[PATCH] rtems/gdb: Fix powerpc builds on FreeBSD.
Mon Nov 28 21:49:04 UTC 2016
On 27/11/2016 11:36, Joel Sherrill wrote:
> On Nov 26, 2016 6:48 PM, "Chris Johns" <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>  > On 26/11/16 4:02 am, Joel Sherrill wrote:
>  > > This has had great support from the gdb developers.
>  > Yes the turn around time for this fix was excellent.
>  > > Did any of the other targets show an issue?
>  > I do not know. I have built sparc tools with the patch. I do not know if
>  > it was also broken.
> This was a build error so we need to build all the tools on FreeBSD to
> check.
I built 4.12/rtems-all on FreeBSD and the following failed:
  epiphany-rtems4.12-gdb-7.8.1-x86_64-freebsd10.3-1
  m32c-rtems4.12-gdb-7.9-x86_64-freebsd10.3-1
  mips-rtems4.12-gcc-6-20161110-newlib-2.4.0.20161025-x86_64-freebsd10.3-1
  mipstx39-rtems4.12-gdb-7.9-x86_64-freebsd10.3-1
The issues are:
  epiphany-rtems4.12-gdb:
  m32c-rtems4.12-gdb-7.9:
  mipstx39-rtems4.12-gdb-7.9:
    - libiconv issue
  mips-rtems4.12-gcc-6-20161110-newlib-2.4.0.20161025:
   - BSD shell issue in the expansion of the multilibs.
>  > > I think this got applied to the 7.12 branch and master, right?
>  > Sorry, I do not know. I think this patch should be pushed until a
>  > release with the fix is available. Ok to push?
> I thought they put it on both but we need the patch so push what is
> needed for 7.12.
They may have however I am not sure what you are asking.
> When 7.12.1 comes out, we will need to also bump mipstx39
Sure.
