RTEMS 4.11 drivers support to SPARC LEON2
Daniel Silveira
daniel.silveira at gmv.com
Tue Oct 25 08:59:19 UTC 2016
Dear all,
I am working on a RASTA 101 with a LEON2 processor including a PCI board XC4V with CAN bus and etc.
I decided to try the provided CAN sample and test CAN bus and respective drivers, but I get a driver failure.
I noticed that I had to make some adaptation to RTEMS 4.11 RC3, some enumerations had changed name (replace KEY_TYPE_INT) and also some include file locations are different (e.g. rasta headers are inside bsp folder).
Reading the documentation and also comments within makefile, it seems the drivers have been only tested (prepared) for LEON3.
I am also interested to play with others buses (1553, Ethernet and Spacewire).
What are the status the mentioned drivers running with RASTA/LEON2?
If they are able to execute them with no issues, where am I able to get samples for LEON2?
Thank you very much
Daniel Silveira (GMV)
P Please consider the environment before printing this e-mail.
______________________
This message including any attachments may contain confidential
information, according to our Information Security Management System,
and intended solely for a specific individual to whom they are addressed.
Any unauthorised copy, disclosure or distribution of this message
is strictly forbidden. If you have received this transmission in error,
please notify the sender immediately and delete it.
Este mensaje, y en su caso, cualquier fichero anexo al mismo,
puede contener informacion clasificada por su emisor como confidencial
en el marco de su Sistema de Gestion de Seguridad de la
Informacion siendo para uso exclusivo del destinatario, quedando
prohibida su divulgacion copia o distribucion a terceros sin la
autorizacion expresa del remitente. Si Vd. ha recibido este mensaje
erroneamente, se ruega lo notifique al remitente y proceda a su borrado.
Gracias por su colaboracion.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20161025/6d130e32/attachment.html>
