Update Atsam BSP Support
Wed Oct 5 14:17:29 UTC 2016
That makes sense.
On Wed, Oct 5, 2016 at 1:17 AM, Sebastian Huber
> One way to keep this in sync would be to simply write the README of each BSP
> in a certain format, e.g. trac wiki and then simply include the content from
> Git in trac. For example via a modified variant of
> https://trac.edgewall.org/attachment/wiki/MacroBazaar/Include.3.py
> Something like this in trac:
> [[RTEMSGitInclude(c/src/lib/libbsp/arm/atsam/README)]]
> On 04/10/16 21:41, Pavel Pisa wrote:
>> Hello Gedare and Alexander,
>> one possible solution to keep that in sync.
>> Change of README in BSP directory
>> to MarkDown or Rest-Text syntax and put on the web
>> generated pages synced directly from master and last stable.
>> On the other hand, wiki allows to include more information
>> and relation links.
>> Best wishes,
>>          Pavel
>> On Tuesday 04 of October 2016 15:21:46 Gedare Bloom wrote:
>>> Thanks. does this BSP have a wiki page? If not, it would be good to
>>> make one for it. Generally we need to do a better job of keeping a
>>> web-visible "feature set" up to date.
>>> On Tue, Oct 4, 2016 at 7:39 AM, Alexander Krutwig
>>> <alexander.krutwig at embedded-brains.de> wrote:
>>>> Hello,
>>>> over the last months, lots of work and effort has been put into the
>>>> development
>>>> of the BSP support for ATSAMV7 microcontrollers by Atmel.
>>>> Thus, I updated the README of the BSP with the work already done in the
>>>> process and
>>>> attached it to this email in order to keep you updated about the
>>>> progress.
>>>> In addition to the work described in the document, we currently work on
>>>> USB and SD-card
>>>> support. Support for NOR flashes is already finished, however, not yet
>>>> committed.
>>>> Best regards,
>>>> Alexander Krutwig
>>>> embedded brains GmbH
>>>> Alexander Krutwig
>>>> Dornierstr. 4
>>>> D-82178 Puchheim
>>>> Germany
>>>> email: alexander.krutwig at embedded-brains.de
>>>> Phone: +49-89-18 94 741 - 17
>>>> Fax:   +49-89-18 94 741 - 09
>>>> PGP: Public key available on request.
>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
>>> devel mailing list
>>> devel at rtems.org
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
