[PATCH 24/30] score: Second part of new MrsP implementation
Mon Oct 31 08:51:55 UTC 2016
Update #2556.
 cpukit/score/include/rtems/score/schedulerimpl.h   | 257 +++++++--------------
 cpukit/score/include/rtems/score/schedulernode.h   | 104 ++-------
 .../score/include/rtems/score/schedulernodeimpl.h  |   1 -
 .../score/include/rtems/score/schedulersmpimpl.h   |  98 +++++---
 cpukit/score/include/rtems/score/threadimpl.h      |   7 +
 cpukit/score/src/schedulerpriorityaffinitysmp.c    |   8 -
 testsuites/smptests/smpmrsp01/init.c               |   5 -
 7 files changed, 187 insertions(+), 293 deletions(-)
diff --git a/cpukit/score/include/rtems/score/schedulerimpl.h b/cpukit/score/include/rtems/score/schedulerimpl.h
index 54ddd53..ac6893e 100644
--- a/cpukit/score/include/rtems/score/schedulerimpl.h
+++ b/cpukit/score/include/rtems/score/schedulerimpl.h
@@ -483,6 +483,9 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Priority_and_sticky_update(
   _Scheduler_Acquire_critical( scheduler, &lock_context );
+  scheduler_node->sticky_level += sticky_level_change;
+  _Assert( scheduler_node->sticky_level >= 0 );
   ( *scheduler->Operations.update_priority )(
     scheduler,
     the_thread,
@@ -929,27 +932,6 @@ typedef void ( *Scheduler_Release_idle_thread )(
   Thread_Control    *idle
-RTEMS_INLINE_ROUTINE void _Scheduler_Thread_set_node(
-  Thread_Control *the_thread,
-  Scheduler_Node *node
-  the_thread->Scheduler.node = node;
-RTEMS_INLINE_ROUTINE void _Scheduler_Thread_set_scheduler_and_node(
-  Scheduler_Node       *node,
-  const Thread_Control *previous_user_of_node
-  const Scheduler_Control *scheduler =
-    _Scheduler_Get_own( previous_user_of_node );
-  the_thread->Scheduler.control = scheduler;
-  _Scheduler_Thread_set_node( the_thread, node );
 extern const bool _Scheduler_Thread_state_valid_state_changes[ 3 ][ 3 ];
 RTEMS_INLINE_ROUTINE void _Scheduler_Thread_change_state(
@@ -975,17 +957,11 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Set_idle_thread(
-  _Assert(
-    node->help_state == SCHEDULER_HELP_ACTIVE_OWNER
-      || node->help_state == SCHEDULER_HELP_ACTIVE_RIVAL
   _Assert( _Scheduler_Node_get_idle( node ) == NULL );
   _Assert(
     _Scheduler_Node_get_owner( node ) == _Scheduler_Node_get_user( node )
-  _Scheduler_Thread_set_node( idle, node );
   _Scheduler_Node_set_user( node, idle );
   node->idle = idle;
@@ -993,25 +969,27 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Set_idle_thread(
  * @brief Use an idle thread for this scheduler node.
- * A thread in the SCHEDULER_HELP_ACTIVE_OWNER or SCHEDULER_HELP_ACTIVE_RIVAL
- * helping state may use an idle thread for the scheduler node owned by itself
- * in case it executes currently using another scheduler node or in case it is
- * in a blocking state.
+ * A thread those home scheduler node has a sticky level greater than zero may
+ * use an idle thread in the home scheduler instance in case it executes
+ * currently in another scheduler instance or in case it is in a blocking
+ * state.
  * @param[in] context The scheduler instance context.
  * @param[in] node The node which wants to use the idle thread.
+ * @param[in] cpu The processor for the idle thread.
  * @param[in] get_idle_thread Function to get an idle thread.
 RTEMS_INLINE_ROUTINE Thread_Control *_Scheduler_Use_idle_thread(
   Scheduler_Context         *context,
+  Per_CPU_Control           *cpu,
   Scheduler_Get_idle_thread  get_idle_thread
   Thread_Control *idle = ( *get_idle_thread )( context );
   _Scheduler_Set_idle_thread( node, idle );
+  _Thread_Set_CPU( idle, cpu );
   return idle;
@@ -1042,7 +1020,6 @@ _Scheduler_Try_to_schedule_node(
   ISR_lock_Context                  lock_context;
   Scheduler_Try_to_schedule_action  action;
-  Thread_Control                   *owner;
   Thread_Control                   *user;
   action = SCHEDULER_TRY_TO_SCHEDULE_DO_SCHEDULE;
@@ -1050,52 +1027,20 @@ _Scheduler_Try_to_schedule_node(
   _Thread_Scheduler_acquire_critical( user, &lock_context );
-  if ( node->help_state == SCHEDULER_HELP_YOURSELF ) {
-    if ( user->Scheduler.state == THREAD_SCHEDULER_READY ) {
-      _Thread_Scheduler_cancel_need_for_help( user, _Thread_Get_CPU( user ) );
-      _Scheduler_Thread_change_state( user, THREAD_SCHEDULER_SCHEDULED );
-    } else {
-      action = SCHEDULER_TRY_TO_SCHEDULE_DO_BLOCK;
-    _Thread_Scheduler_release_critical( user, &lock_context );
-    return action;
-  owner = _Scheduler_Node_get_owner( node );
-  if ( node->help_state == SCHEDULER_HELP_ACTIVE_RIVAL) {
-      _Scheduler_Thread_set_scheduler_and_node( user, node, owner );
-    } else if ( owner->Scheduler.state == THREAD_SCHEDULER_BLOCKED ) {
-      if ( idle != NULL ) {
-        action = SCHEDULER_TRY_TO_SCHEDULE_DO_IDLE_EXCHANGE;
-      } else {
-        _Scheduler_Use_idle_thread( context, node, get_idle_thread );
-    } else {
-      _Scheduler_Node_set_user( node, owner );
-  } else if ( node->help_state == SCHEDULER_HELP_ACTIVE_OWNER ) {
-    } else if ( idle != NULL ) {
-    } else {
-  } else {
-    _Assert( node->help_state == SCHEDULER_HELP_PASSIVE );
-    } else {
-  if ( action == SCHEDULER_TRY_TO_SCHEDULE_DO_SCHEDULE ) {
+  if ( user->Scheduler.state == THREAD_SCHEDULER_READY ) {
+    _Thread_Scheduler_cancel_need_for_help( user, _Thread_Get_CPU( user ) );
+  } else if ( node->sticky_level == 0 ) {
+    action = SCHEDULER_TRY_TO_SCHEDULE_DO_BLOCK;
+  } else if ( idle != NULL ) {
+    action = SCHEDULER_TRY_TO_SCHEDULE_DO_IDLE_EXCHANGE;
+  } else {
+    _Scheduler_Use_idle_thread(
+      context,
+      node,
+      _Thread_Get_CPU( user ),
+      get_idle_thread
@@ -1125,9 +1070,6 @@ RTEMS_INLINE_ROUTINE Thread_Control *_Scheduler_Release_idle_thread(
     node->idle = NULL;
-    _Scheduler_Thread_change_state( idle, THREAD_SCHEDULER_READY );
-    _Scheduler_Thread_set_node( idle, idle->Scheduler.own_node );
     ( *release_idle_thread )( context, idle );
@@ -1171,63 +1113,63 @@ RTEMS_INLINE_ROUTINE Per_CPU_Control *_Scheduler_Block_node(
+  int               sticky_level;
-  Thread_Control   *old_user;
-  Thread_Control   *new_user;
   Per_CPU_Control  *thread_cpu;
+  sticky_level = node->sticky_level;
+  --sticky_level;
+  node->sticky_level = sticky_level;
+  _Assert( sticky_level >= 0 );
   _Thread_Scheduler_acquire_critical( thread, &lock_context );
   thread_cpu = _Thread_Get_CPU( thread );
   _Thread_Scheduler_cancel_need_for_help( thread, thread_cpu );
   _Scheduler_Thread_change_state( thread, THREAD_SCHEDULER_BLOCKED );
   _Thread_Scheduler_release_critical( thread, &lock_context );
-    _Assert( thread == _Scheduler_Node_get_user( node ) );
+  if ( sticky_level > 0 ) {
+    if ( is_scheduled && _Scheduler_Node_get_idle( node ) == NULL ) {
+      Thread_Control *idle;
+      idle = _Scheduler_Use_idle_thread(
+        context,
+        node,
+        thread_cpu,
+        get_idle_thread
+      _Thread_Dispatch_update_heir( _Per_CPU_Get(), thread_cpu, idle );
-    return thread_cpu;
+    return NULL;
-  new_user = NULL;
+  _Assert( thread == _Scheduler_Node_get_user( node ) );
+  return thread_cpu;
-  if ( node->help_state == SCHEDULER_HELP_ACTIVE_OWNER ) {
-    if ( is_scheduled ) {
-      old_user = thread;
-      new_user = _Scheduler_Use_idle_thread( context, node, get_idle_thread );
-  } else if ( node->help_state == SCHEDULER_HELP_ACTIVE_RIVAL ) {
-      old_user = _Scheduler_Node_get_user( node );
-      if ( thread == old_user ) {
-        Thread_Control *owner = _Scheduler_Node_get_owner( node );
-        if (
-          thread != owner
-            && owner->Scheduler.state == THREAD_SCHEDULER_READY
-          new_user = owner;
-          _Scheduler_Node_set_user( node, new_user );
-        } else {
-  } else {
-    /* Not implemented, this is part of the OMIP support path. */
-    _Assert(0);
+RTEMS_INLINE_ROUTINE void _Scheduler_Discard_idle_thread(
+  Scheduler_Context             *context,
+  Thread_Control                *the_thread,
+  Scheduler_Node                *node,
+  Scheduler_Release_idle_thread  release_idle_thread
+  Thread_Control  *owner;
+  Per_CPU_Control *cpu;
-  if ( new_user != NULL ) {
-    Per_CPU_Control *cpu = _Thread_Get_CPU( old_user );
+  idle = _Scheduler_Node_get_idle( node );
+  owner = _Scheduler_Node_get_owner( node );
-    _Scheduler_Thread_change_state( new_user, THREAD_SCHEDULER_SCHEDULED );
-    _Thread_Set_CPU( new_user, cpu );
-    _Thread_Dispatch_update_heir( _Per_CPU_Get(), cpu, new_user );
+  node->idle = NULL;
+  _Assert( _Scheduler_Node_get_user( node ) == idle );
+  _Scheduler_Node_set_user( node, owner );
+  ( *release_idle_thread )( context, idle );
-  return NULL;
+  cpu = _Thread_Get_CPU( idle );
+  _Thread_Set_CPU( the_thread, cpu );
+  _Thread_Dispatch_update_heir( _Per_CPU_Get(), cpu, the_thread );
@@ -1252,46 +1194,20 @@ RTEMS_INLINE_ROUTINE bool _Scheduler_Unblock_node(
   bool unblock;
+  ++node->sticky_level;
+  _Assert( node->sticky_level > 0 );
-    Thread_Control *old_user = _Scheduler_Node_get_user( node );
-    Thread_Control *idle = _Scheduler_Release_idle_thread(
+    _Scheduler_Discard_idle_thread(
       context,
+      the_thread,
       node,
       release_idle_thread
-      _Assert( idle != NULL );
-      new_user = the_thread;
-      _Assert( node->help_state == SCHEDULER_HELP_ACTIVE_RIVAL );
-    } else if ( the_thread != owner ) {
-      _Assert( old_user != the_thread );
-      _Scheduler_Thread_change_state( owner, THREAD_SCHEDULER_READY );
-    } else {
-      _Scheduler_Thread_change_state( the_thread, THREAD_SCHEDULER_READY );
-      new_user = NULL;
+    _Scheduler_Thread_change_state( the_thread, THREAD_SCHEDULER_SCHEDULED );
     unblock = false;
   } else {
     unblock = true;
@@ -1372,21 +1288,6 @@ RTEMS_INLINE_ROUTINE Status_Control _Scheduler_Set(
 #if defined(RTEMS_SMP)
-  _Chain_Extract_unprotected( &old_scheduler_node->Thread.Wait_node );
-  _Assert( _Chain_Is_empty( &the_thread->Scheduler.Wait_nodes ) );
-  _Chain_Initialize_one(
-    &the_thread->Scheduler.Wait_nodes,
-    &new_scheduler_node->Thread.Wait_node
-    &old_scheduler_node->Thread.Scheduler_node.Chain
-  _Assert( _Chain_Is_empty( &the_thread->Scheduler.Scheduler_nodes ) );
-    &the_thread->Scheduler.Scheduler_nodes,
-    &new_scheduler_node->Thread.Scheduler_node.Chain
     const Scheduler_Control *old_scheduler;
@@ -1401,6 +1302,24 @@ RTEMS_INLINE_ROUTINE Status_Control _Scheduler_Set(
         _Scheduler_Block( the_thread );
+      _Assert( old_scheduler_node->sticky_level == 0 );
+      _Assert( new_scheduler_node->sticky_level == 0 );
+      _Chain_Extract_unprotected( &old_scheduler_node->Thread.Wait_node );
+      _Assert( _Chain_Is_empty( &the_thread->Scheduler.Wait_nodes ) );
+      _Chain_Initialize_one(
+        &the_thread->Scheduler.Wait_nodes,
+        &new_scheduler_node->Thread.Wait_node
+        &old_scheduler_node->Thread.Scheduler_node.Chain
+      _Assert( _Chain_Is_empty( &the_thread->Scheduler.Scheduler_nodes ) );
+        &the_thread->Scheduler.Scheduler_nodes,
+        &new_scheduler_node->Thread.Scheduler_node.Chain
       the_thread->Scheduler.own_control = new_scheduler;
       the_thread->Scheduler.control = new_scheduler;
       the_thread->Scheduler.own_node = new_scheduler_node;
diff --git a/cpukit/score/include/rtems/score/schedulernode.h b/cpukit/score/include/rtems/score/schedulernode.h
index 620b029..e27c4a3 100644
--- a/cpukit/score/include/rtems/score/schedulernode.h
+++ b/cpukit/score/include/rtems/score/schedulernode.h
@@ -28,75 +28,6 @@ extern "C" {
- * @brief State to indicate potential help for other threads.
- * @dot
- * digraph state {
- *   y [label="HELP YOURSELF"];
- *   ao [label="HELP ACTIVE OWNER"];
- *   ar [label="HELP ACTIVE RIVAL"];
- *   y -> ao [label="obtain"];
- *   y -> ar [label="wait for obtain"];
- *   ao -> y [label="last release"];
- *   ao -> r [label="wait for obtain"];
- *   ar -> r [label="timeout"];
- *   ar -> ao [label="timeout"];
- * @enddot
-typedef enum {
-   * @brief This scheduler node is solely used by the owner thread.
-   * This thread owns no resources using a helping protocol and thus does not
-   * take part in the scheduler helping protocol.  No help will be provided for
-   * other thread.
-  SCHEDULER_HELP_YOURSELF,
-   * @brief This scheduler node is owned by a thread actively owning a resource.
-   * This scheduler node can be used to help out threads.
-   * In case this scheduler node changes its state from ready to scheduled and
-   * the thread executes using another node, then an idle thread will be
-   * provided as a user of this node to temporarily execute on behalf of the
-   * owner thread.  Thus lower priority threads are denied access to the
-   * processors of this scheduler instance.
-   * In case a thread actively owning a resource performs a blocking operation,
-   * then an idle thread will be used also in case this node is in the
-   * scheduled state.
-  SCHEDULER_HELP_ACTIVE_OWNER,
-   * @brief This scheduler node is owned by a thread actively obtaining a
-   * resource currently owned by another thread.
-   * The thread owning this node is ready and will give away its processor in
-   * case the thread owning the resource asks for help.
-  SCHEDULER_HELP_ACTIVE_RIVAL,
-   * @brief This scheduler node is owned by a thread obtaining a
-   * The thread owning this node is blocked.
-  SCHEDULER_HELP_PASSIVE
-} Scheduler_Help_state;
-#endif
-#if defined(RTEMS_SMP)
  * @brief The scheduler node requests.
 typedef enum {
@@ -146,27 +77,37 @@ struct Scheduler_Node {
   Chain_Node Node;
-   * @brief The thread using this node.
+   * @brief The sticky level determines if this scheduler node should use an
+   * idle thread in case this node is scheduled and the owner thread is
+   * blocked.
-  struct _Thread_Control *user;
+  int sticky_level;
-   * @brief The help state of this node.
+   * @brief The thread using this node.
+   * This is either the owner or an idle thread.
-  Scheduler_Help_state help_state;
+  struct _Thread_Control *user;
-   * @brief The idle thread claimed by this node in case the help state is
-   * SCHEDULER_HELP_ACTIVE_OWNER.
+   * @brief The idle thread claimed by this node in case the sticky level is
+   * greater than zero and the thread is block or is scheduled on another
+   * scheduler instance.
-   * Active owners will lend their own node to an idle thread in case they
-   * execute currently using another node or in case they perform a blocking
-   * operation.  This is necessary to ensure the priority ceiling protocols
-   * work across scheduler boundaries.
+   * This is necessary to ensure the priority ceiling protocols work across
+   * scheduler boundaries.
   struct _Thread_Control *idle;
+#endif
+   * @brief The thread owning this node.
+  struct _Thread_Control *owner;
+#if defined(RTEMS_SMP)
    * @brief The thread accepting help by this node in case the help state is
    * not SCHEDULER_HELP_YOURSELF.
@@ -222,11 +163,6 @@ struct Scheduler_Node {
   } Wait;
-   * @brief The thread owning this node.
-  struct _Thread_Control *owner;
    * @brief The thread priority information used by the scheduler.
    * The thread priority is manifest in two independent areas.  One area is the
diff --git a/cpukit/score/include/rtems/score/schedulernodeimpl.h b/cpukit/score/include/rtems/score/schedulernodeimpl.h
index f590131..62c2fab 100644
--- a/cpukit/score/include/rtems/score/schedulernodeimpl.h
+++ b/cpukit/score/include/rtems/score/schedulernodeimpl.h
@@ -46,7 +46,6 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Node_do_initialize(
   _Chain_Initialize_node( &node->Thread.Wait_node );
   node->Wait.Priority.scheduler = scheduler;
   node->user = the_thread;
-  node->help_state = SCHEDULER_HELP_YOURSELF;
   node->idle = NULL;
   node->accepts_help = the_thread;
   _SMP_sequence_lock_Initialize( &node->Priority.Lock );
diff --git a/cpukit/score/include/rtems/score/schedulersmpimpl.h b/cpukit/score/include/rtems/score/schedulersmpimpl.h
index 6c3a409..67f1595 100644
--- a/cpukit/score/include/rtems/score/schedulersmpimpl.h
+++ b/cpukit/score/include/rtems/score/schedulersmpimpl.h
@@ -781,8 +781,36 @@ static inline Thread_Control *_Scheduler_SMP_Enqueue_scheduled_ordered(
      * The node has been extracted from the scheduled chain.  We have to place
      * it now on the scheduled or ready set.
-    if ( ( *order )( &node->Node, &highest_ready->Node ) ) {
+    if (
+      node->sticky_level > 0
+        && ( *order )( &node->Node, &highest_ready->Node )
       ( *insert_scheduled )( context, node );
+      if ( _Scheduler_Node_get_idle( node ) != NULL ) {
+        ISR_lock_Context  lock_context;
+        _Thread_Scheduler_acquire_critical( owner, &lock_context );
+        if ( owner->Scheduler.state == THREAD_SCHEDULER_READY ) {
+            owner,
+            _Thread_Get_CPU( owner )
+            context,
+            owner,
+            node,
+            _Scheduler_SMP_Release_idle_thread
+          _Scheduler_Thread_change_state( owner, THREAD_SCHEDULER_SCHEDULED );
+        _Thread_Scheduler_release_critical( owner, &lock_context );
       return NULL;
@@ -992,10 +1020,7 @@ static inline Thread_Control *_Scheduler_SMP_Unblock(
       needs_help = ( *enqueue_fifo )( context, node, thread );
     } else {
       _Assert( node_state == SCHEDULER_SMP_NODE_READY );
-      _Assert(
       _Assert( node->idle == NULL );
       if ( node->accepts_help == thread ) {
@@ -1146,38 +1171,58 @@ static inline bool _Scheduler_SMP_Ask_for_help(
-  if (
-    thread->Scheduler.state == THREAD_SCHEDULER_READY
-      && _Scheduler_SMP_Node_state( node ) == SCHEDULER_SMP_NODE_BLOCKED
-    if ( ( *order )( &node->Node, &lowest_scheduled->Node ) ) {
+  if ( thread->Scheduler.state == THREAD_SCHEDULER_READY ) {
+    Scheduler_SMP_Node_state node_state;
+    node_state = _Scheduler_SMP_Node_state( node );
+    if ( node_state == SCHEDULER_SMP_NODE_BLOCKED ) {
+      if ( ( *order )( &node->Node, &lowest_scheduled->Node ) ) {
+          thread,
+          _Thread_Get_CPU( thread )
+        _Scheduler_Thread_change_state( thread, THREAD_SCHEDULER_SCHEDULED );
+        _Thread_Scheduler_release_critical( thread, &lock_context );
+        _Scheduler_SMP_Preempt(
+          context,
+          node,
+          lowest_scheduled,
+          allocate_processor
+        ( *insert_scheduled )( context, node );
+        ( *move_from_scheduled_to_ready )( context, lowest_scheduled );
+        _Scheduler_Release_idle_thread(
+          context,
+          lowest_scheduled,
+        success = true;
+      } else {
+        _Scheduler_SMP_Node_change_state( node, SCHEDULER_SMP_NODE_READY );
+        ( *insert_ready )( context, node );
+        success = false;
+    } else if ( node_state == SCHEDULER_SMP_NODE_SCHEDULED ) {
         thread,
-      _Scheduler_Thread_change_state( thread, THREAD_SCHEDULER_SCHEDULED );
-      _Thread_Scheduler_release_critical( thread, &lock_context );
-      _Scheduler_SMP_Preempt(
         context,
+        thread,
         node,
-        lowest_scheduled,
-        allocate_processor
-      ( *insert_scheduled )( context, node );
-      ( *move_from_scheduled_to_ready )( context, lowest_scheduled );
-      _Scheduler_Release_idle_thread(
-        context,
-        lowest_scheduled,
       success = true;
     } else {
-      _Scheduler_SMP_Node_change_state( node, SCHEDULER_SMP_NODE_READY );
-      ( *insert_ready )( context, node );
       success = false;
   } else {
@@ -1202,6 +1247,7 @@ static inline void _Scheduler_SMP_Reconsider_help_request(
   if (
     thread->Scheduler.state == THREAD_SCHEDULER_SCHEDULED
       && _Scheduler_SMP_Node_state( node ) == SCHEDULER_SMP_NODE_READY
+      && node->sticky_level == 1
     _Scheduler_SMP_Node_change_state( node, SCHEDULER_SMP_NODE_BLOCKED );
     ( *extract_from_ready )( context, node );
diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
index ccfb6bf..b439758 100644
--- a/cpukit/score/include/rtems/score/threadimpl.h
+++ b/cpukit/score/include/rtems/score/threadimpl.h
@@ -570,6 +570,13 @@ void _Thread_Priority_replace(
 void _Thread_Priority_update( Thread_queue_Context *queue_context );
+void _Thread_Priority_and_sticky_update(
+  int             sticky_level_change
+#endif
  * @brief Returns true if the left thread priority is less than the right
  * thread priority in the intuitive sense of priority and false otherwise.
diff --git a/cpukit/score/src/schedulerpriorityaffinitysmp.c b/cpukit/score/src/schedulerpriorityaffinitysmp.c
index 91f9c3b..1163a1a 100644
--- a/cpukit/score/src/schedulerpriorityaffinitysmp.c
+++ b/cpukit/score/src/schedulerpriorityaffinitysmp.c
@@ -335,14 +335,6 @@ static void _Scheduler_priority_affinity_SMP_Check_for_migrations(
       break;
-     * FIXME: Do not consider threads using the scheduler helping protocol
-     * since this could produce more than one thread in need for help in one
-     * operation which is currently not possible.
-    if ( lowest_scheduled->help_state != SCHEDULER_HELP_YOURSELF )
-      break;
      * But if we found a thread which is lower priority than one
      * in the ready set, then we need to swap them out.
diff --git a/testsuites/smptests/smpmrsp01/init.c b/testsuites/smptests/smpmrsp01/init.c
index de5f31c..bb729e0 100644
--- a/testsuites/smptests/smpmrsp01/init.c
+++ b/testsuites/smptests/smpmrsp01/init.c
@@ -1430,11 +1430,6 @@ static void test_mrsp_obtain_and_release_with_help(test_context *ctx)
   rtems_test_assert(rtems_get_current_processor() == 1);
-  sc = rtems_task_wake_after(2);
-  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
-  rtems_test_assert(rtems_get_current_processor() == 1);
    * With this operation the scheduler instance 0 has now only the main and the
    * idle threads in the ready set.
1.8.4.5
