[PATCH] rtems/gdb: Fix powerpc builds on FreeBSD.
Chris Johns
chrisj at rtems.org
Fri Nov 25 08:58:52 UTC 2016
This patch add a GDB patch to the gdb-7.12 build so the PowerPC
builds on FreeBSD.
https://sourceware.org/bugzilla/show_bug.cgi?id=20863
rtems/config/tools/rtems-gdb-7.12-1.cfg | 5 +++++
1 file changed, 5 insertions(+)
diff --git a/rtems/config/tools/rtems-gdb-7.12-1.cfg b/rtems/config/tools/rtems-gdb-7.12-1.cfg
index 215b954..aac4dd6 100644
--- a/rtems/config/tools/rtems-gdb-7.12-1.cfg
+++ b/rtems/config/tools/rtems-gdb-7.12-1.cfg
@@ -24,6 +24,11 @@
%endif
+# Simulator error fix.
+%patch add gdb --rsb-file=PATCH_Define_an_error_function_in_the_PPC_simulator -p1 https://sourceware.org/cgi-bin/get-raw-msg?listname=gdb-patches&date=2016-11&msgid=20161124152917.52189-1-jhb%40FreeBSD.org
# The gdb build instructions. We use 7.xx Release 1.
%include %{_configdir}/gdb-7-1.cfg
2.9.0
