[PATCH] doc: Fix typo
Tue Nov 1 16:19:16 UTC 2016
Thank you for your contribution. The docs/ are undergoing a major
revamp, and the indicated file will no longer be part of the
documentation. Additional typos/fixes are definitely appreciated in
the documentation within RTEMS source code, and when the new docs
repository goes live.
Gedare
On Tue, Oct 11, 2016 at 3:27 PM, Laurent Navet <laurent.navet at gmail.com> wrote:
> add missing 'r' to under.
>  doc/develenv/direct.t | 2 +-
>  1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/doc/develenv/direct.t b/doc/develenv/direct.t
> index 9950b69..23877c1 100644
> --- a/doc/develenv/direct.t
> +++ b/doc/develenv/direct.t
> @@ -116,7 +116,7 @@ This directory also contains RPM specifications for the
>  prebuilt cross-compilation toolsets provided by the
>  RTEMS project.  There are separate subdirectories
>  for each of the components in the RTEMS Cross Compilation
> -Environment unde the  @code{contrib/crossrpms/} directory.
> +Environment under the  @code{contrib/crossrpms/} directory.
>  This directory is configured, built, and installed separately
>  from the RTEMS executive and tests.  This directory will not
>  be discussed further in this document.
> 2.1.4
> devel mailing list
> devel at rtems.org
