[rtems-docs commit] c_user: Re-add task notepads for 4.11. Remove this patch after branching.
Wed Nov 2 23:03:19 UTC 2016
On 03/11/2016 01:57, Joel Sherrill wrote:
> I cut and pasted it from the adjacent configure_xxx constant. I double
> checked and it looks like this is the pattern through almost this entire
> chapter.
>   grep DESCRIPTION configuring_a_system.rst  | uniq -c
>        1 *DESCRIPTION:*
>      140 **DESCRIPTION:**
> The "1" case is in the section describing how they are documented.
Ha that is funny. Will you sort this out?
