Update Atsam BSP Support
Wed Oct 5 05:17:35 UTC 2016
One way to keep this in sync would be to simply write the README of each
BSP in a certain format, e.g. trac wiki and then simply include the
content from Git in trac. For example via a modified variant of
https://trac.edgewall.org/attachment/wiki/MacroBazaar/Include.3.py
Something like this in trac:
[[RTEMSGitInclude(c/src/lib/libbsp/arm/atsam/README)]]
On 04/10/16 21:41, Pavel Pisa wrote:
> Hello Gedare and Alexander,
> one possible solution to keep that in sync.
> Change of README in BSP directory
> to MarkDown or Rest-Text syntax and put on the web
> generated pages synced directly from master and last stable.
> On the other hand, wiki allows to include more information
> and relation links.
> Best wishes,
>          Pavel
> On Tuesday 04 of October 2016 15:21:46 Gedare Bloom wrote:
>> Thanks. does this BSP have a wiki page? If not, it would be good to
>> make one for it. Generally we need to do a better job of keeping a
>> web-visible "feature set" up to date.
>> On Tue, Oct 4, 2016 at 7:39 AM, Alexander Krutwig
>> <alexander.krutwig at embedded-brains.de> wrote:
>>> Hello,
>>> over the last months, lots of work and effort has been put into the
>>> development
>>> of the BSP support for ATSAMV7 microcontrollers by Atmel.
>>> Thus, I updated the README of the BSP with the work already done in the
>>> process and
>>> attached it to this email in order to keep you updated about the
>>> progress.
>>> In addition to the work described in the document, we currently work on
>>> USB and SD-card
>>> support. Support for NOR flashes is already finished, however, not yet
>>> committed.
>>> Best regards,
>>> Alexander Krutwig
>>> embedded brains GmbH
>>> Alexander Krutwig
>>> Dornierstr. 4
>>> D-82178 Puchheim
>>> Germany
>>> email: alexander.krutwig at embedded-brains.de
>>> Phone: +49-89-18 94 741 - 17
>>> Fax:   +49-89-18 94 741 - 09
>>> PGP: Public key available on request.
>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
