[PATCH 21/26] arm: Simplify _ARMV4_Exception_interrupt
    Sebastian Huber
    Tue Nov 15 13:51:53 UTC 2016
Move profiling code closer to bsp_interrupt_disable() to allow re-use of
r9 later.
 cpukit/score/cpu/arm/arm_exc_interrupt.S | 40 ++++++++++++++++++--------------
 1 file changed, 22 insertions(+), 18 deletions(-)
diff --git a/cpukit/score/cpu/arm/arm_exc_interrupt.S b/cpukit/score/cpu/arm/arm_exc_interrupt.S
index 28da989..de5a022 100644
--- a/cpukit/score/cpu/arm/arm_exc_interrupt.S
+++ b/cpukit/score/cpu/arm/arm_exc_interrupt.S
@@ -112,16 +112,23 @@ _ARMV4_Exception_interrupt:
 	str	r2, [SELF_CPU_CONTROL, #PER_CPU_ISR_NEST_LEVEL]
 	str	r3, [SELF_CPU_CONTROL, #PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL]
+	/* Call BSP dependent interrupt dispatcher */
 #ifdef RTEMS_PROFILING
 	cmp	r2, #1
-	bne	.Lprofiling_entry_done
+	bne	.Lskip_profiling
 	bl	_CPU_Counter_read
-	push	{r0, r1}
-.Lprofiling_entry_done:
-#endif
-	/* Call BSP dependent interrupt dispatcher */
+	mov	SELF_CPU_CONTROL, r0
+	bl	bsp_interrupt_dispatch
+	bl	_CPU_Counter_read
+	mov	r2, r0
+	mov	r1, SELF_CPU_CONTROL
+	GET_SELF_CPU_CONTROL	r0
+	bl	_Profiling_Outer_most_interrupt_entry_and_exit
+.Lprofiling_done:
+#else
+#endif
 	/* Decrement interrupt nest and thread dispatch disable level */
 	ldr	r2, [SELF_CPU_CONTROL, #PER_CPU_ISR_NEST_LEVEL]
@@ -131,18 +138,6 @@ _ARMV4_Exception_interrupt:
-#ifdef RTEMS_PROFILING
-	cmp	r2, #0
-	bne	.Lprofiling_exit_done
-	bl	_CPU_Counter_read
-	pop	{r1, r3}
-	mov	r2, r0
-	mov	r0, SELF_CPU_CONTROL
-	bl	_Profiling_Outer_most_interrupt_entry_and_exit
-	ldr	r3, [SELF_CPU_CONTROL, #PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL]
-.Lprofiling_exit_done:
-#endif
 	/* Restore stack pointer */
 	mov	sp, SP_OF_INTERRUPTED_CONTEXT
@@ -239,4 +234,13 @@ _ARMV4_Exception_interrupt:
 	/* Return from interrupt */
 	subs	pc, lr, #4
+#ifdef RTEMS_PROFILING
+#ifdef __thumb__
+.thumb
+#endif
+.Lskip_profiling:
+	b	.Lprofiling_done
+#endif
 #endif /* ARM_MULTILIB_ARCH_V4 */
1.8.4.5
