[PATCH] rtems/gdb: Fix powerpc builds on FreeBSD.
Joel Sherrill
joel at rtems.org
Sun Nov 27 00:36:53 UTC 2016
On Nov 26, 2016 6:48 PM, "Chris Johns" <chrisj at rtems.org> wrote:
> On 26/11/16 4:02 am, Joel Sherrill wrote:
> > This has had great support from the gdb developers.
> Yes the turn around time for this fix was excellent.
> > Did any of the other targets show an issue?
> I do not know. I have built sparc tools with the patch. I do not know if
> it was also broken.
This was a build error so we need to build all the tools on FreeBSD to
check.
> > I think this got applied to the 7.12 branch and master, right?
> Sorry, I do not know. I think this patch should be pushed until a
> release with the fix is available. Ok to push?
I thought they put it on both but we need the patch so push what is needed
for 7.12.
When 7.12.1 comes out, we will need to also bump mipstx39
> Chri
URL: <http://lists.rtems.org/pipermail/devel/attachments/20161126/5c0a4045/attachment.html>
