[PATCH] doc: Fix typo
Joel Sherrill
joel at rtems.org
Wed Nov 2 15:02:34 UTC 2016
For those interested, the new docs are in the rtems-docs git repository
and Chris has a formatted version in his personal ftp directory:
https://ftp.rtems.org/pub/rtems/people/chrisj/docs/
At this point, we have reviewed the conversions of all of the existing
manuals and Chris is doing final tidying up the converted RSB manual.
The new documentation is written in Sphinx which is easy to
deal with and produces nice looking formatted output.
Comments and issues against these docs is appreciated.
--joel
On Tue, Nov 1, 2016 at 11:19 AM, Gedare Bloom <gedare at rtems.org> wrote:
> Thank you for your contribution. The docs/ are undergoing a major
> revamp, and the indicated file will no longer be part of the
> documentation. Additional typos/fixes are definitely appreciated in
> the documentation within RTEMS source code, and when the new docs
> repository goes live.
> Gedare
> On Tue, Oct 11, 2016 at 3:27 PM, Laurent Navet <laurent.navet at gmail.com>
> wrote:
> > add missing 'r' to under.
> > doc/develenv/direct.t | 2 +-
> > 1 file changed, 1 insertion(+), 1 deletion(-)
> > diff --git a/doc/develenv/direct.t b/doc/develenv/direct.t
> > index 9950b69..23877c1 100644
> > --- a/doc/develenv/direct.t
> > +++ b/doc/develenv/direct.t
> > @@ -116,7 +116,7 @@ This directory also contains RPM specifications for
> the
> > prebuilt cross-compilation toolsets provided by the
> > RTEMS project. There are separate subdirectories
> > for each of the components in the RTEMS Cross Compilation
> > -Environment unde the @code{contrib/crossrpms/} directory.
> > +Environment under the @code{contrib/crossrpms/} directory.
> > This directory is configured, built, and installed separately
> > from the RTEMS executive and tests. This directory will not
> > be discussed further in this document.
> > 2.1.4
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20161102/1b3679e1/attachment-0002.html>
