[PATCH 25/30] score: Delete Resource Handler
Mon Oct 31 08:51:56 UTC 2016
Update #2556.
 cpukit/score/Makefile.am                         |   3 -
 cpukit/score/include/rtems/score/resource.h      | 211 ---------------
 cpukit/score/include/rtems/score/resourceimpl.h  | 165 ------------
 cpukit/score/preinstall.am                       |   8 -
 cpukit/score/src/resourceiterate.c               | 104 --------
 testsuites/sptests/Makefile.am                   |   1 -
 testsuites/sptests/configure.ac                  |   1 -
 testsuites/sptests/spresource01/Makefile.am      |  19 --
 testsuites/sptests/spresource01/init.c           | 317 -----------------------
 testsuites/sptests/spresource01/spresource01.doc |  11 -
 testsuites/sptests/spresource01/spresource01.scn |  94 -------
 11 files changed, 934 deletions(-)
 delete mode 100644 cpukit/score/include/rtems/score/resource.h
 delete mode 100644 cpukit/score/include/rtems/score/resourceimpl.h
 delete mode 100644 cpukit/score/src/resourceiterate.c
 delete mode 100644 testsuites/sptests/spresource01/Makefile.am
 delete mode 100644 testsuites/sptests/spresource01/init.c
 delete mode 100644 testsuites/sptests/spresource01/spresource01.doc
 delete mode 100644 testsuites/sptests/spresource01/spresource01.scn
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 447a97c..528c3fe 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -65,8 +65,6 @@ include_rtems_score_HEADERS += include/rtems/score/profiling.h
 include_rtems_score_HEADERS += include/rtems/score/processormask.h
 include_rtems_score_HEADERS += include/rtems/score/rbtree.h
 include_rtems_score_HEADERS += include/rtems/score/rbtreeimpl.h
-include_rtems_score_HEADERS += include/rtems/score/resource.h
-include_rtems_score_HEADERS += include/rtems/score/resourceimpl.h
 include_rtems_score_HEADERS += include/rtems/score/scheduler.h
 include_rtems_score_HEADERS += include/rtems/score/schedulerimpl.h
 include_rtems_score_HEADERS += include/rtems/score/schedulercbs.h
@@ -355,7 +353,6 @@ libscore_a_SOURCES += src/futex.c
 libscore_a_SOURCES += src/profilingisrentryexit.c
 libscore_a_SOURCES += src/mutex.c
 libscore_a_SOURCES += src/once.c
-libscore_a_SOURCES += src/resourceiterate.c
 libscore_a_SOURCES += src/sched.c
 libscore_a_SOURCES += src/semaphore.c
 libscore_a_SOURCES += src/smpbarrierwait.c
diff --git a/cpukit/score/include/rtems/score/resource.h b/cpukit/score/include/rtems/score/resource.h
deleted file mode 100644
index ecf84a7..0000000
--- a/cpukit/score/include/rtems/score/resource.h
+++ /dev/null
@@ -1,211 +0,0 @@
- * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
- *  embedded brains GmbH
- *  Dornierstr. 4
- *  82178 Puchheim
- *  Germany
- *  <rtems at embedded-brains.de>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#ifndef _RTEMS_SCORE_RESOURCE_H
-#define _RTEMS_SCORE_RESOURCE_H
-#include <rtems/score/basedefs.h>
-#include <rtems/score/chain.h>
-#ifdef __cplusplus
-extern "C" {
-#endif /* __cplusplus */
- * @defgroup ScoreResource Resource Handler
- * @ingroup Score
- * @brief Support for resource dependency management.
- * A resource is something that has at most one owner at a time and may have
- * multiple rivals in case an owner is present.  The owner and rivals are
- * impersonated via resource nodes.  A resource is represented via the resource
- * control structure.  The resource controls and nodes are organized as trees.
- * It is possible to detect deadlocks via such a resource tree.  The
- * _Resource_Iterate() function can be used to iterate through such a resource
- * tree starting at a top node.
- * The following diagram shows an example resource tree with sixteen resource
- * nodes n0 up to n15 and sixteen resources r0 up to r15.  The root of this
- * tree is n0.  As a use case threads can be associated with resource nodes.
- * In this case a thread represented by node n0 owns resources r0, r1, r2, r3,
- * r6, r11 and r12 and is in the ready state.  The threads represented by nodes
- * n1 up to n15 wait directly or indirectly via resources owned by n0 and are
- * in a blocked state.
- * @dot
- * digraph {
- *   n0 [style=filled, fillcolor=green];
- *   n0 -> r0;
- *   subgraph {
- *     rank=same;
- *     n1 [style=filled, fillcolor=green];
- *     r0 -> n1;
- *     n2 [style=filled, fillcolor=green];
- *     n1 -> n2;
- *     n4 [style=filled, fillcolor=green];
- *     n2 -> n4;
- *     n6 [style=filled, fillcolor=green];
- *     n4 -> n6;
- *     n8 [style=filled, fillcolor=green];
- *     n6 -> n8;
- *     n15 [style=filled, fillcolor=green];
- *     n8 -> n15;
- *   n1 -> r5;
- *   subgraph {
- *     rank=same;
- *     n3 [style=filled, fillcolor=green];
- *     r5 -> n3;
- *     n12 [style=filled, fillcolor=green];
- *     n3 -> n12;
- *   n3 -> r10;
- *   r10 -> r13;
- *   r13 -> r15;
- *   subgraph {
- *     rank=same;
- *     n10 [style=filled, fillcolor=green];
- *     r15 -> n10;
- *   r5 -> r7;
- *   subgraph {
- *     rank=same;
- *     n11 [style=filled, fillcolor=green];
- *     r7 -> n11;
- *     n14 [style=filled, fillcolor=green];
- *     n11 -> n14;
- *   n14 -> r4;
- *   r7 -> r8;
- *   subgraph {
- *     rank=same;
- *     n13 [style=filled, fillcolor=green];
- *     r8 -> n13;
- *   r8 -> r9;
- *   n8 -> r14;
- *   r0 -> r1;
- *   subgraph {
- *     rank=same;
- *     n7 [style=filled, fillcolor=green];
- *     r1 -> n7;
- *   r1 -> r2;
- *   r2 -> r3;
- *   r3 -> r6;
- *   r6 -> r11;
- *   r11 -> r12;
- *   subgraph {
- *     rank=same;
- *     n5 [style=filled, fillcolor=green];
- *     r12 -> n5;
- *     n9 [style=filled, fillcolor=green];
- *     n5 -> n9;
- * @enddot
- * The following example illustrates a deadlock situation.  The root of the
- * tree tries to get ownership of a resource owned by one of its children.
- * @dot
- * digraph {
- *   n0 -> r0;
- *   subgraph {
- *     rank=same;
- *     r0 -> n1;
- *   n1 -> r1;
- *   n0 -> r1 [label=deadlock, style=dotted];
- * @enddot
-typedef struct Resource_Node Resource_Node;
-typedef struct Resource_Control Resource_Control;
- * @brief Resource node to reflect ownership of resources and a dependency on a
- * resource.
-struct Resource_Node {
-   * @brief Node to build a chain of rivals depending on a resource.
-   * @see Resource_Control::Rivals.
-  Chain_Node Node;
-   * @brief A chain of resources owned by this node.
-   * @see Resource_Control::Node.
-  Chain_Control Resources;
-   * @brief Reference to a resource in case this node has to wait for ownership
-   * of this resource.
-   * It is @c NULL in case this node has no open resource dependency.
-  Resource_Control *dependency;
-   * @brief Reference to the root of the resource tree.
-   * The root references itself.
-  Resource_Node *root;
- * @brief Resource control to manage ownership and rival nodes depending on a
- * resource.
-struct Resource_Control {
-   * @brief Node to build a chain of resources owned by a resource node.
-   * @see Resource_Node::Resources.
-  Chain_Node Node;
-   * @brief A chain of rivals waiting for resource ownership.
-   * @see Resource_Node::Node.
-  Chain_Control Rivals;
-   * @brief The owner of this resource.
-  Resource_Node *owner;
-#ifdef __cplusplus
-#endif /* _RTEMS_SCORE_RESOURCE_H */
diff --git a/cpukit/score/include/rtems/score/resourceimpl.h b/cpukit/score/include/rtems/score/resourceimpl.h
index 4739bda..0000000
--- a/cpukit/score/include/rtems/score/resourceimpl.h
+++ /dev/null
@@ -1,165 +0,0 @@
- *  Dornierstr. 4
- *  82178 Puchheim
- *  Germany
-#ifndef _RTEMS_SCORE_RESOURCEIMPL_H
-#define _RTEMS_SCORE_RESOURCEIMPL_H
-#include <rtems/score/resource.h>
-#include <rtems/score/chainimpl.h>
-#ifdef __cplusplus
-extern "C" {
- * @addtogroup ScoreResource
- * @brief Visitor function for resource node iteration.
- * The visitor is allowed to extract the node.
- * @param[in] node The current resource node.
- * @param[in] arg The argument passed to _Resource_Iterate().
- * @retval true Stop the iteration.
- * @retval false Continue the iteration.
-typedef bool (*Resource_Node_visitor)( Resource_Node *node, void *arg );
- * @brief Iterates over all nodes of a resource dependency tree.
- * @param[in] top The top node to start the iteration.  The visitor function is
- * not invoked for the top node.
- * @param[in] visitor The visitor function.
- * @param[in] arg The argument for the visitor function.
-void _Resource_Iterate(
-  Resource_Node         *top,
-  Resource_Node_visitor  visitor,
-  void                  *arg
-RTEMS_INLINE_ROUTINE void _Resource_Node_initialize( Resource_Node *node )
-  node->dependency = NULL;
-  node->root = node;
-  _Chain_Initialize_node( &node->Node );
-  _Chain_Initialize_empty( &node->Resources );
-RTEMS_INLINE_ROUTINE void _Resource_Node_set_dependency(
-  Resource_Node    *node,
-  node->dependency = dependency;
-RTEMS_INLINE_ROUTINE Resource_Node *_Resource_Node_get_root(
-  const Resource_Node *node
-  return node->root;
-RTEMS_INLINE_ROUTINE void _Resource_Node_set_root(
-  node->root = root;
-RTEMS_INLINE_ROUTINE bool _Resource_Node_owns_resources( const Resource_Node *node )
-  return !_Chain_Is_empty( &node->Resources );
-RTEMS_INLINE_ROUTINE void _Resource_Node_add_resource(
-  Resource_Control *resource
-  _Chain_Prepend_unprotected( &node->Resources, &resource->Node );
-RTEMS_INLINE_ROUTINE void _Resource_Node_extract( Resource_Node *node )
-  _Chain_Extract_unprotected( &node->Node );
-RTEMS_INLINE_ROUTINE void _Resource_Initialize( Resource_Control *resource )
-  resource->owner = NULL;
-  _Chain_Initialize_node( &resource->Node );
-  _Chain_Initialize_empty( &resource->Rivals );
-RTEMS_INLINE_ROUTINE void _Resource_Add_rival(
-  Resource_Control *resource,
-  _Chain_Append_unprotected( &resource->Rivals, &node->Node );
-RTEMS_INLINE_ROUTINE void _Resource_Extract( Resource_Control *resource )
-  _Chain_Extract_unprotected( &resource->Node );
-RTEMS_INLINE_ROUTINE Resource_Node *_Resource_Get_owner(
-  const Resource_Control *resource
-  return resource->owner;
-RTEMS_INLINE_ROUTINE void _Resource_Set_owner(
-  resource->owner = owner;
- * @brief Returns true if this is the most recently obtained resource of the
- * node, and false otherwise.
- * Resources are organized in last in first out order (LIFO).
- * @param[in] resource The resource in question.
- * @param[in] node The node that obtained the resource.
-RTEMS_INLINE_ROUTINE bool _Resource_Is_most_recently_obtained(
-  const Resource_Control *resource,
-  return &resource->Node == _Chain_Immutable_first( &node->Resources );
-#ifdef __cplusplus
-#endif /* _RTEMS_SCORE_RESOURCEIMPL_H */
diff --git a/cpukit/score/preinstall.am b/cpukit/score/preinstall.am
index 94865a0..a694324 100644
--- a/cpukit/score/preinstall.am
+++ b/cpukit/score/preinstall.am
@@ -228,14 +228,6 @@ $(PROJECT_INCLUDE)/rtems/score/rbtreeimpl.h: include/rtems/score/rbtreeimpl.h $(
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/rbtreeimpl.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/rbtreeimpl.h
-$(PROJECT_INCLUDE)/rtems/score/resource.h: include/rtems/score/resource.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/resource.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/resource.h
-$(PROJECT_INCLUDE)/rtems/score/resourceimpl.h: include/rtems/score/resourceimpl.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/resourceimpl.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/resourceimpl.h
 $(PROJECT_INCLUDE)/rtems/score/scheduler.h: include/rtems/score/scheduler.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/scheduler.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/scheduler.h
diff --git a/cpukit/score/src/resourceiterate.c b/cpukit/score/src/resourceiterate.c
index ac8b8b0..0000000
--- a/cpukit/score/src/resourceiterate.c
+++ /dev/null
@@ -1,104 +0,0 @@
- *  Dornierstr. 4
- *  82178 Puchheim
- *  Germany
-#include <rtems/score/resourceimpl.h>
-static Resource_Control *_Resource_Rival_head_to_resource( Chain_Node *head )
-  return RTEMS_CONTAINER_OF( head, Resource_Control, Rivals.Head.Node );
-static Resource_Node *_Resource_Resource_tail_to_rival( Chain_Node *tail )
-  return RTEMS_CONTAINER_OF( tail, Resource_Node, Resources.Tail.Node );
-  void                  *arg
-  Chain_Node *resource_tail = _Chain_Tail( &top->Resources );
-  Resource_Control *resource =
-    (Resource_Control *) _Chain_Head( &top->Resources );
-  Chain_Node *rival_stop = NULL;
-  Resource_Node *rival = NULL;
-  enum {
-    NODE_FORWARD,
-    NODE_BACKWARD,
-    RESOURCE_FORWARD
-  } dir = RESOURCE_FORWARD;
-  bool stop = false;
-  do {
-    switch ( dir ) {
-      case NODE_FORWARD:
-        while ( !stop && &rival->Node != rival_stop ) {
-          Resource_Node *current = rival;
-          rival = (Resource_Node *) _Chain_Next( &rival->Node );
-          stop = ( *visitor )( current, arg );
-        rival_stop = _Chain_Head( &resource->Rivals );
-        dir = NODE_BACKWARD;
-        break;
-      case NODE_BACKWARD:
-        rival = (Resource_Node *) _Chain_Previous( &rival->Node );
-        while (
-          &rival->Node != rival_stop
-            && _Chain_Is_empty( &rival->Resources )
-        if ( &rival->Node != rival_stop ) {
-          resource_tail = _Chain_Tail( &rival->Resources );
-          resource = (Resource_Control *) _Chain_Head( &rival->Resources );
-        } else {
-          resource = _Resource_Rival_head_to_resource( rival_stop );
-          resource_tail = _Chain_Tail( &resource->owner->Resources );
-        dir = RESOURCE_FORWARD;
-        break;
-      case RESOURCE_FORWARD:
-        resource = (Resource_Control *) _Chain_Next( &resource->Node );
-        while (
-          &resource->Node != resource_tail
-            && _Chain_Is_empty( &resource->Rivals )
-        if ( &resource->Node != resource_tail ) {
-          rival_stop = _Chain_Tail( &resource->Rivals );
-          rival = (Resource_Node *) _Chain_First( &resource->Rivals );
-          dir = NODE_FORWARD;
-        } else {
-          rival = _Resource_Resource_tail_to_rival( resource_tail );
-          rival_stop = _Chain_Head( &rival->dependency->Rivals );
-        break;
-  } while ( !stop && rival != top );
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index 20ea9d5..6e01eb2 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -55,7 +55,6 @@ _SUBDIRS += sptimecounter03
 _SUBDIRS += spatomic01
 _SUBDIRS += spintrcritical22
 _SUBDIRS += spsem03
-_SUBDIRS += spresource01
 _SUBDIRS += spmrsp01
 _SUBDIRS += spscheduler01
 _SUBDIRS += spprofiling01
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index c96edd3..2899b16 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -62,7 +62,6 @@ spatomic01/Makefile
 spglobalcon01/Makefile
 spintrcritical22/Makefile
 spsem03/Makefile
-spresource01/Makefile
 spmrsp01/Makefile
 spscheduler01/Makefile
 spfatal28/Makefile
diff --git a/testsuites/sptests/spresource01/Makefile.am b/testsuites/sptests/spresource01/Makefile.am
index 292dd05..0000000
--- a/testsuites/sptests/spresource01/Makefile.am
+++ /dev/null
@@ -1,19 +0,0 @@
-rtems_tests_PROGRAMS = spresource01
-spresource01_SOURCES = init.c
-dist_rtems_tests_DATA = spresource01.scn spresource01.doc
-include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
-include $(top_srcdir)/../automake/compile.am
-include $(top_srcdir)/../automake/leaf.am
-AM_CPPFLAGS += -I$(top_srcdir)/../support/include
-LINK_OBJS = $(spresource01_OBJECTS)
-LINK_LIBS = $(spresource01_LDLIBS)
-spresource01$(EXEEXT): $(spresource01_OBJECTS) $(spresource01_DEPENDENCIES)
-	@rm -f spresource01$(EXEEXT)
-	$(make-exe)
-include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/spresource01/init.c b/testsuites/sptests/spresource01/init.c
index 7b1dd47..0000000
--- a/testsuites/sptests/spresource01/init.c
+++ /dev/null
@@ -1,317 +0,0 @@
- *  Dornierstr. 4
- *  82178 Puchheim
- *  Germany
-#ifdef HAVE_CONFIG_H
-  #include "config.h"
-#endif
-#include <stdio.h>
-#include <rtems.h>
-#include "tmacros.h"
-const char rtems_test_name[] = "SPRESOURCE 1";
-static Resource_Control rt[16];
-static Resource_Node nt[16];
-#define RESOURCE_COUNT RTEMS_ARRAY_SIZE(rt)
-#define NODE_COUNT RTEMS_ARRAY_SIZE(nt)
-static size_t ri(Resource_Control *r)
-  return (size_t) (r - &rt[0]);
-static size_t ni(Resource_Node *n)
-  return (size_t) (n - &nt[0]);
-static void print_node(Resource_Node *n);
-static void print_resource(Resource_Control *r)
-  Chain_Control *rivals = &r->Rivals;
-  if (!_Chain_Is_empty(rivals)) {
-    const Chain_Node *tail = _Chain_Immutable_tail(rivals);
-    Resource_Node *last = (Resource_Node *) _Chain_First(rivals);
-    Resource_Node *next = (Resource_Node *) _Chain_Next(&last->Node);
-    printf(
-      "  subgraph {\n"
-      "    rank=same;\n"
-      "    n%zi [style=filled, fillcolor=green];\n"
-      "    r%zi -> n%zi;\n",
-      ni(last),
-      ri(r),
-      ni(last)
-    while (&next->Node != tail) {
-      printf(
-        "    n%zi -> n%zi;\n",
-        ni(next),
-        ni(last),
-        ni(next)
-      last = next;
-      next = (Resource_Node *) _Chain_Next(&next->Node);
-    printf("  }\n");
-    next = (Resource_Node *) _Chain_First(rivals);
-      print_node(next);
-  Chain_Control *resources = &n->Resources;
-  if (!_Chain_Is_empty(resources)) {
-    const Chain_Node *tail = _Chain_Immutable_tail(resources);
-    Resource_Control *last = (Resource_Control *) _Chain_First(resources);
-    Resource_Control *next = (Resource_Control *) _Chain_Next(&last->Node);
-    printf("  n%zi -> r%zi;\n", ni(n), ri(last));
-    print_resource(last);
-      printf("  r%zi -> r%zi;\n", ri(last), ri(next));
-      print_resource(next);
-      last = next;
-      next = (Resource_Control *) _Chain_Next(&next->Node);
-static const size_t node_seq[NODE_COUNT - 1] =
-  { 1, 2, 4, 6, 8, 15, 3, 12, 10, 11, 14, 13, 7, 5, 9 };
-static bool visitor_all(Resource_Node *n, void *arg)
-  size_t *index = arg;
-  size_t i = *index;
-  printf("n%zi\n", ni(n));
-  rtems_test_assert(i < RTEMS_ARRAY_SIZE(node_seq));
-  rtems_test_assert(node_seq[i] == ni(n));
-  *index = i + 1;
-  return false;
-static bool visitor_seven(Resource_Node *n, void *arg)
-  rtems_test_assert(i < 7);
-  *index = i + 1;
-  return i + 1 >= 7;
-static const bool owns_resources[RESOURCE_COUNT] = {
-  true, true, false, true, false, false, false, false, true, false, false,
-  false, false, false, true, false
-static void add_resource(Resource_Node *n, Resource_Control *r)
-  _Resource_Node_add_resource(n, r);
-  _Resource_Set_owner(r, n);
-static void add_rival(Resource_Control *r, Resource_Node *n)
-  _Resource_Add_rival(r, n);
-  _Resource_Node_set_dependency(n, r);
-  _Resource_Node_set_root(n, &nt[0]);
-static void test_resource_iterate(void)
-  Resource_Node *root = &nt[0];
-  size_t i;
-  printf("digraph {\n");
-  for (i = 0; i < RESOURCE_COUNT; ++i) {
-    _Resource_Initialize(&rt[i]);
-  for (i = 0; i < NODE_COUNT; ++i) {
-    _Resource_Node_initialize(&nt[i]);
-  add_resource(&nt[0], &rt[12]);
-  add_resource(&nt[0], &rt[11]);
-  add_resource(&nt[0], &rt[6]);
-  add_resource(&nt[0], &rt[3]);
-  add_resource(&nt[0], &rt[2]);
-  add_resource(&nt[0], &rt[1]);
-  add_resource(&nt[0], &rt[0]);
-  add_resource(&nt[1], &rt[9]);
-  add_resource(&nt[1], &rt[8]);
-  add_resource(&nt[1], &rt[7]);
-  add_resource(&nt[1], &rt[5]);
-  add_resource(&nt[3], &rt[15]);
-  add_resource(&nt[3], &rt[13]);
-  add_resource(&nt[3], &rt[10]);
-  add_resource(&nt[8], &rt[14]);
-  add_resource(&nt[14], &rt[4]);
-  add_rival(&rt[0], &nt[1]);
-  add_rival(&rt[0], &nt[2]);
-  add_rival(&rt[0], &nt[4]);
-  add_rival(&rt[0], &nt[6]);
-  add_rival(&rt[0], &nt[8]);
-  add_rival(&rt[0], &nt[15]);
-  add_rival(&rt[1], &nt[7]);
-  add_rival(&rt[5], &nt[3]);
-  add_rival(&rt[5], &nt[12]);
-  add_rival(&rt[7], &nt[11]);
-  add_rival(&rt[7], &nt[14]);
-  add_rival(&rt[8], &nt[13]);
-  add_rival(&rt[12], &nt[5]);
-  add_rival(&rt[12], &nt[9]);
-  add_rival(&rt[15], &nt[10]);
-      _Resource_Node_owns_resources(&nt[i]) == owns_resources[i]
-  printf("  n%zi [style=filled, fillcolor=green];\n", ni(root));
-  print_node(root);
-  printf("}\n");
-  i = 0;
-  _Resource_Iterate(root, visitor_all, &i);
-  rtems_test_assert(i == 15);
-  i = 0;
-  _Resource_Iterate(root, visitor_seven, &i);
-  rtems_test_assert(i == 7);
-static void test_resource_simple(void)
-  Resource_Control r0;
-  Resource_Control r1;
-  Resource_Node n0;
-  _Resource_Node_initialize(&n0);
-  rtems_test_assert(!_Resource_Node_owns_resources(&n0));
-  rtems_test_assert(_Resource_Node_get_root(&n0) == &n0);
-  rtems_test_assert(n0.dependency == NULL);
-  _Resource_Node_set_root(&n0, NULL);
-  rtems_test_assert(_Resource_Node_get_root(&n0) == NULL);
-  _Resource_Node_set_root(&n0, &n0);
-  _Resource_Initialize(&r0);
-  rtems_test_assert(_Resource_Get_owner(&r0) == NULL);
-  rtems_test_assert(_Chain_Is_empty(&r0.Rivals));
-  _Resource_Set_owner(&r0, &n0);
-  rtems_test_assert(_Resource_Get_owner(&r0) == &n0);
-  _Resource_Set_owner(&r0, NULL);
-  _Resource_Initialize(&r1);
-  _Resource_Node_add_resource(&n0, &r0);
-  rtems_test_assert(_Resource_Node_owns_resources(&n0));
-  rtems_test_assert(_Resource_Is_most_recently_obtained(&r0, &n0));
-  _Resource_Node_add_resource(&n0, &r1);
-  rtems_test_assert(!_Resource_Is_most_recently_obtained(&r0, &n0));
-  rtems_test_assert(_Resource_Is_most_recently_obtained(&r1, &n0));
-  _Resource_Extract(&r1);
-  rtems_test_assert(!_Resource_Is_most_recently_obtained(&r1, &n0));
-  _Resource_Extract(&r0);
-  _Resource_Add_rival(&r0, &n0);
-  rtems_test_assert(!_Chain_Is_empty(&r0.Rivals));
-  _Resource_Node_extract(&n0);
-static void Init(rtems_task_argument arg)
-  TEST_BEGIN();
-  test_resource_simple();
-  test_resource_iterate();
-  TEST_END();
-  rtems_test_exit(0);
-#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
-#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
-#define CONFIGURE_MAXIMUM_TASKS 1
-#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
-#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
-#include <rtems/confdefs.h>
diff --git a/testsuites/sptests/spresource01/spresource01.doc b/testsuites/sptests/spresource01/spresource01.doc
index eda0f12..0000000
--- a/testsuites/sptests/spresource01/spresource01.doc
+++ /dev/null
@@ -1,11 +0,0 @@
-This file describes the directives and concepts tested by this test set.
-test set name: spresource01
-directives:
-  - _Resource_Iterate()
-concepts:
-  - Ensure that interation over resource nodes works.
diff --git a/testsuites/sptests/spresource01/spresource01.scn b/testsuites/sptests/spresource01/spresource01.scn
index 6a4f8de..0000000
--- a/testsuites/sptests/spresource01/spresource01.scn
+++ /dev/null
@@ -1,94 +0,0 @@
-*** BEGIN OF TEST SPRESOURCE 1 ***
-digraph {
-  n0 [style=filled, fillcolor=green];
-  n0 -> r0;
-  subgraph {
-    rank=same;
-    n1 [style=filled, fillcolor=green];
-    r0 -> n1;
-    n2 [style=filled, fillcolor=green];
-    n1 -> n2;
-    n4 [style=filled, fillcolor=green];
-    n2 -> n4;
-    n6 [style=filled, fillcolor=green];
-    n4 -> n6;
-    n8 [style=filled, fillcolor=green];
-    n6 -> n8;
-    n15 [style=filled, fillcolor=green];
-    n8 -> n15;
-  n1 -> r5;
-  subgraph {
-    rank=same;
-    n3 [style=filled, fillcolor=green];
-    r5 -> n3;
-    n12 [style=filled, fillcolor=green];
-    n3 -> n12;
-  n3 -> r10;
-  r10 -> r13;
-  r13 -> r15;
-  subgraph {
-    rank=same;
-    n10 [style=filled, fillcolor=green];
-    r15 -> n10;
-  r5 -> r7;
-  subgraph {
-    rank=same;
-    n11 [style=filled, fillcolor=green];
-    r7 -> n11;
-    n14 [style=filled, fillcolor=green];
-    n11 -> n14;
-  n14 -> r4;
-  r7 -> r8;
-  subgraph {
-    rank=same;
-    n13 [style=filled, fillcolor=green];
-    r8 -> n13;
-  r8 -> r9;
-  n8 -> r14;
-  r0 -> r1;
-  subgraph {
-    rank=same;
-    n7 [style=filled, fillcolor=green];
-    r1 -> n7;
-  r1 -> r2;
-  r2 -> r3;
-  r3 -> r6;
-  r6 -> r11;
-  r11 -> r12;
-  subgraph {
-    rank=same;
-    n5 [style=filled, fillcolor=green];
-    r12 -> n5;
-    n9 [style=filled, fillcolor=green];
-    n5 -> n9;
-n1
-n2
-n4
-n6
-n8
-n15
-n3
-n12
-n10
-n11
-n14
-n13
-n7
-n5
-n9
-n1
-n2
-n4
-n6
-n8
-n15
-n3
-*** END OF TEST SPRESOURCE 1 ***
1.8.4.5
