[PATCH v3] arm/xilinx_zynq: Disable the MMU and the data and instruction cache on boot.
Chris Johns
chrisj at rtems.org
Thu Sep 1 01:48:57 UTC 2016
On 01/09/2016 00:30, Pavel Pisa wrote:
> Hello Chris,
> I am trying to think about consequences.
Thank you for this.
> On Wednesday 31 of August 2016 04:16:34 Chris Johns wrote:
>> The u-boot loader can enable the MMU plus the data and instruction caches.
>> Disable them and if the data cache is enabled clear it before turn the
>> caches off.
>> Closes #2774.
> I think that this is critical problem and has to be solved.
> May be, this should be committed because it solves problems
> for your actual boot and is probably OK for UP.
> But for SMP, I think that there are more problems. When I look into
> rtems/c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h
> I see
>> #ifdef RTEMS_SMP
>> BSP_START_TEXT_SECTION static inline void
>> arm_a9mpcore_start_on_secondary_processor(void)
>> uint32_t ctrl;
>> arm_a9mpcore_start_set_vector_base();
>> arm_gic_irq_initialize_secondary_cpu();
>> ctrl = arm_cp15_start_setup_mmu_and_cache(
>> 0,
>> ARM_CP15_CTRL_AFE | ARM_CP15_CTRL_Z
> If you add arm_cp15_data_cache_clean_all_levels() into
> arm_cp15_start_setup_mmu_and_cache() then according to my understanding
> of case there can be problems if cache is already or still enabled
> on primary CPU.
> I have started to check how are the caches implemented on Zynq
> and my debug code shows that arm_cp15_data_cache_clean_all_levels()
> sees only the first cache level on the CPU. It seem that controler
> is not part of the CPU architecture. So that means that for Zynq
> use of arm_cp15_data_cache_clean_all_levels() is OK.
> The result
> cache levels:
> clidr 0x09200003 loc 1
> level 0 ctype 3
> level 0 ccsidr 0x701FE019
> line_power 0x05 associativity 0x04 way_shift 0x1E
> level 1 ctype 0
> level 2 ctype 0
> This means no cache above level 1 are detected by CP15 code and level
> of coherency is 1 anyway so safe for Zynq. But RPi2 shows multiple levels
> for example. So I would vote to move code into per BSP part the same
> way as Cyclone has that.
OK.
>> arm_cp15_set_domain_access_control(
>> ARM_CP15_DAC_DOMAIN(ARM_MMU_DEFAULT_CLIENT_DOMAIN, ARM_CP15_DAC_CLIENT)
>> /* FIXME: Sharing the translation table between processors is brittle */
>> arm_cp15_set_translation_table_base(
>> (uint32_t *) bsp_translation_table_base
>> ctrl |= ARM_CP15_CTRL_I | ARM_CP15_CTRL_C | ARM_CP15_CTRL_M;
>> arm_cp15_set_control(ctrl);
>> _SMP_Start_multitasking_on_secondary_processor();
> Further analysis for generic case.
> If it is ensured that cache is disabled on primary CPU during start
> of all secondary CPUs and then sequence
> invalidate cache
> wait on barrier with primary
> enable cache
> wait on barrier with promary
> start multitasking
> should be OK.
> But mixing can be bad.
> When I look into "altera-cyclone-v" which I expect that it is the
> most tested one by Sebastian, then it solves this problem
> by explicitly putting invalidate into bsp_start_hook_0()
> rtems/c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstarthooks.c
> BSP_START_TEXT_SECTION void bsp_start_hook_0( void )
> arm_cp15_instruction_cache_invalidate();
> arm_cp15_data_cache_invalidate_all_levels();
> arm_a9mpcore_start_hook_0();
> This is called even on secondary CPU and L1 caches setup can
> be mixed for short while. But it is not problem because
> L2 cache should be enabled only after
> rtems/c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspsmp.c:_CPU_SMP_Start_processor()
> started = _Per_CPU_State_wait_for_non_initial_state(cpu_index, 0);
> finishes according to the comment.
> But when I try to analyze order by traceback
> _SMP_Handler_initialize
> rtems_initialize_data_structures
> RTEMS_SYSINIT_ITEM(
> rtems_initialize_data_structures,
> RTEMS_SYSINIT_DATA_STRUCTURES,
> RTEMS_SYSINIT_ORDER_MIDDLE
> RTEMS_SYSINIT_BSP_WORK_AREAS
> RTEMS_SYSINIT_BSP_START
> RTEMS_SYSINIT_INITIAL_EXTENSIONS
> so there are enabled other CPUs and there is wait for sync
> RTEMS_SYSINIT_USER_EXTENSIONS
> RTEMS_SYSINIT_CPU_SET
> L2 cache is enabled in bsp_start_hook_1() on Cyclone
> /* Enable unified L2 cache */
> rtems_cache_enable_data();
> But bsp_start_hook_1() is called early in the boot process even
> on Cyclone from libbsp/arm/shared/start/start.S. So I see even there
> problems to clarify that sequence is completely OK.
> I am not expert for SMP and ARM for sure. But I have doubts that
> all that is OK. I try follow with some patch which i consider correct.
> But not sure.
I have tested the patch you posted and it is working. I have manually
run a few of the single core and SMP tests including the capture engine
one I have been fixing.
I am going to push your fix and the 2nd core patch of mine. If there are
further issues identified we can work on those. I think we need to rule
a line here to work from.
> There is another problem which I have noticed on RPi.
> Cache invalidate when U-boots starts application with cache enabled
> can lead to the lost of some data or code, because they are held
> only in cache before cache invalidate and disabled.
> So I suggest to flush data there before cache disable.
> Best wishes,
> Pavel
> PS: comments are little convoluted, because I have spent quite large amount
> of time by rethinking and generally looked at that during coordination
> of more other projects done by studnets at the university.
Sure.
I have a concern we are pushing specialised fixes out and down in the
BSPs and this is has a long term effect of making further changes harder
because the spread of testing plus it makes it more difficult for others
to provide support for similar or close processor variants.
