[PATCH] libmisc/xz: Add xz decompression.
Tue Oct 11 23:11:28 UTC 2016
Add support to untar XZ compressed files.
 cpukit/Makefile.am                    |    3 +
 cpukit/libmisc/Makefile.am            |   10 +-
 cpukit/libmisc/untar/untar.h          |   63 ++
 cpukit/libmisc/untar/untar_txz.c      |  109 +++
 cpukit/libmisc/xz/COPYING             |   10 +
 cpukit/libmisc/xz/README              |    9 +
 cpukit/libmisc/xz/xz.h                |  304 +++++++++
 cpukit/libmisc/xz/xz_config.h         |  124 ++++
 cpukit/libmisc/xz/xz_crc32.c          |   59 ++
 cpukit/libmisc/xz/xz_crc64.c          |   50 ++
 cpukit/libmisc/xz/xz_dec_lzma2.c      | 1175 +++++++++++++++++++++++++++++++++
 cpukit/libmisc/xz/xz_dec_stream.c     |  847 ++++++++++++++++++++++++
 cpukit/libmisc/xz/xz_lzma2.h          |  204 ++++++
 cpukit/libmisc/xz/xz_private.h        |  156 +++++
 cpukit/libmisc/xz/xz_stream.h         |   62 ++
 cpukit/preinstall.am                  |    9 +
 cpukit/wrapup/Makefile.am             |    1 +
 testsuites/libtests/configure.ac      |    2 +
 testsuites/libtests/tar01/Makefile.am |   26 +-
 testsuites/libtests/tar01/init.c      |   74 ++-
 20 files changed, 3292 insertions(+), 5 deletions(-)
 create mode 100644 cpukit/libmisc/untar/untar_txz.c
 create mode 100644 cpukit/libmisc/xz/COPYING
 create mode 100644 cpukit/libmisc/xz/README
 create mode 100644 cpukit/libmisc/xz/xz.h
 create mode 100644 cpukit/libmisc/xz/xz_config.h
 create mode 100644 cpukit/libmisc/xz/xz_crc32.c
 create mode 100644 cpukit/libmisc/xz/xz_crc64.c
 create mode 100644 cpukit/libmisc/xz/xz_dec_lzma2.c
 create mode 100644 cpukit/libmisc/xz/xz_dec_stream.c
 create mode 100644 cpukit/libmisc/xz/xz_lzma2.h
 create mode 100644 cpukit/libmisc/xz/xz_private.h
 create mode 100644 cpukit/libmisc/xz/xz_stream.h
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index feca7ab..6ca5e16 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -48,6 +48,9 @@ include_uuid_HEADERS = libmisc/uuid/uuid.h
 include_utf8procdir = $(includedir)/utf8proc
 include_utf8proc_HEADERS = libmisc/utf8proc/utf8proc.h
+include_xzdir = $(includedir)
+include_xz_HEADERS = libmisc/xz/xz.h
 include_sysdir = $(includedir)/sys
 include_sys_HEADERS =
diff --git a/cpukit/libmisc/Makefile.am b/cpukit/libmisc/Makefile.am
index 97e14b0..dda5b99 100644
--- a/cpukit/libmisc/Makefile.am
+++ b/cpukit/libmisc/Makefile.am
@@ -155,7 +155,8 @@ EXTRA_DIST += stackchk/README
 ## libuntar
 noinst_LIBRARIES += libuntar.a
-libuntar_a_SOURCES = untar/untar.c untar/untar_tgz.c untar/untar.h
+libuntar_a_SOURCES = untar/untar.c untar/untar_txz.c untar/untar_tgz.c \
+	untar/untar.h
 EXTRA_DIST += untar/README
@@ -192,6 +193,13 @@ libuuid_a_SOURCES = uuid/clear.c uuid/compare.c uuid/copy.c uuid/gen_uuid.c \
 	uuid/isnull.c uuid/pack.c uuid/parse.c uuid/unpack.c uuid/unparse.c \
 	uuid/uuid_time.c uuid/uuidd.h uuid/uuidP.h
+## xz-embedded
+noinst_LIBRARIES += libxz.a
+libxz_a_SOURCES = xz/xz/h xz/xz_crc32.c xz/xz_crc64.c \
+	xz/xz_dec_lzma2.c xz/xz_dec_stream.c
+EXTRA_DIST += xz/README xz/COPING
 include $(srcdir)/preinstall.am
 include $(top_srcdir)/automake/local.am
diff --git a/cpukit/libmisc/untar/untar.h b/cpukit/libmisc/untar/untar.h
index 3c8bb74..b97d1d5 100644
--- a/cpukit/libmisc/untar/untar.h
+++ b/cpukit/libmisc/untar/untar.h
@@ -21,6 +21,7 @@
 #include <stddef.h>
 #include <tar.h>
 #include <zlib.h>
+#include <xz.h>
 #include <rtems/print.h>
@@ -117,6 +118,34 @@ typedef struct {
 } Untar_GzChunkContext;
+typedef struct {
+   * @brief Instance of Chunk Context needed for tar decompression.
+  Untar_ChunkContext base;
+   * @brief Xz context.
+  struct xz_dec* strm;
+   * @brief Xz buffer.
+  struct xz_buf buf;
+   * @brief Buffer that contains the inflated data.
+  void *inflateBuffer;
+   * @brief Size of buffer that contains the inflated data.
+  size_t inflateBufferSize;
+} Untar_XzChunkContext;
  * @brief Initializes the Untar_ChunkContext files out of a part of a block of
  * memory.
@@ -175,6 +204,40 @@ int Untar_FromGzChunk_Print(
   const rtems_printer* printer
+ * @brief Initializes the Untar_ChunkXzContext.
+ * @param Untar_ChunkXzContext *context [in] Pointer to a context structure.
+ * @param enum xz_mode mode [in] Dictionary mode.
+ * @param uint32_t dict_max [in] Maximum size of dictionary.
+ * @param void *inflateBuffer [in] Pointer to a context structure.
+ * @param size_t inflateBufferSize [in] Size of inflateBuffer.
+int Untar_XzChunkContext_Init(
+  Untar_XzChunkContext *ctx,
+  enum xz_mode mode,
+  uint32_t dict_max,
+  void *inflateBuffer,
+ * @brief Untars a XZ compressed POSIX TAR file.
+ * This is a subroutine used to rip links, directories, and
+ * files out of a tar.gz/tgz file.
+ * @param Untar_ChunkContext *context [in] Pointer to a context structure.
+ * @param ssize buflen [in] Size of valid bytes in input buffer.
+ * @param z_stream *strm [in] Pointer to the current zlib context.
+int Untar_FromXzChunk_Print(
+  void *chunk,
+  size_t chunk_size,
+  const rtems_printer* printer
  * This converts octal ASCII number representations into an
  * unsigned long.  Only support 32-bit numbers for now.
diff --git a/cpukit/libmisc/untar/untar_txz.c b/cpukit/libmisc/untar/untar_txz.c
new file mode 100644
index 0000000..89c7a06
--- /dev/null
+++ b/cpukit/libmisc/untar/untar_txz.c
@@ -0,0 +1,109 @@
+ * Copyright (c) 2016 Chris Johns <chrisj.rtems.org>.  All rights reserved.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/untar.h>
+  int status = UNTAR_SUCCESSFUL;
+  xz_crc32_init();
+  Untar_ChunkContext_Init(&ctx->base);
+  ctx->inflateBuffer = inflateBuffer;
+  ctx->inflateBufferSize = inflateBufferSize;
+  ctx->strm = xz_dec_init(mode, dict_max);
+  if (ctx->strm == NULL) {
+    status = UNTAR_FAIL;
+  return status;
+  void *chunk,
+  const rtems_printer *printer
+  int untar_status = UNTAR_SUCCESSFUL;
+  enum xz_ret status = XZ_OK;
+    return UNTAR_FAIL;
+  ctx->buf.in = (const uint8_t*) chunk;
+  ctx->buf.in_pos = 0;
+  ctx->buf.in_size = chunk_size;
+  ctx->buf.out = (uint8_t *) ctx->inflateBuffer;
+  /* Inflate until output buffer is not full */
+  do {
+    ctx->buf.out_pos = 0;
+    ctx->buf.out_size = ctx->inflateBufferSize;
+    status = xz_dec_run(ctx->strm, &ctx->buf);
+    if (status == XZ_OPTIONS_ERROR)
+      status = XZ_OK;
+    if (status == XZ_OK && ctx->buf.out_pos != 0) {
+      untar_status = Untar_FromChunk_Print(&ctx->base,
+                                           ctx->inflateBuffer,
+                                           ctx->buf.out_pos,
+                                           NULL);
+      if (untar_status != UNTAR_SUCCESSFUL) {
+        break;
+  } while (ctx->buf.in_pos != ctx->buf.in_size && status == XZ_OK);
+  if (status != XZ_OK) {
+    xz_dec_end(ctx->strm);
+    ctx->strm = NULL;
+    if (untar_status == UNTAR_SUCCESSFUL) {
+      switch (status) {
+      case XZ_OK:
+      case XZ_STREAM_END:
+        break;
+      case XZ_UNSUPPORTED_CHECK:
+        rtems_printf(printer, "XZ unsupported check\n");
+        break;
+      case XZ_MEM_ERROR:
+        rtems_printf(printer, "XZ memory allocation error\n");
+        break;
+      case XZ_MEMLIMIT_ERROR:
+        rtems_printf(printer, "XZ memory usage limit reached\n");
+        break;
+      case XZ_FORMAT_ERROR:
+        rtems_printf(printer, "Not a XZ file\n");
+        break;
+      case XZ_OPTIONS_ERROR:
+        rtems_printf(printer, "Unsupported options in XZ header\n");
+        break;
+      case XZ_DATA_ERROR:
+        rtems_printf(printer, "XZ file is corrupt (data)\n");
+        break;
+      case XZ_BUF_ERROR:
+        rtems_printf(printer, "XZ file is corrupt (buffer)\n");
+        break;
+      untar_status = UNTAR_FAIL;
+  return untar_status;
diff --git a/cpukit/libmisc/xz/COPYING b/cpukit/libmisc/xz/COPYING
index 0000000..fc4fbf7
--- /dev/null
+++ b/cpukit/libmisc/xz/COPYING
@@ -0,0 +1,10 @@
+Licensing of XZ Embedded
+    All the files in this package have been written by Lasse Collin
+    and/or Igor Pavlov. All these files have been put into the
+    public domain. You can do whatever you want with these files.
+    As usual, this software is provided "as is", without any warranty.
diff --git a/cpukit/libmisc/xz/README b/cpukit/libmisc/xz/README
index 0000000..8989781
--- /dev/null
+++ b/cpukit/libmisc/xz/README
@@ -0,0 +1,9 @@
+XZ Emebdded
+Chris Johns <chrisj at rtems.org> 2016
+The code is take from the git repo:
+ http://git.tukaani.org/xz-embedded.git
+The source has been pulled out of the Linux structure held in the repo.
diff --git a/cpukit/libmisc/xz/xz.h b/cpukit/libmisc/xz/xz.h
index 0000000..0a4b38d
--- /dev/null
+++ b/cpukit/libmisc/xz/xz.h
@@ -0,0 +1,304 @@
+ * XZ decompressor
+ * Authors: Lasse Collin <lasse.collin at tukaani.org>
+ *          Igor Pavlov <http://7-zip.org/>
+ * This file has been put into the public domain.
+ * You can do whatever you want with this file.
+#ifndef XZ_H
+#define XZ_H
+#ifdef __KERNEL__
+#	include <linux/stddef.h>
+#	include <linux/types.h>
+#else
+#	include <stddef.h>
+#	include <stdint.h>
+#endif
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* In Linux, this is used to make extern functions static when needed. */
+#ifndef XZ_EXTERN
+#	define XZ_EXTERN extern
+#endif
+ * enum xz_mode - Operation mode
+ * @XZ_SINGLE:              Single-call mode. This uses less RAM than
+ *                          than multi-call modes, because the LZMA2
+ *                          dictionary doesn't need to be allocated as
+ *                          part of the decoder state. All required data
+ *                          structures are allocated at initialization,
+ *                          so xz_dec_run() cannot return XZ_MEM_ERROR.
+ * @XZ_PREALLOC:            Multi-call mode with preallocated LZMA2
+ *                          dictionary buffer. All data structures are
+ *                          allocated at initialization, so xz_dec_run()
+ *                          cannot return XZ_MEM_ERROR.
+ * @XZ_DYNALLOC:            Multi-call mode. The LZMA2 dictionary is
+ *                          allocated once the required size has been
+ *                          parsed from the stream headers. If the
+ *                          allocation fails, xz_dec_run() will return
+ *                          XZ_MEM_ERROR.
+ * It is possible to enable support only for a subset of the above
+ * modes at compile time by defining XZ_DEC_SINGLE, XZ_DEC_PREALLOC,
+ * or XZ_DEC_DYNALLOC. The xz_dec kernel module is always compiled
+ * with support for all operation modes, but the preboot code may
+ * be built with fewer features to minimize code size.
+enum xz_mode {
+	XZ_SINGLE,
+	XZ_PREALLOC,
+	XZ_DYNALLOC
+ * enum xz_ret - Return codes
+ * @XZ_OK:                  Everything is OK so far. More input or more
+ *                          output space is required to continue. This
+ *                          return code is possible only in multi-call mode
+ *                          (XZ_PREALLOC or XZ_DYNALLOC).
+ * @XZ_STREAM_END:          Operation finished successfully.
+ * @XZ_UNSUPPORTED_CHECK:   Integrity check type is not supported. Decoding
+ *                          is still possible in multi-call mode by simply
+ *                          calling xz_dec_run() again.
+ *                          Note that this return value is used only if
+ *                          XZ_DEC_ANY_CHECK was defined at build time,
+ *                          which is not used in the kernel. Unsupported
+ *                          check types return XZ_OPTIONS_ERROR if
+ *                          XZ_DEC_ANY_CHECK was not defined at build time.
+ * @XZ_MEM_ERROR:           Allocating memory failed. This return code is
+ *                          possible only if the decoder was initialized
+ *                          with XZ_DYNALLOC. The amount of memory that was
+ *                          tried to be allocated was no more than the
+ *                          dict_max argument given to xz_dec_init().
+ * @XZ_MEMLIMIT_ERROR:      A bigger LZMA2 dictionary would be needed than
+ *                          allowed by the dict_max argument given to
+ *                          xz_dec_init(). This return value is possible
+ *                          only in multi-call mode (XZ_PREALLOC or
+ *                          XZ_DYNALLOC); the single-call mode (XZ_SINGLE)
+ *                          ignores the dict_max argument.
+ * @XZ_FORMAT_ERROR:        File format was not recognized (wrong magic
+ *                          bytes).
+ * @XZ_OPTIONS_ERROR:       This implementation doesn't support the requested
+ *                          compression options. In the decoder this means
+ *                          that the header CRC32 matches, but the header
+ *                          itself specifies something that we don't support.
+ * @XZ_DATA_ERROR:          Compressed data is corrupt.
+ * @XZ_BUF_ERROR:           Cannot make any progress. Details are slightly
+ *                          different between multi-call and single-call
+ *                          mode; more information below.
+ * In multi-call mode, XZ_BUF_ERROR is returned when two consecutive calls
+ * to XZ code cannot consume any input and cannot produce any new output.
+ * This happens when there is no new input available, or the output buffer
+ * is full while at least one output byte is still pending. Assuming your
+ * code is not buggy, you can get this error only when decoding a compressed
+ * stream that is truncated or otherwise corrupt.
+ * In single-call mode, XZ_BUF_ERROR is returned only when the output buffer
+ * is too small or the compressed input is corrupt in a way that makes the
+ * decoder produce more output than the caller expected. When it is
+ * (relatively) clear that the compressed input is truncated, XZ_DATA_ERROR
+ * is used instead of XZ_BUF_ERROR.
+enum xz_ret {
+	XZ_OK,
+	XZ_STREAM_END,
+	XZ_UNSUPPORTED_CHECK,
+	XZ_MEM_ERROR,
+	XZ_MEMLIMIT_ERROR,
+	XZ_FORMAT_ERROR,
+	XZ_OPTIONS_ERROR,
+	XZ_DATA_ERROR,
+	XZ_BUF_ERROR
+ * struct xz_buf - Passing input and output buffers to XZ code
+ * @in:         Beginning of the input buffer. This may be NULL if and only
+ *              if in_pos is equal to in_size.
+ * @in_pos:     Current position in the input buffer. This must not exceed
+ *              in_size.
+ * @in_size:    Size of the input buffer
+ * @out:        Beginning of the output buffer. This may be NULL if and only
+ *              if out_pos is equal to out_size.
+ * @out_pos:    Current position in the output buffer. This must not exceed
+ *              out_size.
+ * @out_size:   Size of the output buffer
+ * Only the contents of the output buffer from out[out_pos] onward, and
+ * the variables in_pos and out_pos are modified by the XZ code.
+struct xz_buf {
+	const uint8_t *in;
+	size_t in_pos;
+	size_t in_size;
+	uint8_t *out;
+	size_t out_pos;
+	size_t out_size;
+ * struct xz_dec - Opaque type to hold the XZ decoder state
+struct xz_dec;
+ * xz_dec_init() - Allocate and initialize a XZ decoder state
+ * @mode:       Operation mode
+ * @dict_max:   Maximum size of the LZMA2 dictionary (history buffer) for
+ *              multi-call decoding. This is ignored in single-call mode
+ *              (mode == XZ_SINGLE). LZMA2 dictionary is always 2^n bytes
+ *              or 2^n + 2^(n-1) bytes (the latter sizes are less common
+ *              in practice), so other values for dict_max don't make sense.
+ *              In the kernel, dictionary sizes of 64 KiB, 128 KiB, 256 KiB,
+ *              512 KiB, and 1 MiB are probably the only reasonable values,
+ *              except for kernel and initramfs images where a bigger
+ *              dictionary can be fine and useful.
+ * Single-call mode (XZ_SINGLE): xz_dec_run() decodes the whole stream at
+ * once. The caller must provide enough output space or the decoding will
+ * fail. The output space is used as the dictionary buffer, which is why
+ * there is no need to allocate the dictionary as part of the decoder's
+ * internal state.
+ * Because the output buffer is used as the workspace, streams encoded using
+ * a big dictionary are not a problem in single-call mode. It is enough that
+ * the output buffer is big enough to hold the actual uncompressed data; it
+ * can be smaller than the dictionary size stored in the stream headers.
+ * Multi-call mode with preallocated dictionary (XZ_PREALLOC): dict_max bytes
+ * of memory is preallocated for the LZMA2 dictionary. This way there is no
+ * risk that xz_dec_run() could run out of memory, since xz_dec_run() will
+ * never allocate any memory. Instead, if the preallocated dictionary is too
+ * small for decoding the given input stream, xz_dec_run() will return
+ * XZ_MEMLIMIT_ERROR. Thus, it is important to know what kind of data will be
+ * decoded to avoid allocating excessive amount of memory for the dictionary.
+ * Multi-call mode with dynamically allocated dictionary (XZ_DYNALLOC):
+ * dict_max specifies the maximum allowed dictionary size that xz_dec_run()
+ * may allocate once it has parsed the dictionary size from the stream
+ * headers. This way excessive allocations can be avoided while still
+ * limiting the maximum memory usage to a sane value to prevent running the
+ * system out of memory when decompressing streams from untrusted sources.
+ * On success, xz_dec_init() returns a pointer to struct xz_dec, which is
+ * ready to be used with xz_dec_run(). If memory allocation fails,
+ * xz_dec_init() returns NULL.
+XZ_EXTERN struct xz_dec *xz_dec_init(enum xz_mode mode, uint32_t dict_max);
+ * xz_dec_run() - Run the XZ decoder
+ * @s:          Decoder state allocated using xz_dec_init()
+ * @b:          Input and output buffers
+ * The possible return values depend on build options and operation mode.
+ * See enum xz_ret for details.
+ * Note that if an error occurs in single-call mode (return value is not
+ * XZ_STREAM_END), b->in_pos and b->out_pos are not modified and the
+ * contents of the output buffer from b->out[b->out_pos] onward are
+ * undefined. This is true even after XZ_BUF_ERROR, because with some filter
+ * chains, there may be a second pass over the output buffer, and this pass
+ * cannot be properly done if the output buffer is truncated. Thus, you
+ * cannot give the single-call decoder a too small buffer and then expect to
+ * get that amount valid data from the beginning of the stream. You must use
+ * the multi-call decoder if you don't want to uncompress the whole stream.
+XZ_EXTERN enum xz_ret xz_dec_run(struct xz_dec *s, struct xz_buf *b);
+ * xz_dec_reset() - Reset an already allocated decoder state
+ * This function can be used to reset the multi-call decoder state without
+ * freeing and reallocating memory with xz_dec_end() and xz_dec_init().
+ * In single-call mode, xz_dec_reset() is always called in the beginning of
+ * xz_dec_run(). Thus, explicit call to xz_dec_reset() is useful only in
+ * multi-call mode.
+XZ_EXTERN void xz_dec_reset(struct xz_dec *s);
+ * xz_dec_end() - Free the memory allocated for the decoder state
+ * @s:          Decoder state allocated using xz_dec_init(). If s is NULL,
+ *              this function does nothing.
+XZ_EXTERN void xz_dec_end(struct xz_dec *s);
+ * Standalone build (userspace build or in-kernel build for boot time use)
+ * needs a CRC32 implementation. For normal in-kernel use, kernel's own
+ * CRC32 module is used instead, and users of this module don't need to
+ * care about the functions below.
+#ifndef XZ_INTERNAL_CRC32
+#	ifdef __KERNEL__
+#		define XZ_INTERNAL_CRC32 0
+#	else
+#		define XZ_INTERNAL_CRC32 1
+#	endif
+#endif
+ * If CRC64 support has been enabled with XZ_USE_CRC64, a CRC64
+ * implementation is needed too.
+#ifndef XZ_USE_CRC64
+#	undef XZ_INTERNAL_CRC64
+#	define XZ_INTERNAL_CRC64 0
+#endif
+#ifndef XZ_INTERNAL_CRC64
+#	ifdef __KERNEL__
+#		error Using CRC64 in the kernel has not been implemented.
+#	else
+#		define XZ_INTERNAL_CRC64 1
+#	endif
+#endif
+#if XZ_INTERNAL_CRC32
+ * This must be called before any other xz_* function to initialize
+ * the CRC32 lookup table.
+XZ_EXTERN void xz_crc32_init(void);
+ * Update CRC32 value using the polynomial from IEEE-802.3. To start a new
+ * calculation, the third argument must be zero. To continue the calculation,
+ * the previously returned value is passed as the third argument.
+XZ_EXTERN uint32_t xz_crc32(const uint8_t *buf, size_t size, uint32_t crc);
+#endif
+#if XZ_INTERNAL_CRC64
+ * This must be called before any other xz_* function (except xz_crc32_init())
+ * to initialize the CRC64 lookup table.
+XZ_EXTERN void xz_crc64_init(void);
+ * Update CRC64 value using the polynomial from ECMA-182. To start a new
+XZ_EXTERN uint64_t xz_crc64(const uint8_t *buf, size_t size, uint64_t crc);
+#endif
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/cpukit/libmisc/xz/xz_config.h b/cpukit/libmisc/xz/xz_config.h
index 0000000..eb9dac1
--- /dev/null
+++ b/cpukit/libmisc/xz/xz_config.h
@@ -0,0 +1,124 @@
+ * Private includes and definitions for userspace use of XZ Embedded
+ * Author: Lasse Collin <lasse.collin at tukaani.org>
+#ifndef XZ_CONFIG_H
+#define XZ_CONFIG_H
+/* Uncomment to enable CRC64 support. */
+/* #define XZ_USE_CRC64 */
+/* Uncomment as needed to enable BCJ filter decoders. */
+/* #define XZ_DEC_X86 */
+/* #define XZ_DEC_POWERPC */
+/* #define XZ_DEC_IA64 */
+/* #define XZ_DEC_ARM */
+/* #define XZ_DEC_ARMTHUMB */
+/* #define XZ_DEC_SPARC */
+ * MSVC doesn't support modern C but XZ Embedded is mostly C89
+ * so these are enough.
+#ifdef _MSC_VER
+typedef unsigned char bool;
+#	define true 1
+#	define false 0
+#	define inline __inline
+#else
+#	include <stdbool.h>
+#endif
+#include <stdlib.h>
+#include <string.h>
+#include "xz.h"
+#define kmalloc(size, flags) malloc(size)
+#define kfree(ptr) free(ptr)
+#define vmalloc(size) malloc(size)
+#define vfree(ptr) free(ptr)
+#define memeq(a, b, size) (memcmp(a, b, size) == 0)
+#define memzero(buf, size) memset(buf, 0, size)
+#ifndef min
+#	define min(x, y) ((x) < (y) ? (x) : (y))
+#endif
+#define min_t(type, x, y) min(x, y)
+ * Some functions have been marked with __always_inline to keep the
+ * performance reasonable even when the compiler is optimizing for
+ * small code size. You may be able to save a few bytes by #defining
+ * __always_inline to plain inline, but don't complain if the code
+ * becomes slow.
+ * NOTE: System headers on GNU/Linux may #define this macro already,
+ * so if you want to change it, you need to #undef it first.
+#ifndef __always_inline
+#	ifdef __GNUC__
+#		define __always_inline \
+			inline __attribute__((__always_inline__))
+#	else
+#		define __always_inline inline
+#	endif
+#endif
+/* Inline functions to access unaligned unsigned 32-bit integers */
+#ifndef get_unaligned_le32
+static inline uint32_t get_unaligned_le32(const uint8_t *buf)
+	return (uint32_t)buf[0]
+			| ((uint32_t)buf[1] << 8)
+			| ((uint32_t)buf[2] << 16)
+			| ((uint32_t)buf[3] << 24);
+#endif
+#ifndef get_unaligned_be32
+static inline uint32_t get_unaligned_be32(const uint8_t *buf)
+	return (uint32_t)(buf[0] << 24)
+			| ((uint32_t)buf[1] << 16)
+			| ((uint32_t)buf[2] << 8)
+			| (uint32_t)buf[3];
+#endif
+#ifndef put_unaligned_le32
+static inline void put_unaligned_le32(uint32_t val, uint8_t *buf)
+	buf[0] = (uint8_t)val;
+	buf[1] = (uint8_t)(val >> 8);
+	buf[2] = (uint8_t)(val >> 16);
+	buf[3] = (uint8_t)(val >> 24);
+#endif
+#ifndef put_unaligned_be32
+static inline void put_unaligned_be32(uint32_t val, uint8_t *buf)
+	buf[0] = (uint8_t)(val >> 24);
+	buf[1] = (uint8_t)(val >> 16);
+	buf[2] = (uint8_t)(val >> 8);
+	buf[3] = (uint8_t)val;
+#endif
+ * Use get_unaligned_le32() also for aligned access for simplicity. On
+ * little endian systems, #define get_le32(ptr) (*(const uint32_t *)(ptr))
+ * could save a few bytes in code size.
+#ifndef get_le32
+#	define get_le32 get_unaligned_le32
+#endif
+#endif
diff --git a/cpukit/libmisc/xz/xz_crc32.c b/cpukit/libmisc/xz/xz_crc32.c
index 0000000..34532d1
--- /dev/null
+++ b/cpukit/libmisc/xz/xz_crc32.c
@@ -0,0 +1,59 @@
+ * CRC32 using the polynomial from IEEE-802.3
+ * This is not the fastest implementation, but it is pretty compact.
+ * The fastest versions of xz_crc32() on modern CPUs without hardware
+ * accelerated CRC instruction are 3-5 times as fast as this version,
+ * but they are bigger and use more memory for the lookup table.
+#include "xz_private.h"
+ * STATIC_RW_DATA is used in the pre-boot environment on some architectures.
+ * See <linux/decompress/mm.h> for details.
+#ifndef STATIC_RW_DATA
+#	define STATIC_RW_DATA static
+#endif
+STATIC_RW_DATA uint32_t xz_crc32_table[256];
+	const uint32_t poly = 0xEDB88320;
+	uint32_t i;
+	uint32_t j;
+	uint32_t r;
+	for (i = 0; i < 256; ++i) {
+		r = i;
+		for (j = 0; j < 8; ++j)
+			r = (r >> 1) ^ (poly & ~((r & 1) - 1));
+		xz_crc32_table[i] = r;
+	return;
+	crc = ~crc;
+	while (size != 0) {
+		crc = xz_crc32_table[*buf++ ^ (crc & 0xFF)] ^ (crc >> 8);
+		--size;
+	return ~crc;
diff --git a/cpukit/libmisc/xz/xz_crc64.c b/cpukit/libmisc/xz/xz_crc64.c
index 0000000..ca1caee
--- /dev/null
+++ b/cpukit/libmisc/xz/xz_crc64.c
@@ -0,0 +1,50 @@
+ * CRC64 using the polynomial from ECMA-182
+ * This file is similar to xz_crc32.c. See the comments there.
+#endif
+STATIC_RW_DATA uint64_t xz_crc64_table[256];
+	const uint64_t poly = 0xC96C5795D7870F42;
+	uint32_t i;
+	uint32_t j;
+	uint64_t r;
+		r = i;
+		xz_crc64_table[i] = r;
+	return;
+	crc = ~crc;
+		crc = xz_crc64_table[*buf++ ^ (crc & 0xFF)] ^ (crc >> 8);
+		--size;
+	return ~crc;
diff --git a/cpukit/libmisc/xz/xz_dec_lzma2.c b/cpukit/libmisc/xz/xz_dec_lzma2.c
index 0000000..08c3c80
--- /dev/null
+++ b/cpukit/libmisc/xz/xz_dec_lzma2.c
@@ -0,0 +1,1175 @@
+ * LZMA2 decoder
+#include "xz_lzma2.h"
+ * Range decoder initialization eats the first five bytes of each LZMA chunk.
+#define RC_INIT_BYTES 5
+ * Minimum number of usable input buffer to safely decode one LZMA symbol.
+ * The worst case is that we decode 22 bits using probabilities and 26
+ * direct bits. This may decode at maximum of 20 bytes of input. However,
+ * lzma_main() does an extra normalization before returning, thus we
+ * need to put 21 here.
+#define LZMA_IN_REQUIRED 21
+ * Dictionary (history buffer)
+ * These are always true:
+ *    start <= pos <= full <= end
+ *    pos <= limit <= end
+ * In multi-call mode, also these are true:
+ *    end == size
+ *    size <= size_max
+ *    allocated <= size
+ * Most of these variables are size_t to support single-call mode,
+ * in which the dictionary variables address the actual output
+ * buffer directly.
+struct dictionary {
+	/* Beginning of the history buffer */
+	uint8_t *buf;
+	/* Old position in buf (before decoding more data) */
+	size_t start;
+	/* Position in buf */
+	size_t pos;
+	 * How full dictionary is. This is used to detect corrupt input that
+	 * would read beyond the beginning of the uncompressed stream.
+	size_t full;
+	/* Write limit; we don't write to buf[limit] or later bytes. */
+	size_t limit;
+	 * End of the dictionary buffer. In multi-call mode, this is
+	 * the same as the dictionary size. In single-call mode, this
+	 * indicates the size of the output buffer.
+	size_t end;
+	 * Size of the dictionary as specified in Block Header. This is used
+	 * together with "full" to detect corrupt input that would make us
+	 * read beyond the beginning of the uncompressed stream.
+	uint32_t size;
+	 * Maximum allowed dictionary size in multi-call mode.
+	 * This is ignored in single-call mode.
+	uint32_t size_max;
+	 * Amount of memory currently allocated for the dictionary.
+	 * This is used only with XZ_DYNALLOC. (With XZ_PREALLOC,
+	 * size_max is always the same as the allocated size.)
+	uint32_t allocated;
+	/* Operation mode */
+	enum xz_mode mode;
+/* Range decoder */
+struct rc_dec {
+	uint32_t range;
+	uint32_t code;
+	 * Number of initializing bytes remaining to be read
+	 * by rc_read_init().
+	uint32_t init_bytes_left;
+	 * Buffer from which we read our input. It can be either
+	 * temp.buf or the caller-provided input buffer.
+	size_t in_pos;
+	size_t in_limit;
+/* Probabilities for a length decoder. */
+struct lzma_len_dec {
+	/* Probability of match length being at least 10 */
+	uint16_t choice;
+	/* Probability of match length being at least 18 */
+	uint16_t choice2;
+	/* Probabilities for match lengths 2-9 */
+	uint16_t low[POS_STATES_MAX][LEN_LOW_SYMBOLS];
+	/* Probabilities for match lengths 10-17 */
+	uint16_t mid[POS_STATES_MAX][LEN_MID_SYMBOLS];
+	/* Probabilities for match lengths 18-273 */
+	uint16_t high[LEN_HIGH_SYMBOLS];
+struct lzma_dec {
+	/* Distances of latest four matches */
+	uint32_t rep0;
+	uint32_t rep1;
+	uint32_t rep2;
+	uint32_t rep3;
+	/* Types of the most recently seen LZMA symbols */
+	enum lzma_state state;
+	 * Length of a match. This is updated so that dict_repeat can
+	 * be called again to finish repeating the whole match.
+	uint32_t len;
+	 * LZMA properties or related bit masks (number of literal
+	 * context bits, a mask dervied from the number of literal
+	 * position bits, and a mask dervied from the number
+	 * position bits)
+	uint32_t lc;
+	uint32_t literal_pos_mask; /* (1 << lp) - 1 */
+	uint32_t pos_mask;         /* (1 << pb) - 1 */
+	/* If 1, it's a match. Otherwise it's a single 8-bit literal. */
+	uint16_t is_match[STATES][POS_STATES_MAX];
+	/* If 1, it's a repeated match. The distance is one of rep0 .. rep3. */
+	uint16_t is_rep[STATES];
+	 * If 0, distance of a repeated match is rep0.
+	 * Otherwise check is_rep1.
+	uint16_t is_rep0[STATES];
+	 * If 0, distance of a repeated match is rep1.
+	 * Otherwise check is_rep2.
+	uint16_t is_rep1[STATES];
+	/* If 0, distance of a repeated match is rep2. Otherwise it is rep3. */
+	uint16_t is_rep2[STATES];
+	 * If 1, the repeated match has length of one byte. Otherwise
+	 * the length is decoded from rep_len_decoder.
+	uint16_t is_rep0_long[STATES][POS_STATES_MAX];
+	 * Probability tree for the highest two bits of the match
+	 * distance. There is a separate probability tree for match
+	 * lengths of 2 (i.e. MATCH_LEN_MIN), 3, 4, and [5, 273].
+	uint16_t dist_slot[DIST_STATES][DIST_SLOTS];
+	 * Probility trees for additional bits for match distance
+	 * when the distance is in the range [4, 127].
+	uint16_t dist_special[FULL_DISTANCES - DIST_MODEL_END];
+	 * Probability tree for the lowest four bits of a match
+	 * distance that is equal to or greater than 128.
+	uint16_t dist_align[ALIGN_SIZE];
+	/* Length of a normal match */
+	struct lzma_len_dec match_len_dec;
+	/* Length of a repeated match */
+	struct lzma_len_dec rep_len_dec;
+	/* Probabilities of literals */
+	uint16_t literal[LITERAL_CODERS_MAX][LITERAL_CODER_SIZE];
+struct lzma2_dec {
+	/* Position in xz_dec_lzma2_run(). */
+	enum lzma2_seq {
+		SEQ_CONTROL,
+		SEQ_UNCOMPRESSED_1,
+		SEQ_UNCOMPRESSED_2,
+		SEQ_COMPRESSED_0,
+		SEQ_COMPRESSED_1,
+		SEQ_PROPERTIES,
+		SEQ_LZMA_PREPARE,
+		SEQ_LZMA_RUN,
+		SEQ_COPY
+	} sequence;
+	/* Next position after decoding the compressed size of the chunk. */
+	enum lzma2_seq next_sequence;
+	/* Uncompressed size of LZMA chunk (2 MiB at maximum) */
+	uint32_t uncompressed;
+	 * Compressed size of LZMA chunk or compressed/uncompressed
+	 * size of uncompressed chunk (64 KiB at maximum)
+	uint32_t compressed;
+	 * True if dictionary reset is needed. This is false before
+	 * the first chunk (LZMA or uncompressed).
+	bool need_dict_reset;
+	 * True if new LZMA properties are needed. This is false
+	 * before the first LZMA chunk.
+	bool need_props;
+struct xz_dec_lzma2 {
+	 * The order below is important on x86 to reduce code size and
+	 * it shouldn't hurt on other platforms. Everything up to and
+	 * including lzma.pos_mask are in the first 128 bytes on x86-32,
+	 * which allows using smaller instructions to access those
+	 * variables. On x86-64, fewer variables fit into the first 128
+	 * bytes, but this is still the best order without sacrificing
+	 * the readability by splitting the structures.
+	struct rc_dec rc;
+	struct dictionary dict;
+	struct lzma2_dec lzma2;
+	struct lzma_dec lzma;
+	 * Temporary buffer which holds small number of input bytes between
+	 * decoder calls. See lzma2_lzma() for details.
+	struct {
+		uint32_t size;
+		uint8_t buf[3 * LZMA_IN_REQUIRED];
+	} temp;
+ * Dictionary *
+ * Reset the dictionary state. When in single-call mode, set up the beginning
+ * of the dictionary to point to the actual output buffer.
+static void dict_reset(struct dictionary *dict, struct xz_buf *b)
+	if (DEC_IS_SINGLE(dict->mode)) {
+		dict->buf = b->out + b->out_pos;
+		dict->end = b->out_size - b->out_pos;
+	dict->start = 0;
+	dict->pos = 0;
+	dict->limit = 0;
+	dict->full = 0;
+/* Set dictionary write limit */
+static void dict_limit(struct dictionary *dict, size_t out_max)
+	if (dict->end - dict->pos <= out_max)
+		dict->limit = dict->end;
+	else
+		dict->limit = dict->pos + out_max;
+/* Return true if at least one byte can be written into the dictionary. */
+static inline bool dict_has_space(const struct dictionary *dict)
+	return dict->pos < dict->limit;
+ * Get a byte from the dictionary at the given distance. The distance is
+ * assumed to valid, or as a special case, zero when the dictionary is
+ * still empty. This special case is needed for single-call decoding to
+ * avoid writing a '\0' to the end of the destination buffer.
+static inline uint32_t dict_get(const struct dictionary *dict, uint32_t dist)
+	size_t offset = dict->pos - dist - 1;
+	if (dist >= dict->pos)
+		offset += dict->end;
+	return dict->full > 0 ? dict->buf[offset] : 0;
+ * Put one byte into the dictionary. It is assumed that there is space for it.
+static inline void dict_put(struct dictionary *dict, uint8_t byte)
+	dict->buf[dict->pos++] = byte;
+	if (dict->full < dict->pos)
+		dict->full = dict->pos;
+ * Repeat given number of bytes from the given distance. If the distance is
+ * invalid, false is returned. On success, true is returned and *len is
+ * updated to indicate how many bytes were left to be repeated.
+static bool dict_repeat(struct dictionary *dict, uint32_t *len, uint32_t dist)
+	size_t back;
+	uint32_t left;
+	if (dist >= dict->full || dist >= dict->size)
+		return false;
+	left = min_t(size_t, dict->limit - dict->pos, *len);
+	*len -= left;
+	back = dict->pos - dist - 1;
+		back += dict->end;
+	do {
+		dict->buf[dict->pos++] = dict->buf[back++];
+		if (back == dict->end)
+			back = 0;
+	} while (--left > 0);
+	return true;
+/* Copy uncompressed data as is from input to dictionary and output buffers. */
+static void dict_uncompressed(struct dictionary *dict, struct xz_buf *b,
+			      uint32_t *left)
+	size_t copy_size;
+	while (*left > 0 && b->in_pos < b->in_size
+			&& b->out_pos < b->out_size) {
+		copy_size = min(b->in_size - b->in_pos,
+				b->out_size - b->out_pos);
+		if (copy_size > dict->end - dict->pos)
+			copy_size = dict->end - dict->pos;
+		if (copy_size > *left)
+			copy_size = *left;
+		*left -= copy_size;
+		memcpy(dict->buf + dict->pos, b->in + b->in_pos, copy_size);
+		dict->pos += copy_size;
+		if (DEC_IS_MULTI(dict->mode)) {
+			if (dict->pos == dict->end)
+				dict->pos = 0;
+			memcpy(b->out + b->out_pos, b->in + b->in_pos,
+					copy_size);
+		dict->start = dict->pos;
+		b->out_pos += copy_size;
+		b->in_pos += copy_size;
+ * Flush pending data from dictionary to b->out. It is assumed that there is
+ * enough space in b->out. This is guaranteed because caller uses dict_limit()
+ * before decoding data into the dictionary.
+static uint32_t dict_flush(struct dictionary *dict, struct xz_buf *b)
+	size_t copy_size = dict->pos - dict->start;
+			dict->pos = 0;
+		memcpy(b->out + b->out_pos, dict->buf + dict->start,
+				copy_size);
+	return copy_size;
+ * Range decoder *
+/* Reset the range decoder. */
+static void rc_reset(struct rc_dec *rc)
+	rc->range = (uint32_t)-1;
+	rc->code = 0;
+	rc->init_bytes_left = RC_INIT_BYTES;
+ * Read the first five initial bytes into rc->code if they haven't been
+ * read already. (Yes, the first byte gets completely ignored.)
+static bool rc_read_init(struct rc_dec *rc, struct xz_buf *b)
+	while (rc->init_bytes_left > 0) {
+		if (b->in_pos == b->in_size)
+			return false;
+		rc->code = (rc->code << 8) + b->in[b->in_pos++];
+		--rc->init_bytes_left;
+	return true;
+/* Return true if there may not be enough input for the next decoding loop. */
+static inline bool rc_limit_exceeded(const struct rc_dec *rc)
+	return rc->in_pos > rc->in_limit;
+ * Return true if it is possible (from point of view of range decoder) that
+ * we have reached the end of the LZMA chunk.
+static inline bool rc_is_finished(const struct rc_dec *rc)
+	return rc->code == 0;
+/* Read the next input byte if needed. */
+static __always_inline void rc_normalize(struct rc_dec *rc)
+	if (rc->range < RC_TOP_VALUE) {
+		rc->range <<= RC_SHIFT_BITS;
+		rc->code = (rc->code << RC_SHIFT_BITS) + rc->in[rc->in_pos++];
+ * Decode one bit. In some versions, this function has been splitted in three
+ * functions so that the compiler is supposed to be able to more easily avoid
+ * an extra branch. In this particular version of the LZMA decoder, this
+ * doesn't seem to be a good idea (tested with GCC 3.3.6, 3.4.6, and 4.3.3
+ * on x86). Using a non-splitted version results in nicer looking code too.
+ * NOTE: This must return an int. Do not make it return a bool or the speed
+ * of the code generated by GCC 3.x decreases 10-15 %. (GCC 4.3 doesn't care,
+ * and it generates 10-20 % faster code than GCC 3.x from this file anyway.)
+static __always_inline int rc_bit(struct rc_dec *rc, uint16_t *prob)
+	uint32_t bound;
+	int bit;
+	rc_normalize(rc);
+	bound = (rc->range >> RC_BIT_MODEL_TOTAL_BITS) * *prob;
+	if (rc->code < bound) {
+		rc->range = bound;
+		*prob += (RC_BIT_MODEL_TOTAL - *prob) >> RC_MOVE_BITS;
+		bit = 0;
+	} else {
+		rc->range -= bound;
+		rc->code -= bound;
+		*prob -= *prob >> RC_MOVE_BITS;
+		bit = 1;
+	return bit;
+/* Decode a bittree starting from the most significant bit. */
+static __always_inline uint32_t rc_bittree(struct rc_dec *rc,
+					   uint16_t *probs, uint32_t limit)
+	uint32_t symbol = 1;
+	do {
+		if (rc_bit(rc, &probs[symbol]))
+			symbol = (symbol << 1) + 1;
+		else
+			symbol <<= 1;
+	} while (symbol < limit);
+	return symbol;
+/* Decode a bittree starting from the least significant bit. */
+static __always_inline void rc_bittree_reverse(struct rc_dec *rc,
+					       uint16_t *probs,
+					       uint32_t *dest, uint32_t limit)
+	uint32_t i = 0;
+	do {
+		if (rc_bit(rc, &probs[symbol])) {
+			*dest += 1 << i;
+		} else {
+			symbol <<= 1;
+	} while (++i < limit);
+/* Decode direct bits (fixed fifty-fifty probability) */
+static inline void rc_direct(struct rc_dec *rc, uint32_t *dest, uint32_t limit)
+	uint32_t mask;
+	do {
+		rc_normalize(rc);
+		rc->range >>= 1;
+		rc->code -= rc->range;
+		mask = (uint32_t)0 - (rc->code >> 31);
+		rc->code += rc->range & mask;
+		*dest = (*dest << 1) + (mask + 1);
+	} while (--limit > 0);
+ * LZMA *
+/* Get pointer to literal coder probability array. */
+static uint16_t *lzma_literal_probs(struct xz_dec_lzma2 *s)
+	uint32_t prev_byte = dict_get(&s->dict, 0);
+	uint32_t low = prev_byte >> (8 - s->lzma.lc);
+	uint32_t high = (s->dict.pos & s->lzma.literal_pos_mask) << s->lzma.lc;
+	return s->lzma.literal[low + high];
+/* Decode a literal (one 8-bit byte) */
+static void lzma_literal(struct xz_dec_lzma2 *s)
+	uint16_t *probs;
+	uint32_t symbol;
+	uint32_t match_byte;
+	uint32_t match_bit;
+	uint32_t offset;
+	uint32_t i;
+	probs = lzma_literal_probs(s);
+	if (lzma_state_is_literal(s->lzma.state)) {
+		symbol = rc_bittree(&s->rc, probs, 0x100);
+	} else {
+		symbol = 1;
+		match_byte = dict_get(&s->dict, s->lzma.rep0) << 1;
+		offset = 0x100;
+		do {
+			match_bit = match_byte & offset;
+			match_byte <<= 1;
+			i = offset + match_bit + symbol;
+			if (rc_bit(&s->rc, &probs[i])) {
+				offset &= match_bit;
+			} else {
+				symbol <<= 1;
+				offset &= ~match_bit;
+		} while (symbol < 0x100);
+	dict_put(&s->dict, (uint8_t)symbol);
+	lzma_state_literal(&s->lzma.state);
+/* Decode the length of the match into s->lzma.len. */
+static void lzma_len(struct xz_dec_lzma2 *s, struct lzma_len_dec *l,
+		     uint32_t pos_state)
+	uint16_t *probs;
+	uint32_t limit;
+	if (!rc_bit(&s->rc, &l->choice)) {
+		probs = l->low[pos_state];
+		limit = LEN_LOW_SYMBOLS;
+		s->lzma.len = MATCH_LEN_MIN;
+	} else {
+		if (!rc_bit(&s->rc, &l->choice2)) {
+			probs = l->mid[pos_state];
+			limit = LEN_MID_SYMBOLS;
+			s->lzma.len = MATCH_LEN_MIN + LEN_LOW_SYMBOLS;
+		} else {
+			probs = l->high;
+			limit = LEN_HIGH_SYMBOLS;
+					+ LEN_MID_SYMBOLS;
+	s->lzma.len += rc_bittree(&s->rc, probs, limit) - limit;
+/* Decode a match. The distance will be stored in s->lzma.rep0. */
+static void lzma_match(struct xz_dec_lzma2 *s, uint32_t pos_state)
+	uint16_t *probs;
+	uint32_t dist_slot;
+	uint32_t limit;
+	lzma_state_match(&s->lzma.state);
+	s->lzma.rep3 = s->lzma.rep2;
+	s->lzma.rep2 = s->lzma.rep1;
+	s->lzma.rep1 = s->lzma.rep0;
+	lzma_len(s, &s->lzma.match_len_dec, pos_state);
+	probs = s->lzma.dist_slot[lzma_get_dist_state(s->lzma.len)];
+	dist_slot = rc_bittree(&s->rc, probs, DIST_SLOTS) - DIST_SLOTS;
+	if (dist_slot < DIST_MODEL_START) {
+		s->lzma.rep0 = dist_slot;
+	} else {
+		limit = (dist_slot >> 1) - 1;
+		s->lzma.rep0 = 2 + (dist_slot & 1);
+		if (dist_slot < DIST_MODEL_END) {
+			s->lzma.rep0 <<= limit;
+			probs = s->lzma.dist_special + s->lzma.rep0
+					- dist_slot - 1;
+			rc_bittree_reverse(&s->rc, probs,
+					&s->lzma.rep0, limit);
+		} else {
+			rc_direct(&s->rc, &s->lzma.rep0, limit - ALIGN_BITS);
+			s->lzma.rep0 <<= ALIGN_BITS;
+			rc_bittree_reverse(&s->rc, s->lzma.dist_align,
+					&s->lzma.rep0, ALIGN_BITS);
+ * Decode a repeated match. The distance is one of the four most recently
+ * seen matches. The distance will be stored in s->lzma.rep0.
+static void lzma_rep_match(struct xz_dec_lzma2 *s, uint32_t pos_state)
+	uint32_t tmp;
+	if (!rc_bit(&s->rc, &s->lzma.is_rep0[s->lzma.state])) {
+		if (!rc_bit(&s->rc, &s->lzma.is_rep0_long[
+				s->lzma.state][pos_state])) {
+			lzma_state_short_rep(&s->lzma.state);
+			s->lzma.len = 1;
+			return;
+	} else {
+		if (!rc_bit(&s->rc, &s->lzma.is_rep1[s->lzma.state])) {
+			tmp = s->lzma.rep1;
+		} else {
+			if (!rc_bit(&s->rc, &s->lzma.is_rep2[s->lzma.state])) {
+				tmp = s->lzma.rep2;
+			} else {
+				tmp = s->lzma.rep3;
+		s->lzma.rep0 = tmp;
+	lzma_state_long_rep(&s->lzma.state);
+	lzma_len(s, &s->lzma.rep_len_dec, pos_state);
+/* LZMA decoder core */
+static bool lzma_main(struct xz_dec_lzma2 *s)
+	uint32_t pos_state;
+	 * If the dictionary was reached during the previous call, try to
+	 * finish the possibly pending repeat in the dictionary.
+	if (dict_has_space(&s->dict) && s->lzma.len > 0)
+		dict_repeat(&s->dict, &s->lzma.len, s->lzma.rep0);
+	 * Decode more LZMA symbols. One iteration may consume up to
+	 * LZMA_IN_REQUIRED - 1 bytes.
+	while (dict_has_space(&s->dict) && !rc_limit_exceeded(&s->rc)) {
+		pos_state = s->dict.pos & s->lzma.pos_mask;
+		if (!rc_bit(&s->rc, &s->lzma.is_match[
+			lzma_literal(s);
+		} else {
+			if (rc_bit(&s->rc, &s->lzma.is_rep[s->lzma.state]))
+				lzma_rep_match(s, pos_state);
+			else
+				lzma_match(s, pos_state);
+			if (!dict_repeat(&s->dict, &s->lzma.len, s->lzma.rep0))
+				return false;
+	 * Having the range decoder always normalized when we are outside
+	 * this function makes it easier to correctly handle end of the chunk.
+	rc_normalize(&s->rc);
+	return true;
+ * Reset the LZMA decoder and range decoder state. Dictionary is nore reset
+ * here, because LZMA state may be reset without resetting the dictionary.
+static void lzma_reset(struct xz_dec_lzma2 *s)
+	uint16_t *probs;
+	size_t i;
+	s->lzma.state = STATE_LIT_LIT;
+	s->lzma.rep0 = 0;
+	s->lzma.rep1 = 0;
+	s->lzma.rep2 = 0;
+	s->lzma.rep3 = 0;
+	 * All probabilities are initialized to the same value. This hack
+	 * makes the code smaller by avoiding a separate loop for each
+	 * probability array.
+	 * This could be optimized so that only that part of literal
+	 * probabilities that are actually required. In the common case
+	 * we would write 12 KiB less.
+	probs = s->lzma.is_match[0];
+	for (i = 0; i < PROBS_TOTAL; ++i)
+		probs[i] = RC_BIT_MODEL_TOTAL / 2;
+	rc_reset(&s->rc);
+ * Decode and validate LZMA properties (lc/lp/pb) and calculate the bit masks
+ * from the decoded lp and pb values. On success, the LZMA decoder state is
+ * reset and true is returned.
+static bool lzma_props(struct xz_dec_lzma2 *s, uint8_t props)
+	if (props > (4 * 5 + 4) * 9 + 8)
+		return false;
+	s->lzma.pos_mask = 0;
+	while (props >= 9 * 5) {
+		props -= 9 * 5;
+		++s->lzma.pos_mask;
+	s->lzma.pos_mask = (1 << s->lzma.pos_mask) - 1;
+	s->lzma.literal_pos_mask = 0;
+	while (props >= 9) {
+		props -= 9;
+		++s->lzma.literal_pos_mask;
+	s->lzma.lc = props;
+	if (s->lzma.lc + s->lzma.literal_pos_mask > 4)
+		return false;
+	s->lzma.literal_pos_mask = (1 << s->lzma.literal_pos_mask) - 1;
+	lzma_reset(s);
+	return true;
+ * LZMA2 *
+ * The LZMA decoder assumes that if the input limit (s->rc.in_limit) hasn't
+ * been exceeded, it is safe to read up to LZMA_IN_REQUIRED bytes. This
+ * wrapper function takes care of making the LZMA decoder's assumption safe.
+ * As long as there is plenty of input left to be decoded in the current LZMA
+ * chunk, we decode directly from the caller-supplied input buffer until
+ * there's LZMA_IN_REQUIRED bytes left. Those remaining bytes are copied into
+ * s->temp.buf, which (hopefully) gets filled on the next call to this
+ * function. We decode a few bytes from the temporary buffer so that we can
+ * continue decoding from the caller-supplied input buffer again.
+static bool lzma2_lzma(struct xz_dec_lzma2 *s, struct xz_buf *b)
+	size_t in_avail;
+	uint32_t tmp;
+	in_avail = b->in_size - b->in_pos;
+	if (s->temp.size > 0 || s->lzma2.compressed == 0) {
+		tmp = 2 * LZMA_IN_REQUIRED - s->temp.size;
+		if (tmp > s->lzma2.compressed - s->temp.size)
+			tmp = s->lzma2.compressed - s->temp.size;
+		if (tmp > in_avail)
+			tmp = in_avail;
+		memcpy(s->temp.buf + s->temp.size, b->in + b->in_pos, tmp);
+		if (s->temp.size + tmp == s->lzma2.compressed) {
+			memzero(s->temp.buf + s->temp.size + tmp,
+					sizeof(s->temp.buf)
+						- s->temp.size - tmp);
+			s->rc.in_limit = s->temp.size + tmp;
+		} else if (s->temp.size + tmp < LZMA_IN_REQUIRED) {
+			s->temp.size += tmp;
+			b->in_pos += tmp;
+			return true;
+		} else {
+			s->rc.in_limit = s->temp.size + tmp - LZMA_IN_REQUIRED;
+		s->rc.in = s->temp.buf;
+		s->rc.in_pos = 0;
+		if (!lzma_main(s) || s->rc.in_pos > s->temp.size + tmp)
+			return false;
+		s->lzma2.compressed -= s->rc.in_pos;
+		if (s->rc.in_pos < s->temp.size) {
+			s->temp.size -= s->rc.in_pos;
+			memmove(s->temp.buf, s->temp.buf + s->rc.in_pos,
+					s->temp.size);
+			return true;
+		b->in_pos += s->rc.in_pos - s->temp.size;
+		s->temp.size = 0;
+	if (in_avail >= LZMA_IN_REQUIRED) {
+		s->rc.in = b->in;
+		s->rc.in_pos = b->in_pos;
+		if (in_avail >= s->lzma2.compressed + LZMA_IN_REQUIRED)
+			s->rc.in_limit = b->in_pos + s->lzma2.compressed;
+		else
+			s->rc.in_limit = b->in_size - LZMA_IN_REQUIRED;
+		if (!lzma_main(s))
+			return false;
+		in_avail = s->rc.in_pos - b->in_pos;
+		if (in_avail > s->lzma2.compressed)
+			return false;
+		s->lzma2.compressed -= in_avail;
+		b->in_pos = s->rc.in_pos;
+	if (in_avail < LZMA_IN_REQUIRED) {
+			in_avail = s->lzma2.compressed;
+		memcpy(s->temp.buf, b->in + b->in_pos, in_avail);
+		s->temp.size = in_avail;
+		b->in_pos += in_avail;
+	return true;
+ * Take care of the LZMA2 control layer, and forward the job of actual LZMA
+ * decoding or copying of uncompressed chunks to other functions.
+XZ_EXTERN enum xz_ret xz_dec_lzma2_run(struct xz_dec_lzma2 *s,
+				       struct xz_buf *b)
+	uint32_t tmp;
+	while (b->in_pos < b->in_size || s->lzma2.sequence == SEQ_LZMA_RUN) {
+		switch (s->lzma2.sequence) {
+		case SEQ_CONTROL:
+			 * LZMA2 control byte
+			 * Exact values:
+			 *   0x00   End marker
+			 *   0x01   Dictionary reset followed by
+			 *          an uncompressed chunk
+			 *   0x02   Uncompressed chunk (no dictionary reset)
+			 * Highest three bits (s->control & 0xE0):
+			 *   0xE0   Dictionary reset, new properties and state
+			 *          reset, followed by LZMA compressed chunk
+			 *   0xC0   New properties and state reset, followed
+			 *          by LZMA compressed chunk (no dictionary
+			 *          reset)
+			 *   0xA0   State reset using old properties,
+			 *          followed by LZMA compressed chunk (no
+			 *          dictionary reset)
+			 *   0x80   LZMA chunk (no dictionary or state reset)
+			 * For LZMA compressed chunks, the lowest five bits
+			 * (s->control & 1F) are the highest bits of the
+			 * uncompressed size (bits 16-20).
+			 * A new LZMA2 stream must begin with a dictionary
+			 * reset. The first LZMA chunk must set new
+			 * properties and reset the LZMA state.
+			 * Values that don't match anything described above
+			 * are invalid and we return XZ_DATA_ERROR.
+			tmp = b->in[b->in_pos++];
+			if (tmp == 0x00)
+				return XZ_STREAM_END;
+			if (tmp >= 0xE0 || tmp == 0x01) {
+				s->lzma2.need_props = true;
+				s->lzma2.need_dict_reset = false;
+				dict_reset(&s->dict, b);
+			} else if (s->lzma2.need_dict_reset) {
+				return XZ_DATA_ERROR;
+			if (tmp >= 0x80) {
+				s->lzma2.uncompressed = (tmp & 0x1F) << 16;
+				s->lzma2.sequence = SEQ_UNCOMPRESSED_1;
+				if (tmp >= 0xC0) {
+					 * When there are new properties,
+					 * state reset is done at
+					 * SEQ_PROPERTIES.
+					s->lzma2.need_props = false;
+					s->lzma2.next_sequence
+							= SEQ_PROPERTIES;
+				} else if (s->lzma2.need_props) {
+				} else {
+							= SEQ_LZMA_PREPARE;
+					if (tmp >= 0xA0)
+						lzma_reset(s);
+			} else {
+				if (tmp > 0x02)
+				s->lzma2.sequence = SEQ_COMPRESSED_0;
+				s->lzma2.next_sequence = SEQ_COPY;
+			break;
+		case SEQ_UNCOMPRESSED_1:
+					+= (uint32_t)b->in[b->in_pos++] << 8;
+			s->lzma2.sequence = SEQ_UNCOMPRESSED_2;
+			break;
+		case SEQ_UNCOMPRESSED_2:
+					+= (uint32_t)b->in[b->in_pos++] + 1;
+			break;
+		case SEQ_COMPRESSED_0:
+					= (uint32_t)b->in[b->in_pos++] << 8;
+			s->lzma2.sequence = SEQ_COMPRESSED_1;
+			break;
+		case SEQ_COMPRESSED_1:
+			s->lzma2.sequence = s->lzma2.next_sequence;
+			break;
+		case SEQ_PROPERTIES:
+			if (!lzma_props(s, b->in[b->in_pos++]))
+			s->lzma2.sequence = SEQ_LZMA_PREPARE;
+		/* Fall through */
+		case SEQ_LZMA_PREPARE:
+			if (s->lzma2.compressed < RC_INIT_BYTES)
+			if (!rc_read_init(&s->rc, b))
+				return XZ_OK;
+			s->lzma2.compressed -= RC_INIT_BYTES;
+			s->lzma2.sequence = SEQ_LZMA_RUN;
+		case SEQ_LZMA_RUN:
+			 * Set dictionary limit to indicate how much we want
+			 * to be encoded at maximum. Decode new data into the
+			 * dictionary. Flush the new data from dictionary to
+			 * b->out. Check if we finished decoding this chunk.
+			 * In case the dictionary got full but we didn't fill
+			 * the output buffer yet, we may run this loop
+			 * multiple times without changing s->lzma2.sequence.
+			dict_limit(&s->dict, min_t(size_t,
+					b->out_size - b->out_pos,
+					s->lzma2.uncompressed));
+			if (!lzma2_lzma(s, b))
+			s->lzma2.uncompressed -= dict_flush(&s->dict, b);
+			if (s->lzma2.uncompressed == 0) {
+				if (s->lzma2.compressed > 0 || s->lzma.len > 0
+						|| !rc_is_finished(&s->rc))
+				rc_reset(&s->rc);
+				s->lzma2.sequence = SEQ_CONTROL;
+			} else if (b->out_pos == b->out_size
+					|| (b->in_pos == b->in_size
+						&& s->temp.size
+						< s->lzma2.compressed)) {
+				return XZ_OK;
+			break;
+		case SEQ_COPY:
+			dict_uncompressed(&s->dict, b, &s->lzma2.compressed);
+			if (s->lzma2.compressed > 0)
+				return XZ_OK;
+			break;
+	return XZ_OK;
+XZ_EXTERN struct xz_dec_lzma2 *xz_dec_lzma2_create(enum xz_mode mode,
+						   uint32_t dict_max)
+	struct xz_dec_lzma2 *s = kmalloc(sizeof(*s), GFP_KERNEL);
+	if (s == NULL)
+		return NULL;
+	s->dict.mode = mode;
+	s->dict.size_max = dict_max;
+	if (DEC_IS_PREALLOC(mode)) {
+		s->dict.buf = vmalloc(dict_max);
+		if (s->dict.buf == NULL) {
+			kfree(s);
+			return NULL;
+	} else if (DEC_IS_DYNALLOC(mode)) {
+		s->dict.buf = NULL;
+		s->dict.allocated = 0;
+	return s;
+XZ_EXTERN enum xz_ret xz_dec_lzma2_reset(struct xz_dec_lzma2 *s, uint8_t props)
+	/* This limits dictionary size to 3 GiB to keep parsing simpler. */
+	if (props > 39)
+		return XZ_OPTIONS_ERROR;
+	s->dict.size = 2 + (props & 1);
+	s->dict.size <<= (props >> 1) + 11;
+	if (DEC_IS_MULTI(s->dict.mode)) {
+		if (s->dict.size > s->dict.size_max)
+			return XZ_MEMLIMIT_ERROR;
+		s->dict.end = s->dict.size;
+		if (DEC_IS_DYNALLOC(s->dict.mode)) {
+			if (s->dict.allocated < s->dict.size) {
+				vfree(s->dict.buf);
+				s->dict.buf = vmalloc(s->dict.size);
+					return XZ_MEM_ERROR;
+	s->lzma.len = 0;
+	s->lzma2.need_dict_reset = true;
+	s->temp.size = 0;
+	return XZ_OK;
+XZ_EXTERN void xz_dec_lzma2_end(struct xz_dec_lzma2 *s)
+	kfree(s);
diff --git a/cpukit/libmisc/xz/xz_dec_stream.c b/cpukit/libmisc/xz/xz_dec_stream.c
index 0000000..d652550
--- /dev/null
+++ b/cpukit/libmisc/xz/xz_dec_stream.c
@@ -0,0 +1,847 @@
+ * .xz Stream decoder
+#include "xz_stream.h"
+#ifdef XZ_USE_CRC64
+#	define IS_CRC64(check_type) ((check_type) == XZ_CHECK_CRC64)
+#else
+#	define IS_CRC64(check_type) false
+#endif
+/* Hash used to validate the Index field */
+struct xz_dec_hash {
+	vli_type unpadded;
+	vli_type uncompressed;
+	uint32_t crc32;
+struct xz_dec {
+	/* Position in dec_main() */
+	enum {
+		SEQ_STREAM_HEADER,
+		SEQ_BLOCK_START,
+		SEQ_BLOCK_HEADER,
+		SEQ_BLOCK_UNCOMPRESS,
+		SEQ_BLOCK_PADDING,
+		SEQ_BLOCK_CHECK,
+		SEQ_INDEX,
+		SEQ_INDEX_PADDING,
+		SEQ_INDEX_CRC32,
+		SEQ_STREAM_FOOTER
+	} sequence;
+	/* Position in variable-length integers and Check fields */
+	uint32_t pos;
+	/* Variable-length integer decoded by dec_vli() */
+	vli_type vli;
+	/* Saved in_pos and out_pos */
+	size_t in_start;
+	size_t out_start;
+	/* CRC32 or CRC64 value in Block or CRC32 value in Index */
+	uint64_t crc;
+#else
+	/* CRC32 value in Block or Index */
+	uint32_t crc;
+#endif
+	/* Type of the integrity check calculated from uncompressed data */
+	enum xz_check check_type;
+	 * True if the next call to xz_dec_run() is allowed to return
+	 * XZ_BUF_ERROR.
+	bool allow_buf_error;
+	/* Information stored in Block Header */
+	struct {
+		 * Value stored in the Compressed Size field, or
+		 * VLI_UNKNOWN if Compressed Size is not present.
+		vli_type compressed;
+		 * Value stored in the Uncompressed Size field, or
+		 * VLI_UNKNOWN if Uncompressed Size is not present.
+		/* Size of the Block Header field */
+		uint32_t size;
+	} block_header;
+	/* Information collected when decoding Blocks */
+	struct {
+		/* Observed compressed size of the current Block */
+		/* Observed uncompressed size of the current Block */
+		/* Number of Blocks decoded so far */
+		vli_type count;
+		 * Hash calculated from the Block sizes. This is used to
+		 * validate the Index field.
+		struct xz_dec_hash hash;
+	} block;
+	/* Variables needed when verifying the Index field */
+	struct {
+		/* Position in dec_index() */
+		enum {
+			SEQ_INDEX_COUNT,
+			SEQ_INDEX_UNPADDED,
+			SEQ_INDEX_UNCOMPRESSED
+		} sequence;
+		/* Size of the Index in bytes */
+		vli_type size;
+		/* Number of Records (matches block.count in valid files) */
+		vli_type count;
+		 * Hash calculated from the Records (matches block.hash in
+		 * valid files).
+	} index;
+	 * Temporary buffer needed to hold Stream Header, Block Header,
+	 * and Stream Footer. The Block Header is the biggest (1 KiB)
+	 * so we reserve space according to that. buf[] has to be aligned
+	 * to a multiple of four bytes; the size_t variables before it
+	 * should guarantee this.
+	struct {
+		size_t pos;
+		size_t size;
+		uint8_t buf[1024];
+	} temp;
+	struct xz_dec_lzma2 *lzma2;
+#ifdef XZ_DEC_BCJ
+	struct xz_dec_bcj *bcj;
+	bool bcj_active;
+#endif
+#ifdef XZ_DEC_ANY_CHECK
+/* Sizes of the Check field with different Check IDs */
+static const uint8_t check_sizes[16] = {
+	0,
+	4, 4, 4,
+	8, 8, 8,
+	16, 16, 16,
+	32, 32, 32,
+	64, 64, 64
+#endif
+ * Fill s->temp by copying data starting from b->in[b->in_pos]. Caller
+ * must have set s->temp.pos to indicate how much data we are supposed
+ * to copy into s->temp.buf. Return true once s->temp.pos has reached
+ * s->temp.size.
+static bool fill_temp(struct xz_dec *s, struct xz_buf *b)
+	size_t copy_size = min_t(size_t,
+			b->in_size - b->in_pos, s->temp.size - s->temp.pos);
+	memcpy(s->temp.buf + s->temp.pos, b->in + b->in_pos, copy_size);
+	s->temp.pos += copy_size;
+	if (s->temp.pos == s->temp.size) {
+		s->temp.pos = 0;
+		return true;
+	return false;
+/* Decode a variable-length integer (little-endian base-128 encoding) */
+static enum xz_ret dec_vli(struct xz_dec *s, const uint8_t *in,
+			   size_t *in_pos, size_t in_size)
+	uint8_t byte;
+	if (s->pos == 0)
+		s->vli = 0;
+	while (*in_pos < in_size) {
+		byte = in[*in_pos];
+		++*in_pos;
+		s->vli |= (vli_type)(byte & 0x7F) << s->pos;
+		if ((byte & 0x80) == 0) {
+			/* Don't allow non-minimal encodings. */
+			if (byte == 0 && s->pos != 0)
+			s->pos = 0;
+		s->pos += 7;
+		if (s->pos == 7 * VLI_BYTES_MAX)
+	return XZ_OK;
+ * Decode the Compressed Data field from a Block. Update and validate
+ * the observed compressed and uncompressed sizes of the Block so that
+ * they don't exceed the values possibly stored in the Block Header
+ * (validation assumes that no integer overflow occurs, since vli_type
+ * is normally uint64_t). Update the CRC32 or CRC64 value if presence of
+ * the CRC32 or CRC64 field was indicated in Stream Header.
+ * Once the decoding is finished, validate that the observed sizes match
+ * the sizes possibly stored in the Block Header. Update the hash and
+ * Block count, which are later used to validate the Index field.
+static enum xz_ret dec_block(struct xz_dec *s, struct xz_buf *b)
+	enum xz_ret ret;
+	s->in_start = b->in_pos;
+	s->out_start = b->out_pos;
+#ifdef XZ_DEC_BCJ
+	if (s->bcj_active)
+		ret = xz_dec_bcj_run(s->bcj, s->lzma2, b);
+	else
+#endif
+		ret = xz_dec_lzma2_run(s->lzma2, b);
+	s->block.compressed += b->in_pos - s->in_start;
+	s->block.uncompressed += b->out_pos - s->out_start;
+	 * There is no need to separately check for VLI_UNKNOWN, since
+	 * the observed sizes are always smaller than VLI_UNKNOWN.
+	if (s->block.compressed > s->block_header.compressed
+			|| s->block.uncompressed
+				> s->block_header.uncompressed)
+	if (s->check_type == XZ_CHECK_CRC32)
+		s->crc = xz_crc32(b->out + s->out_start,
+				b->out_pos - s->out_start, s->crc);
+	else if (s->check_type == XZ_CHECK_CRC64)
+		s->crc = xz_crc64(b->out + s->out_start,
+#endif
+	if (ret == XZ_STREAM_END) {
+		if (s->block_header.compressed != VLI_UNKNOWN
+				&& s->block_header.compressed
+					!= s->block.compressed)
+		if (s->block_header.uncompressed != VLI_UNKNOWN
+				&& s->block_header.uncompressed
+					!= s->block.uncompressed)
+		s->block.hash.unpadded += s->block_header.size
+				+ s->block.compressed;
+		s->block.hash.unpadded += check_sizes[s->check_type];
+#else
+			s->block.hash.unpadded += 4;
+		else if (IS_CRC64(s->check_type))
+			s->block.hash.unpadded += 8;
+#endif
+		s->block.hash.uncompressed += s->block.uncompressed;
+		s->block.hash.crc32 = xz_crc32(
+				(const uint8_t *)&s->block.hash,
+				sizeof(s->block.hash), s->block.hash.crc32);
+		++s->block.count;
+	return ret;
+/* Update the Index size and the CRC32 value. */
+static void index_update(struct xz_dec *s, const struct xz_buf *b)
+	size_t in_used = b->in_pos - s->in_start;
+	s->index.size += in_used;
+	s->crc = xz_crc32(b->in + s->in_start, in_used, s->crc);
+ * Decode the Number of Records, Unpadded Size, and Uncompressed Size
+ * fields from the Index field. That is, Index Padding and CRC32 are not
+ * decoded by this function.
+ * This can return XZ_OK (more input needed), XZ_STREAM_END (everything
+ * successfully decoded), or XZ_DATA_ERROR (input is corrupt).
+static enum xz_ret dec_index(struct xz_dec *s, struct xz_buf *b)
+	enum xz_ret ret;
+	do {
+		ret = dec_vli(s, b->in, &b->in_pos, b->in_size);
+		if (ret != XZ_STREAM_END) {
+			index_update(s, b);
+			return ret;
+		switch (s->index.sequence) {
+		case SEQ_INDEX_COUNT:
+			s->index.count = s->vli;
+			 * Validate that the Number of Records field
+			 * indicates the same number of Records as
+			 * there were Blocks in the Stream.
+			if (s->index.count != s->block.count)
+			s->index.sequence = SEQ_INDEX_UNPADDED;
+			break;
+		case SEQ_INDEX_UNPADDED:
+			s->index.hash.unpadded += s->vli;
+			s->index.sequence = SEQ_INDEX_UNCOMPRESSED;
+			break;
+		case SEQ_INDEX_UNCOMPRESSED:
+			s->index.hash.uncompressed += s->vli;
+			s->index.hash.crc32 = xz_crc32(
+					(const uint8_t *)&s->index.hash,
+					sizeof(s->index.hash),
+					s->index.hash.crc32);
+			--s->index.count;
+			break;
+	} while (s->index.count > 0);
+ * Validate that the next four or eight input bytes match the value
+ * of s->crc. s->pos must be zero when starting to validate the first byte.
+ * The "bits" argument allows using the same code for both CRC32 and CRC64.
+static enum xz_ret crc_validate(struct xz_dec *s, struct xz_buf *b,
+				uint32_t bits)
+	do {
+			return XZ_OK;
+		if (((s->crc >> s->pos) & 0xFF) != b->in[b->in_pos++])
+		s->pos += 8;
+	} while (s->pos < bits);
+	s->crc = 0;
+	s->pos = 0;
+ * Skip over the Check field when the Check ID is not supported.
+ * Returns true once the whole Check field has been skipped over.
+static bool check_skip(struct xz_dec *s, struct xz_buf *b)
+	while (s->pos < check_sizes[s->check_type]) {
+			return false;
+		++b->in_pos;
+		++s->pos;
+	s->pos = 0;
+	return true;
+#endif
+/* Decode the Stream Header field (the first 12 bytes of the .xz Stream). */
+static enum xz_ret dec_stream_header(struct xz_dec *s)
+	if (!memeq(s->temp.buf, HEADER_MAGIC, HEADER_MAGIC_SIZE))
+		return XZ_FORMAT_ERROR;
+	if (xz_crc32(s->temp.buf + HEADER_MAGIC_SIZE, 2, 0)
+			!= get_le32(s->temp.buf + HEADER_MAGIC_SIZE + 2))
+	if (s->temp.buf[HEADER_MAGIC_SIZE] != 0)
+	 * Of integrity checks, we support none (Check ID = 0),
+	 * CRC32 (Check ID = 1), and optionally CRC64 (Check ID = 4).
+	 * However, if XZ_DEC_ANY_CHECK is defined, we will accept other
+	 * check types too, but then the check won't be verified and
+	 * a warning (XZ_UNSUPPORTED_CHECK) will be given.
+	s->check_type = s->temp.buf[HEADER_MAGIC_SIZE + 1];
+	if (s->check_type > XZ_CHECK_MAX)
+	if (s->check_type > XZ_CHECK_CRC32 && !IS_CRC64(s->check_type))
+		return XZ_UNSUPPORTED_CHECK;
+#else
+#endif
+	return XZ_OK;
+/* Decode the Stream Footer field (the last 12 bytes of the .xz Stream) */
+static enum xz_ret dec_stream_footer(struct xz_dec *s)
+	if (!memeq(s->temp.buf + 10, FOOTER_MAGIC, FOOTER_MAGIC_SIZE))
+	if (xz_crc32(s->temp.buf + 4, 6, 0) != get_le32(s->temp.buf))
+	 * Validate Backward Size. Note that we never added the size of the
+	 * Index CRC32 field to s->index.size, thus we use s->index.size / 4
+	 * instead of s->index.size / 4 - 1.
+	if ((s->index.size >> 2) != get_le32(s->temp.buf + 4))
+	if (s->temp.buf[8] != 0 || s->temp.buf[9] != s->check_type)
+	 * Use XZ_STREAM_END instead of XZ_OK to be more convenient
+	 * for the caller.
+/* Decode the Block Header and initialize the filter chain. */
+static enum xz_ret dec_block_header(struct xz_dec *s)
+	enum xz_ret ret;
+	 * Validate the CRC32. We know that the temp buffer is at least
+	 * eight bytes so this is safe.
+	s->temp.size -= 4;
+	if (xz_crc32(s->temp.buf, s->temp.size, 0)
+			!= get_le32(s->temp.buf + s->temp.size))
+	s->temp.pos = 2;
+	 * Catch unsupported Block Flags. We support only one or two filters
+	 * in the chain, so we catch that with the same test.
+#ifdef XZ_DEC_BCJ
+	if (s->temp.buf[1] & 0x3E)
+#else
+	if (s->temp.buf[1] & 0x3F)
+#endif
+	/* Compressed Size */
+	if (s->temp.buf[1] & 0x40) {
+		if (dec_vli(s, s->temp.buf, &s->temp.pos, s->temp.size)
+					!= XZ_STREAM_END)
+		s->block_header.compressed = s->vli;
+	} else {
+		s->block_header.compressed = VLI_UNKNOWN;
+	/* Uncompressed Size */
+	if (s->temp.buf[1] & 0x80) {
+				!= XZ_STREAM_END)
+		s->block_header.uncompressed = s->vli;
+	} else {
+		s->block_header.uncompressed = VLI_UNKNOWN;
+#ifdef XZ_DEC_BCJ
+	/* If there are two filters, the first one must be a BCJ filter. */
+	s->bcj_active = s->temp.buf[1] & 0x01;
+	if (s->bcj_active) {
+		if (s->temp.size - s->temp.pos < 2)
+		ret = xz_dec_bcj_reset(s->bcj, s->temp.buf[s->temp.pos++]);
+		if (ret != XZ_OK)
+			return ret;
+		 * We don't support custom start offset,
+		 * so Size of Properties must be zero.
+		if (s->temp.buf[s->temp.pos++] != 0x00)
+#endif
+	/* Valid Filter Flags always take at least two bytes. */
+	/* Filter ID = LZMA2 */
+	if (s->temp.buf[s->temp.pos++] != 0x21)
+	/* Size of Properties = 1-byte Filter Properties */
+	if (s->temp.buf[s->temp.pos++] != 0x01)
+	/* Filter Properties contains LZMA2 dictionary size. */
+	if (s->temp.size - s->temp.pos < 1)
+	ret = xz_dec_lzma2_reset(s->lzma2, s->temp.buf[s->temp.pos++]);
+	if (ret != XZ_OK)
+		return ret;
+	/* The rest must be Header Padding. */
+	while (s->temp.pos < s->temp.size)
+	s->temp.pos = 0;
+	s->block.compressed = 0;
+	s->block.uncompressed = 0;
+	return XZ_OK;
+static enum xz_ret dec_main(struct xz_dec *s, struct xz_buf *b)
+	enum xz_ret ret;
+	 * Store the start position for the case when we are in the middle
+	 * of the Index field.
+	while (true) {
+		switch (s->sequence) {
+		case SEQ_STREAM_HEADER:
+			 * Stream Header is copied to s->temp, and then
+			 * decoded from there. This way if the caller
+			 * gives us only little input at a time, we can
+			 * still keep the Stream Header decoding code
+			 * simple. Similar approach is used in many places
+			 * in this file.
+			if (!fill_temp(s, b))
+				return XZ_OK;
+			 * If dec_stream_header() returns
+			 * XZ_UNSUPPORTED_CHECK, it is still possible
+			 * to continue decoding if working in multi-call
+			 * mode. Thus, update s->sequence before calling
+			 * dec_stream_header().
+			s->sequence = SEQ_BLOCK_START;
+			ret = dec_stream_header(s);
+			if (ret != XZ_OK)
+				return ret;
+		case SEQ_BLOCK_START:
+			/* We need one byte of input to continue. */
+				return XZ_OK;
+			/* See if this is the beginning of the Index field. */
+			if (b->in[b->in_pos] == 0) {
+				s->in_start = b->in_pos++;
+				s->sequence = SEQ_INDEX;
+				break;
+			 * Calculate the size of the Block Header and
+			 * prepare to decode it.
+			s->block_header.size
+				= ((uint32_t)b->in[b->in_pos] + 1) * 4;
+			s->temp.size = s->block_header.size;
+			s->temp.pos = 0;
+			s->sequence = SEQ_BLOCK_HEADER;
+		case SEQ_BLOCK_HEADER:
+				return XZ_OK;
+			ret = dec_block_header(s);
+			if (ret != XZ_OK)
+				return ret;
+			s->sequence = SEQ_BLOCK_UNCOMPRESS;
+		case SEQ_BLOCK_UNCOMPRESS:
+			ret = dec_block(s, b);
+				return ret;
+			s->sequence = SEQ_BLOCK_PADDING;
+		case SEQ_BLOCK_PADDING:
+			 * Size of Compressed Data + Block Padding
+			 * must be a multiple of four. We don't need
+			 * s->block.compressed for anything else
+			 * anymore, so we use it here to test the size
+			 * of the Block Padding field.
+			while (s->block.compressed & 3) {
+					return XZ_OK;
+				if (b->in[b->in_pos++] != 0)
+				++s->block.compressed;
+			s->sequence = SEQ_BLOCK_CHECK;
+		case SEQ_BLOCK_CHECK:
+			if (s->check_type == XZ_CHECK_CRC32) {
+				ret = crc_validate(s, b, 32);
+					return ret;
+			else if (IS_CRC64(s->check_type)) {
+				ret = crc_validate(s, b, 64);
+					return ret;
+			else if (!check_skip(s, b)) {
+				return XZ_OK;
+#endif
+			break;
+		case SEQ_INDEX:
+			ret = dec_index(s, b);
+				return ret;
+			s->sequence = SEQ_INDEX_PADDING;
+		case SEQ_INDEX_PADDING:
+			while ((s->index.size + (b->in_pos - s->in_start))
+					& 3) {
+				if (b->in_pos == b->in_size) {
+					return XZ_OK;
+			/* Finish the CRC32 value and Index size. */
+			/* Compare the hashes to validate the Index field. */
+			if (!memeq(&s->block.hash, &s->index.hash,
+					sizeof(s->block.hash)))
+			s->sequence = SEQ_INDEX_CRC32;
+		case SEQ_INDEX_CRC32:
+				return ret;
+			s->temp.size = STREAM_HEADER_SIZE;
+			s->sequence = SEQ_STREAM_FOOTER;
+		case SEQ_STREAM_FOOTER:
+				return XZ_OK;
+			return dec_stream_footer(s);
+	/* Never reached */
+ * xz_dec_run() is a wrapper for dec_main() to handle some special cases in
+ * multi-call and single-call decoding.
+ * In multi-call mode, we must return XZ_BUF_ERROR when it seems clear that we
+ * are not going to make any progress anymore. This is to prevent the caller
+ * from calling us infinitely when the input file is truncated or otherwise
+ * corrupt. Since zlib-style API allows that the caller fills the input buffer
+ * only when the decoder doesn't produce any new output, we have to be careful
+ * to avoid returning XZ_BUF_ERROR too easily: XZ_BUF_ERROR is returned only
+ * after the second consecutive call to xz_dec_run() that makes no progress.
+ * In single-call mode, if we couldn't decode everything and no error
+ * occurred, either the input is truncated or the output buffer is too small.
+ * Since we know that the last input byte never produces any output, we know
+ * that if all the input was consumed and decoding wasn't finished, the file
+ * must be corrupt. Otherwise the output buffer has to be too small or the
+ * file is corrupt in a way that decoding it produces too big output.
+ * If single-call decoding fails, we reset b->in_pos and b->out_pos back to
+ * their original values. This is because with some filter chains there won't
+ * be any valid uncompressed data in the output buffer unless the decoding
+ * actually succeeds (that's the price to pay of using the output buffer as
+ * the workspace).
+	size_t in_start;
+	size_t out_start;
+	enum xz_ret ret;
+	if (DEC_IS_SINGLE(s->mode))
+		xz_dec_reset(s);
+	in_start = b->in_pos;
+	out_start = b->out_pos;
+	ret = dec_main(s, b);
+	if (DEC_IS_SINGLE(s->mode)) {
+		if (ret == XZ_OK)
+			ret = b->in_pos == b->in_size
+					? XZ_DATA_ERROR : XZ_BUF_ERROR;
+			b->in_pos = in_start;
+			b->out_pos = out_start;
+	} else if (ret == XZ_OK && in_start == b->in_pos
+			&& out_start == b->out_pos) {
+		if (s->allow_buf_error)
+			ret = XZ_BUF_ERROR;
+		s->allow_buf_error = true;
+	} else {
+		s->allow_buf_error = false;
+	return ret;
+	struct xz_dec *s = kmalloc(sizeof(*s), GFP_KERNEL);
+	if (s == NULL)
+		return NULL;
+	s->mode = mode;
+#ifdef XZ_DEC_BCJ
+	s->bcj = xz_dec_bcj_create(DEC_IS_SINGLE(mode));
+	if (s->bcj == NULL)
+		goto error_bcj;
+#endif
+	s->lzma2 = xz_dec_lzma2_create(mode, dict_max);
+	if (s->lzma2 == NULL)
+		goto error_lzma2;
+	xz_dec_reset(s);
+	return s;
+error_lzma2:
+#ifdef XZ_DEC_BCJ
+	xz_dec_bcj_end(s->bcj);
+error_bcj:
+#endif
+	kfree(s);
+	return NULL;
+	s->sequence = SEQ_STREAM_HEADER;
+	s->pos = 0;
+	s->crc = 0;
+	memzero(&s->block, sizeof(s->block));
+	memzero(&s->index, sizeof(s->index));
+	s->temp.pos = 0;
+	if (s != NULL) {
+		xz_dec_lzma2_end(s->lzma2);
+#ifdef XZ_DEC_BCJ
+#endif
+		kfree(s);
diff --git a/cpukit/libmisc/xz/xz_lzma2.h b/cpukit/libmisc/xz/xz_lzma2.h
new file mode 100644
index 0000000..071d67b
--- /dev/null
+++ b/cpukit/libmisc/xz/xz_lzma2.h
@@ -0,0 +1,204 @@
+ * LZMA2 definitions
+ * Authors: Lasse Collin <lasse.collin at tukaani.org>
+ *          Igor Pavlov <http://7-zip.org/>
+ * This file has been put into the public domain.
+ * You can do whatever you want with this file.
+#ifndef XZ_LZMA2_H
+#define XZ_LZMA2_H
+/* Range coder constants */
+#define RC_SHIFT_BITS 8
+#define RC_TOP_BITS 24
+#define RC_TOP_VALUE (1 << RC_TOP_BITS)
+#define RC_BIT_MODEL_TOTAL_BITS 11
+#define RC_BIT_MODEL_TOTAL (1 << RC_BIT_MODEL_TOTAL_BITS)
+#define RC_MOVE_BITS 5
+ * Maximum number of position states. A position state is the lowest pb
+ * number of bits of the current uncompressed offset. In some places there
+ * are different sets of probabilities for different position states.
+#define POS_STATES_MAX (1 << 4)
+ * This enum is used to track which LZMA symbols have occurred most recently
+ * and in which order. This information is used to predict the next symbol.
+ * Symbols:
+ *  - Literal: One 8-bit byte
+ *  - Match: Repeat a chunk of data at some distance
+ *  - Long repeat: Multi-byte match at a recently seen distance
+ *  - Short repeat: One-byte repeat at a recently seen distance
+ * The symbol names are in from STATE_oldest_older_previous. REP means
+ * either short or long repeated match, and NONLIT means any non-literal.
+enum lzma_state {
+	STATE_LIT_LIT,
+	STATE_MATCH_LIT_LIT,
+	STATE_REP_LIT_LIT,
+	STATE_SHORTREP_LIT_LIT,
+	STATE_MATCH_LIT,
+	STATE_REP_LIT,
+	STATE_SHORTREP_LIT,
+	STATE_LIT_MATCH,
+	STATE_LIT_LONGREP,
+	STATE_LIT_SHORTREP,
+	STATE_NONLIT_MATCH,
+	STATE_NONLIT_REP
+/* Total number of states */
+#define STATES 12
+/* The lowest 7 states indicate that the previous state was a literal. */
+#define LIT_STATES 7
+/* Indicate that the latest symbol was a literal. */
+static inline void lzma_state_literal(enum lzma_state *state)
+	if (*state <= STATE_SHORTREP_LIT_LIT)
+		*state = STATE_LIT_LIT;
+	else if (*state <= STATE_LIT_SHORTREP)
+		*state -= 3;
+	else
+		*state -= 6;
+/* Indicate that the latest symbol was a match. */
+static inline void lzma_state_match(enum lzma_state *state)
+	*state = *state < LIT_STATES ? STATE_LIT_MATCH : STATE_NONLIT_MATCH;
+/* Indicate that the latest state was a long repeated match. */
+static inline void lzma_state_long_rep(enum lzma_state *state)
+	*state = *state < LIT_STATES ? STATE_LIT_LONGREP : STATE_NONLIT_REP;
+/* Indicate that the latest symbol was a short match. */
+static inline void lzma_state_short_rep(enum lzma_state *state)
+	*state = *state < LIT_STATES ? STATE_LIT_SHORTREP : STATE_NONLIT_REP;
+/* Test if the previous symbol was a literal. */
+static inline bool lzma_state_is_literal(enum lzma_state state)
+	return state < LIT_STATES;
+/* Each literal coder is divided in three sections:
+ *   - 0x001-0x0FF: Without match byte
+ *   - 0x101-0x1FF: With match byte; match bit is 0
+ *   - 0x201-0x2FF: With match byte; match bit is 1
+ * Match byte is used when the previous LZMA symbol was something else than
+ * a literal (that is, it was some kind of match).
+#define LITERAL_CODER_SIZE 0x300
+/* Maximum number of literal coders */
+#define LITERAL_CODERS_MAX (1 << 4)
+/* Minimum length of a match is two bytes. */
+#define MATCH_LEN_MIN 2
+/* Match length is encoded with 4, 5, or 10 bits.
+ * Length   Bits
+ *  2-9      4 = Choice=0 + 3 bits
+ * 10-17     5 = Choice=1 + Choice2=0 + 3 bits
+ * 18-273   10 = Choice=1 + Choice2=1 + 8 bits
+#define LEN_LOW_BITS 3
+#define LEN_LOW_SYMBOLS (1 << LEN_LOW_BITS)
+#define LEN_MID_BITS 3
+#define LEN_MID_SYMBOLS (1 << LEN_MID_BITS)
+#define LEN_HIGH_BITS 8
+#define LEN_HIGH_SYMBOLS (1 << LEN_HIGH_BITS)
+#define LEN_SYMBOLS (LEN_LOW_SYMBOLS + LEN_MID_SYMBOLS + LEN_HIGH_SYMBOLS)
+ * Maximum length of a match is 273 which is a result of the encoding
+ * described above.
+#define MATCH_LEN_MAX (MATCH_LEN_MIN + LEN_SYMBOLS - 1)
+ * Different sets of probabilities are used for match distances that have
+ * very short match length: Lengths of 2, 3, and 4 bytes have a separate
+ * set of probabilities for each length. The matches with longer length
+ * use a shared set of probabilities.
+#define DIST_STATES 4
+ * Get the index of the appropriate probability array for decoding
+ * the distance slot.
+static inline uint32_t lzma_get_dist_state(uint32_t len)
+	return len < DIST_STATES + MATCH_LEN_MIN
+			? len - MATCH_LEN_MIN : DIST_STATES - 1;
+ * The highest two bits of a 32-bit match distance are encoded using six bits.
+ * This six-bit value is called a distance slot. This way encoding a 32-bit
+ * value takes 6-36 bits, larger values taking more bits.
+#define DIST_SLOT_BITS 6
+#define DIST_SLOTS (1 << DIST_SLOT_BITS)
+/* Match distances up to 127 are fully encoded using probabilities. Since
+ * the highest two bits (distance slot) are always encoded using six bits,
+ * the distances 0-3 don't need any additional bits to encode, since the
+ * distance slot itself is the same as the actual distance. DIST_MODEL_START
+ * indicates the first distance slot where at least one additional bit is
+ * needed.
+#define DIST_MODEL_START 4
+ * Match distances greater than 127 are encoded in three pieces:
+ *   - distance slot: the highest two bits
+ *   - direct bits: 2-26 bits below the highest two bits
+ *   - alignment bits: four lowest bits
+ * Direct bits don't use any probabilities.
+ * The distance slot value of 14 is for distances 128-191.
+#define DIST_MODEL_END 14
+/* Distance slots that indicate a distance <= 127. */
+#define FULL_DISTANCES_BITS (DIST_MODEL_END / 2)
+#define FULL_DISTANCES (1 << FULL_DISTANCES_BITS)
+ * For match distances greater than 127, only the highest two bits and the
+ * lowest four bits (alignment) is encoded using probabilities.
+#define ALIGN_BITS 4
+#define ALIGN_SIZE (1 << ALIGN_BITS)
+#define ALIGN_MASK (ALIGN_SIZE - 1)
+/* Total number of all probability variables */
+#define PROBS_TOTAL (1846 + LITERAL_CODERS_MAX * LITERAL_CODER_SIZE)
+ * LZMA remembers the four most recent match distances. Reusing these
+ * distances tends to take less space than re-encoding the actual
+ * distance value.
+#define REPS 4
+#endif
diff --git a/cpukit/libmisc/xz/xz_private.h b/cpukit/libmisc/xz/xz_private.h
index 0000000..482b90f
--- /dev/null
+++ b/cpukit/libmisc/xz/xz_private.h
@@ -0,0 +1,156 @@
+#ifndef XZ_PRIVATE_H
+#define XZ_PRIVATE_H
+#ifdef __KERNEL__
+#	include <linux/xz.h>
+#	include <linux/kernel.h>
+#	include <asm/unaligned.h>
+	/* XZ_PREBOOT may be defined only via decompress_unxz.c. */
+#	ifndef XZ_PREBOOT
+#		include <linux/slab.h>
+#		include <linux/vmalloc.h>
+#		include <linux/string.h>
+#		ifdef CONFIG_XZ_DEC_X86
+#			define XZ_DEC_X86
+#		endif
+#		ifdef CONFIG_XZ_DEC_POWERPC
+#			define XZ_DEC_POWERPC
+#		endif
+#		ifdef CONFIG_XZ_DEC_IA64
+#			define XZ_DEC_IA64
+#		endif
+#		ifdef CONFIG_XZ_DEC_ARM
+#			define XZ_DEC_ARM
+#		endif
+#		ifdef CONFIG_XZ_DEC_ARMTHUMB
+#			define XZ_DEC_ARMTHUMB
+#		endif
+#		ifdef CONFIG_XZ_DEC_SPARC
+#			define XZ_DEC_SPARC
+#		endif
+#		define memeq(a, b, size) (memcmp(a, b, size) == 0)
+#		define memzero(buf, size) memset(buf, 0, size)
+#	endif
+#	define get_le32(p) le32_to_cpup((const uint32_t *)(p))
+#else
+	 * For userspace builds, use a separate header to define the required
+	 * macros and functions. This makes it easier to adapt the code into
+	 * different environments and avoids clutter in the Linux kernel tree.
+#	include "xz_config.h"
+#endif
+/* If no specific decoding mode is requested, enable support for all modes. */
+#if !defined(XZ_DEC_SINGLE) && !defined(XZ_DEC_PREALLOC) \
+		&& !defined(XZ_DEC_DYNALLOC)
+#	define XZ_DEC_SINGLE
+#	define XZ_DEC_PREALLOC
+#	define XZ_DEC_DYNALLOC
+#endif
+ * The DEC_IS_foo(mode) macros are used in "if" statements. If only some
+ * of the supported modes are enabled, these macros will evaluate to true or
+ * false at compile time and thus allow the compiler to omit unneeded code.
+#ifdef XZ_DEC_SINGLE
+#	define DEC_IS_SINGLE(mode) ((mode) == XZ_SINGLE)
+#else
+#	define DEC_IS_SINGLE(mode) (false)
+#endif
+#ifdef XZ_DEC_PREALLOC
+#	define DEC_IS_PREALLOC(mode) ((mode) == XZ_PREALLOC)
+#else
+#	define DEC_IS_PREALLOC(mode) (false)
+#endif
+#ifdef XZ_DEC_DYNALLOC
+#	define DEC_IS_DYNALLOC(mode) ((mode) == XZ_DYNALLOC)
+#else
+#	define DEC_IS_DYNALLOC(mode) (false)
+#endif
+#	define DEC_IS_MULTI(mode) (true)
+#elif defined(XZ_DEC_PREALLOC) || defined(XZ_DEC_DYNALLOC)
+#	define DEC_IS_MULTI(mode) ((mode) != XZ_SINGLE)
+#else
+#	define DEC_IS_MULTI(mode) (false)
+#endif
+ * If any of the BCJ filter decoders are wanted, define XZ_DEC_BCJ.
+ * XZ_DEC_BCJ is used to enable generic support for BCJ decoders.
+#ifndef XZ_DEC_BCJ
+#	if defined(XZ_DEC_X86) || defined(XZ_DEC_POWERPC) \
+			|| defined(XZ_DEC_IA64) || defined(XZ_DEC_ARM) \
+			|| defined(XZ_DEC_ARM) || defined(XZ_DEC_ARMTHUMB) \
+			|| defined(XZ_DEC_SPARC)
+#		define XZ_DEC_BCJ
+#	endif
+#endif
+ * Allocate memory for LZMA2 decoder. xz_dec_lzma2_reset() must be used
+ * before calling xz_dec_lzma2_run().
+						   uint32_t dict_max);
+ * Decode the LZMA2 properties (one byte) and reset the decoder. Return
+ * XZ_OK on success, XZ_MEMLIMIT_ERROR if the preallocated dictionary is not
+ * big enough, and XZ_OPTIONS_ERROR if props indicates something that this
+ * decoder doesn't support.
+					 uint8_t props);
+/* Decode raw LZMA2 stream from b->in to b->out. */
+				       struct xz_buf *b);
+/* Free the memory allocated for the LZMA2 decoder. */
+XZ_EXTERN void xz_dec_lzma2_end(struct xz_dec_lzma2 *s);
+#ifdef XZ_DEC_BCJ
+ * Allocate memory for BCJ decoders. xz_dec_bcj_reset() must be used before
+ * calling xz_dec_bcj_run().
+XZ_EXTERN struct xz_dec_bcj *xz_dec_bcj_create(bool single_call);
+ * Decode the Filter ID of a BCJ filter. This implementation doesn't
+ * support custom start offsets, so no decoding of Filter Properties
+ * is needed. Returns XZ_OK if the given Filter ID is supported.
+ * Otherwise XZ_OPTIONS_ERROR is returned.
+XZ_EXTERN enum xz_ret xz_dec_bcj_reset(struct xz_dec_bcj *s, uint8_t id);
+ * Decode raw BCJ + LZMA2 stream. This must be used only if there actually is
+ * a BCJ filter in the chain. If the chain has only LZMA2, xz_dec_lzma2_run()
+ * must be called directly.
+XZ_EXTERN enum xz_ret xz_dec_bcj_run(struct xz_dec_bcj *s,
+				     struct xz_dec_lzma2 *lzma2,
+/* Free the memory allocated for the BCJ filters. */
+#define xz_dec_bcj_end(s) kfree(s)
+#endif
+#endif
diff --git a/cpukit/libmisc/xz/xz_stream.h b/cpukit/libmisc/xz/xz_stream.h
index 0000000..66cb5a7
--- /dev/null
+++ b/cpukit/libmisc/xz/xz_stream.h
@@ -0,0 +1,62 @@
+ * Definitions for handling the .xz file format
+#ifndef XZ_STREAM_H
+#define XZ_STREAM_H
+#if defined(__KERNEL__) && !XZ_INTERNAL_CRC32
+#	include <linux/crc32.h>
+#	undef crc32
+#	define xz_crc32(buf, size, crc) \
+		(~crc32_le(~(uint32_t)(crc), buf, size))
+#endif
+ * See the .xz file format specification at
+ * http://tukaani.org/xz/xz-file-format.txt
+ * to understand the container format.
+#define STREAM_HEADER_SIZE 12
+#define HEADER_MAGIC "\3757zXZ"
+#define HEADER_MAGIC_SIZE 6
+#define FOOTER_MAGIC "YZ"
+#define FOOTER_MAGIC_SIZE 2
+ * Variable-length integer can hold a 63-bit unsigned integer or a special
+ * value indicating that the value is unknown.
+ * Experimental: vli_type can be defined to uint32_t to save a few bytes
+ * in code size (no effect on speed). Doing so limits the uncompressed and
+ * compressed size of the file to less than 256 MiB and may also weaken
+ * error detection slightly.
+typedef uint64_t vli_type;
+#define VLI_MAX ((vli_type)-1 / 2)
+#define VLI_UNKNOWN ((vli_type)-1)
+/* Maximum encoded size of a VLI */
+#define VLI_BYTES_MAX (sizeof(vli_type) * 8 / 7)
+/* Integrity Check types */
+enum xz_check {
+	XZ_CHECK_NONE = 0,
+	XZ_CHECK_CRC32 = 1,
+	XZ_CHECK_CRC64 = 4,
+	XZ_CHECK_SHA256 = 10
+/* Maximum possible Check ID */
+#define XZ_CHECK_MAX 15
+#endif
diff --git a/cpukit/preinstall.am b/cpukit/preinstall.am
index 5d4649a..9514390 100644
--- a/cpukit/preinstall.am
+++ b/cpukit/preinstall.am
@@ -46,6 +46,15 @@ $(PROJECT_INCLUDE)/utf8proc/utf8proc.h: libmisc/utf8proc/utf8proc.h $(PROJECT_IN
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/utf8proc/utf8proc.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/utf8proc/utf8proc.h
+$(PROJECT_INCLUDE)/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)
+	@: > $(PROJECT_INCLUDE)/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/$(dirstamp)
+$(PROJECT_INCLUDE)/xz.h: libmisc/xz/xz.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/xz.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/xz.h
 $(PROJECT_INCLUDE)/sys/$(dirstamp):
 	@$(MKDIR_P) $(PROJECT_INCLUDE)/sys
 	@: > $(PROJECT_INCLUDE)/sys/$(dirstamp)
diff --git a/cpukit/wrapup/Makefile.am b/cpukit/wrapup/Makefile.am
index c9b326d..768a903 100644
--- a/cpukit/wrapup/Makefile.am
+++ b/cpukit/wrapup/Makefile.am
@@ -65,6 +65,7 @@ TMP_LIBS += ../libmisc/libutf8proc.a
 endif
 TMP_LIBS += ../libmisc/libuuid.a
+TMP_LIBS += ../libmisc/libxz.a
 TMP_LIBS += ../libi2c/libi2c.a
 if LIBPCI
diff --git a/testsuites/libtests/configure.ac b/testsuites/libtests/configure.ac
index 77b92e0..430c509 100644
--- a/testsuites/libtests/configure.ac
+++ b/testsuites/libtests/configure.ac
@@ -32,6 +32,7 @@ RTEMS_CHECK_CPUOPTS([RTEMS_POSIX_API])
 AC_PROG_LN_S
 AC_PATH_PROG([PAX],[pax],no)
 AC_PATH_PROG([GZIP],[gzip],no)
+AC_PATH_PROG([XZ],[xz],no)
 AS_IF([test "x$PAX" = "xno"],[
 	AC_MSG_ERROR([pax is missing.])
@@ -40,6 +41,7 @@ AS_IF([test "x$PAX" = "xno"],[
 AC_CHECK_HEADERS([complex.h])
 AM_CONDITIONAL(TARTESTS,test "$as_ln_s" = "ln -s" && test -n "$PAX" && test -n "$GZIP")
+AM_CONDITIONAL(TARTEST_XZ,test -n "$XZ")
 AM_CONDITIONAL(HAS_CXX,test "$rtems_cv_HAS_CPLUSPLUS" = "yes")
 AM_CONDITIONAL([HAS_COMPLEX],[test "$ac_cv_header_complex_h" = yes])
diff --git a/testsuites/libtests/tar01/Makefile.am b/testsuites/libtests/tar01/Makefile.am
index 8b03e59..d64d2c6 100644
--- a/testsuites/libtests/tar01/Makefile.am
+++ b/testsuites/libtests/tar01/Makefile.am
@@ -16,6 +16,14 @@ BUILT_SOURCES += initial_filesystem_tar.h
 BUILT_SOURCES += initial_filesystem_tar_gz.c
 BUILT_SOURCES += initial_filesystem_tar_gz.h
+if TARTEST_XZ
+tar01_SOURCES += initial_filesystem_tar_xz.c
+tar01_SOURCES += initial_filesystem_tar_xz.h
+BUILT_SOURCES += initial_filesystem_tar_xz.c
+BUILT_SOURCES += initial_filesystem_tar_xz.h
+endif TARTEST_XZ
 dist_rtems_tests_DATA = tar01.scn
 dist_rtems_tests_DATA += tar01.doc
 endif TARTESTS
@@ -29,6 +37,10 @@ AM_CPPFLAGS += -I$(top_srcdir)/include
 AM_CPPFLAGS += -I$(top_srcdir)/../support/include
 AM_CPPFLAGS += -I$(top_srcdir)/../psxtests/include
+if TARTEST_XZ
+AM_CFLAGS += -DHAVE_XZ=1
+endif TARTEST_XZ
 LINK_OBJS = $(tar01_OBJECTS) $(tar01_LDADD)
 LINK_LIBS = $(tar01_LDLIBS)
@@ -46,12 +58,20 @@ CLEANFILES += initial_filesystem_tar.h
 initial_filesystem_tar_gz.c: initial_filesystem.tar.gz
 	$(BIN2C) -C initial_filesystem.tar.gz initial_filesystem_tar_gz
-CLEANFILES += initial_filesystem_tar_gz.h
+CLEANFILES += initial_filesystem_tar_gz.c
 initial_filesystem_tar_gz.h: initial_filesystem.tar.gz
 	$(BIN2C) -H initial_filesystem.tar.gz initial_filesystem_tar_gz
+initial_filesystem_tar_xz.c: initial_filesystem.tar.xz
+	$(BIN2C) -C initial_filesystem.tar.xz initial_filesystem_tar_xz
+CLEANFILES += initial_filesystem_tar_xz.c
+initial_filesystem_tar_xz.h: initial_filesystem.tar.xz
+	$(BIN2C) -H initial_filesystem.tar.xz initial_filesystem_tar_xz
+CLEANFILES += initial_filesystem_tar_xz.h
 initial_filesystem.tar:
 	rm -rf initial_fs
 	$(MKDIR_P) initial_fs/home
@@ -69,6 +89,10 @@ initial_filesystem.tar.gz: initial_filesystem.tar
 	$(GZIP) < initial_filesystem.tar > initial_filesystem.tar.gz
 CLEANFILES += initial_filesystem.tar.gz
+initial_filesystem.tar.xz: initial_filesystem.tar
+	$(XZ) --lzma2=dict=8192 < initial_filesystem.tar > initial_filesystem.tar.xz
+CLEANFILES += initial_filesystem.tar.xz
 endif TARTESTS
 clean-local:
diff --git a/testsuites/libtests/tar01/init.c b/testsuites/libtests/tar01/init.c
index 7d4f1b9..f8f26c9 100644
--- a/testsuites/libtests/tar01/init.c
+++ b/testsuites/libtests/tar01/init.c
@@ -25,6 +25,9 @@
 #include "initial_filesystem_tar.h"
 #include "initial_filesystem_tar_gz.h"
+#if HAVE_XZ
+#include "initial_filesystem_tar_xz.h"
+#endif
 const char rtems_test_name[] = "TAR 1";
@@ -34,11 +37,16 @@ void test_untar_from_memory(void);
 void test_untar_from_file(void);
 void test_untar_chunks_from_memory(void);
 void test_untar_unzip_tgz(void);
+void test_untar_unzip_txz(void);
 #define TARFILE_START initial_filesystem_tar
 #define TARFILE_SIZE  initial_filesystem_tar_size
 #define TARFILE_GZ_START initial_filesystem_tar_gz
 #define TARFILE_GZ_SIZE  initial_filesystem_tar_gz_size
+#if HAVE_XZ
+#define TARFILE_XZ_START initial_filesystem_tar_xz
+#define TARFILE_XZ_SIZE  initial_filesystem_tar_xz_size
+#endif
 void test_cat(
   char *file,
@@ -92,6 +100,8 @@ void test_untar_from_file(void)
   int                rv;
   ssize_t            n;
+  puts( "" );
   puts( "Copy tar image to test.tar" );
   /* Copy tar image from object to file in IMFS */
   fd = open( "/test.tar", O_CREAT|O_TRUNC|O_WRONLY, 0777 );
@@ -141,6 +151,8 @@ void test_untar_chunks_from_memory(void)
   char *buffer = (char *)TARFILE_START;
   size_t buflen = TARFILE_SIZE;
+  puts( "" );
   rtems_print_printer_printf(&printer);
   /* make a directory to untar it into */
@@ -185,6 +197,10 @@ void test_untar_unzip_tgz(void)
   size_t buflen = TARFILE_GZ_SIZE;
   char inflate_buffer;
+  puts( "" );
+  rtems_test_assert( buflen != 0 );
@@ -218,6 +234,60 @@ void test_untar_unzip_tgz(void)
   test_cat( "/dest3/symlink", 0, 0 );
+#if HAVE_XZ
+  int status;
+  rtems_printer     printer;
+  int rv;
+  Untar_XzChunkContext ctx;
+  size_t i = 0;
+  char *buffer = (char *)TARFILE_XZ_START;
+  size_t buflen = TARFILE_XZ_SIZE;
+  char inflate_buffer;
+  puts( "" );
+  rtems_print_printer_printf(&printer);
+  /* make a directory to untar it into */
+  rv = mkdir( "/dest4", 0777 );
+  rtems_test_assert( rv == 0 );
+  rv = chdir( "/dest4" );
+  printf( "Untaring chunks from txz - " );
+   * Use 8K dict, this is set on the command line of xz when compressing.
+  status = Untar_XzChunkContext_Init(&ctx, XZ_DYNALLOC,
+                                     8 * 1024, &inflate_buffer, 1);
+  rtems_test_assert(status == UNTAR_SUCCESSFUL);
+  for(i = 0; i < buflen; i++) {
+    status = Untar_FromXzChunk_Print(&ctx, &buffer[i], 1, &printer);
+  printf( "successful\n" );
+  printf( "========= /dest4/home/test_file =========\n" );
+  test_cat( "/dest4/home/test_file", 0, 0 );
+  printf( "========= /dest4/home/test_script =========\n" );
+  test_cat( "/dest4/home/test_script", 0, 0 );
+  test_untar_check_mode("/dest4/home/test_script", 0755);
+  printf( "========= /dest4/symlink =========\n" );
+  test_cat( "/dest4/symlink", 0, 0 );
+#endif
 rtems_task Init(
   rtems_task_argument ignored
@@ -225,12 +295,10 @@ rtems_task Init(
   TEST_BEGIN();
   test_untar_from_memory();
-  puts( "" );
   test_untar_from_file();
-  puts( "" );
   test_untar_chunks_from_memory();
-  puts( "" );
   test_untar_unzip_tgz();
+  test_untar_unzip_txz();
   TEST_END();
   exit( 0 );
2.9.0
