the_message_queue, queue_context );
> while (
> ( the_thread =
> @@ -50,18 +47,17 @@ CORE_message_queue_Status _CORE_message_queue_Do_broadcast(
> the_message_queue,
> buffer,
> size,
> - mp_callout,
> 0,
> - lock_context
> + queue_context
> number_broadcasted += 1;
> - _CORE_message_queue_Acquire( the_message_queue, lock_context );
> + _CORE_message_queue_Acquire( the_message_queue, queue_context );
> - _CORE_message_queue_Release( the_message_queue, lock_context );
> + _CORE_message_queue_Release( the_message_queue, queue_context );
> *count = number_broadcasted;
> return CORE_MESSAGE_QUEUE_STATUS_SUCCESSFUL;
> diff --git a/cpukit/score/src/coremsgclose.c b/cpukit/score/src/coremsgclose.c
> index 1951e9f..e24d756 100644
> --- a/cpukit/score/src/coremsgclose.c
> +++ b/cpukit/score/src/coremsgclose.c
> @@ -22,9 +22,9 @@
> #include <rtems/score/wkspace.h>
> static Thread_Control *_CORE_message_queue_Was_deleted(
> the_thread->Wait.return_code = CORE_MESSAGE_QUEUE_STATUS_WAS_DELETED;
> @@ -32,12 +32,9 @@ static Thread_Control *_CORE_message_queue_Was_deleted(
> return the_thread;
> -#endif
> @@ -50,8 +47,7 @@ void _CORE_message_queue_Do_close(
> _CORE_message_queue_Was_deleted,
> - mp_callout,
> - lock_context
> + queue_context
> (void) _Workspace_Free( the_message_queue->message_buffers );
> diff --git a/cpukit/score/src/coremsgflush.c b/cpukit/score/src/coremsgflush.c
> index 38f26b7..e5b51f9 100644
> --- a/cpukit/score/src/coremsgflush.c
> +++ b/cpukit/score/src/coremsgflush.c
> @@ -23,7 +23,7 @@
> Chain_Node *inactive_head;
> @@ -59,7 +59,7 @@ uint32_t _CORE_message_queue_Flush(
> * fixed execution time that only deals with pending messages.
> count = the_message_queue->number_of_pending_messages;
> if ( count != 0 ) {
> @@ -78,6 +78,6 @@ uint32_t _CORE_message_queue_Flush(
> _Chain_Initialize_empty( &the_message_queue->Pending_messages );
> return count;
> diff --git a/cpukit/score/src/coremsgseize.c b/cpukit/score/src/coremsgseize.c
> index fcc95a7..b05ddd6 100644
> --- a/cpukit/score/src/coremsgseize.c
> +++ b/cpukit/score/src/coremsgseize.c
> @@ -24,7 +24,6 @@
> #include <rtems/score/thread.h>
> -#include <rtems/score/wkspace.h>
> @@ -33,7 +32,7 @@ void _CORE_message_queue_Seize(
> size_t *size_p,
> bool wait,
> CORE_message_queue_Buffer_control *the_message;
> @@ -58,7 +57,7 @@ void _CORE_message_queue_Seize(
> * So return immediately.
> _CORE_message_queue_Free_message_buffer(the_message_queue, the_message);
> return;
> #else
> @@ -80,7 +79,7 @@ void _CORE_message_queue_Seize(
> the_message_queue,
> the_message
> return;
> @@ -100,8 +99,7 @@ void _CORE_message_queue_Seize(
> the_thread,
> - NULL,
> - lock_context
> + queue_context
> return;
> @@ -109,7 +107,7 @@ void _CORE_message_queue_Seize(
> if ( !wait ) {
> executing->Wait.return_code = CORE_MESSAGE_QUEUE_STATUS_UNSATISFIED_NOWAIT;
> return;
> @@ -125,6 +123,6 @@ void _CORE_message_queue_Seize(
> STATES_WAITING_FOR_MESSAGE,
> timeout,
> CORE_MESSAGE_QUEUE_STATUS_TIMEOUT,
> - lock_context
> diff --git a/cpukit/score/src/coremsgsubmit.c b/cpukit/score/src/coremsgsubmit.c
> index 82cfa1a..06fd698 100644
> --- a/cpukit/score/src/coremsgsubmit.c
> +++ b/cpukit/score/src/coremsgsubmit.c
> @@ -25,25 +25,22 @@
> const void *buffer,
> size_t size,
> -#endif
> bool wait,
> @@ -55,9 +52,8 @@ CORE_message_queue_Status _CORE_message_queue_Do_submit(
> the_message_queue,
> buffer,
> size,
> - mp_callout,
> submit_type,
> - lock_context
> + queue_context
> if ( the_thread != NULL ) {
> @@ -90,20 +86,20 @@ CORE_message_queue_Status _CORE_message_queue_Do_submit(
> ( *the_message_queue->notify_handler )(
> the_message_queue,
> - lock_context
> + queue_context
> } else {
> #else
> #endif
> #if !defined(RTEMS_SCORE_COREMSG_ENABLE_BLOCKING_SEND)
> return CORE_MESSAGE_QUEUE_STATUS_TOO_MANY;
> #else
> @@ -112,7 +108,7 @@ CORE_message_queue_Status _CORE_message_queue_Do_submit(
> * on the queue.
> if ( !wait ) {
> @@ -121,7 +117,7 @@ CORE_message_queue_Status _CORE_message_queue_Do_submit(
> * deadly to block in an ISR.
> if ( _ISR_Is_in_progress() ) {
> return CORE_MESSAGE_QUEUE_STATUS_UNSATISFIED;
> @@ -142,7 +138,7 @@ CORE_message_queue_Status _CORE_message_queue_Do_submit(
> timeout,
> - lock_context
> return CORE_MESSAGE_QUEUE_STATUS_UNSATISFIED_WAIT;
> #endif
> diff --git a/cpukit/score/src/coremutex.c b/cpukit/score/src/coremutex.c
> index ea5e759..ecca244 100644
> --- a/cpukit/score/src/coremutex.c
> +++ b/cpukit/score/src/coremutex.c
> @@ -92,9 +92,9 @@ CORE_mutex_Status _CORE_mutex_Initialize(
> the_thread->Wait.return_code = CORE_MUTEX_WAS_DELETED;
> @@ -103,9 +103,9 @@ Thread_Control *_CORE_mutex_Was_deleted(
> the_thread->Wait.return_code = CORE_MUTEX_STATUS_UNSATISFIED_NOWAIT;
> diff --git a/cpukit/score/src/coremutexsurrender.c b/cpukit/score/src/coremutexsurrender.c
> index 746fee1..040a580 100644
> --- a/cpukit/score/src/coremutexsurrender.c
> +++ b/cpukit/score/src/coremutexsurrender.c
> @@ -23,12 +23,9 @@
> #include <rtems/score/coremuteximpl.h>
> -#endif
> @@ -46,17 +43,17 @@ CORE_mutex_Status _CORE_mutex_Do_surrender(
> if ( the_mutex->Attributes.only_owner_release ) {
> if ( !_Thread_Is_executing( holder ) ) {
> return CORE_MUTEX_STATUS_NOT_OWNER_OF_RESOURCE;
> /* XXX already unlocked -- not right status */
> if ( !the_mutex->nest_count ) {
> return CORE_MUTEX_STATUS_SUCCESSFUL;
> @@ -71,12 +68,12 @@ CORE_mutex_Status _CORE_mutex_Do_surrender(
> #if defined(RTEMS_DEBUG)
> /* should never occur */
> return CORE_MUTEX_STATUS_NESTING_NOT_ALLOWED;
> #endif
> @@ -84,7 +81,7 @@ CORE_mutex_Status _CORE_mutex_Do_surrender(
> break;
> #else
> /* must be CORE_MUTEX_NESTING_ACQUIRES or we wouldn't be here */
> #endif
> @@ -126,7 +123,7 @@ CORE_mutex_Status _CORE_mutex_Do_surrender(
> the_thread,
> - mp_callout
> + queue_context
> @@ -155,10 +152,10 @@ CORE_mutex_Status _CORE_mutex_Do_surrender(
> unblock,
> the_thread,
> - lock_context
> } else {
> diff --git a/cpukit/score/src/corerwlockobtainread.c b/cpukit/score/src/corerwlockobtainread.c
> index fcbaf4a..639ea70 100644
> --- a/cpukit/score/src/corerwlockobtainread.c
> +++ b/cpukit/score/src/corerwlockobtainread.c
> @@ -24,11 +24,11 @@
> #include <rtems/score/watchdog.h>
> - bool wait,
> + bool wait,
> @@ -37,13 +37,13 @@ void _CORE_RWLock_Seize_for_reading(
> * If any thread is waiting, then we wait.
> - _CORE_RWLock_Acquire_critical( the_rwlock, lock_context );
> + _CORE_RWLock_Acquire_critical( the_rwlock, queue_context );
> switch ( the_rwlock->current_state ) {
> case CORE_RWLOCK_UNLOCKED:
> the_rwlock->current_state = CORE_RWLOCK_LOCKED_FOR_READING;
> the_rwlock->number_of_readers += 1;
> - _CORE_RWLock_Release( the_rwlock, lock_context );
> + _CORE_RWLock_Release( the_rwlock, queue_context );
> executing->Wait.return_code = CORE_RWLOCK_SUCCESSFUL;
> return;
> @@ -55,7 +55,7 @@ void _CORE_RWLock_Seize_for_reading(
> if ( !waiter ) {
> return;
> @@ -70,7 +70,7 @@ void _CORE_RWLock_Seize_for_reading(
> if ( !wait ) {
> executing->Wait.return_code = CORE_RWLOCK_UNAVAILABLE;
> return;
> @@ -89,6 +89,6 @@ void _CORE_RWLock_Seize_for_reading(
> STATES_WAITING_FOR_RWLOCK,
> timeout,
> CORE_RWLOCK_TIMEOUT,
> - lock_context
> diff --git a/cpukit/score/src/corerwlockobtainwrite.c b/cpukit/score/src/corerwlockobtainwrite.c
> index e1bb1bd..a7d1bb1 100644
> --- a/cpukit/score/src/corerwlockobtainwrite.c
> +++ b/cpukit/score/src/corerwlockobtainwrite.c
> @@ -24,11 +24,11 @@
> - bool wait,
> + bool wait,
> @@ -38,12 +38,12 @@ void _CORE_RWLock_Seize_for_writing(
> the_rwlock->current_state = CORE_RWLOCK_LOCKED_FOR_WRITING;
> return;
> @@ -57,7 +57,7 @@ void _CORE_RWLock_Seize_for_writing(
> if ( !wait ) {
> return;
> @@ -76,6 +76,6 @@ void _CORE_RWLock_Seize_for_writing(
> timeout,
> - lock_context
> diff --git a/cpukit/score/src/corerwlockrelease.c b/cpukit/score/src/corerwlockrelease.c
> index 6f76aad..81e01d1 100644
> --- a/cpukit/score/src/corerwlockrelease.c
> +++ b/cpukit/score/src/corerwlockrelease.c
> @@ -35,9 +35,9 @@ static bool _CORE_RWLock_Is_waiting_for_reading(
> static Thread_Control *_CORE_RWLock_Flush_filter(
> CORE_RWLock_Control *the_rwlock;
> @@ -74,8 +74,8 @@ static Thread_Control *_CORE_RWLock_Flush_filter(
> @@ -85,11 +85,11 @@ CORE_RWLock_Status _CORE_RWLock_Surrender(
> if ( the_rwlock->current_state == CORE_RWLOCK_UNLOCKED){
> /* This is an error at the caller site */
> return CORE_RWLOCK_SUCCESSFUL;
> @@ -98,7 +98,7 @@ CORE_RWLock_Status _CORE_RWLock_Surrender(
> if ( the_rwlock->number_of_readers != 0 ) {
> /* must be unlocked again */
> @@ -119,8 +119,7 @@ CORE_RWLock_Status _CORE_RWLock_Surrender(
> &the_rwlock->Wait_queue.Queue,
> CORE_RWLOCK_TQ_OPERATIONS,
> _CORE_RWLock_Flush_filter,
> - NULL,
> - lock_context
> + queue_context
> diff --git a/cpukit/score/src/coresem.c b/cpukit/score/src/coresem.c
> index 02a3837..c94f2b7 100644
> --- a/cpukit/score/src/coresem.c
> +++ b/cpukit/score/src/coresem.c
> @@ -38,9 +38,9 @@ void _CORE_semaphore_Initialize(
> the_thread->Wait.return_code = CORE_SEMAPHORE_WAS_DELETED;
> @@ -49,9 +49,9 @@ Thread_Control *_CORE_semaphore_Was_deleted(
> the_thread->Wait.return_code = CORE_SEMAPHORE_STATUS_UNSATISFIED_NOWAIT;
> diff --git a/cpukit/score/src/futex.c b/cpukit/score/src/futex.c
> index 66085a8..d7945d1 100644
> --- a/cpukit/score/src/futex.c
> +++ b/cpukit/score/src/futex.c
> @@ -104,25 +104,25 @@ int _Futex_Wait( struct _Futex_Control *_futex, int *uaddr, int val )
> typedef struct {
> - int count;
> -} Futex_Lock_context;
> + int count;
> +} Futex_Context;
> static Thread_Control *_Futex_Flush_filter(
> - Futex_Lock_context *futex_lock_context;
> + Futex_Context *context;
> - futex_lock_context = (Futex_Lock_context *) lock_context;
> + context = (Futex_Context *) queue_context;
> - if ( futex_lock_context->count <= 0 ) {
> return NULL;
> - --futex_lock_context->count;
> + --context->count;
> return the_thread;
> @@ -130,10 +130,10 @@ static Thread_Control *_Futex_Flush_filter(
> int _Futex_Wake( struct _Futex_Control *_futex, int count )
> Futex_Control *futex;
> - Futex_Lock_context lock_context;
> + Futex_Context context;
> futex = _Futex_Get( _futex );
> - _Futex_Queue_acquire( futex, &lock_context.Base );
> + _Futex_Queue_acquire( futex, &context.Base.Lock_context );
> * For some synchronization objects like barriers the _Futex_Wake() must be
> @@ -141,17 +141,16 @@ int _Futex_Wake( struct _Futex_Control *_futex, int count )
> * check this condition early.
> if ( __predict_true( _Thread_queue_Is_empty( &futex->Queue.Queue ) ) ) {
> - _Futex_Queue_release( futex, &lock_context.Base );
> + _Futex_Queue_release( futex, &context.Base.Lock_context );
> return 0;
> return (int) _Thread_queue_Flush_critical(
> &futex->Queue.Queue,
> FUTEX_TQ_OPERATIONS,
> _Futex_Flush_filter,
> - NULL,
> + &context.Base
> diff --git a/cpukit/score/src/mpci.c b/cpukit/score/src/mpci.c
> index 0b51e38..4022a80 100644
> --- a/cpukit/score/src/mpci.c
> +++ b/cpukit/score/src/mpci.c
> @@ -321,24 +321,25 @@ void _MPCI_Receive_server(
> - MP_packet_Prefix *the_packet;
> - MPCI_Packet_processor the_function;
> - Thread_Control *executing;
> + MP_packet_Prefix *the_packet;
> + MPCI_Packet_processor the_function;
> + Thread_Control *executing;
> executing = _Thread_Get_executing();
> for ( ; ; ) {
> executing->receive_packet = NULL;
> &_MPCI_Semaphore,
> executing,
> true,
> WATCHDOG_NO_TIMEOUT,
> - &lock_context
> + &queue_context
> for ( ; ; ) {
> @@ -370,10 +371,10 @@ void _MPCI_Receive_server(
> void _MPCI_Announce ( void )
> - (void) _CORE_semaphore_Surrender( &_MPCI_Semaphore, 0, &lock_context );
> + (void) _CORE_semaphore_Surrender( &_MPCI_Semaphore, &queue_context );
> void _MPCI_Internal_packets_Send_process_packet (
> diff --git a/cpukit/score/src/mutex.c b/cpukit/score/src/mutex.c
> index e27075e..0b12232 100644
> --- a/cpukit/score/src/mutex.c
> +++ b/cpukit/score/src/mutex.c
> @@ -125,11 +125,11 @@ static void _Mutex_Acquire_slow(
> static void _Mutex_Release_slow(
> - Mutex_Control *mutex,
> - Thread_queue_Heads *heads,
> - bool keep_priority,
> + Mutex_Control *mutex,
> + Thread_queue_Heads *heads,
> + bool keep_priority,
> if (heads != NULL) {
> @@ -146,17 +146,17 @@ static void _Mutex_Release_slow(
> operations,
> first,
> - NULL
> + queue_context
> _Thread_queue_Boost_priority( &mutex->Queue.Queue, first );
> unblock,
> first,
> - lock_context
> } else {
> - _Mutex_Queue_release( mutex, lock_context);
> + _Mutex_Queue_release( mutex, &queue_context->Lock_context );
> if ( !keep_priority ) {
> @@ -169,9 +169,9 @@ static void _Mutex_Release_slow(
> static void _Mutex_Release_critical(
> Thread_queue_Heads *heads;
> @@ -193,14 +193,14 @@ static void _Mutex_Release_critical(
> || !executing->priority_restore_hint;
> if ( __predict_true( heads == NULL && keep_priority ) ) {
> - _Mutex_Queue_release( mutex, lock_context );
> } else {
> mutex,
> executing,
> heads,
> keep_priority,
> - lock_context
> + queue_context
> @@ -297,16 +297,17 @@ int _Mutex_Try_acquire( struct _Mutex_Control *_mutex )
> void _Mutex_Release( struct _Mutex_Control *_mutex )
> - Mutex_Control *mutex;
> + Mutex_Control *mutex;
> mutex = _Mutex_Get( _mutex );
> - executing = _Mutex_Queue_acquire( mutex, &lock_context );
> + executing = _Mutex_Queue_acquire( mutex, &queue_context.Lock_context );
> _Assert( mutex->owner == executing );
> - _Mutex_Release_critical( mutex, executing, &lock_context );
> + _Mutex_Release_critical( mutex, executing, &queue_context );
> static Mutex_recursive_Control *_Mutex_recursive_Get(
> @@ -426,23 +427,27 @@ int _Mutex_recursive_Try_acquire( struct _Mutex_recursive_Control *_mutex )
> void _Mutex_recursive_Release( struct _Mutex_recursive_Control *_mutex )
> Mutex_recursive_Control *mutex;
> unsigned int nest_level;
> mutex = _Mutex_recursive_Get( _mutex );
> - executing = _Mutex_Queue_acquire( &mutex->Mutex, &lock_context );
> + &mutex->Mutex,
> + &queue_context.Lock_context
> _Assert( mutex->Mutex.owner == executing );
> nest_level = mutex->nest_level;
> if ( __predict_true( nest_level == 0 ) ) {
> - _Mutex_Release_critical( &mutex->Mutex, executing, &lock_context );
> + _Mutex_Release_critical( &mutex->Mutex, executing, &queue_context );
> } else {
> mutex->nest_level = nest_level - 1;
> - _Mutex_Queue_release( &mutex->Mutex, &lock_context );
> + _Mutex_Queue_release( &mutex->Mutex, &queue_context.Lock_context );
> diff --git a/cpukit/score/src/semaphore.c b/cpukit/score/src/semaphore.c
> index 4e70b79..3d0d5f5 100644
> --- a/cpukit/score/src/semaphore.c
> +++ b/cpukit/score/src/semaphore.c
> @@ -110,18 +110,19 @@ void _Semaphore_Wait( struct _Semaphore_Control *_sem )
> void _Semaphore_Post( struct _Semaphore_Control *_sem )
> - Semaphore_Control *sem;
> - Thread_queue_Heads *heads;
> + Semaphore_Control *sem;
> + Thread_queue_Heads *heads;
> sem = _Semaphore_Get( _sem );
> - _Semaphore_Queue_acquire( sem, &lock_context );
> + _Semaphore_Queue_acquire( sem, &queue_context.Lock_context );
> heads = sem->Queue.Queue.heads;
> if ( heads == NULL ) {
> _Assert( sem->count < UINT_MAX );
> ++sem->count;
> - _Semaphore_Queue_release( sem, &lock_context );
> + _Semaphore_Queue_release( sem, &queue_context.Lock_context );
> } else {
> const Thread_queue_Operations *operations;
> @@ -133,8 +134,7 @@ void _Semaphore_Post( struct _Semaphore_Control *_sem )
> &sem->Queue.Queue,
> operations,
> first,
> - NULL,
> - &lock_context
> + &queue_context
> diff --git a/cpukit/score/src/threadqenqueue.c b/cpukit/score/src/threadqenqueue.c
> index cda7c86..a1a37e1 100644
> --- a/cpukit/score/src/threadqenqueue.c
> +++ b/cpukit/score/src/threadqenqueue.c
> @@ -99,7 +99,7 @@ bool _Thread_queue_Do_extract_locked(
> #endif
> @@ -108,12 +108,13 @@ bool _Thread_queue_Do_extract_locked(
> if ( !_Objects_Is_local_id( the_thread->Object.id ) ) {
> - Thread_Proxy_control *the_proxy;
> - _Assert( mp_callout != NULL );
> + Thread_Proxy_control *the_proxy;
> the_proxy = (Thread_Proxy_control *) the_thread;
> - the_proxy->thread_queue_callout = mp_callout;
> + mp_callout = queue_context->mp_callout;
> + _Assert( mp_callout != NULL );
> + the_proxy->thread_queue_callout = queue_context->mp_callout;
> #endif
> @@ -164,14 +165,11 @@ void _Thread_queue_Unblock_critical(
> -#endif
> bool unblock;
> @@ -180,24 +178,28 @@ void _Thread_queue_Do_extract_critical(
> queue,
> operations,
> the_thread,
> - mp_callout
> + queue_context
> unblock,
> queue,
> the_thread,
> - lock_context
> void _Thread_queue_Extract( Thread_Control *the_thread )
> - void *lock;
> - Thread_queue_Queue *queue;
> + void *lock;
> + Thread_queue_Queue *queue;
> - lock = _Thread_Lock_acquire( the_thread, &lock_context );
> + &queue_context,
> + _Thread_queue_MP_callout_do_nothing
> + lock = _Thread_Lock_acquire( the_thread, &queue_context.Lock_context );
> queue = the_thread->Wait.queue;
> @@ -208,11 +210,10 @@ void _Thread_queue_Extract( Thread_Control *the_thread )
> queue,
> the_thread->Wait.operations,
> the_thread,
> - _Thread_queue_MP_callout_do_nothing,
> - &lock_context
> + &queue_context
> } else {
> - _Thread_Lock_release( lock, &lock_context );
> + _Thread_Lock_release( lock, &queue_context.Lock_context );
> @@ -225,10 +226,11 @@ Thread_Control *_Thread_queue_Do_dequeue(
> #endif
> - Thread_Control *the_thread;
> + Thread_Control *the_thread;
> - _Thread_queue_Acquire( the_thread_queue, &lock_context );
> + _Thread_queue_Context_initialize( &queue_context, mp_callout );
> + _Thread_queue_Acquire( the_thread_queue, &queue_context.Lock_context );
> the_thread = _Thread_queue_First_locked( the_thread_queue, operations );
> @@ -239,11 +241,10 @@ Thread_Control *_Thread_queue_Do_dequeue(
> &the_thread_queue->Queue,
> operations,
> the_thread,
> - mp_callout,
> - &lock_context
> + &queue_context
> } else {
> - _Thread_queue_Release( the_thread_queue, &lock_context );
> + _Thread_queue_Release( the_thread_queue, &queue_context.Lock_context );
> return the_thread;
> diff --git a/cpukit/score/src/threadqflush.c b/cpukit/score/src/threadqflush.c
> index 0413388..8b23194 100644
> --- a/cpukit/score/src/threadqflush.c
> +++ b/cpukit/score/src/threadqflush.c
> @@ -21,24 +21,21 @@
> #include <rtems/score/threadimpl.h>
> (void) queue;
> - (void) lock_context;
> return the_thread;
> -#endif
> size_t flushed;
> @@ -60,7 +57,7 @@ size_t _Thread_queue_Do_flush_critical(
> first = ( *operations->first )( heads );
> - first = ( *filter )( first, queue, lock_context );
> + first = ( *filter )( first, queue, queue_context );
> if ( first == NULL ) {
> break;
> @@ -69,7 +66,7 @@ size_t _Thread_queue_Do_flush_critical(
> queue,
> operations,
> first,
> - mp_callout
> + queue_context
> if ( do_unblock ) {
> _Chain_Append_unprotected( &unblock, &first->Wait.Node.Chain );
> @@ -84,8 +81,10 @@ size_t _Thread_queue_Do_flush_critical(
> if ( node != tail ) {
> - _Thread_queue_Queue_release( queue, lock_context );
> + _Thread_queue_Queue_release( queue, &queue_context->Lock_context );
> do {
> @@ -100,7 +99,7 @@ size_t _Thread_queue_Do_flush_critical(
> _Thread_Dispatch_enable( cpu_self );
> } else {
> return flushed;
> diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
> index 30536f7..52d68de 100644
> --- a/cpukit/score/src/threadrestart.c
> +++ b/cpukit/score/src/threadrestart.c
> @@ -87,24 +87,24 @@ static void _Thread_Raise_real_priority(
> typedef struct {
> - void *exit_value;
> + void *exit_value;
> #endif
> -} Thread_Join_lock_context;
> +} Thread_Join_context;
> static Thread_Control *_Thread_Join_flush_filter(
> - Thread_Join_lock_context *join_lock_context;
> + Thread_Join_context *join_context;
> - join_lock_context = (Thread_Join_lock_context *) lock_context;
> + join_context = (Thread_Join_context *) queue_context;
> - the_thread->Wait.return_argument = join_lock_context->exit_value;
> + the_thread->Wait.return_argument = join_context->exit_value;
> return the_thread;
> @@ -112,13 +112,17 @@ static Thread_Control *_Thread_Join_flush_filter(
> static void _Thread_Wake_up_joining_threads( Thread_Control *the_thread )
> - Thread_Join_lock_context join_lock_context;
> + Thread_Join_context join_context;
> - join_lock_context.exit_value = the_thread->Life.exit_value;
> + join_context.exit_value = the_thread->Life.exit_value;
> #endif
> - _Thread_State_acquire( the_thread, &join_lock_context.Base );
> + _Thread_queue_Context_initialize( &join_context.Base, NULL );
> + &the_thread->Join_queue,
> + &join_context.Base.Lock_context
> &the_thread->Join_queue.Queue,
> THREAD_JOIN_TQ_OPERATIONS,
> @@ -127,8 +131,7 @@ static void _Thread_Wake_up_joining_threads( Thread_Control *the_thread )
> #else
> #endif
> - NULL,
> - &join_lock_context.Base
> diff --git a/testsuites/sptests/spintrcritical22/init.c b/testsuites/sptests/spintrcritical22/init.c
> index b5044d9..3670d1a 100644
> --- a/testsuites/sptests/spintrcritical22/init.c
> +++ b/testsuites/sptests/spintrcritical22/init.c
> @@ -33,12 +33,12 @@ static test_context ctx_instance;
> static Semaphore_Control *get_semaphore_control(rtems_id id)
> - sem = _Semaphore_Get(id, &lock_context);
> + sem = _Semaphore_Get(id, &queue_context, NULL);
> rtems_test_assert(sem != NULL);
> - _ISR_lock_ISR_enable(&lock_context);
> + _ISR_lock_ISR_enable(&queue_context.Lock_context);
> return sem;
> diff --git a/testsuites/tmtests/tm26/task1.c b/testsuites/tmtests/tm26/task1.c
> index da37eee..68cb246 100644
> --- a/testsuites/tmtests/tm26/task1.c
> +++ b/testsuites/tmtests/tm26/task1.c
> @@ -477,9 +477,10 @@ rtems_task Floating_point_task_2(
> void complete_test( void )
> - uint32_t index;
> - rtems_id task_id;
> + uint32_t index;
> + rtems_id task_id;
> + ISR_lock_Context lock_context;
> benchmark_timer_initialize();
> thread_resume( Middle_tcb );
> @@ -513,8 +514,8 @@ void complete_test( void )
> for ( index=1 ; index <= OPERATION_COUNT ; index++ ) {
> - (void) _Semaphore_Get( Semaphore_id, &lock_context );
> - _ISR_lock_ISR_enable( &lock_context );
> + (void) _Semaphore_Get( Semaphore_id, &queue_context, NULL );
> + _ISR_lock_ISR_enable( &queue_context.Lock_context );
> semaphore_get_time = benchmark_timer_read();
> 1.8.4.5
> devel mailing list
> devel at rtems.org
