Building All Output Formats for RTEMS Docs
Christian Mauderer
christian.mauderer at embedded-brains.de
Mon Nov 7 08:27:33 UTC 2016
> On 07/11/2016 09:40, Christian Mauderer wrote:
>> I tested to build the documentation on Arch Linux. I had to install some
>> additional packages (see attached patch 2) and I had to work around a TypeError
>> (see first part of attached error.log and patch 1) during the "waf configure".
> Sorry about that. I was about to push the same patch.
>> While building there was another tool missing (pygmentize - see second part of
>> error.log). Eventually it would be nice to add a check for this in the
>> configure step?
> Both patches pushed.
> Thanks.
> Chris
Hello Chris,
with your patch that removes lato and inconsolata, there are now fewer packages necessary on Arch. It is now not longer necessary to install the quite large texlive-fontsextra (nearly 700MB). Beneath that, the pygmentize packet has somehow been lost in my original patch to the README.
I appended a patch that will remove texlive-fontsextra from the Arch Linux section of the README and add pygmentize again.
Kind regards
Christian Mauderer
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20161107/0000455c/attachment-0002.bin>
