Building All Output Formats for RTEMS Docs
Joel Sherrill
joel at rtems.org
Mon Nov 7 21:02:12 UTC 2016
For CentOS, I am trying to install the Texlive version now. It is taking
a LONG time. It had an estimated install time of about 4 hours and
died on the first attempt.
If this works on CentOS 6, then I will repeat for CentOS 7 and Fedora
23. If all goes well, this can be the recommended solution on those
distributions.
After that, I will investigate Ubuntu if no one beats me to it.
--joel
On Mon, Nov 7, 2016 at 2:27 AM, Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> > On 07/11/2016 09:40, Christian Mauderer wrote:
> >> I tested to build the documentation on Arch Linux. I had to install some
> >> additional packages (see attached patch 2) and I had to work around a
> TypeError
> >> (see first part of attached error.log and patch 1) during the "waf
> configure".
> > Sorry about that. I was about to push the same patch.
> >> While building there was another tool missing (pygmentize - see second
> part of
> >> error.log). Eventually it would be nice to add a check for this in the
> >> configure step?
> > Both patches pushed.
> > Thanks.
> > Chris
> Hello Chris,
> with your patch that removes lato and inconsolata, there are now fewer
> packages necessary on Arch. It is now not longer necessary to install the
> quite large texlive-fontsextra (nearly 700MB). Beneath that, the pygmentize
> packet has somehow been lost in my original patch to the README.
> I appended a patch that will remove texlive-fontsextra from the Arch Linux
> section of the README and add pygmentize again.
> Kind regards
> Christian Mauderer
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20161107/b7ea6753/attachment-0002.html>
