[PATCH] doc: Fix typo
Laurent Navet
laurent.navet at gmail.com
Tue Oct 11 19:27:31 UTC 2016
add missing 'r' to under.
doc/develenv/direct.t | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/doc/develenv/direct.t b/doc/develenv/direct.t
index 9950b69..23877c1 100644
--- a/doc/develenv/direct.t
+++ b/doc/develenv/direct.t
@@ -116,7 +116,7 @@ This directory also contains RPM specifications for the
prebuilt cross-compilation toolsets provided by the
RTEMS project. There are separate subdirectories
for each of the components in the RTEMS Cross Compilation
-Environment unde the @code{contrib/crossrpms/} directory.
+Environment under the @code{contrib/crossrpms/} directory.
This directory is configured, built, and installed separately
from the RTEMS executive and tests. This directory will not
be discussed further in this document.
2.1.4
