[PATCH] rtems/gdb: Fix powerpc builds on FreeBSD.
Joel Sherrill
joel at rtems.org
Fri Nov 25 17:02:26 UTC 2016
This has had great support from the gdb developers.
Did any of the other targets show an issue?
I think this got applied to the 7.12 branch and master, right?
--joel
On Fri, Nov 25, 2016 at 2:58 AM, Chris Johns <chrisj at rtems.org> wrote:
> This patch add a GDB patch to the gdb-7.12 build so the PowerPC
> builds on FreeBSD.
> https://sourceware.org/bugzilla/show_bug.cgi?id=20863
> rtems/config/tools/rtems-gdb-7.12-1.cfg | 5 +++++
> 1 file changed, 5 insertions(+)
> diff --git a/rtems/config/tools/rtems-gdb-7.12-1.cfg
> b/rtems/config/tools/rtems-gdb-7.12-1.cfg
> index 215b954..aac4dd6 100644
> --- a/rtems/config/tools/rtems-gdb-7.12-1.cfg
> +++ b/rtems/config/tools/rtems-gdb-7.12-1.cfg
> @@ -24,6 +24,11 @@
> %endif
> +# Simulator error fix.
> +%patch add gdb --rsb-file=PATCH_Define_an_error_function_in_the_PPC_simulator
> -p1 https://sourceware.org/cgi-bin/get-raw-msg?listname=gdb-
> patches&date=2016-11&msgid=20161124152917.52189-1-jhb%40FreeBSD.org
> # The gdb build instructions. We use 7.xx Release 1.
> %include %{_configdir}/gdb-7-1.cfg
> 2.9.0
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20161125/3eeac450/attachment-0002.html>
