LM3S69xx BSP Qemu Error
    Martin Galvan
    martin.galvan at tallertechnologies.com
    Thu May 26 20:21:13 UTC 2016
That's odd, I've used that BSP many times before and it always worked fine.
The BSP README (and patches) are quite old, and IIRC their purpose was to actually make Qemu
emulate the board properly. Any fairly recent version of Qemu shouldn't need any additional
patching; I was running RTEMS on it back in 2014 without issues.
Are you using the current Qemu master? That should work fine. If it doesn't, I can assist
you with some of the testing.
